View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Idle fluctuating, stalling after I removed VAFC
- I NEED WIRING HELP FOR MY ITR DASH IN EG PLEASE HELP
- TURBO KIT
- newbie in this ish!!!!
- building my ls turbo hatch
- Need your help!!!!! Anyone???
- 99-00 Civic Si with a 98+ JDM Type R - which exhaust system?? which will bolt on? or will it?
- yellow bulbs
- HID question
- LS Project
- civic and ITR evap purge solenoids
- Idle vibration?
- Will the GSR OEM Dual Bend Shifter fit EK with D16?
- Problem with idle and throttle! Need Help!
- 97 civic DX EVAP canister vent shut valve (CVS): where is it located?
- Power Steering??!!!
- Energy Suspension Ball Joint Boots
- WORKemotion CR Kai (Not an A/P question)
- Stock VX Hatch backs...chime in
- z6 missing at low and high rpms
- stupid y7 IM
- ignition problem
- cam swap
- si brake swap
- doing a swap need help
- Big Electrical Problems
- Question on SI seats..
- Question About HX Sensor is it 5 wire or 4 wire?
- Finally got my RSX seats into my EG!
- 1999 Civic LX RPM Issue!
- civic 96-00 2 door an 4 door have the same rear seats??
- Q's on Valve Adjustments
- 3 connectors on power steering reservoir?
- starter just clicks
- ENGINE REVING HIGH
- port and polished d16z6 head..
- Quick-harmless question.
- 99 ex ecu
- Rpm Problem
- head questions
- Having a wierd clutch problem need quick help
- GSR DISTRIBUTER
- spindle swap
- Hesitation/bogging issues, 99 Civic Si
- head studs
- Full headlight retrofit with relay harness for aftermarket headlight
- coupe/hatch bumper on a 4dr?
- D16y8 to D16y7 downgrade issues--have I found them all?
- RANDOM STEREOOO..
- how to question???
- coilovers
- HELP! parking lights dont work but signal does.93 ex
- Cant decide
- z6 compression issue
- adjusting clutch pedal feel? 93 cx
- Fuel Pump not priming, But Main relay clicks!
- H22 Powered EG Owners Opinions
- DIY brake and rotor repalcement
- jdm b16a2 to usdm b16a2???
- Bent suspension correction.
- how bad is a tiny leak in the head gasket?
- 96'civic rear disc ???
- overheating problems
- 99 Civic DX Coupe
- Coilovers... 93 hatch
- PLEASE HELP WITH A CAR PROBLEM!!!!!
- Junkyards kick ass!!
- 92 Si gauge cluster plug and play for 92DX???
- AEM Fuel Filter needs modification
- What do you think about the JDM ITR Recaros
- so whats next on the project guys?
- PICS OF YOUR EG
- Wrong alternator pulley?
- glow guages
- 95 Civic EX won't start - Distributor or Computer failure likely?
- disconnected battery overnight now the horn goes off and can't start
- the "i" designation
- AC Friendly Headers
- USDM ITR Header in a 2000 civic si?
- stripping paint off plastics? aircraft stripper?
- how do i become an urestricted member?
- Exhaust problems... WATER COMING OUT OF MUFFLER! WHAT!? WHY!?
- Totally weird electrical problem - '95 del sol
- engine harness question
- need help fast!!!!
- What exhaust is this?
- Check engine light!
- ****Looking to setup audio system in 92 hatch****
- Intake Temp Sensor Mod?
- Huge axle problem
- INNOVATIVE VS HASPORT MOUNTS
- what a sad day...
- euro manifold h22 IAT sensor mystery thinger majigger tommy hillfigger wigger
- Car Overheats, replaced thermostat, radiator, flushed system, good water pump
- <><><> SHOCK SETTINGS!
- 99-00 OEM Bumper fitment with fmic- Pic request
- rusted header bolt need help fast
- Need help with steering wheel problem!!!
- Ignition Switch
- Block Holes Stripped,for head studs, can this be fixed
- YO I NEED SOME HELP!!!
- '95 Civic LX Windows won't stay up?
- Identify this shock...
- where is the plug to check a cell in a vx hatch?
- 95cx AC into 97HX
- didnt pass inspection
- Ebay - look at this civic, crazy interior
- Secondary o2 sensor??
- z6 flywheel fit a 96 HX
- Screechling noise! help
- 92 civic ex
- ***new to the forum...just want to say hi***
- smog??
- 92 civic b18b swap
- Searched and can't find how to safely remove all AC Parts from my civic ex 95
- is ingalls torque dampener really worth it? or NRg??
- my check engine light comes on and my car loses power
- flywheel for z6 fit on a b7
- Gab sports coilovers?
- LA people
- Under the hood
- Mystery Part
- Eibach 2007
- tranny question
- EJ8 Help Needed
- Tranny codes
- valve cover bolts
- 96 Civic CEL 45
- please help
- Hissing sound coming from my alternator area...**VIDEO** Please help
- can someone do me a favor? (simple wiring and speed) :)
- Bout to lose my mind, 99 EX w/z6 swap, issues
- 95 civic d16z6 cam gear install
- car not starting. fuel pump?
- ITB's
- FIFV and IAC
- need some help with obd2 code
- dizzy help: jdm b16 in a ek . help me run right.
- Need help with Steering wheel hub
- best fitting exhaust for hybrid civic b16 eg hb.
- Rota C8s
- What is the expected mpg for a b16a2?
- Turbo?
- Need help with aftermath of 8 month storage!!!
- is b17 good for boost?
- MSD 6AL on B18C GSR
- Help With EG rear cargo install!!
- BAD IDLE
- no 3rd brake like now after new spoiler, what to do?
- need a lil help
- 93 civic not starting firing order is good timing still feels off
- 92-95 window visors
- swapping a b series into ek. questions about axles.
- Swapping a D16Y8 into '93 VX
- heat not working!! pls help
- Shifter extension???
- b16 swap into a 95 vx... i have some swap questions
- Factory traction control for Integra/Civic?
- Half Cut or Complete Swap
- What to power my EJ1 with?
- weird noise squeeking noise after a run on track?? We checked alternator belt and it got loose?
- car wont start after changing spark plugs!
- Good to run????
- tubo/boost
- Engine check light?
- JDM B18B able to get Ref'd in California?
- b20 head on a b18 block?
- o2 cesor check engine
- 98 EK Problems PLEASE HELP!!
- intake manifold question
- 92-95 Civic DX to d16z6 (VTEC Subharness) from rywire
- EMANAGE TUNING I NEED HELP
- stock steel wheel specs
- Rywire subharness
- ok so i let go of the gas....AND CAR SPEEDS UP....end up going through red light almost killing myse
- installing arp head studs,all of the studs are not even is this safe
- My First Honda Project
- 2000 civic 5 spd. ecu question
- OSAKAJDMMOTORS.com
- Brakes Question
- ep3 ctr sideskirts fittment on 96-00 civics?
- Doing an Auto to Manual swap right now for 92 civic!!!
- itb??
- Civic 00 SI > CEL > 45 O2 sensor Fuel is too rich ? Help PLEASE!
- Wiper Motor Plug
- Who has done a valve adjustment?
- 1993 A/C compressor replacement
- 112% injector cycle duty...
- WATER PUMP PROBLEM NEED HELP!!!!
- please help me its drivin me crazy
- Which brake cable?
- I'm Lost
- feedback on this company?
- My horn has stopped working
- replacing crank sensor
- installing ferio window deflectors
- I removed the alternator from the top of my Del Sol DOHC VTEC Engine
- Just a heads up for the EM1 Owners...
- ECU wiring HELP!!
- Question about installing the H4 HID aftermarket kit
- eg6 jdm stanley sidemarkers?
- radiator help.
- timing need help
- Question about the way tires put power to wheels???
- wich clutch should i get?
- Brake Lines advice
- for you guys who has done rear brake conversions
- timing belt/water pump project questons...
- taking hub apart
- weak fuel pump?
- Keyless Entry Programming?
- can someone tell me the physical difference between an OBD1 B18a1 and an OBD0 b18a
- Ek Cx hatch antenna?
- Couple quick questions
- spoiler
- advice on a turbo setup
- Broken Bolt on Rear Shock......NEED HELP ASAP!!!!
- won't go into first gear?
- What do you think?
- EG Clock
- What to with this del sol?
- radiator fan relay
- How long does stock clutch last?
- Height Adjust ?
- Y7/Y8 Mini Me... blocking oil passage in the HEAD?
- GRINDING INTO 5TH GEAR.......
- What salvageable left on the Motor?
- What to do with $1000?
- d16 dizzy????
- Silcon rad hoses from Ebay, check it out yay or nay??
- Clutch Question
- H22 Euro Swap into EK - What do i need?
- TPS adjustment
- What are roll cages for? (Newb question i kno) anything to do with performance?
- adjustment of e-brake?
- Any DIY Timing belt write-ups??? (SEARCHED)
- Weird idle/intermittent no start
- tie rods?
- do i have to rebuild?
- Someone Scratched my car!!!
- oxygen sensor simulator?
- ls vtech
- Carsound Cat
- Looking for Rota Slipstream wheels
- TRANS FOR D16Y8...2000 EX
- jdm si-r cluster in ej2
- LS engine harness
- 96 ls block with p28 chipped comp in 99 ek?
- does a high flow cat hurt you????
- alternative to ARP head studs?
