View Full Version : Honda Civic / Del Sol (1992 - 2000)
- EK shifting HARD & not shifting at all sometimes (Automatic), Why?
- EK clustergoing into EG wiring?
- Power to Manual Swap (WINDOWS)
- Eagle Rods + Lots of water = ...
- Quick question on stock exhaust...
- Rear Disc conversion
- 00 hatch tails... look alikes?
- CRV seats..
- Windshield wipers
- Which intake manifold would be best for B18C1
- Please ID these seat rails for me . . .
- look at what i just did
- front lca help
- crv five lug swap...
- wut rims would u choose?
- Where are the TN,NC,SC,GA,AL,FLA down south people at
- Rear Camber Washer Correction Disaster! -can someone help??
- HKS exhaust on my civic w/VID clip;DL if you want/flames available
- i need help
- keyless entry for 98 civic
- wtb: stock civic 92-95 steering wheel w/ hub
- Civic 98 headlamp ADJUSTMENT
- Tein SS before and after
- 1.5 sohc
- B18C5-EK SWAP??
- Help,Sol acting up,GRRRRRRR
- does anyone know where to get a ls for 1500 or less?
- Mugen Exhaust?
- best oem tb?
- ....thread a stripped bolt thread....
- 96-98 shift boot = 92-95 shift boot??
- In response to Saddam owned!!!!
- knuckle compatibility for 00 civic si
- New forum check out my hatch...
- start the car up, then jumps to 2krpm is it damaging the engine
- Having trouble starting
- what winter tires are you using?
- post pics of your EG hatch...
- J's and B16
- 00' Ls seats in 03 Civic
- Show off** Apex'i N1 and GT-Spec exhaust shots (searched) no luck
- Tire diameter?
- so what size cat do i need??
- got car tuned and dynoed. graph inside
- B20 HAVE knock sensor?
- CF hatch for ej question
- rear lca questions
- help on vtec solenoid bolt size and valve cover bolt size
- POLL: Cam recommendations for b16a
- maybe needing a new streering rack?
- Has anybody had their car tuned at Torque Freaks in Portland?
- Trucks and civics dont mix
- '97 Civic DX "Rolling" Idle Problem?
- EK oddities at the gas pump
- Weighted me hatch
- steering problems
- D series tranny built up questions
- Anyone that has done their own swap, please respond and say yes....
- corner lights are acting funny, please help?
- BOOM BOOM
- Should I Get a y8 Tranny With Quaife LSD, or a JDM D15B Tranny With LSD?
- My car is messing up left and right:/
- 99 civic sedan front bumper
- Which Is Better To Buy For boost????????
- who and where is a great shop to get tuning done in socal
- Torqe Steer
- EG civic with ek side skirts...
- Saddam's oWneD!!!!!!!!
- Would Integra Door Panels fit a 92-95 Eg??? LMK PLZ!!!!
- which EK's didn't come with abs?
- about to get a ls motor for my hatch
- Tokico Advanced Handling Package
- what options are there for having HIDs in egs/eks
- EK w/o the meat, what do u think?
- Suspension set up ?'s ... LOOK
- zc tranny questions?
- Chassis Flex with High Springrates?
- Oops. Crashed.
- 96 civic ex tanabe G Power Medalion cat back on a 96 dx civic!
- what wheel/slick combo?
- need help w/halo projector lights
- B-Series Carbon Fiber Valve Cover?
- ? best deal on clutch for b18c1 ?
- Biggest tire on GSR swirlies?
- Installation Of mugen lip???
- EG SI model...
- imagestation any other site like this...
- Strange noise coming from backside after lowering car
- A crazy dyno day (B18C/hatch)
- MY BRAKE LIGHTS DON"T WORK!!!! NEED HELP
- turbo question
- help or tips on fixing a friends EX
- trade Eibach for H&R???
- sol vs coupe
- Be gentle. Just looking for some help.
- B16 ECU with itr cams...
- Post pictures of DelSols with any stock Honda or Acura wheels
- making room for more gauges
- ot: c'z driver position on ebay
- what is your nicest engine bay....
- got light!!! need help
- will drop car soon, need opinions on a camber
- Is my motor dead =/
- what do you guys think??
- AEM FPR Vacuum nipple broke off
- si rear sway on ex
- security for the rear hatch and window
- Tell me if I'm good...
- How to TEST HID without putting it inside the headlight?
- second part of the v-afc harness
- Whats wrong with my motor? B20/vtech leaking oil out the back! **HELP**
- how did u do this???????
- Anyone seen this for cheap front camber correction?
- looking for lsd tranny for 92 civic hb w/h22a.
- Cruise Control problem... I think??? 99 si...
- took a look at a eg civic hatch
- pics of my eh2
- Powerfc or Hondata?
- Skunk2 intake manifold, str 70mm throttle body on JDM B16
- im getting sick of this
- axle .wtf
- Carbon Fiber CAI?? Who makes them?
- ALARMS
- Battery Question
- boosted b20 how much is to much?
- Which swap would be cheaper?
- Now I attract Mahatma...
- ebay power garage superstore?
- B series swap motor mounts
- caliper bolt stripped
- First time posting pics, flame away.
- civic HX Header question???????????????????????
- B20 swap into a 92-95 Civic
- Tein Flex Coilovers Have Adjustible Upper Mount????
- Just shit that is bugging me
- EK Airbag Tray ?
- Just joined the Si club!
- sohc turbo, what is the best spark plug to use?
- -Help!- check engine light
- help..ctr swaybar installation
- for those of you with km/h gauges...
- need weight loss sugestions
- Wats Wrong With This Picture?
- HELP!! Wind Shield Wipers wont stop!!
- gauge face installation 94 EX?
- RSR ex mag with ITR sway bar on EG HATCH?
- IACV on 97 Civic EX
- Comp Cam P/N 59300
- ek air bag trays
- Trans options for D series setup?
- Will Mugen pedals have clearance issues when my AutoLock is used?
- ****Need tech info on NX kit
- Aftermarket LUG NUTS Help
- Oil control orifice....LS/VTEC..h23a/vtec ??? hmm to remove or not to remove?
- Whoa look at these prices! heeltoeauto rocks!
- front strut damper fork
- GSR thermostat same as d16z6?
- B16 bad gas mileage
- Carfax please
- LS swap to 96 civic
- Am i missing a ground
- 2 questions ???
- inspection related question (PA people)...
- Ravelco Anti-Theft
- ITR swap...5 lug compatibility Q
- ** Want to Buy JDM B18 W LSD Tranny PA AREA ****
- what to check for when buying a used engine?
- Alternator Plug issues? obdI vs. obdII
- Greddy EVO
- molding help
- color help
- Getting Kicked In The Balls By My Car...
- Eg clock
- Camber messed up......help please...
- GSR or RS???
- RSX front (base) Brakes into a EG Civic
- D16y8: Drop compression ratio
- can someone link me to a specific thread...???
- etdeath of EJ1 *JADE* 645PM (PST)
- Happy Holidays from IPS Racing
- B20Z/92-95 Civic parts list...?
- White EGs and blue interior
- LS turbo sol?
- 96-97 GSR/ SE wheels?? (6 spoke)
- carsound cat do i need w/ air or not? does my cat have an o2 sensor
- HELP: JDM b18c type r in a eg vx?
- Anyone ever strip a valve cover nut...
- WTB folding mirrors for 96-98 civic
- clutch master cylinder
- EVAP canister shut valve?!?!?
- throttle cable replacement on 97 civic lx d16
- HID......can you convert a 9005 housing to fit a H4 HID kit?
- Dynod a couple of B16's today.
- Still no start (need help)!!!
- 99-00 Si Gauge Cluster in a 92-95 Civic!!?!?!?!?!?!?!?!?!?<--------
- New security system
- iacv problems
- ingalls camber kit. 96-00 civic kit same as 88-95?
- Best swap
- need help w/ sohc vtec wiring
- 99-00 civic si guage cluster removal? tried a search.
- Quick question about I/H/E
- OE cd players for an eg
- Locate 99 Civic Rear Trailing arm??? ***PICS***
- 100% gauranteed to never be stolen
- azenis heavy?
- I am the proud owner of a 5th Gen Hatch!!! :)
- Is this a good deal...for the money
- Plug wires popping out???
- Golden Eagle Blockguard....
- Is this why my vtec doesn't work.... how do i fix it?
- Gotta model question
- JDM ITR Header Q.
- caliper"s" ceased??
- What Intermediate Shaft Do I Use With My B18C1 Swap?
- what exhausts are ya'll running on b18c5s?
- *HOW TO: Old school... Glowing "Si" gauge logo trick!*
- Anyone remember the thread for that guy who made gobs of power on a d series???
- temp gauge fluctuating
- Rpm/speedo lineup
- bad heater
- KYB GR-2 vs. Tokiko Blues
- a
- Frozen door or freaky locks?
- Z6 TO B1???
- automatic tranny fluid change
- any EK9 type r owners out there
- 92-96 lude seats in ek civic
- Where can I find ....
- Pic request: 92-95 civic coupe with CF trunk lid
- help me with this squealing noise
- Help Me! EG Morals
- Dseries tranny ? eliminate Torque steer?
- 1998 Hatch --> CX vs. DX
- Where to get wingsWest RS sideskirts for EG hatch for cheap?
- Dont buy cheap header = Failed emissions
- what do u guys think of my ls/vtec setup?
- Benefits to SSR lca in an EK?
- Help with ditching tips
- EG2 SiR's Wanna-Be EG2 Del Sol Vtec
- will z6 header work on JDM D15 vtec???
- 99 si rear disc conv. question???
- I need THE CLUSTER Wiring DIagram FOR EK
- what header can I use with my b16?
- all motor B or tuRbo D
- Carbon fiber hatch for EG HB???
- what factor header/cat/ and exhaust is this!!! pics!!
- I just purchased a 2000 type R full swap - thinking about swapping into 92EG
- rear sway bay??
- neuspeed race/neuspeed koni
