View Full Version : Honda Civic / Del Sol (1992 - 2000)
- RS*R Down Springs Rock!
- intake manifold
- So my boot is busted !
- d16 axels
- EJ looking for Slipstreams - what offset?
- What type of taillights should I buy?
- Never thought I would see a local store sponsor someone. So Cal
- Needs help 98 F23A1
- Milling a z6 head
- best H.I.D.'s for the buck
- Black Floor Mats
- B series engine weight
- Can I turbo?
- hid's
- pic request: knock sensor on a d16y8 block
- GSR Tranny in a b16a3 del sol..
- Stroker B16A from stock honda parts?
- HKS t-25 turbo kit
- B16a Head + B18c5 Block throwing cel 9 (cyp)
- GSR/B16 distributor different?
- under dash fuse box
- JDM header dyno results
- tough descion - Accord or not
- del sol shifter
- alternator belt problem
- CAn a 94+ GSR/Type R instr cluster fit in Del Sol ?
- Discussion, Not flame war... EG vs. EK
- Ferrea valvetrain???
- CEL CODES fr. cspeedracing...
- 99 civic si tail light and corner light problem....
- Deal or not?
- ITR seats fit in a 2001 Civic???
- Engine block cleaning
- burnouts
- dumb crooks
- Removing stock spoiler
- Htach Weights.
- Using a D15b7 distributor on a D16Y8/D15b7 minime
- Maker of 99-00 HB Taillights
- What could this do to a clutch?
- ok need help motor probs!!!! b18c oil pressure!!!!!
- Will it cause damage?
- Gauge lights dont turn on some times...
- which type of TEIN i should get??? HA SS RA FLEX OR WHAT??
- $100 Dyno runs in the Reno/Carson Valley area
- Snap off steering wheel.....yes or no?
- Civic DX cam??? which one?
- Horrible Noise!
- 99 and up conversion
- eg civic spark plug question
- 93 del sol trunk release?
- 6 Puck ACT problems
- need opinions
- Where can i get CTR Recaro Seats?
- WILL 93 GS TEG rear disc brakes would fit my 92 CX HATCH?
- my 93 teg seats are not fitting in my 92 hatch what to do???
- Why is insurance so expensive?
- b18b1 F/I vs. N/A
- Koyo radiators?
- Phoenix Members
- My Civic For Sale....
- getting a b16a1, need to know what timing belt...
- p72 ecu on b16
- short shifter install
- are SiRs offered in Automatic????????
- JDM 4-1 comes trough on the Dyno
- overheating the 99 ex.. heater not working??
- Corbeau Forza Seats
- stuck rear brake shoe?
- EVAP on B18?
- How to Make a Swap legal???
- Venom 400....
- help!! anyone knows how I can ship an engine to other state?
- Just need some info before I buy this Civic
- Anyone ever got a CEL for (ECT) Engine coolant Temperature? but car's temp is fine?
- ls/vtec? (tryed search)
- HELP! Idle Surging ('93 EG)
- stroking a b16
- Type R head or jun 3 cams?
- B20/vtec questions
- Tire Questions??
- Brake question????
- Custom 2.25 piping?
- weigh my car?
- wiring harness question
- CARS NEEDED for dyno testing! NJ/NY Area.
- question on ground controls...
- Red springs/suspension??
- Why does my car feel so laggy? And also another ?
- Reward: To those who have video footage of my Hybrid "KOOP"
- What exhuast would be best for 99-00 civic si?
- What off set to for a EK??
- Si tranny in Dx or z6 w/stock dx tranny?
- High Mileage motor oil.
- could this be done??
- Horn problem
- AEM conversion question...please help
- Sunroof problem
- Exhaust silcencer really work? Where can I get one?
- anyone know what exhaust this is?
- poor man's type R
- can u take that black dust sheild of the rear gs-r disk brakes
- crash d
- Looking for a swap shop in the Sac area?
- Aftermarket tach problems
- SOHC VTEC wiring, where can I find a wiring schematic or step by step
- sell my intake>>??
- 97 civic cd player installation.. electrical (fuse) problems
- fuel question
- No emissions
- b16a motor mount bolts...
- STILL Overheating EH3!!!!
- Interior bubbling?
- All motor B16A2
- Recovered stolen car.
- y7. What size exhaust
- anyone in tri-state area go 2 Nanuet on WED & SAT.
- B18 won't start
- **Fram SureDRAIN - Anyone try it out yet???**
- overheating at idle
- obd1 code 41
- Has anybody ever purchased a swap from hondamotorsonline.com
- 5G civic to 6G Insturment cluster conversion
- gsr head?
- Idle Problem
- Need your expertise about civic
- please help-GSR swap into del sol s
- Looking for a high-amp 96-00 Civic/ Del Sol Alternator for a good price?
- fuel filter help
- D16z6 and D16y8 axles
- Vision Corners
- Yeah, so did you move?
- How to test for a worn clutch?
- wire harness for EK
- seat fitment
- this is a dumb question but...
- Manual door panels wont come out! help CIVIC 99
- Anyone looking for CP-FG's?
- Need advice on my first mod (suspension)!
- Adding A/C to a 93 LX???
- Where to buy suspension Techniques 22mm rear sway/tie bar combo?
- Bottom end question
- Stock front sway bar on '92 Si?
- weight differences EG vs EF hatch...
- ITR springs on Koni shocks, and attn: ED TANG.
- 96 hatch - cel codes 17, 41, 65
- 2.25" piping and ITR muffler on a stock DX?
- ES (poly bushing) master kit, anyone using it?
- dyno results inside.....problem
- ** EG people PLease post ur suspension setup **
- TDC crank angle sensor pulley CEL (help!)
- cell code 71 and 41 on stock 96 hatch
- 00 Civic Si w/B18C5, What header??
- how much can i expect to pay for carbon duckbill for EK
- Copper head gasket
- i have seen it all now
- does anyone know the TOP FUEL WEBSITE???
- brake problems... any suggestions???
- are 2000 spec ITR cams the same as CTR cams? (did search)
- Is it true? aftermarket Civic Si or DX exhaust will bolt in a hatch 99 civic
- 00 si burning oil?
- cars cuts off after half throttle
- is this an alright deal??
- H-T kicks ass
- Power Steering to Manual?
- 02 si s2000???
- 1/4 at 200+mph
- california to minnesota
- please guide me
- engine sputtering at low rpm
- what color hatch...newbie queston....
- B20 question in a 95 del sol si (OBDI car OBD2 motor)
- Nitrous direct port injection
- 2" or 2.25" piping?
- AC with 6th Gen Hatch w/B16A...
- Anyone know how much this spoon lip is for a 6th gen hatch?
- Where can I find ZEX parts online?
- I just saw an EG with a carbon fiber ROOF!
- Question regarding different JDM Motors....
- What rear LCA's do I use in 5g EX coupe to run a swaybar?
- Analyze my time slip plz
- Coilovers
- o2 extension
- Please help me put this to a rest !!!!
- Someone Keyed my car tonight!
- My syncros are fuct! Should I just buy a new tranny or get them fixed?
- B16s or B18s.
- Racing Harts Sold....
- thanks yall
- del sol rims
- Meet In Indy ****Team Sol*****
- any under-axle exhaust?
- Need Help w/ Hood installation.
- Can someone answer this!!!!!!!
- need help guys
- vafc setting
- carbon fiber hoods-whichis the best?
- Looking for a few good shops
- price for h22?
- Couple QUESTIONS please reply as soon as possible
- LS Swap
- Screwed up my temp gauge????
- D.I.Y. Sparco seat mounts for OEM EG/EH/EJ sliderails
- This is starting to piss me off
- gauge cluster?
- help with vents in 92 cx
- Hondamotorsonline.com, JDMhondaparts.com, and JayDM.com
- Ultra Performance
- Timing Belt
- 2 quick vids from my new camera mount
- I thought the D16 didn't have a knock sensor???
- will 95si alternator fit my 97dx?
- no one?
- What can i expect from this mustang?
- what suspension will fit on 92-95 civics?
- sideview mirrors?
- Tanabe Racing Medalion ?
- si or ex bumper on a98 dx??
- KYB AGX's...help!!!
- i saw some black grease in my intake manifold
- 99 Civic Si
- motor questionn??
- service connecter on 96 dx hatch
- B-series turbo manifold that can be used with A/C, and still produce power
- Import auto salvage install?
- can someone help me find a mugen lip 92-95 civic lip
- Will Si front sway fit on Ex?
- need help , car is surging
- tire question
- Location of Fuel Pump Relay
- 2001 civc coupe
- FS: Custom Del Sol Sub Enclosure and Subs
- Help me get rid of this annoying sound.
- What hatch to buy, 93 Si or 96 DX
- bearings for a b16a1
- Question about civics
- Decision (still)
- 90 teg seats into a 92 hatch?
- OEM Sticker
- Honda Roller-cams VX/HX
- Hey Anybody have NEUSPEED RACE springs on their civic?
- Anyone here have TANABE PRECEDEO springs on their EG civic?
- Removing A/C???
- If anyone is interested in the Civic "Factory Performance" package...
- radiator problems
- thinking about swap...i need help
- N1 clearance problems? nahhhhhhhhhhhhhhhhhhhh
- how to tell if the which head is JDM B16A2 and B16A I
- eg manual to power???
- Anyone ever get tired of driving there Civic...?
