View Full Version : Honda Civic / Del Sol (1992 - 2000)
- fuse box under hood
- Touge civic?
- GSR PISTON
- Check out my Eclipse.
- will this work... efficiently
- No o2 sensor on dc header
- Photo Request: Upper Balljoint on 92-95 Civic when it's in place.
- Head gasket???
- Hondata S300 In Si.
- DIY City Lights Jdm conversion
- ls vtec reliability
- Help with motor install into a 92 DX???
- Rattling Noise from engine bay.
- 93 honda civic DX... New Exhaust
- 96 hatch with ctr exhaust?
- Whats the advantage with 4 disc breaks instead of 2 disc in front and 2 drums in the back?
- my civic eg8 is sold =[
- B18C1 with ITR or CTR parts?
- need link
- ls dizzy for lsvtec
- Offset math is FUN!
- best exhaust for 2000 Civic Si?
- injectors
- car shuts off while driving
- headgasket question
- Will a 99-00 b16 DIZZY CAP fit a 99 GSR DIZZY????
- Installation of Cold Air
- Gas Gauge Needle broken
- Will b16 Supercharger fit on b18c5?
- SKUNKII cat back exhaust!
- Turbo my zc or swap.
- dyno sheet
- p28 cel 40 & 50 ? wtf
- axle problem
- bad 02=intermittent severe hesitation?
- h22 into a del sol
- What exhaust and cat for 95 coupe/ b18b1 hybrid?
- airbag light fix with resistor help
- K20A2 Injectors
- Ek9
- jdm d15 hp rating non-vtec
- Installing an axle
- Hang with me...Jeep trans question
- Mirror Disassembly
- Need answer fast - who makes the alternator for..
- .... are all OEM eg/ek D15-D16 header the same size?
- Type-R Interior in an EG????
- my car doesnt start !!
- I need help
- Greddy Evo TT muffler
- i got a question
- Jack Stands???
- what do i need to check if i can Vtec my D14A4.
- ATTENTION!!!
- Si Stolen, Nassau County Long Island New York
- clutch pedel gettiing stock then coming up to noral place keep bleeding i dont know what is up!!!
- eg/ek skirts on a del sol?
- transmission help
- thinking about getting some slicks
- clutch master cylinder help
- VTECH
- BRAKE HELP!!!
- Price?
- best place for car alignment in the new york city area
- I NEED SOME HELP?
- B16 swap into del sol.............startup issues
- will obd0 starters work on an obdI car?
- help serious porblem
- Speedometer not working HELP
- JDM d15b with cx tranny
- 92 hatch
- H-seires back to B-series:: Hassle or strait foward:: I just need info.
- quick question with a picture.
- ek steering/handling problem
- Windsheild Wiper/ Headlight Problem?
- Skunk2 vs Ground Control
- USDM ecu help?
- Question.. 99-00 headlights fit 96-98??
- good deal on swap?
- Civic Cooling and heating problems
- dohc zc in to eg instead of vx motor pro and cons
- what's the safest way to install a 3-point harness to a del sol
- EG Civic Ignition problem
- jdm headlights and side markers???
- lca's???
- WTB: D16z6 block
- need help with my 99 hatch
- What would make..
- quick mini me question
- i just got my oem "style" foglights in the mail...im having an issue
- Help with diagnosing noises
- S1 tranny LSD!
- neutral start safety switch?
- Z6 camshaft in A6 ?
- jdm fog lights
- Part number of the main relay that's under the dash near the fuses?
- axle back fitment question
- d series transmission. How do I get the gearset back in
- Axle poped out under boot
- Body Shops in San Diego?
- Looking for: Evenescence Turbo Civic Hatch Video
- questions on B20 vtec swap......
- Air Bag Install 99-00 Si
- My car bounces up and down on idle when stepping on accelerator when warm
- JDM b16a for sale
- pods and guages
- Integra dash questions
- about how much to get a bent valve guide fixed at machine shop???
- searched...
- Projector Question
- Adjusting the TPS?
- Motor mounts
- what kind of tranny does 1996 civic hatchback dx have?
- will a 04' single cam motor fit into an EG?
- LS VTEC swap
- camshafts and cam gears
- New Motor
- foglight seller question
- Steering counsel SMOKING
- Del Sol
- ecu motor question
- ECU codes..... HELP!!!
- 96-00 ek colors?
- ek sideskirts Q
- question for b swap eg people
- I need help finding a color for my eg
- HELP!!! Alternator problems
- cat-back piping only?
- Steam / Oil coming out of bottom left valve cover bolt area ASAP help :)
- EG with upper grill?
- Car won't start, any ideas?
- got a question bout AICV
- **i need help wiring VTEC**
- Vibrations? and i did search didnt find any solution
- rear disc conversion
- EG hatch Cargo cover, which speakers?
- Help please!!
- anybody hear of this?
- TPS Sensor
- Conflicting info
- Needs some help with a project of mine
- ? about a EK9 JDM Civic Type R carbon fiber climate controls
- Motor Swap: Easiest, Fuel Efficient, Full Bolt Ons?
- triangular windows, Del Sol
- 92 dx hatch with d16z6
- Wanted: Stock Exhaust Manifold-Cat for 99 Civic DX in South Calif (L.A.)
- Exhaust Question
- Am I doing something wrong here or what...?
- jdm civic typre r headlights
- sensor ?
- exhaust brand... how's this ones quality?
- ignition trouble
- Belts making CHAINSAW screeeeeeeching noises at start up, this is pissing me off!
- Motor in Fl?
- power steering problems
- how crucial is an exhaust
- High Beam problem
- yes or no... simple question
- APEXi World Sport exhaust for EG ?
- What Kind/Brand Of Motor Oil To Use?
- Why do I have to hit my dashboard to get the instrument panel light to work??
- question about suspension
- Walkthrough. Installing Hood Locks
- usdm vs. jdm
- Hondata S200 problems???
- pros/cons of the gs-r
- Birthday Today
- what shift linkage do i use with my hydrolic to cable conversion in 92 civic ?
- my rhd eg6 conversion
- Engine light on, O2 sim don't work. Help!!!
- em1???
- 3.2 cl supercharged mid engine rear drive delsol 94,can it be done
- clutch pedal adjustment(grab/release)
- Wagner ThermoQuiet Brake pads...anyone use them?
- Best Cold Air for the money?
- quick alt. question..
- VTEC Head instead of an entire engine swap?
- EK swap???NEW TO THIS
- greddy turbo kit
- How to tell if a tranny is a SIR 00 tranny ?
- Help w/ECU choices
- ES mount inserts for b16 EJ6
- Ecu ?....
- Hondata s200
- Fitting a VENOM I-M. PLEASE HELP!!!
- Cel 16 & 41 AFTER changing throw out bearing HELP!!
- brake dont brake well...help
- Pictures Request: Apexi N1 exhaust on 92-95 EG hatchback
- B18B swap into 97 civic ex
- HELP!!! Having problems with brakes.
- expletive ALLLL THE B-SERIES ENIGNE WANNNA RACE MY V6 BITCHHHESSSS 4 BANNGER SUCK ON THIS
- kenji211.com ECU !!! ANYONE!!!!
- VTEC and revlimite for B16a2/B18c1
- which bracket do i use?
- cable and hyrdo tranny Q
- Who knows about dizzys? 97 Civic Coupe EX
- Is this 96 CX hatch worth $1000?
- Intake manifold
- I want to get a body kit, but......
- hit a curb...what else could be wrong?
- Will tailights for a 92-95 hatch fit a 92-95 civic?
- HELP!!!! Problem with brakes.
- HOW TO MAKE YOU OWN LEAKDOWN TESTER! instructions inside!!
- ECU help
- obd1 to obd2
- non normal 1st gear
- My old 93 vx rip
- Whats the easiest way...brake switch.
- Calling South Carolina members for paint help
- Bride Brix II + Sparco Bracket = ???
- ebay c pillars
- ls swap into 94 civic hatch?
- spline count?
- 92 B16 xsi into a 93civic dx coupe questions
- 99 civic si wiring help
- Sever Oil blow-by, Rings shot? valve seals,guides?
- My 93 civic dx hatch....
- 97 civic POURS THICK WHITE SMOKE!!!!!!!!!!!!!!!!!!!!
- B16b transmission questions
- exhaust wrap header tape
- Exhaust Information
- Did any 1995-2000 Civics come with black interiors?
- EG or EH
- Traction bar help
- Install 96-00 Civic cupholder/shifter/armrest console into a 92-95 Civic? How to?
- someone to paint my car?
- Just a silly noise maker
- dc header 2 pc or 1 pc
- My car revs up when idle
- Auto 2 Manual: Little black box where clutch pedal goes???
- MUGEN RG
- CF hood with turbo?
- dash lights
- What type of valve lifters does a civic have
- NEED ANY ENGINE ASAP
- Should i buy this EK?
- What Kinda Cleaner do you use to clean the inside carpet and seats of your car?
- rhd woes
- &$*% cambers
- Headlights and gauge cluster lights go dim then get bright, bad groud?
- HELP! funny thud
- surgeing idle and engine light come on
- installed thermostat but heat is not very hot
- speedo question
- dc2 seats fit into 92 4dr civic?
- prelude seats
- b16 headache...need opinion!!
- How to remove climate control radio bezel 96-98 Civic hatchback
- damn muffler issues
- FAILED AT THE CARB REF, NEED HELP.
