View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Header with 2.5" collector for D-series?
- power door lock pigtail
- 1000 mile round trip at 80 mph @ 5500 rpms
- head specs
- bleeding breaks
- help what is good engine swap for 98 civic 4dr????
- which bolt do i remove to fill my tranny?
- wiring problem
- mounts... i think i have a big problem
- car wont start.. not battery or starter... please help
- Can you swap a Civic 96-98 Climate Control to a 99-00 one? How To?
- 94 Sol Si, right window and rear window suddenly won't roll up (power)
- LS rods Si pistons
- Engine Light help
- LS Civic
- anyone know what this cam is "for d16z6"
- Accord resistor box in 92 si. Will this work??
- del sol with an h22, a/c possible?
- brand new primer oem civic front bumper?
- gauge cluster dead
- VTEC head swap
- tranny code question
- CEL code 16: Fuel Injectors
- 93 civic si
- Civic Axles
- Stupid ECU Question???
- b18 on a 97 EK
- Vtec Solenoid?!?!?!?
- carpet question
- i need help!!! ecu question
- d15b8
- OBD0 B16A into a 92 EG OBD1 ???'s searched some
- random technology CAT?
- gsr manifold
- gas gauge question
- si rotors
- best swap for a 92 civic hatch
- HOW TO AC
- d16 block y8 head
- knock sensor years?
- EK CTR Suspension & Spring questions...
- Prices increasing for used Civics? Whats you local market like?
- my car wont keep its timing
- interresting A/C inquiry
- Fs/Ft- 93 Eg hatch B20z swap
- Thinking about reviving the sol a little bit.. any idea the costs??
- question regarding ctr steering wheel air bag
- D15B7 distributor
- EK Alignment question, no mods
- lighting problem
- Rear Diagram!? Help Please
- MODS?
- HELP Wiring up horn for Quick Release
- SOHC VTEC CAMshaft
- Seat rails
- my new '95 coupe: Project Rice-Be-Gone!
- Anyone know of a light that will fit w/out cutting?
- WHICH TURBO
- 99 si shocks question
- my UKDM eg6 VTi-turbo
- Is there a way to install a cd player w/ the stock pocket?
- help!! B20 in a EK and wont turn on??fuel pump??
- HELP!! 2000 Civic Dx SRS light
- Need a QUIETER Exhaust!!!!
- questions regarding to oil change for my 2000 Civic Si.
- Brake lines....
- post pics of ur back bumper with a diffuser
- 93 del sol Speedometer and Tack probs
- stiffy question
- 1999-2000 ek hatchback owners..a question
- Speedo want work
- 2000 automatic transmission problems?
- bogging out?!...
- Motor Swap for 98 EK ?
- ek hatchback heart transplant...
- SMIC and Foglights?
- b18b nos?
- started off with d16 now b16 still not happy
- ---Need Advice on a car with no paint.----
- rear disc/ebrake cable question
- header question!
- My Del Sol....His 240sx.....SHOULD I TRADE?!
- help
- Rear disc brakes
- Need the right Ecu
- switching auto. b16 to manual motor mount question
- Neep Quick (about jdm SiR steering wheel installation)
- Integra Blinker relay On civic??
- 6200 rev limit?
- hesitation at high rpms
- how do you like your TEIN S-TECH springs?
- Block with missing sensors please HELP
- B16A OBD1 what is the correct alternator belt GSR or Si?
- question with seats?
- Need Help: Del Sol Alternator
- Radiator fan not working
- Check engine light on EM1??
- Lift points
- 94 civic mini me NOT running right at all HELP!
- d16y5 block/d16y8 head wiring?
- i need a 96-98 complete power system.
- where to install montoring equipment on my ek dash
- Power to manual windows?!
- will any p28 manual work with my ls vtec manual
- integra front end on civic
- post your pimp ej1 pics! show a noob whats up!
- Bad "wahhhhh" noise
- getting a gsr swap which tranny?
- Check Engine Light - o2 Sensor replaced?
- Finally did something with my headlights...
- Squealing/squeaking noise. Help plz!
- ac problem
- Difference between sincle-stage and a two-stage vacuum pump?
- ********go away u stupit light*************
- Wheel and Tire question for EK hatch
- vtec controller
- Would this intake setup work?
- Did any of the 94 del sol's com with a d16z6 stock???
- how to loosen a/c belt tensioner
- 14 sec. quarter mile
- what mounts to use for gsr swap into em1?
- VIN numbers on Gsr
- converting 98 front end to 00 front end
- NSX calipers on a EG hatch
- Mini-me swap
- wire harness question
- Fog light problem
- Valve adjustment spec for a d16z6
- ZC's
- NEED HELP WITH TURBO MANIFOLD
- Water pump problems?
- Yet another Syncromesh post
- Distributor HELP
- HELP-who has done a k20a swap wit a ep3 cluster in EG...??
- another problem...this time with vtec
- basic question on p&P gsr head
- What AC Bracket/Mount for EK with Si swap?
- buddy club spec iv cams
- Please Help. 98 Ls trans problem
- Car died, no turnover & clicking from fusebox
- 1997 civic lx ac question help (in tx 102 degrees)
- engine problems
- Type R or mugen front lip??
- Need Help " Can i fit an entire d-series motor in my backseat?"
- B16 clutch specs plz
- my engine is dying and i don't know where to start...
- Odd electrical/coolant system problem?
- Tranny/clutch Prob
- 98 civic dx
- tranny question
- automatic to manaul
- Shock Compatability
- vision type tc mirror :REPAIR HOW TO:
- JDM DC2 TYPE R srs STEERING WHEEL IN A EG
- EK Sidemarker Install
- help meeeee
- 93 hatch cluster problem
- Car hit my rear passenger side trunk corner...what can I do with no body work experience and little
- check engine light...what can I do to fix code P1456?
- Need a stock Dx engine AT
- a/c belt
- drove through water and car died is engine toast?
- i need help...ls block or a GSR?
- canadian hatch???
- Need photos of Eg on springs not coilovers
- HEY...
- Primary oxygen sensor heater code NEW O2
- ****my STOLEN del sol recovered in lenox CA. stripped (pics)!!!***
- tranny issue
- Power Steering Rack - busted piece!?
- AC questions.. searched
- P28 ECU Manual or Automatic
- weird lug nuts
- There is spark and fuel but it won't start?
- D series parts interchange question.
- quick ecu question
- i have no fuel...
- REF question
- i have a d16y7 head will a ex vtec d16y8 help?
- i need a 96-98 complete power steering system
- Door lock cylinder/tumbler for a 2000 coupe?
- Power loss at 6000rpm
- link to my car on the RR/AX forum
- Integra mirrors on Civic EK?
- Gauge cluster problem
- Anybody have any expierence with these people?
- overheating problem
- GSR Swap in 92-95 Civic Hatch Si Throwing Codes??
- Batterry light on???? Alternator searched
- quick noobie question about 92-95 civic bumpers
- A Couple of SMOG Questions!
- Emergency Brake light stays on...
- OEM Si cd player harness
- ek foglight problem
- Apexi Neo harness same as VAFC 1 and 2?
- Custom Roof Lining
- Want to boost my D16!!!!
- can a b16 aftermarket cam seal fit on a d16?
- Few Questions.. NEED HELP!!!
- i need an ecu, help!!!!!!!!!
- NEED 2 FIND EP3 cluster wiring harness diagram
- help please question about rings
- Sticky tires for SI wheels
- B16 or SOHC turbo?
- 97 gsr wiring harness
- d16y5 with a d16y8 head?
- rings are fried
- LIGHTS
- 99-00 tail lights, question...
- ITB'S FOR SALE FOR B16/ TYPE R HEAD ONLY!
- question eg with kyb agx with H&R sport spring,
- Where can I buy this bezel from? Raybrig rear foglight bezel
- 98 DX tranny compatible with a 99 DX motor?
- nothin but problems
- 99-00 si motor mounts
- ZC best compretion pistons in a stock ZC Dohc
- oem cat converter nut size
- 94 civic ac switch problems
- swapped in D15B, idles/starts great, cant hold RPM steady
- Tein Type HR??
- grinding noise when going 60mph or above
- uhhhh wtf? (5 pics)
- vibration on right side of car when car is being pushed hard
- ebay nippon pistons, (seriously?)
- EK engine mounts
- Mini-Me HP Gains?
- Carbon fiber trunk cant find them????
- Installing in dash CD player
- cutting the antenna?
- How do you?
- Whats wrong??
- DAMPER KIT SET-UP
- Honda ECU and Acura Engine Combination causing problems?
- Doorlocks stopped working>
- trying to remove axle problems. castle nut spinning along with balljoint
- What belt size are you using for AC with a GSR swap in 93 Coupe?
- Distributer Sparkplug wires witch one goes too witch d16z6
- intakes?
- 4-1 or 4-2-1 header??
- Good SPRING RATE In KG/MM for TANABE Springs
- Someone on here surely has the answer to my swap question
- CAR WON'T START? try the clutch interrupt switch
- 96 GSR motor, 97 civic EX...what cat do I run?
- tORQUE ON cRANKSHAFT PULLEYS D16Z6
- New Calipers?
- Wobbling Steering wheel
- which linkage or shifter do I use for a b18 swap?
- 17's on stock suspension?
- build a high compression motor
- A/C issue... during the hottest week of the year in michigan, of course!
