View Full Version : Honda Civic / Del Sol (1992 - 2000)
- hello :wave:
- clutches
- throwing a P1157 code
- head gasket b16
- Screws for rotor?
- slow h22a civic
- Buddy Club Pro Spec Exhaust System
- del sol side vents
- quick ls and gsr block question
- front end steering
- interior lights
- Mini Me Question..throwing code54...Searched and Searched i swear..nothing..please help!!
- ngk plug numbers
- 92 Civic Fuel Smell
- 2000 Honda Civic h/b DX bogs when a/c is on for a while.
- spedo not working then freaking out????????
- My introduction
- help installing apex vteccontroller!!
- cel codes again.... "170, 172, 325"
- up for suggestions on struts
- Please Help. RPM's Limited and Very Slow Acceleration
- lights wont turn off
- fresh gsr swap in hatch, running VERY rich. PLEASE HELP
- s20/ s40 5spd transmission schematics
- You think it was a bad idea???????? im lost!!
- Correct Method for Timing Belt Tension
- Inspection help?
- '94 Repair Help
- hx wheels ???????
- crower cam
- Part Number for tail light gasket
- Did garrett ever make a turbo kit?
- Noob in need of help
- D16Z6 oil dipstick tube leak
- car wont start... need some help.
- Need pages from the 92-95 helms manual
- The Best Place To Buy Parts For Your Honda
- Skunk2 lowering springs, need opinions!
- d15 mini me z6
- 1992 civic hatch
- What Honda did these wheel come off of?
- cracked d16y7 manifold
- Climate Control back lighting issue
- CYP CKP obd1 bypass
- ls swap 4000k Rev limiter??
- HELP!!!! PLEASE!! CAR WONT START!! mini-me problem
- Engine problems
- Body parts
- Gas gauge question
- installing piston rings
- will ITR sway bar endlinks work on a 95 si??
- how can i replace ignition switch
- 93 civic
- know any good DIY swap guides
- Wire tuck O2 Sensor code
- Odometer Speedometer SRS Light = Gauge Cluster?
- obd2 b16 to obd1 b16
- d15b7 vs d15b8
- Question about installing a bucket seat
- speedometer going crazy and lights get dim?
- Steering Wheel Airbag Question
- squeasing power from a 15b
- car wont go pass 4000 RPM's
- Replacing front rotors 99 HB
- 92-95 Civic J's Racing exhausts
- wat transmission should i get ?
- fender
- D series map sensor on a b series?
- Manual rack?
- HELP!!!
- y8 starter
- Steering wheel/ air bag problem!
- No speedo and engine check light
- 97 Honda engine blowout?
- 2000 Si stolen and stripped...To rebuild or not to rebuild
- Motor Mount or Axle Problem? Help
- Which axles to use? B18b in a 98 civic
- Quick question.
- Hard to start car with 1/4th a tank of gas or less.
- help on wiring hatch HIDS
- Completely Clueless- Need Advice/Input 92 Civic with odd symptoms
- NEED HELP with my account
- 95 civic cx hatch, wider radiator.... whats best bet
- 1996 Civic EX Rear Five lug Swap Question
- Have axle problem
- hard decision
- 92 eg hatch
- need help, b18b set up turbo
- nasty noise on right hand turns? help!
- need info!!!!just bought a car but could i return it (found out tranny was bad and other stuff)
- '00 ek4 already burned 3 ecu's. Help needed!
- sensor on d16y8 identification
- questions about my swap? 1992 civic cx
- Storing your car in a tent for winter? Anyone try it?
- fuel pump help plz
- still loosing oil, ideas?
- f20b obd2 ready and getting h22 obd1 would this work?
- Radiator fan allways on
- coilover help
- question about b20 rod bolts what zise are they 9 or 8mm
- Idle Problem,Electrical???
- GSR vs LS oilpick up (i want to use a gsr oil pan on a LS)
- Best Axles?
- tuning help
- distributor or coil or what please help ?
- ABS Light On
- Car doesn't start one try, CEL comes on after driving awhile
- Good or bad: d15z1 with HX trans
- 2.5in donut gasket? Where can I find one?
- EK Cluster In EG Issues
- Removing top hats from shocks?
- del sol exhaust question
- Quick Question about buying lug nuts for HX wheels
- Shudder and 5th gear question
- Can I put AC in my civic hx (has continuous variable trans)
- NEED HELP B18C gsr is messed up.......
- Just Saying.
- PROBLEM WITH SWAP!! NEED HELP!
- radio code?
- How to remove front upper control arms / ball joint for installing new ucas 92 Civic
- SPARKPLUG HELP PLEASE 1998 HONDA CIVIC LX SEDAN?
- JDM front end
- Installing Cruise control + airconditioning into EJ7?
- d16z6 compression problem...need help
- 50/50 tails on EJ6 sedan
- Evotion springs
- need assistance please...
- accelerator/fuel problem?
- Help Swap B18b1 in Coupe 2000
- Need new axles on my LS swap what do I match them to?
- ex brakes
- should i buy or not(99 si 3000)?
- wheel locks
- MEMBERSHIP CANCELLATION
- HELP! fuel pump kill switch!! which wire?
- 97 ex brakes on rt4wd wagon
- Fuses beside the battery?
- trail user?
- steering wheel shakes....losing acceleration.
- WTB:HONDA CIVIC MUD FLAPS GUARDS 1996-1998 4DR !
- rack n pinion help making noise
- Rear hatch wont open
- IAB doesn't work after OBD2 to OBD1 conversion
- harness removal
- Car breaks up around 5,000rpms...
- difference between 2 door and 4 door
- the rear signal light of a civic 00
- GReddy Evo2 Exhaust - Opinions/Help
- Car Won't Start after wire burned...HELP!!!
- /// ~ Getting a chip re-burned - NEED INFO! ~\\\
- LS Swap
- Question about Tranny?
- Axle help!!!!! Urgent
- Sounds a little sketch.....
- What are the 3 sets of wires going to the Ignition key tumbler?
- 96-00 civic b-series swap mounts?
- so the numbers on the JDM vin tags are engine seriel numbers correct? (pic)
- Electrical Short draining my battery (Deck Ground Wire Electrical Short?)
- ph12/d12 carburetor...
- d15b 3 stage vtec 5spd tranny?
- Conversion harness? OBD2 to OBD1? Smoggable?
- MB6 (B18C4)
- oem part supplier needed
- damn alternator ground....
- usdm ecu?
- Help:swap wiring with pictures
- cam gear's
- bad 02 sensor no vtec?
- how long are your side skirts?
- gsr swap in 95 civic
- HELP:: How to refurbish some blades?
- Ignition Problem/ Random missfire/ Dizzy help
- Will Catback from a 2 door Civic fit on a 3dr?
- 99-00 Seat rail removal
- piaa crystal ion h3 at walmart?
- Ek hatch MPG, is??....
- need help locating a swap..
- vacuum diagram for z6 intake
- Project Daily Beater... I have question please help me along...
- Stolen 97 EK April 4 2008
- What kind of numbers should i have?
- trouble with my swap
- Getting my chip re-burned. Need some info
- Neuspeed sport springs
- CEL code 19 (automatic trans lockup valve) i have a manual p28
- 96-00 civic arm rest
- anyone have a usdm p72?!?!?!?!
- ej8 rear window spoiler!!
- Random question
- Problem with my fuel gauge
- gas smell
- No more hatch...sad day
- bodt work
- Rear Main Seal.
- custom build shops!!
- My Dyno run with VIDEO
- foglights ???????
- need help! running problems/wont start
- power steering yes or no?
- dyno results for swaped civic gsr
- ws2 on 94 si hb making tapping sound???????
- Can't Decide
- rhd sales man
- OBD1 SOHC Dizzy on OBD2 DOHC head...
- NEED HELP!!!!!!
- Im Lost!!!
- Help with starter
- 1994 Honda Civic Dx - Car almost starts but wont turn over.
- type R lip question
- 1 and 2 Cylinder not firing! PLease help!
- choice of exhaust - what would you have?
- Trouble shooting: Oil fouled plug on number two from the distro
- 95 distributor work in a 96 civic?
- White smoke and water coming out of exhuast
- door pannels
- Anyone deal with Randy Kuehl Honda in Cedar Rapids, IOWA? "showroom" = Rusty :(
- squeak???
- meet bust! riverside
- having trouble with my swap
- 92 CX Hatch Low Fuel warning light adding
- car shut off while driving *** urgent ***
- Short Shifter
- header question........
- help!! with my mph and mileage. dont work
- 2 questions..
- DIY License plate relocator
- spark plugs????
- fuel leak...?
- 99 ex sputters for a few minutes when I fill up with gas then runs fine any ideas?
- ecu making my car have idle like vacuum leak
- will they fit?????
- need help
- Bully Clucth?
- Axle/Driveshaft Boot replacement question
- valve cover bolts
- Thinking of lowering my EG question!!!!!!
- eg coupe sun roof leak
- eg coupe rear seats
- B series swap (power steering ?)
- Intro and Question about P/S
- EM1 engine mount
- Wierd Lights problem.
- Springs that don't drop much?
- turbo build NEED HELP!!
- 2000 LX (D16Y7) Motor/Trans mounts, torque-limiter, shifter bushings, MPG, etc.
- damn o2 sensor ?
- Replaced hatchglass shock mount
- Can i use ARP and Orginal head studs??
- Check engine light came on after turning on wiper
- Location of G401,G402,and G552 on 99 Civic
