View Full Version : Honda Civic / Del Sol (1992 - 2000)
- HOW to BAR yur new engine swap?
- what color are ej1s available in
- eg paint color?
- will a lower rear tie bar for 96-00 civic fit a 92-95 civic?
- xenon
- is this a good deal?
- from what year to what year were the civic si coupes made with the b16 motor?
- OBD1 VTEC Motor Into 98, OBD2 Non-VTEC Harness, Help?
- LS Motor
- installed timing belt one tooth off.. possibly bent valve?
- 94 h/b rear swap ?
- Axle bearing inside of rubber boot? CV joint? I think I need a new one.... (PICTURE INSIDE) HELP....
- tow my car from the shop?
- Bouncing Idle
- EG/EK coilover interchangable?
- 98 civic dx (doing ls/vtec swap)
- buying mugen
- CEL Help
- what loc tite on flywheel bolts
- took off my first head got a few questions.
- GSR swap What should I set vtec at?
- taking off rear hub, 1 torx screw stripped!!!!
- My horn is broken
- how do you remove seatbelts from A pillar?
- question on B18b
- A/C question
- 2 map sensor plugs, which one to use
- going from obd2 to obd1 problem!!!
- gsr motor
- 2000 SI foglights install...NEED HELP ASAP!!!!
- Where to buy aftermarket tie rod?
- quick question tps
- o2 sensor problem
- Civic Si's @ Auctions
- vision type tc side rearview mirrors.
- online repair maunal
- I got robbed again errrrrr
- ECU question for my H22a
- Swapping in Acura EL leathers into my EK...what do i do about the rears?
- car flutters until warmed up
- P14 H23 ECU with B16 in 00 EK.. Possible?
- Does anyone know the weight difference between D16 and B16 motor/ man tranny?
- Air Conditioner compressor cycling on and off immediately?
- B-series tranny part compatibility question...
- clutch or tranny problem or something else?
- stock y8 head capability
- B16a,b18b,b20,h22a ON 98 EK HATCH
- knock sensor?? do i need one?
- Sound from Front Drivers Side Wheel Area...
- ROTA SLIPSTREAM???
- 99-00 SI light wiring diagran needed please
- Lookin for a body kit for a 93 civic
- V-Tec?
- 92-95 Coilovers. Will they fit on an EF?
- just making sure im doing it right, replacing cap
- HELP! axle wont come out and the end is MUSHROOMED!
- car keeps blowing ignition fuse. help.
- idle/smoke
- Headers
- Best way to bleed air from cooling system?
- Help with check engine light...
- tint?
- Air conditioning question on recharge?
- Opinion on what engine to put in my Eg
- OEM foglights not turning on!
- Body Kits
- Koyo Showa radiators
- How much should i expect to pay for an ex/si tranny??
- jdm foglights
- new guy
- Flywheel & Clutch advice for a friend
- jdm corners
- Y4F Tranny? To Buy or Not To Buy.... That IS the Question!
- Rear Brake Drum Removal - 96 Civic - having trouble
- Climate Control Relocation
- Is the HX Engine (D16Y5) any good?
- What Replacement Brakes for 4x114.3??
- Exhaust/Muffler question
- Motor and front Lip question?
- Swaping from CX to EX cluster but RPM gauge doesn't work!
- thermo control valve on d16z6
- 99 climate control in a 96?
- OBX Twin Loop Muffler installation - need help
- Jumpy idle
- swap problem HELP!!
- electric problems??
- quick axle question
- breaking in my motor.. help
- Car Just Shuts Off
- exhaust help
- need advice on turbo setup for 99 si
- Rounded Off Oil Drain Bolt...#!%&
- steering problem (not good)
- D15b swap write up
- '94 VX
- EG Exhaust Pic ?
- gsr tranny question?
- Question about vehicle titles
- Battery keeps on dying...
- engine oil dipstick
- crv b20 lack of power helppp
- clutch paddle leak
- why dont we do a...
- INTEGRA CLUSTER ON EG
- need help on my civic, rear sets
- Door Lock
- EK swap question
- Crazy EG backseat
- Pic Request: EG with stock grill removed
- I bought an msd digital window switch need help
- Car Does nothing when I put it in Gear??
- mini me woes
- ECU
- Good Idea or Bad Idea?
- Del Sol Pro's and Con's The official end all thread.
- Intake Sucked up water :-(
- Honda motors
- Bumper before / after pics
- Timing Belt tension???
- Fluidyne Radiator has no Transmission Cooler
- How rare is this hood?
- starting-charging-dead battery crisis....
- Compression Numbers
- import builders head package HELP
- h22 tranny question
- new motor need help ! code 16 for d15b vtec
- temp needle goes up and down all day long!!??? HELP
- Help for my beautiful inner CV boot!!!
- Removing Pistons without removing Crankshaft
- Harness rewire? Starts w/ AEM, not stock ECU (2000 Si)
- UBERDATA
- Need a little help with ABS problem
- *HELP* radiator drain plug problem *HELP*
- Dist. Questions
- INDENTIFYING SOHC VTEC HEADS
- 95 eg igniter issues?
- Stuttering civic.
- Tail/Brake lights staying on all the time. Help me Please
- tail lights
- question about bushings
- Another Stupid question. Will these Coilovers fit?
- Oil light lighting up on mini me...
- Tranny Problems HELP
- Crank angle sensor ????????
- I did a search...and nothing!! Power steering question!!
- Car not always starting up.
- what i need for a d16y8 head
- body kit....(flame suit on)
- Cams, Valve Springs, Retainers
- A/C help with '94 Civic!
- vtec disengaging at 6500rpm code 4
- swap is done
- Hydro-locked motor (searched)
- seized Ground Control
- delsol oem bumper nut and bolt sizes?
- where is the iat sensor on my 95 civic hatch cx i cant find it!
- is ls vtec worth it
- d series with b-series head??
- radiator fans dont turn on
- civic CEL Code 1 help please tried searching
- quietest muffler that makes power....??
- Sellin my car....this is a scam right?
- MoT Failed
- Pic Request: Milano red hatch with mugen rnr's
- 96 civic, ignition
- New Guy needs Help
- sohc vtec swap
- weird idle, bogging, choking after plugging in p2t ecu
- I'm having an electrical problem
- how to remove front hub? ADVANCED ADVICE NEEDED!!
- B16B stock intake manifold vs Skunk2
- fields vtec controller settings for b16a3??
- Comptech?
- WHICH wiring harness? obd2 or obd1
- Car not going into gear on the ground but is when off the ground.. help
- after mini me swap. running really rich???
- Del Sol dash swap into an EH2 questions. Don't flame, read on...
- Looking 4 great used car sites for imports.....
- how often to change these out?
- Anyone Know Erick from Honda Fiend???
- Map Sensor problem
- Help me with my del sol
- EnGiNe PrIcEs???
- fuel filter
- squeaking noise coming from clutch pedal
- Mini me swap help.. tried search but no help :(
- **Pic Request** White Civics, With White Or Black Rims!!! (Tryed Search)
- CRX dash fit...?
- Weird electrical problem - - 95 cx
- Main Battery Fuse Keeps Popping
- Momo Installation Help
- does a bigger diameter gain more hp?
- Help, I am confused
- jdm defrost switch lighting up?*searched*
- Ignitor compatibility
- question?????....searched
- What happened to my distributor?
- **power window conversion**
- short shifter help
- help with integra dash swap in eg
- is a hx and ex pipe size the same? yes or no
- Surging temperature needle
- nyn
- p1366 camshaft tdc sensor no 2
- need help/opinion, car keeps dieing. (story)
- questions about my flywheel? help
- will these pads fit?
- Engine Lag ? .
- checking a check engine?
- Liscense Plate Relocator?
- Quick question about jdm dizzy
- Worth of EG SiR cluster with a few problems?
- eg for sale
- Valve and compression question
- NEED HELP ASAP PROBLEM WITH MY MOTOR?
- Hasport A/C mount for D15B7 -> B18C4 swap
- where to find green rims???
- CEL 67 Help?
- gas milegae
- Ok sorry here it is again
- Problem with auto tranny
- Engine cranked up, sputtered, died, won't start now.
- sohc swap question
- color code
- 88-91 springs are lower right?
- VSM EK picture thread
- code 21. vtec solenoid help
- blown motor
- ecu problem
- ZC DOHC with Z6 HEAD!!!
- check engine/mileage issue
- JDM EG9 tail lights Vs. USDM EG9 tail lights
- motor mount question
- Hi im new....wtf is wrong with these forums?
- 99' Civic HX engine swap question
- del sol springs
- throwin codes...
- sway bars
- Paint, yes i've searched.....
- 93 Cx Hatch - Strange excellerations.
- USDM or JDM B18B?
- New Thermostat
- Caliper relocation question
- civic wieght reduction HELP
- Can YOU Identify these cam gears?
- brakes
- Civic Twin? Acura EL-S?
- Knuckle installation help
- need help radiator leaking!!!
- Pioneer deck into 92 DX hatch HELP!!!
