View Full Version : Honda Civic / Del Sol (1992 - 2000)
- what is the best way to paint my bumper? its go bondo on it??
- b20b in Civic Time in 1/4?
- spoon 2 piece 4-2 + 2-1 header vs spoon 4-2-1 header?
- what should i do next w/ my eg6 type-r?
- DIY R134 air conditioning recharge ???s
- Sell Car or Swap Engine?
- Power Windows install on an EK
- spec R full coilovers, anyone have any info on these!?
- More D16 questions (used the search option already)
- Which muffler should i custom pipe to.. (D16z6)
- dont flame me plz... opinionz plz (be honest)
- what shifter are you using on you hb? pics please...
- Help...... Shifting problem
- problem hookin air/fuel gauge up
- wuz up
- Koni yellow height adjustment
- Help! With A/C Mount!
- Security ?'s
- How to ID Si springs
- **Single Cam Camshafts ..D16 modding help**
- Will 99-00 si coupe stock b-piping fit 96-00 hatch?
- Good deal... Yes or NO?
- ls tech in in civic please help!!!!!!
- which rims???
- Burning oil
- Y8 turbo overheating
- Want a carbon fiber hood, but need a great price.
- what is the tranny code?? ek+
- does anyone have 2000 si rims with tires for 250
- d16y8 on 94 civic hb
- bought some eagle rods for my d16z6..do i to notch cylinder wall?
- Swap Question (reliability)
- which header for a b16a2 would be the besT?
- red sparcos...
- Question...need an answer please...
- 7th gen Si seats in 5th gen.
- need advice...1st swap
- what ecu do i need?/does it matter?
- **98 JDM itr MOTOR/ EG questions about my ECU please help!**
- GSR Tranny
- Real JDM?
- tranny problem
- valve cover gasket replacement on jdm b16
- Trying to help friend with compression test
- Parinoid or not???? (kinda long)
- NA vs. FI, which is best for 03 civic 5 speed?
- I need help: couple problems with my hatch
- I need help with Corbeau TRS's...
- Here's my boring hatch I just got a couple weeks ago :p
- why cant you fit the h22 axles on a 94 civic?
- overheating dilemna
- MAP sensor signs of failer?
- lookin for members in the middle tennessee area
- Grinding noise when I turn right???
- super 2nr club battle
- where to buy a b16a1?
- launching
- *+*EG hatch? VS, EG coupe?*+*
- Rear ITR sway bar endlink bolt/bushing part #'s
- del sol roll bar
- 00' si acting weird
- anyone with a gsr swap in a civic hatch
- Help on kill switch 99-00 civic
- clutch squeeking prior to engagement-anyone know why?
- New one piece headlights for eg hatch/coupe yes/no?
- A friend of mine has a VX and is looking to convert it to a 4 wire o2 sensor......
- T1R and Spoon N1 from 5g hatch-->5g Coupe
- B18c5 in EH2, PR3???
- want new motor gsr or v-tech any for sale
- body brace
- Oil leaking from pan
- Del Sol smacked up...need parts HELP
- 2002 civic headlights conversion on 93 hatchback
- forum ?
- 2002 conversion on 93 hatchback
- Did all 96-00 Civic EXs have 10.2 front brakes??????????????????
- anyone ever used aftermarket pillow ball mounts?
- I Need help
- FS: GReddy SP Exhaust (catback) 1998-2001 Civic Coupe
- 16" slipstreams, what size tires? for a budget
- Do 96-00 Honda Civics have speed sensitive power steering?
- header install
- yey...i got my 92 si front sway bar..any tips??
- h22 swap sugestion
- Just bought a JDM 23mm... What am I missing to put it on...
- CV Boots
- manual steering rack
- Girlfriend F!@KED up her car! ! !
- what kind of horsepower and torque (general) should i expect out of this setup?
- b18c in 92- civic ex
- ...DelSol Engine Swap?...
- How hard do you drive your car?
- 5 Zigen Imperio 05 18's
- My Tach stopped working...Help??
- What seats fit my 91 HB?
- timing belt for Y8 head on Z6 block
- Shifting without the clutch?
- Car stutters between 3,000-3,500?
- Pics of the Hybrid93Hatch - Dial up take a break!
- Replacing Distributor O-Ring
- What would you pay (00 Si shell)?
- I need HELP!
- Went to Tein USA today for some maintenance service...
- 94 GSR 4 soor for my 94 del Sol... worth it?
- i'm about to puchase a set of 2000 si rims
- Removing the front fenders
- quarter mile time on a 93 hatch
- cyl head compatilbility question
- 94 civic swap?
- vtec controler?
- P30 Blitz program
- code 45, erg
- Body swaps????
- EG SI suspension same as non-si?
- HELP!! I need more power.
- What diameter catback? Gains?
- do 94 integra struts work good on a 92 civic?
- Dipstick not showing oil, but not burning oil..
- spray on vinyl
- I am kinda Stuck on a Decision. Engine Swap or Keep it Stock and FI
- staying in turbo/nitrous longer
- Engine Oil poll
- Carfax Request
- b18c in 92- civic
- projector head lights
- taillight question...
- Did the search thing, exhaust help....
- grinding
- Vafc question
- ex cluster in dx not working? help
- Anybody with itr motor? what kind of times being run in the 1/4 NA?
- Picked up a b18b1
- Opinions of RS*R exhaust on 99 SI????
- dc sports
- What size bulbs to buy for my EG??
- EG SwayBar Q's
- Needed...help on passenger side door lock motor
- are car sound high-flow cats nice
- universal o2 sensor question...
- Fiberglass
- Post videos of your car hitting vtec ( if possible )!!! lets hear em!!
- need pics Please!
- what would happen>> b18c head on a b16a block
- Manual Conversion...I know this has been posted many times. Just take a look.......
- need someone to chip my ecu!!!
- ebrake help plz
- MY LAST POST ............... As a civillian
- Pedal Install Help
- flywheel resurface, what shop in bay area?
- LS/VTEC OR H22 power
- temp guage does not work
- Which is a better color for a EG? Blue or Teal?
- HEeeeeelLLLlllllppPPPPpppp H4 bulbs!!!!
- Where is the a/c compressor located?
- Strange Noise
- Del Sol Seats??
- HKS or A'pexi exhaust?
- can some one run me a car fax
- F*CK mini-me all a flame
- clutch swirling noise help!
- 18 inch on a 2000 civic
- Can anyone answer this question????
- map censor
- Heater doesn't work
- I Can't Win!
- question about valves
- 99-00 Si trying to install a type r intake manifold
- something is leaking
- mini-me on, and... NOT RUNNING
- overheating problems! please help!
- Really stupid question about compression tests
- could someone run a carfax report for me??? im in need...
- AEM intake question
- Just got new slipstream's check it out
- Water pump replacement?
- b16 tb on a y8 intake manifold (automatic) y7 engine
- 96-97 del sol front bumper
- jus spent 87 bucks at the acura dealer, doh!
- Pics of my new car 99 ACURA 1.6EL
- vtec has to cool down????
- Traction bar made by a racer for the racers..
- SRR ear swaybar setup
- where to get the best deals on Tein coilovers
- AutoX virgin no more... (56k should have no problems)
- shift knob removal
- D16z6 head pics????
- Hows this setup for minime?
- J's racing intake, and a question. :)
- Gauge Overlay...Anyone done it?
- CAI and FMIC air temps
- OEM swaybar upgrades for EG?
- Anyone got a top end blueprint??
- Pics of my Turbo Coupe...
- ECU ??????
- Swapping disks to 96 ex coupe??
- best exhaust for 93 hatchback
- Magnaflow
- What could I get for my car? Thinking about getting something new
- O2 sensor wire harness for 98 HX
- alignment question on a 00 si
- my s2000 seats are here!! YAY!!! WEEEEEEEEEEE!!!!!!!!
- Exhaust rattling really bad...
- valve train components
- 1st gen. hdm b16 head gasket? doing maintenance
- Problem with clock on my EG
- 99 civic steering wheel mounting?????
- is this right? (AEM intake install)
- Apex'i Rev/Speed Meter
- ac gas question
- anyone have an ek hatch with a Si sohc motor in it?
- 2 1/2 inch exhaust cat back
- 92 Civic sedan front suspension arms the same as GSR's?
- who makes factory honda clutch's?
- EMERGENCY!! On the quest for VTEC!
- I just ordered my engine from hmotorsonline.
- homemade turbo kit on 93 civic dx INSTALL HELP
- HIDs in OEM fogs? anyone done it yet?
- n e body know size of sway bars for 93 honda civic ex??
- might anyone know of any GOOD shops in CT?
- msd pills?
- Breaking in my friends new motor
- quick AC removal question
- ITR dash in eg hatch
- real quick question (headlights)
- 96 Civic EX in So Cal With Questions
- EG Hatch Exhaust on EG Coupe?
- 92-95 civic 2dr coupe rear bumper????
- Fuel line replacement fun
- EG+ITR rear bar+ 3" exhaust = ??
- Fill Tranny fluid from the Top?
- Looking for mods for my Hybrid
- My radiator fan doesn't work, but the car's temp.....
- Why do I not want a Front Sway Bar?
- 92-95 civic 4dr body kit or lip?
- b16b ?
- GSR Sway on 96 EK
- Ever mounted your own tires?
- Just to get him back........
- EK9 00 hatchback, power folding mirriors.
- B20Z Info
- What Engine should I swap in ? I have an automatic 92 CX
- cluster problem???
- Teal/Drk Teal on EG Civic???
- Another msd Q?
- MSD ignition
- Fastbrakes 2-Piston Rear Brake Upgrade
- side skirts?
- **knock off j's racing intake**
- usdm or JDM B18C1 swap? Obd1 or obd2? Advantages/disadvantages or both
- Couple of questions on Honda's
