- s2000 antenna
- axle questions......help me
- 99-00 Civic Si exhaust?
- To bore Or not to bore that is the question???
- podering a lil sumptin sumptin.......
- Engine Swap Questions
- anyone ever traded cars before?
- fmu problems???
- flywheel or cam gears?
- Max Speed Coilovers Any Good??
- need side moldings and stock rear bumper!!!!!
- Which sway bar setup is better for 96-00 Civic? 22f/13r or 26f/13r?
- specs on d16z6 dyno2000
- 96 dx b series swap. ex wiring harness yes or no?
- Installing Skunk2 Short Shifter
- B18b Power Steering
- b18b1 vs. b18c1
- auto axles same as std axles?
- 5 lug conversion on 93 hb
- Where can I get a spoiler like this?
- I swapped an SI cluster into my DX and it shows my idle at 1500. How do I adjust?
- seat help needed
- jdmhondaparts gold pillar bar
- tanabe g-power on a EG?
- VIS hood with GSR swap
- for those of u running integ fuel pumps....
- My new Add-On. :0)
- URGENT please advise on skunk2 exhaust!!!!!
- Best coilover system?
- my cat is mad at me
- dumb question!
- automatic is fucking trippin.
- What Coupe?
- ATTN: Tom & all you trim painters out there...
- Is All-Motor Worth It?
- 92 hatch question
- FI - start off motor, b16a2.....
- Dohc93hatch best avitar ever
- Ls turbo top speed ?
- how should I fix and paint my bumper? ( did search)
- Got a code 74 (cylinder # 4 misfire)
- Good drop distance?
- Wheels, Offset, Bigger Brakes, and You
- n00b PoSt <<< : ( <<<< EK DOOR PANELS !
- Cracked Sidewall on my tire. Help!!
- Project H22-> 93 Civic EX to 92 VX 99% Done! 56k people = no no.
- How do you take that sticker goo off your window.
- why 40+ offset when -40 would give you wider track?
- Is $208 a good price to change a thermostat and a fan switch?
- hooking up zex kit need help
- Itr cams in B16a
- Jonathon SOLD me D15 motor... Marietta/Senoia
- help with tranny!!!!
- SPC Performance camber kit?
- Can someone vouch for SWEET?!
- Anyone know this guy
- displacement over-bore on a d series
- specialty products
- Will 96-98 or 99-00 AC compressor be compatible for an EG?
- Tail Lamp is Now a Fish Tank
- request pic of eg hatch with LS wheels
- Reupholstery?????
- need a shop in new jerseay to do swap!
- bad news on the track guys....
- first time poster... long time reader 13.3@108
- Questions on motor internals
- i got a problem....
- auto trans fluid?
- new civic member on honda-tech :)
- roll or cut fenders
- 96-98: OEM rear lip???
- what r u guys paying for tein s-tech springs for 97 ek
- 4 sale RacingHart c5 3pcs rims
- 02 civic turbo?
- Complete: the eg o` doom
- blue print of a turbo?
- Who has rota's? Do you feel different?
- Suspension question
- iacv idea air control valve problem on my d16z6 how do i clean it help!!!!
- torque for upper arm
- are the bushings on the rear lower control arm the same for eg and eks?
- Got this off Ebay for 5 bucks!!!!
- One Honda Specialist????
- What is the ECU in 93 Civic EX stick?
- Does JDM integra center console fit an EG hatch?
- single overhead cam
- Clutch petal getting softer and softer?
- zex system
- Should i get Vision corners??
- stroker kit for....
- Did a search...Please Help!?
- swaping in a siR b16a
- what should be replaced pre swap?
- EK side markers
- Help Me
- How good is the quality of CF Hood from JDMHondaparts.
- Where do I find eyelids for my del sol?
- 4grand
- Best things to buy. Need help.
- car died on me this morning. what could be wrong?
- Can anyone run a Carfax for me?
- Teg cluster in 92-95 abs light on?
- Spark Plug wires: Do they make a difference in performance
- Head skimming
- link for ebay intake?
- Need Advice On What To Do With 92 CX
- Anyone Heard of a HONDA Civic GX????
- what's the exact weight of a 1999 civic Si? did search
- EK:center passenger air blower...is this common?
- vtec controller
- argh- car broke down
- Any Bay Area Folks with Boosted Civic's
- Baked Oil
- Hatchback window
- headlight conversions
- Newbie question ! about air intakes
- could i have blown my headgasket w/ turbo? help!
- new paint
- intake filter
- How do my times seem??
- stock cat ok for swap
- Tech Question + new pics
- butterflies on a b18c1
- ATT: EK yellow hatch with stolen CF lip in Vegas 5/7/03
- what can go bad that would rob me of power?
- 96-00 EK spring install
- d16z6 pcv need help
- New Swap: Running rich
- Cat back exhaust question
- testing pixs
- CRX exhaust piping?
- Any Body From Jersey
- Need help with ignition wires!!!
- Fabricating A/C line in 92-95eg to fit INTEGRA compressors *pic*
- What year Civic comes with D16Z6 ?
- two more d series questions
- Toronto Civic Owners
- Turbo ...what do u guys think.
- of those of you who have skunk2
- 99 civic dx cluster
- do tein coilovers rust
- DX coupe road noise..
- Spoon Stroker kit ?
- del sol: stopping targa leaks
- Owned by a civic DOOR
- Suspension upgrade...... advice and assistance please
- my stupid hatch lock wont work...
- Intake on a civic hybrid?
- Auto to Manual conversion, 00 EX
- AEM ITR CAI - 99-00 Si
- mugen coilovers or tein Basic dampers.Street use
- B16 swap into a eg
- MD area engine shops
- good coilovers?
- still having problems on noise under my car
- still no luck tracking down vacuum leak. Anyone have any suggestions?
- nuff about stolen cars...what about ways to keep it from happening.....
- Anyone with pictures of an Ek w/c8's?
- Any one know which tb to get for a Y8 I/M swap....
- help on installing type R lip
- Do i have to use the jam nuts when installing Konis?
- Help! New D Series Final Drive!!!
- civic rear hatch lenses
- wtb vision corners
- d16z6 tranny vs. y8
- Hatch Wing Light
- Pics of Painted Spoon Spoiler On a EK
- Mid-pipe question
- what stock seats fit into an ek?
- fuse diagram???
- So you wake up and realize you are modifying...a Civic...
- N/A vs. Turbo Question
- Where to run a certain wire off my tach?
- Ek steering on Eg
- Rust On Disc
- Rear disc conversion on my EG?????
- feed back on my little project
- Rear disc brakes onto EG
- One year since theft!!
- Doors Sagging?
- willing to pay!
- Help me out please! Need info on D16Y8 in a 1992 VX
- Can '93 integra seats be installed in a 97 hatch?
- differences in autometers grey pillar pods
- Adjustable Cam gears for '97 del sol si
- Carlisle canceled already...?
- new to h-t :)
- h22a in a 97 civic
- GSR in a hatch, need my options....
- Stock rims with Falken Azenis
- Civic front bumper support...
- EG rear arms
- Wiring on a 96 Civic LX sedan (corners)
- anyone know about this car?
- My J's Racing Tower BAR !!
- in4 door sir 2
- Need help/ideas.......topic: Screws on Rotor removal w/pics!
- 98 Civic EX steering column and air bag removal.. how?
- ITR rear sway bar on 92 HB ??
- Honda EX 2003
- Rim Design
- GSR b-pipe on an ej?
- eg door slams :(
- Is fiberimage any good?
- problem with mugen chip.
- Head gasket
- JDMFaze.com - Another one bites the dust.
- Will EK sedan front end fit on EK coupe?
- Adding V-Tec to d16y7
- I got some new rims for the EM1!
- is anyone using a high/low H.I.D set-up?
- Offset question
- Sanding rims
- Toda cams with integra type r springs??
- help converting from a 95 civic Auto to Manual
- GSR tach in a hatch
- h22 in 98 civic 4 dr
- JDM Type R Transmission Main Shaft in an EX trany?
- anyone have this setup?
- Hey everyone check out the pics of my car!!!
- Decah.net Door Conversion... Any Info??
- FS: JG Edelbrock intake manifold for b16 or type R
- Tanabe Sustec Pro SS and Koni Yellows mix & match
- anyone every order from jdmshit.com?
- what plug wires for b16?
- C-West lugnuts??
- AirBag Light Came On
- looking for a pic of a ek that was FS
- lugnut question
- clutch interlock switch
- Aftermarket camshaft, what's the idle like? Using stock valvetrain?
- Comptech Icebox fit on H22A EG?
- din audio console for 2002
- fpr compatibility question
- Best tranny setup for a b16a2
- Can you pait this ?????
- D15b7 what mod next??
- Post Videos Here
- Help Me
- reliable sites that sell dseries engines
- Turbo SOHC EK vs. B16a hatch video
- OBD 2 harness: plug n play?
- cheap, LIGHT audio solutions??
- Tanabe RM catback rusting??
- Honda Civic HB FOR SALE
- Looking for EG hatch pics... (post or forward me to a site of pics please)
- 97 turbo hatch pics what do you think
- is HKS filter good 4 NA B16a2?
- B18 Series swap or H22 into Cx??
- Wiring...what tha hoogit?
