- Quick Question...
- Vafc 2 switch over too hondata
- secondary o2 affect vtec engagement???
- How much is a rolling chassis worth?
- Acura Legend Throttle body work on B-series?
- good sway bar for an eg????
- ANYONE IN FLORIDA CAN DO MY HID FOR AN EM1? $$$$$
- LSD transmission question
- WTF 92 CX, proportion valve help, rear disc conversion searched.
- exhaust help
- Whats wrong with my car. 98 Civic EX Coupe
- Quick release bolt for shift linkage?
- Please help a honda newbie: Looking for a fun hatch for around 5k.
- 3" exhaust
- No CEL when I unplug knock sensor.
- distributor question
- best seats for a 2 door
- dc sports header
- 90-93 axle vs 94+ integra axles
- Not your Typical OBD 2 to OBD 1 conversion...
- tranny question about lsd
- EG: What suspension parts should I take from a '92 Si?
- B18b1 FS
- fuse box
- help plugs fouling
- FELPRO HeadGasket
- OHIO engine swappers?
- trans question
- Shocks and Springs
- what do you pay for insurance?
- help me decide wheels!!!
- HELP...Why do I have to hit my climate control to make it light up?
- Spindle+Upper+Lower Control Arms guess what happened?
- vafc on a non V-tec moter
- head gasket
- check engine light code verry werid 9 CYP - cylinder sensor
- Springs or Coilovers?
- EXHAUST HELP! (93 Si)
- need help!!! speedometer fuel and temp gauge wont work
- First Mods
- HELP! my baby is hurt and is bleeding from the head!
- DX to SI Harness and now problems
- Short Ram Intakes
- carbon fiber hood
- O2 sensor - colour code
- NEW TO CIVIC
- APEX'i N1 Universal Muffler Sound Clip??
- busted antenna on an ek
- Price I could get for this...97 Project
- adding cruise control??
- 2000 Civic Si making a whisling sound?
- B16A Gear Box question?
- JDM look here
- Crank pulley
- i need some parts
- Step by step Cruise control instructions? (found some not same car)
- Orange Corners adn JDM Question
- Oil pan/timing belt install
- My windsheild wiper is getting me mad
- Trouble with my car
- Civic 1994 motor running problems ?
- jdm parts for my del sol
- 4wheel-drive ek civic.IMPOSSIBLE OR POSSIBLE
- So i crashed today.. need an HT estimate.
- car for sale - wont let me post in the classifieds
- Help with wheel paint and balancing!
- What is the diameter of the front wheel hub on a Del Sol?
- HELP: Issues wiht NON-CHIPPED P28 w/ harness installed into 00 Civic Si
- Fs 92 civic hatchback dx
- Type of hood...body kit or lip
- Which Type R LSD for my UKDM '98 EK4 3 dr B16A2 DOHC 1.6?
- 99-00 EX dash conversion in 96-98 civic....??? Is it HARD?
- Iam new! and i have a Speedo problem
- momo steering wheel horn install help for 99 civic lx
- black widow 2
- JDM SIR2 B16A
- 94 hatch rear panel
- Del Sol ights
- How much is to get BAR?
- cams raising compression???
- which master cylinder?
- ITR springs on an EK hatch
- d16y8
- d series block
- Oil pan question
- eg headlight help
- Nissan Skyline: Illegal or not????!
- hatch 94 dx
- calling dohc and his buddy luserkid
- More D15B Swap problems
- Maintinance Required
- Chipped ECU
- how to change master/slave cylinder.
- motor mounts
- where to buy splash guards for 94 coupe?
- DOHC ZC swap into my 93 hatch
- Fcuking Thieves!!!!!!!!!
- how do you make your pictures on here bigger!!
- Favorite exhaust?
- Steering Wheel
- cable clutch conversion kit for hydro clutch HELP!!!
- B16-A CHECK ENGINE LIGHT?
- apexi mufflers on ebay
- Complete Color Change Over..
- eg hatch one piece front end?
- Del Sol Amber Cluster
- Throttle body gasket
- 93 hatch si turbo what would you do?
- NEX & Tein
- DIY short ram intake or CAI
- My Seafoam Experience
- Quick high flow cat question...
- WTF: I Give The Car Gas and it drops in rpms like a big gulp then recovers but sputters.HELP
- EK Power Loss And A/C Problem...
- What do i need to make my EK 00 DX accept front strut bars.
- pleasehelpdoorhandles
- Help - motor boggles when in gear up to 4000rpm
- quick cam gear question
- Engine Light goes on when i hit 50mph????
- Help! 94 Civic Start UP Clicking and dead battery and fuel pump surging
- D15b7 gas mileage
- TOYO or FALKEN??
- del sol
- Went to the Ref Station today Good & Bad (Need some help)
- CEL qestion
- Clutch Problem! Help!
- 92 eg problem
- Injectors broken or ok???
- anyone running act prolite and where did you get it?
- Windsheild Desfrosters not working.....?....amber light? look...
- D15b2 oil pan on SOHC ZC???
- powersteering pump.
- b16 sirII swap in 93 civic ex idle question?
- what shift linkage is this?
- What the best HID kit for my 94 Civic?
- LS VTEC swap.....
- traction bars on a daily driver?
- Del Sol lips
- si cluster
- who has converted to obd1 from obd2?
- has anybody heard of this company?
- WHAT'S WRONG?????
- Gear Box Y21-2006648
- series of 96-00 conversion questions
- what sensors will disengage vtec when not working.
- MY B18 Tranny
- CHALLENGE: Post pics of your ABS-equipped EH3 Hatchback! Your own pics only!
- my 95 coupe EJ1 highway drift experience - xanga entry link
- Can someone tell me how to connect a Autometer Fuel level guage in a 95 GSR??? THANKS
- oil on my plugs
- sea foam safe to use on my engine?
- Need pics: insides of Denji headlights and/or HID projector retrofit in Denji's
- B16A HELP
- Skunk2 cams/valves/springs/retainers
- Which EK side skirts on 92 civic 4dr
- hmmm stupid CEL
- Need a pic of EGR Valve and Location on a 1997 Civic 1.5L
- Need to hot wire the radiator
- hid kit w/projector angel eyes?
- Replaced clutch master now clutch slips huge!! Pedal adjustment possibility?
- help
- oem wheels fs
- EG ECU PROBLEM!!!
- Sol rear disc swap cables too short Q's!
- B16 Engine buildup
- :best place to get Earls SS brake lines??:
- ~EG tire is offsided
- installed engine found extra map sensor dont know were it does please help
- I need fenders for my civic ASAP
- EG hatch Front lower brace
- Suspension noises, help!
- Gauges for honda civic 93 DX
- Brake Pads and Shoes?
- clutch master cylinder from ebay?
- anyone from massachusetts?
- wanted: D16Y8 exhaust manifold and catylitic converter
- Anybody had dealings with Wheelcomponents.com ??
- Your EG suspension setup and y u like it
- New to the EG world, intake question
- Any advice on my setup?
- Grant Steering Wheel on 92 Civic VX??? help
- JDM Hatchback Trunk Box ---> sedan or coupe ???
- aem fitment help for u.k car
- BRAKE QUESTION FOR MY CIVIC
- EG: Anyone fit a rear lower tie bar to their Suspension Techniques Sway bar kit?
- how much does timing belt alignment cost?
- 96-98 to 99-00 dash conversion inspired by chameleon. Defroster fix!
- TECH QUESTION: Rear Driver side Trailing arm install question
- any idea on how to clean engine?
- hi new here
- thermostat problem, HELP!
- 92 civic cx for trade
- New Struts..
- Looking for a good tune shop
- which hose water temp gauge install (checked archives)
- "POOR MANS TYPE R"? (gsr bottom end w/ b16a head)
- need help ASAP:parts hunting
- ek radiator swap
- stolen tools and my house got vandalized sacramento sucks
- Tail lights question
- k20a2 help
- help ! stupid question
- HELP: CEL code 20
- need help..and advice
- will integra rear seat fit in 4dr civic(92-95
- CX Steering rack - is there a better alternative?
- ECU Chipping Question. 20 Pin Socket.....
- hydrolocked ; can i look through the cylinder...
- PLEASE HELP! Where can I get 96-98 OEM fog lamps?
- What can i use from an NSX on my EG????
- how do u wire a civic moon roof and power mirrors into a integra dash?
- Can I run this without a turbo? Can I hydrolock?
- help me !!!!!! Motor mounts
- Fiberglass hoods? What does it mean when the hood is just a "skin" and cost 1/2 the price?
- Water Temp Gauge Install Que
- Righting the worst automotive wrong I've ever seen (56K Grab a Snickers)
- 2compression test
- What do you think? should i worry?
- torque wrench in tight spaces?!?
- turbo kit
- EXHAUSTS: custom vs branded
- ecu p28 on a itr programming
- Did the EG come with some kind of side skirt stock?
- Clutch question
- slick size and wheel questions
- Sputtering Question.......need some advice asap ......
- can i buy a clue??
- low beam and high beam at same time? (searched)
- Blown Shift Bulb, Chocolate Spark Plugs..
- ~STOLEN TONIGHT! Need help in KC MO ASAP!!
- how to remove pin stripe on door?
- if i upgrade to a 255 walbro fuel pump would that waste my gas on my stock motor?
- Resistor Box (problem with it..i have searched!!!)
- What is the STOCK weight of the Civic DX?
- CF hood Webbing... Any Sealants available?
- clutch problems
- Guage Clusters that can be used in EG's what have you seen and difficulty
- Car running lean
- Question about Goodridge Brake Lines
- Trial user issue
- I got a 98 dx civic hatch (and now I've got a few questions)
- swap problem need help asap
- what psi??
- Backfiring..
- HOW DO I NOT BE A TRIAL USER AND HAVE AN AVATER??
- Clutch Resivoir Leak ***HELP***
- Headlight Bulb Size H4 or 9003
- Who's rebuilt their Z6?
- 99-00 rear defroster wiring diagram please.
- 17''
