View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Generic coilovers...any good ones out there?
- difference between auto and manual y8 TB?
- swappin speedos
- HELP! MY CLUTCH IS WACK!
- just saying what up
- Aircraft remover harm??
- F20C swap?
- Where's the fuel pump switch?
- magnaflow
- steering wheel goes left
- civic ex auto to manual
- Axle Question...
- Intake Manifold/TB question
- getting paint off tires?
- LS engine rebuild help
- k series mount kit for EG
- NEED HELP installing EK cigarette lighter/ashtray console.
- Next Step in tunning my car???
- Installing Autometer Tach Into eg
- Good Buy??
- What would you do????
- Fly wheels?
- tansmission
- manifold opinion
- Need a 96-00 sohc drivers side mount, help guys!
- Are 96-98 harness Same as 99-00????
- ?'s about so called PnP cluster swap
- Alternator Pulley Install **
- Is this a good price for a Civic SI Type R
- what should i check for when buying a used Civic....
- I need an A/C Sytem for my del sol
- What's Your Opinion on A White 94 Ex coupe W/.......I need opinions
- Bled brakes after rear disc swap.. WAY TOO SPONGY
- any one have the DIY to put a DC2 cluster in a EG?!?!??!
- OBD0 ----> OBD1
- OBD0 ----> OBD1
- Is this a 99+ Civic Si Cam?
- Which TB to use on the Y8?
- DIY: How to turn your civc into a lawnmower
- IGNITION PROBLEMS! HELP!!
- clicking noise after swap causes shutdown? b16a2 in 99 4dr lx
- 3BAR and Hack
- sleeved JDM or Dart block
- Civic Hood Lock
- Having problem with my AC!!!! can you help?
- T1R catback on an eg....anyone?
- 00 Si Best Exhaust set up?!
- 94-01 2dr Integra front seats into a 92 4dr EG?
- no compression on cylinders 3 and 4?
- SI exhaust system VS GSR exhaust system
- How stiff is the clutch pedal with a *sprung* 6 puck clutch?
- V-Tech chip for my civic Worth it?
- need help
- Biggest bang for my honda civic...
- What size tire for a HX rim?
- rattling noise when at 1500 rpms
- Intake cam timing
- axle ?'s
- B16A but what year?
- 1100 idle surging to 2500....on good days
- eg and ek cat the same size?
- how to tell the difference between distributors?
- how do i know which ac compressor I have?
- OEM catalytic converter compatability
- What Next?
- fan wont turn on...
- suspension for intergra
- 99 hx catback system
- 2004 civic with bad brakes ????
- will a comptech type r header fit 00 si?
- Strut bars
- Help!About ideal speed when the car in traffic or practice back-in!
- Strut Bar Opinions
- B18C swap into Y7 question...
- Catalyst system Efficiency below Threshold Malfunctioning or defective catalyst
- OT-Thanks to everyone!!!!!
- vti cluster (yes I searched)
- Guys, Help Please.
- angled mufflers rice or nice?
- oil leaking.
- accelerating stuttering
- Japanese Civic HB
- Help! Raddling sound when starting in 1st gear from stop...
- Wheel Bearing ??
- B20 swap help
- connect the dots la la lala
- New CF trunk for my Sol
- for u guys running msd 6al box
- Dressing up a 2004 Civic SI coupe
- Is it safe
- Brake Fluid Leak - Please help!
- help: drop forks on my civic
- help: drop forks on 2000 civic
- b16 w/99 gsr tranny?
- is a b16 worth getting?
- ripple dents?
- b18C1 or a b18C5 ?
- Spark plugs covered in oil....
- Help with my "mini-me" swap, pics of cyclinder head....
- shift linkage problem?
- New Lip on my Sol
- Hydro vs. regular tranny?
- chassis to lca bolt will not go back in
- Suspension question...
- *****STOLEN CAR IN CRANFORD, NJ**********
- Freind needs your advice NOW
- d16y8 camshaft choice
- 92 hatch, just installed pioneer head unit. Certain wiring??
- (help) what things to mount n wire ctr mirrors
- New to Honda's, cars in general, My project
- GSR hubs on civic?
- Canadian Clear Guage Cluster Cover for 96-00 Civic?
- My First Swap, Feel Free to Comment
- anyone with a JDM B16 i need help
- Cable and Hydro trans.
- 92-95 civic questions about interior and turbo stuff
- Fast idle valve problem on a b18c eg???
- need help choosing motor mounts....HELP!
- N/A or Boost
- help me help my friend (brake noise)
- bad oil leak..blown headgasket?
- ZC Axles or DX Axles?
- dashboard lights.
- Del Sol is a car with high expenses
- Timing question??
- Ek with jdm ITR engine
- Will my car pass smog?
- engine revs up when shifting (at)
- ECU question
- swap BAR question
- Grounding Problem (wacky gauges and no batt charge)
- smog ek asap not passing
- cleaning fast idle valve
- What is leaking???
- Can 13's fit on 1994 Civic EX???
- is anyone going to PACIFIC RACEWAY TMR?
- i need help
- where to get a (urethane) blitz style front bumper
- Radio Fuse keeps on blowing.
- Which to modify??
- 92 hatch shaking and stalling with a/c on
- anyone know how to wire a safc I into a 99-00 civic dx?
- ANGEL EYES.....CANT SEE!!!!!
- Removing Headers from a B16 on a EG
- ctr lsd tranny...
- 5g header fit on 6g?
- Stripped holes on AC compressor where high & Low pressure fittings go.
- 96-98 civic radio block off plate...
- first time at the track
- swap question
- obd2 alternator to obd1 wiring harness"help"
- PLEASE HELP!!! Need Fuse panel layout 00 Civic Si
- bad ecu?
- need to get a PR3 ecu...
- The people that have done DIY Shortened Shocks!
- new racing LENSO 17 inch Rims.
- R. I. P. 95 CIVIC COUPE
- Newbie. Just saying hello and asking opinoin on work that ive done.
- Whitch valve cover is this?
- Spoon Cluster for EK
- tranny went out yesterday.. what tranny should i get
- where can you find pistons for a b16a.
- DIY: Strut bar installation on a 96-00 Civic DX, LX, CX, HX. ANY type.
- Need help with tranny
- Comptech sway bar squeak noise information
- NEED AC HELP GUYS !!!
- can a dohc vtec valve cover fit a 95' b18b1?
- info on a swap..
- Rear disc conversion...will 1990 integra work?
- d15z1 to d15b JDM VTEC, which exhaust needed???
- question about map sensor
- Where can I buy a rear oem or oem style lower lip for my 00 Civic SI?
- New del sol trunk lid w OEM spoiler
- check engine light need some good help
- how to :bleed Clutch..?
- z6 exaust manifold on y8?
- ne honda tuners around toms river?
- shat! i think my AC Condenser just died! grind grind clunk clunk squeak squeak
- GSR seats into a 200 civic dx
- New 93 Civic sedan
- Floor harness for a 99-00 si
- Suspension ?
- Steering Wheel Swap
- help!! engine swap??
- Which axle to use.....
- replacing wheel stud on a 1998 Honda Civic EX
- Civic grill question
- do i have a vtech?
- Quick question on springs install on ek hatch
- dc2 -eg exhaust setup
- i have a d16y8 and i was wonderin....
- spun rod bearing help?
- eg H22 skunk2 inatke mani?
- Nut off the Exhaust Manifold
- Need help......B18B going into 98 hatch
- I need to find a type r pistions
- Spark plug gap?
- Finally Receive my Rigid 3pt. Sturt
- What size of Slicks for my 13" Steelies (tires are on them right now 170/70/R13)
- any ideas?
- How long to take to install Input shaft bearing?
- Question for those who got STATE REF tickets
- where is the best place to buy a B16 engine???
- SCAMMER RETRACTION MODERATOR PLEASE READ
- is it worth it?
- skunk2 intake manifold hoses question (searched)
- HELP!! Never Ending Idle Problem!!
- swap question for 92-95 civic coupe
- seeing if any one wants lips? for there ride
- Anything i can do to automatic??
- Radiator leaked coolant but from where?! Baffled.
- AEM alternator pulley equipped 99 Si -- just got back from Autozone
- CraneCams hi-6 dsr & ps 92 race coil,.... good for 93 civic w/ B16???
- 2000 civic ex radiator fan won't turn on
- The current model Civic 2 door coupe... Does it exist in Japan?
- 99-00 front clip
- rattling from the bottom end
- About my Fankenstein AGAIN...
- 92-95 civic dash conversion to 94 and up integra
- Car won't start when hot!!
- About wiring confused
- My goddam car wouldn't start this morning. Fuel Filter?
- exhaust question. cali
- interior for my ek!?!
- Need some help on Buying an Eg
- lights in air vents? led?
- for those that have spoiler holes in the trunk, what did you use to cover it?
- ls/vtec into 98 ek
- Is a front strut bar connector really that helpful on an EG?
- What do you guys think? oil Prob perhaps?
- Coilovers for DC2R into EG question
- How much horse does this frankenstein make???
- Skun2 manifold = more vibration?
- Anyone a Certified Honda Mechanic?
- Help!!!!!!!!!!!!!!
- will a 92-95 civic lower strut bar fit on a 93 del sol?
- Does anyone kno the link for ...
- problem with clearing codes on 95 dx
- AC INSTALL: HOW TO ??
- How safe is to ride around on blown rear struts?
- dif. in swapping a USDM y6 compared too JDM SOHC vtec?
- How cheap can I go on shocks with GCs???
- ac in gsr engine?
- 20not getting updated
- IACV, IAT, idle problems, MAP experts! - need help
- working on it 3 weeks now??
- need inspection
- jdm d15b dual vtec engine on ebay.
- 215/40/16's on an Eg
- D17 tranny swap (are the axels the same)????
