View Full Version : Honda Civic / Del Sol (1992 - 2000)
- new fly/clutch options?
- k20/k24 swap ?ns 90 crx or 00 ex coupe
- 95 CX HB cluster Question, any answers?
- D16y8 spark plugs
- Difference between pre 99-00 bumpers??
- Vehicle Speed sensor
- **Honda-Tech Guru's only** B16a serious internal problem** Video**
- am I missing a plug or something here
- 96 civic HX with a ZC sohc vtec: what do i need to make it work?
- help: honda ek 96 code p0453 and p0505
- hmotorsonline?
- parking pole
- seat rail travel?
- Project Burning EGG
- quick noob question!!!
- VIN tag location(s)??
- hks BOV flange?
- Aem cai fitment question
- Help in identification of Map Sensor (solved.)
- Infamous vtec not engaging, code 21
- What's better for a d16z6, with 500 to 800?
- What would make my spedometer jhump?
- radio problem...need help
- Oil Filter Shredded!!! Help Please!
- D16Z6 timing lines??
- Cylinder compression 96 civic lx 236k miles
- Engine swap questions
- Shift Linkage problem, or grinds second! little help.
- ITB's??
- cant get my car started after swapping blocks.
- adding vtec sensor and solenoid wiring to 96 civic harness. help!
- Help my eg hatch
- Working with OBD2
- k20 swap
- single cam trouble
- Looks like I need an o2 sensor..
- proper o2 sensor?
- Stolin si
- any ideas
- Help me with my idle surge! (vid inside
- green and purple h22
- B18A1 build
- Aftermarket Seats - Whats the deal with these?
- D15Z1 internals and head into/onto D15B7 block?
- ITB's?
- how do I regulate the fuel pressure?
- Tuning question for experienced tuners only
- 4door gsr front brakes on eg stock knuckle????
- sohc zc cams in d15b7
- operation: S2Killer (redux)
- how to ignore a code?
- Need measurements for Sparco bracket
- New here!!!
- IAT Sensor
- how do you keep your foglights from cracking?
- 92-95 CIVIC OEM Parts Looking to trade or sale
- Wiring nightmare
- COULD it be air gasket ?? @LOOK@ PLEASE HELP
- Bolt-on Swap for 95 civic DX - manual
- 99-00 EK9 Green ECU PLUG QUESTION
- 94 civic
- ebay coil over sleeves won't lower HELP
- Wiring nightmare!
- anyone know of other pages to test rims visual for my car?
- Cel codes
- 94 civic ecu
- Passenger Side Airbag Removal
- wat exhaust is this?
- 96 Civic passenger window only goes down with drivers door shut
- 95eg with built z6 swap
- 92 Civic Sedan (Should I go H22 or B18c?)
- d15 turbo
- cam upgrade ?
- WHAT???? Aftermarket Vtec cylinder heads
- aftermarket steering wheel alignment issues pls help!!!!
- write up for wheel stud replacment???
- will this short shifter fit?
- I want to install red badge on my OEM grill, if u have photos please post them
- I want to install rims on mi civic99 please post photos...
- Blowing blue smoke.
- What are these coilovers?
- b18 vitara piston combo?
- Knock sensor install on a D16z6?
- What do you guys think of these ebay Foglights
- ej2 speedo problem
- 95 civic supercharger question
- whats the serial of civics like ek,ej, etc...
- D-series modifications benefits?
- my brakes locked up
- suspension question
- 98 civic CHECK ENGINE LIGHT FLASHING
- Where to buy 96-98 Ctr lip?
- b18b intake in ek chassis
- Please identify if this is 96-98 or 99-00 civic hood.
- Car fluid?
- what boost controller do you recommend?
- eg hatchback cluster
- what cluster will fit??
- EF or EG shift linkage?
- Hood latch adjustment
- Sway bar tearing frame?
- Need help with swap
- NRG quick release screws
- Need Pics of Hanging Muffler
- cyp code issues
- Car temp still on cold. few other probs
- 00 civic gas tank size
- ► Humbly requesting your support...
- Fast Tricks on how to get the Back L Motor mount in?!?!
- b series fuel rail ?
- Eg rear disk conversion ?
- Tach. Help
- Rubbing issues?
- Cant get door panel back on, noob question
- need 92-95 civic radio wiring diagram(cut harness)
- front tires bowing out.
- Sway bar end links
- B18A1 into 92 CX hatch
- Eibach Pro Kit or Pro-Sytem kit
- rad hose problem
- Swapping b16 for ls motor. Plug n play?
- Cracked Exhaust Manifold! *Help*
- What do change with timing belt?
- Rhd ctr
- sway bar questions....
- Del Sol vibrates with the roof off...
- EG power door locks anyone snap a pic of the door lock moduel connectors.
- ebay short shifters
- Eg Civic D15 Vacume leak
- timing a zc with a z6 head
- New here
- 2000 Civic Si Keyless Entry Remote #??
- Finding an EK thats right for me..
- 99 jdm b18c into 2000 Si
- Need ecu pins for 99-00 civic ex d16y8
- help on how to switch obd2 to obd1 b16a
- Help! Thrown rod in b16a2
- seat swap.
- Still having code 41 issues.....
- Car does not have 1,3,5 gears
- 2000 civic LX auto won't up shift to 2nd @ WOT
- Distributor and TB question On B18C1
- Nasty white smoke on acceleration
- New Ignition for a 4Dr Ferio
- help, this happens with every hondas climate control ive ever had
- **Air Refiner**
- Alot of white smoke during warm up...
- safe?
- Fuel pump and fuel filter question
- Where can I buy an O2 sensor?
- anyone have pics of skunk2 sport shocks and skunk2 springs?
- Overheating
- head gasket problem?
- seat bracket question!
- identifying si tranny or z6 tranny
- I need a part number
- turn/hazard relay location
- Swap Not fitting in b16a2 into ek hatch
- Please help-head? And crankshaft?
- 2000 Civic Si; Lift point help
- 92 hatch stolen 2.15.09 south east Pa.
- K swap Problem - Disable the immoblizer
- idle bounce @1500rpms only
- d16z6 head on d16y8 block....
- phearable.net Ecu chip problem
- piston help!!!
- can a eg front end fit a del sol
- need some advice on my trans
- which brand and where to buy (tierods?)
- OBD2 Motor into OBD1 Car?? HELP!
- boost limit
- Converting Climate Control 96-98 to 99-00
- Maintencance Required
- Need help on Suspension Plz Plz ty!!!!!
- Need your thoughts
- weird eletrical problem
- Is honda bond needed when replacing valve cover?
- power surging
- What to do about my trans????
- Traded my broken down 92 si for a stock 95 cx
- car doesnt start
- b20 swap
- need help
- Need help - car wont go
- Should i buy a HX?
- new axle seals but still leakin
- Sub frame question.
- OBD0? OBD1? or OBD2?
- Engine swap on 1995 Honda Civic hatch DX
- Has anyone ordered ITR calipers
- blox 72mm tb and blox tps. how do i set it? ohms?
- Fading Sideskirts? Opinions.
- bolt inside a combustion chamber
- dizzy timing
- Master cylinder swap
- when braking, rattling sound
- ep3 seats...sit low? how
- should i build the d16z6
- Eg fog light question
- sensor identification?
- need help skunk 2 springs or skunk 2 coilover?
- 99 Si brake pedal dead zone
- power steering question
- 96 civic wont budge?help me
- Honda vs acura parts pricing
- Car wont start alarm help / relay
- Power steering belt size for swapped eg
- del Sol antenna delete
- need help installing megan headers 2000 civic
- Sppon lsd tranny, what should it feel like when turning
- abs wiring removal?
- BOUNCY IDLE ? LL NEW REBUILT, when cold weird idle HELP !
- mini me swap problem!!! help asap
- turboing a d15b7 non-vtec
- b16a power figures
- Car Cranks over but wont start
- H22 del sol
- air to fuel gauge question
- Dash lights & Tail lights Don't work!! PLEASE HELP!!!!!!!
- Time BelT *QuesTion*
- Super high RPM when i turn on my car
- Replacing wheel bearing and rear suspension on '92 LX
- Injector wiring problems!
- Brakes Line won't come off of Prop Valve! HELP!
- Newbies~ How to replace a timeing belt on a 96?
- sohc header, how much difference?
- tach signal...00 d16y8 to ej1
- 98 seats removal, how?1
- Do you have a 99-00 EBP Si?
- EK2 Steering Wheel & a not working Horn
- B18b1 swap in ek what exhaust?????
- idle problem , please help..
- injector compatibility?
- CEL light problem
- 92 Honda Civic NO SPARK **FOLLOW UP**
- yyour insight on N/A highway car build
- d16z6 in a ej8?
- rear disc swap
- Looking into buying this car! Help
- Type R Crank pulley? Any Good?
- 3 Questions About Shifters???
- First build GSR N/A
- Walboro 255 LP/HP Fuel Pump Question..
- Opinions about these pics
- help: 96 ek 02 sensor wiring
- what is a ZC engine?
- Dirty Spark Plug QUESTION EM1
- what is an easy swap for my eg
- rebuilting my motor should i use ebay gasket or oem???
- k24 element bottom end with a2 head?
