View Full Version : Honda Civic / Del Sol (1992 - 2000)
- NEED HELP WITH AUDIO?!!?!?!?
- my 99 si stolen
- what ecu does my car need please help thanks
- Car Dies While Driving (AGAIN, AGAIN)
- Octane Question for JDM motor
- need help imediatly working on car today please respond.. vtec to non vtec
- My vtec is acting weird, can anyone help?
- modifying an RSX-s exhaust to fit an ej8
- 99 SI dies out!!!
- Shift Knob - Del Sol
- help on ckf sensor (crank sensor)
- Stiff suspension
- chip tuning. need help
- Selling my D16y5
- What's your favorite paint color for a car in general?
- My tranny doesnt want to go into gear. Why???
- apex-i turbo timer
- stereo problems
- Fujitsubo Legalis R exhaust.... on EG sedan?
- Quick axle question
- Will a 92 ex automatic shift linkage work in a 99 dx civic
- gsr BB in a 93 si hatch?
- Auto to M/t conversion,b16a2 engine
- Ported intake manifold,B16a2
- Water Pump gasket
- Enabling Door Locks
- A/C warm during idle, cold when moving
- auto bseries swap in 92 EG CIVIC 4DR
- HONDA TROUBLE - hit pot hole and engine has cut out
- anyone know what cluster this is
- to ls/vtec or not ?
- Turbo question
- Exhaust question
- about how much of a difference in hoursepower or torque will gain if i get hks hi-power full catback
- Throttle Position Absolute Percentage?
- SEARCHED:Gas gauge moves around a lot
- wheel bearing
- pic. request please help
- whats the compration ratio for b18b with b16 pistons,
- sohc vtec head question
- how to fix cel code 14
- 92 Hatchback Si Interior!
- steering wheel removal
- 2000 civic fender linings fit on 93 civic?
- 2000 civic ex a/c help
- Air/fuel gauge hook up
- Need Help Finishing up my Distributor
- Need help with o2 sensor
- HOW do i find out if my map senosr is bad? or if connector is.
- **Civic DX cluster to SIR cluster question
- Speed Sensor Part # Si 2000
- Floor mat
- Can I use 93 Integra Axles/Shift Linkage in my 96 Civic?
- WHICH ONE?!?!?!
- yo need someones help
- weird start up problem? not the starter!
- Exhaust Issue - Sorta
- engine not as loud?
- B16 Axles
- cluster question
- Dyno Results
- B18B into a 1992 Civic SI hatchback
- 97 engine problems
- DA half shaft and axles on a newere B-series swap?
- b20 vtec boost question..
- few quick questions about flywheels
- n/a automatic
- clutch going bad
- depo foglights on my 96 civic w/ 99-00 front bumper
- mirror help
- help!!! avantages of b18 to b16 in a del sol??
- got a honda civic question
- MB6 Civic 1.8 VTi cluster help
- look at this....
- need some help!!!
- HELP!!! B20
- 96 ek problem, oxygen content code 1
- hi guys
- 98 Si Trans In 95 Honda Civic Dx Coupe I Was Told It Works?? True Or False??
- what is the different on 54 or 57 trim on a garrett t3/t4 turbo?
- SOHC tech: obd2 JDM D15b Dual vtec solenoid question, search did not help really.
- Stage 2 DD
- low rpm studdering
- Honda Wont Start When Hot
- motor mount question
- k24 good or bad
- OBD1/OBD2 Differences - H22/23
- new clutch
- h22 or sohc turbo? please help
- power mirrors wont turn left or right (both of them)
- Will both distributors work?
- skunk2 manifold owners
- b20 with itr oil pump is it ok
- Advise
- Code 41: Heated Oxygen Sensor Heater
- Possible transmission problem?
- SO..IM BAK ONCE AGAIN WITH A WHITE EG!! I PAID $1000 WAT YALL THINK???
- Del sol A/C
- B16a2 Wiring HELP!!!!!
- Hi idle and smoke (searched)
- buying a d17a2 for an ek hatch
- quick easy map ??? ecu pinout
- ebay stuff
- Power slot rotors
- Is there anything which might...
- RSX Steering Wheel
- Purge valve stuck shut help!
- HELLLLLPP !! PLZZZ! I HAVE WORK AT 3 AND I LOCKED MY KEYS IN THE TRUNK!
- 92 CX Steering Column Loose
- del Sol VTEC vs. Si brakes?
- Fogs / Aux Lights - 96 Del Sol
- Plugs and wires
- need to rebuild d series starter
- PCS XFC.. anyone tried this yet??
- im new here
- ef w obd0 ls swap... weird problem/ fuel/wiring
- vx wiring harness question
- Intermittent speedometer...94 Civic w/ D15B7
- your opinion on what might be wrong here...
- My USDM/JDM/EDM Del Sol
- Del Sol Front Lip
- Sparks?
- How to remove the front bumper off a 99 honda civic?
- 96-98 & 99-00 civic strut bars different?
- help H22a swap EK ... no speed... or blinker
- hi comp pistons with boost?
- questions about ek foglights
- White smoke out of the exhaust? Doesn't smell like coolant...
- My Civic broken into (Vtech chip stolen)
- AC system for 1995 Honda Del Sol V-tec
- Better Cel/ABS/ SRS codes PLZ.
- suspension making noise
- help about a CEL after changing exhaust manifold on y7 to y8
- k20a parts...
- RADIATOR MAKES NOISE! HELP!
- motor knocking. problem?
- 1996-2000 OEM Honda Alarm's???
- DASH LIGHTS WACKED OUT
- RIGHT TAIL LIGHT DOESNT COME ON WHEN CAR ISNT STARTED
- ls/vtec wit ctr pistons =HELP=
- Plate Mounting Trouble
- another newbie, just got a '99 si, need some tips
- alright i have some throttle cable issue after swap help please
- GOT A De Ze head need a good BLOCK NE sugestions
- Blown head gasket????
- does anybody know how to get sema tickets
- Question about manual conversion
- What is a good radiator for Civic 92-95 EG6
- need help finding 1999-2000 civic si gauge cluster
- Car wont start: relay clicking, headlights turn off electronics help! HELP!
- head lights uneven
- 96-98 rear valance?
- eg suspension ghost problem , HELP!!
- Need to replace front lower control arm, HELP!!!
- how do you install a ek front on a del sol????? HELP PLEASE
- headers
- shift linkage
- Motor Build info.
- Brake Light stays on???
- muffler size
- Questions regarding 97 Civic Guage. Help?
- camber adjustment............
- overhating
- compression check help
- Upgraded software or no?
- Curious about timing
- project rhd coupe
- newbish question about ek rear seatbelt
- msd engine bay pictures
- Battery?
- transmission winding noise. help.
- clutch slave cylinder bad?
- 96 Gs-R to 96 Civic Lx Brakes??
- dash lights
- strut mount??
- Shifting clicking
- eg6 towing capacity LOL ?
- question about mounts and swaps
- starter problem
- i feel really stupid...
- New seat question..
- sub frame lca bolt repair
- Installation on breather filter
- help!!!!!!!! d15 b-vtec swap
- y8 tranny question
- PLEASE HELP MY CAR WAS STOLEN BUT I GOT IT BACK NEED SOME HELP ON REPAIRS
- black smoke from exhaust
- new car and new to the site!
- bolt size?
- H22a in 98 honda civic coupe
- would it fit????
- Lower Control Arm???
- d16y7 Transmission Help?!
- Better brakes
- help honda gurus....car starts but will run like its misfiring all cylinders....turbod
- identify this Bumper
- GC Extended tophat fitment question.
- GSR Q's
- Which turbo or turbo kit is best for my fully rebuilt 9:0.1 d16z6 motor with 300 to 350whp?
- b16 cam gears question
- HID removal for TL-s Repost
- D15B7 intake manifold on y7 motor
- Taking off ek side skirts?
- Gauges In the Glove BOX?
- RADIATOR CORE SUPPORT HOW TO...NEED HELP PLEASE!!!
- suspension setup
- 5 cel codes
- will suspention off a 94 civic ex work on a 98civic ex??
- mystery plugs after obd1 motor in obd2 car and harness
- RHD JDM Conversions in SD?
- Bolt into Tranny, is it fixable? 2000 B16
- EK JDM Sidemarker Stay On/Off?
- F'ing Swap!!!!!
- autometer egt showing 100f when key off/out???
- Replace the driver side mount
- thermostat ?
- trick to depining igintion harness
- Pic request of spark plug wires
- removal of radiator support?
- interior question
- wet sparkplug?
- Driveability and mileage gone to crap!!
- 07 SI front seats
- HELP QUESTION!!
- Help with wires under dash
- Secondary O2 sensor question
- Main Relay clicks, and engine Hiccups
- ASR Brace Question help!
- fuel filter????
- internal coil compaired to external coil ?'s
- SoCal Suspension shop's...Any?
- Suspension Installation issues.....Please HELP!!!!
- B16A2 boost question???
- broke into my car, so i need parts
- B17a into EG
- check engine code 20 EDL
- brand new clutch problem.
- F22B2 into EJ8
- Approximate weight savings?
- Repost: Swaybar Bushings Loose on Swaybar?
- charging up a battery
- Fuel pressure question
- auto swap ECU question.
- Car Dies While Driving (AGAIN)
- puddle of water inside my 92 civic sedan..
- Ek owners with b16,b18,b20 motor need help
- 92-95 civic RHD conversion, what else is needed?
- swap/turbo/nos
- JDM navigation?
- 96 LX D16y7 -> D17a1
