View Full Version : Honda Civic / Del Sol (1992 - 2000)
- 2.2 engine conversion in a CRX!!!
- weird timing problem
- b series exhaust manifold gasket size
- 93 civic TRIPPIN..need help!!!!!!!!
- ITR front tie bar fit EK?
- max hp
- Codes: 15, 21, and now 3. IGN, VTEC, and MAP help.
- i need your help
- VTEC Nightmare!!!
- Any info or feedback about these two engines. Recons 275hp stoker motor & Gsport motor.
- B Cruz's hardships with JDMtheory.com...
- ::what front lip is this?::
- 02 WRX seats in a 99-00 civic
- P06 with Ls Low Rev...
- how to wire IACV to ecu??
- 4 door GSR catback on a 99 Si?
- Which AC belt am i looking for on the B series swap in an EG?
- Help 00 si pulls random to the right
- Tokico Blue Hp gas shocks. Worth the money?
- Is there a skid plate for the DC Sports JDM header?
- swap ??????????
- ITR Fuel Pump, ITR Master Brake Cylinder should I or shouldn't I...
- firestarters
- STOCK b20vtec crvtec track times in my ek hatch
- what are signs of a clutch failing??
- need help
- Where Did You Buy Your Carbon Fiber Hood?
- CDN prices on motors and parts please
- intake manifolds, which?
- STIPH Phabs gauge pod
- AEM CAI Filter Size (searched)
- short ram air intake
- scammer, DC sports JDM iTR header & 94 JDM B18C SiR-G
- I need a part.
- 94+ Integra Dash into a 95 civic, how do u do it?
- b20b question...
- HELP PLEASE =) 00 Si deck into 98 dx hb
- GSR in a hatch... what you run?
- anyone with axxis pads experience noisy braking
- Running Saturated injectors with a resistor box? Possible?
- Bad distributor? Ignitor?
- Wiring up some JDM headlights??
- Sohc Shirt?
- ls motor acting up.....
- how to install a rear abs conversion?
- My first time drag racing. need help.
- so i got $2500...boost or swap?
- grant steering wheel into a 97 civic? what hub?
- kyb agx shocks....question.
- Aftermarket Cat
- GSR sway bar+LCA's+92 Civic, quick questions
- Need Howto
- New user to the site have some questions.
- OBD Conversion Question???
- replacment part numbers for clutch install
- Info Needed For ZC Swap
- will my buddies gsr exhaust fit on my eg coupe? mods needed?
- car stalling?????
- Has anyone heard the Megan Racing cat back????
- help car wont start HELP just got engine drop done
- Rear Disc EX
- Mugen Chip
- Is a JDM B16 complete swap worth 1800?
- lower ball joint problem
- stolen car VIN?? Anyone with a carfax account please help!
- K20 Civic project and parts lists.
- Hub Centering Rings on a 98 Honda Civic w/ Rota Grid Rims
- pulling axle from midshaft, searched for 20 minutes
- Which Springs Go Where
- My Honda Del Sol
- HEY....can you do like ol' V8er's and weld spider gears RATHER than LSD???
- please help
- Bogging Woes....
- GETTING NEW SHOCKS/SPRINGS ! HELP !!!
- 215/45/16 tires fit on a 99 civic coupe?
- what size tires??
- Removing B16A rocker cover
- First Time At The Track... Need Practice...
- cel light on engine revving high
- please help car wont start
- camber problem which kit
- Hey internet guru....
- Please Help. what should I do
- ITR aluminum a/c mount
- WHICH ENGINE?
- possible to run vtec on a non vtec ecu, temporarily ?
- Thinking about swapping.
- WENT TO THE TRACK AGAIN. Timeslips in.
- A/C relay problem?
- bottom end
- VTEC problems
- EK sidemarker WIRING
- ELD
- 1994 Civic DX
- Separating tranny fom block
- reassembling B16
- Tourqe specs for a d15b7
- b18a or b16a? what do you think...
- Anyone had this problem?
- H&R Sport Springs on 99 SI
- Difference between VX and VC hatches?
- Swap Question?
- Looking for performance shop/mechanic
- INSTALL/HOW TO: '92 Civic Front Sway Bar
- Gas pedal is really Stiff and it's VERY hard to shift gears (auto)
- Rattling @ 2500 RPM
- Should I motor swap a GSR motor or go with some boost.
- More CEL's tell me what you think it is
- Replacing my clutch. Any ideas?
- is the 00 civic si rear crossmember on a si weld on or bolt on?
- Regular tire irons work on Skunk2 lugs??
- My car idles really low, need help!!!!
- help me get my b16 in!!
- ::where can i get this??::
- 00 front lip on 98?
- h22????
- is this a blown head gasket?
- running a wire from the fuse box ??
- painting plastic engine parts
- Comparing 2000 Civic Ex to 2004 Civic Ex
- cusco roll cage :)
- found a 93 si hatch and a 94 dx hatch.. which one?
- ***legal***
- Need HELP with car audio!!
- Question on venom 400 performance module
- My nitrous track times
- Which HB best fits you???
- How to Convert OBd1 car to Obd2???
- So I Get My Engine Swap Done.......
- Del Sol Question
- Picture help!
- Went to the track tonight. video's in side
- DC5 ITR Steering Wheel
- jdm d15b with d16 block?
- Recommended Engine Swaps?
- New Syncro's?
- throttle body
- Alignment issues. need help making both tires aimed strait ahead.
- HOW MUCH INTERIOR DO YOU HAVE?
- B16A2 USDM into a 1999 Civic Ex
- Idea on front clip install
- 3rd gears grindin whatshould i do until i can afford a new trans.
- Need a spoon n1 for a 2000 civic si
- racing seats...
- Q:Loud ticking after shut off?
- Eg6 Engine question
- 11 Sec Daily Driven Civic
- will the trunk lid fit?
- Anyone know what a code 36 is
- Pics of my Honduh Civic Si(56K DIE LOTS OF PICS)
- smokes from exhaust
- Quick KYB AGX Setting Question.
- h22 question....
- Clutch DISC
- 4dr bumper?
- Does o4 Civic tail lights fit on an o1 Civic?
- B20B(non-vtec) Swap Directions for a '92 EG?
- code 9?
- alignment after Neuspeed sports
- B16a1 Into a 94 Del Sol Help!!!!
- spark gap
- Dynoed my car, i dont think the result is good (pic)
- Anyone here done or have a h22a del sol?
- help with high idle
- MOMO START BUCKET SEAT fits RECARO UNIVERSAL BRACKET/slider???
- broken bolt in chassis
- Primary O2 sensor question.......
- omni coilovers? skunk 2
- d15z1 questions...
- Synchro's questions...
- short shifter install problem: need help.
- Leaking fuel from gas tank area? Need help.
- Will 96-98 civic suspension fit 92-95 civic????
- Anyone know the correct way to mount a 4pt harness into a EJ1?
- how can i get overspray off my tint?
- EK People help me with this stuff please.
- So I bought a new engine.... (56 ouch)
- Paypal .. Safe as you think? As honest as you think?
- whats the diference between b16a1 and b16a2
- Moonroof Slider Help
- 2001 Civic - Waiting to be modded (Semi-Newbie)
- Just wanted to introduce myself...
- Neuspeed tie bar combo/s
- oem type r exhaust?
- b18c1 cutting off at 7500 rpm
- GM Syncromesh FM
- help me installing this timing belt drive pulley
- Accident Dilemma
- help! i need a rear control arm for my civic
- Newly Purchased Civic
- can a b16b type engine fit in my 92 hatchback?
- Anyone using the VW Corrado rotors on their EG Civic?
- 2 red s2k seats 4 sale...
- clicking in the dash
- spring rating?
- transmission noise?
- problem with starter turning flywheel
- help i have 3 codes throwing at me... i need help to fix them...
- Integra seat install problem.
- Car overheating while at idle?
- Meaning of warning light?
- SCAMS on internet for car parts!
- B16 IAC problem?
- Did the search-hasport vs. hcp
- Lowering springs longer then stock springs?????
- 94 civic engine swap
- Couple of questions: Power Windows & Cluster Swap (searched)
- ** All SOHC fans, my first swap - the JDM D15B! **
- anyone tried/have these ebay heatshield intakes?
- Those with Tein S-Tech, KYB AGX, and 17" wheels on your EG...
- 1 for me... None for the thieves!!!!
- Momo Wheel Install
- power steering rack to manual rack
- Gauge Cluster - RPM and Spedo fluttering
- 94 del sol manuals? Please this is kinda urgent.
- Loss of power/studder
- chipped p28 vs stock pr3?
- De-ricing my civic...question on rims
- Rear bumper fit
- I replaced my AEM CAI with a V2, hmmm...
- what exhaust is this?
- Where is that D series compression check thingy?
- CIVIC NEEDLES AT NIGHT
- spoon throttle body with type r manifold?
- d16z6 ecu with d16y8 motor?
- Can someone please run a VIN for me?
- Swap question.........is this necessary??
- A Question on L.S.D
- oil in cylinders
- D series transmission's that have a stock LSD???
- What model is this??
- audio wiring ?
- Buying a 92-95 civic...
- B16a manuals
- My suspension
- 97 EX auto to manual IM???
- p30 ecu question
- UGH, bad exhaust?
- About to ship a head, how do i clean it out so it wont leak oil everywhere?
- Will a VX ECU work in a Si? Please Help!
- cel number 3 ( map) on a 93 del sol w/ 94 gsr swap
- pic request: 99-00 si cluster night time amber shots
- Exhaust leak?
- Check Engine Light after exhaust??????
- anyone have more info on Tilton MC?
- Error 22 VTEC pressure valve on P30, while OK on stock P2T
- turning cam to TDC
- camber question
- Got a question bout gettin da rite setup...Need some help
- Can anyone comment on these tires? Falken Ziex ZE-512's?
