View Full Version : Honda Civic / Del Sol (1992 - 2000)
- need help!
- Rear Strut Tower brace.
- Bonquisha got dyno'd today...
- exhaust question
- 2000 sohc cam questions
- 90-93 Integra rotors work on 95 Civic EX?
- Does anyone have the AEM V2 intake installed?
- rear disc sizes (eg/dc)
- Civic stereo removal....
- Drift showoff....
- D16y8 and D16z6 pistons...
- Clear Taillight How To
- Best place to buy a sohc vtec swap?
- 17 inch wheels VS. suspension
- Corbeau cr1s
- shifter?
- RSX = 2003 Civic Coupe?
- JDM CLimate Control
- f/s 92 civic si hatchback (custom)
- 90-91 b18a into 97 cx
- K20 JDM Motor/Suspension in a 2002 Civic finished.
- oil question, from regular to synthetic and back to regular
- Help!!! Is there such thing as ??????
- HX vs. EX wiring harness differences?
- Tech Topic - Hardware Needed to Install Civic Si Lip - $AVE MONEY and do it Right!
- Stripping interrior, Need help.
- Type R Sway Bar: Just installed on my 95 Si
- Another Damn Exhaust Question
- Camshaft Question
- Funky idel
- upgrading my RAD. to 'Teg rad... I need some info...
- Shift Linkage Bolt
- d16Z6 crower cam
- Camber and launches
- ef vs. eg
- should i buy this motor?
- LS Swap
- how do you take off the screws of the air filter box???
- ok settle this for us.
- how much would u guys pay for a 99 jdm rhd ek9 ???
- Check engine light is on....
- 2 1/2" cat back on ex too big?
- energy supension
- my baby
- 2000 civic ex sohc intake
- h22 motor mounts
- ITR intake manifold or Spoon header?
- b16a or b18c gsr
- h22 fully built w/ t4 turbo!!!
- What intake for my car.
- auto to manual conversion (did search)
- INFO? on new 03 civic SI
- $1500 for a 5 spd civic dx with 200K miles. should i get it?
- D series engines vs. B series engines--what are the advantages or disadvantages of both?
- how many Si's where made?
- area 51
- smog testing questions
- Si JDM Front End??
- sorry about the spellling
- k20 swap in eg6
- Setting FPR to pass emissions?
- CODE help....
- How to remove delsol door panel?
- VTEC controller help
- how much HP aprrox ? does intake gain ?
- Did I blow my AGX shock?
- reinforcement bars?
- Just did Auto to manual , Need help with Key in ignition getting stuck :(
- Which valve covers said vtec on them, what years and models
- I've had ENOUGH of this B16 HATE!!
- 98 civic lx auto tranny swap recommendations DOHC
- can i see ur lugz....anyone here with 5 lug conversion post some pics
- help me make a decision plz...... about my b16a
- I've Made Up My Mind - GS-R JRSC and ???
- Interesting Conversion for 96-98.... really!
- HID questions for MTK Kommander or anyone else
- 5 Spoke GSR rims
- initial D civic?
- Integra LS (94+) AEM intake fit in egg?
- Already searched, aftermarket del sol axleback fit 92-95 hatch?
- Please HELP ME!!!??? My car will NOT move anymore. I need to fix this so I can get to work.
- Piston help! ASAP!!!
- Custom Sparco Colors and Interior Suede
- Cusco rear lower tie bar.
- honda civic radio removal - 6g
- A/C Power.
- what program to run??
- valve seals help!
- needs pics of spoon rear upper bar mounts on eg body...HELP!
- can't figure out engine codes
- what do you guys think about a b16a for an ek?
- Bad Gauges
- Fodoho woes
- H22a HB Stolen in Northern Virginia!
- idle adjustment screw on tb does nothing? why
- Put my coilovers on today and noticed....
- what is a "cold start" injector?
- idle stuck at 4K but when MAP sensor is unplugged it goes to kinda normal is this bad?
- Why road racers don't respect NASCAR
- Question about tickets.. i got 1
- Might be out before I even started
- would a 96 intake fit on a 01 civic ex
- What happens to EBC Green Stuff when used properly
- 98 EK JDM itr swap 5 lug
- Rays Lug Nuts: Anyone have black ones?
- idle going loco....
- OTish: where can i get a b18c5/b18c-r long block for my eh2?
- turn off the ABS?
- How hard is it to replace the slave cyl.?
- 75 shot on a d16, anyone done it?
- awnser this dyno question
- bunch of crvtec questions awnser at will!!!!!!!!!
- jdm parts???
- WTB: 2002 left headlight for civic 2 door.
- jumping speedometer
- GSR mesh and Spoon lugs???
- EG seats and Del Sol seats Help Please
- attn south jersey and central jersey...
- in a race,who would win
- wiring ?
- Brakes SUCK
- Some Pics and a Cool Video From an External EG Camera Mount! PICS FIXED!
- Does ECU has fuses?
- With so many differnet opinions........(Once again a header question)
- Quick Question on Seat Rails
- USDM/JDM ITR 5 lug Conversion and D series motor....can it be done?
- Jamex seats I need brackets to fit del sol
- Tranny Questions???????????
- Carbing Lower Tie Bar Reviews!
- New to forum, question about b16a swap w/ Helms.
- ITR CAI on an EX??
- Horrid Screeching Sound, HELP!
- 96 cx weight?
- Rear Camber Trick (searched)
- bleeding brake lines.
- Wiring Evap Purge Solenoid on B16A->93 CX = A20 already occupied?!?
- ctr pistons in itr
- 95 stock SI runs rough/knocks when cold?
- lost my NX jetting chart
- Apex'i AFC
- Vtec wire??
- E-Brake
- *siGH*
- my shitty pics!
- Illuminas are they shitty?
- Detonation?
- how should i build my b16a to have better lowend power and tourqe then a b18c?
- NE1 Ran a air duct/piping to a Short Ram intake? Pictures?
- Snow Day in Upper NYS with Brian(Video)
- Those of you with KYB AGX...
- Where to order square metal bar?
- B20 people, Post your Gas Mileage and setup!
- greddy intercooler fitment!! please help
- EG+ Side Molding Question
- intercooler piping question....
- skunk2 camber kit questions...
- pistonskeep stock rods or buy eagle
- rebuilding my valvetraIN B16 ANY SUGGESTIONS ??
- Trunk Leaks
- Help with Honda S2000 start button in an EG coupe!!!
- type r rear swaybar with BSQ style kit/ energy suspension bushings
- Ecu chipped
- help with my swap!
- Trying to get the right shocks for the best price...
- H22A Swap
- tech question, help! vtec not working
- Question about tire fitting on certain wheel....
- WTF? brake lights dont work anymore?
- JHP.COM Spoon Replica Side Mirrors?
- Spring Differences
- 93 coupe UCA
- turbo my b16a or b18c5 which one?
- what is makin my car do this???!!!!!
- Why cant i check my codes????
- Civic in Rallycross Video - Listen to the end
- Nex coilover good or bad?
- sohc compression ?
- door whistle ?
- Neuspeed Short Shifter
- CTR pistons ? B16
- Should I buy this car?
- weird problem
- finally
- itr cams in a b16a sir2 question
- After months of waiting, I got fed up and Painted my car on my own....Pics inside.
- EK Duckbill pictures pahse: 2 enjoy
- Where can I find a JUN front chin spoiler for an EG
- Got boost? Hell no!
- Motor Mount Q
- Bubble in tire
- EK SRS Steering wheels......what Honda/Acura wheels fit the 96-00 Civic?
- got a new cam(d16) have a question
- Leaking Taillights
- insurance issues after car is stolen, help needed
- Mugen RNR Wheels Caps
- Looking for paint in South NJ....
- remove cat for more hp? does it work
- Where can I get a apexi Exhaust Gasket?
- Attn: 99-00 Si Owners
- How much h/p do you think im pushing..and what 1/4 time do think ill run..
- Well yesterday i was bored so i painted my friends headlights. Pics Included(56 I Own Joooo)
- Fender Flare
- anyone have any pics of 99-00 Si rims with falken azenis?
- WHat clutch is better......ACT or clutch masters
- Dunno if you guys can help me out, but i'll ask here anyway.
- Bouncy Idle - Follow up.
- 2001 taillights
- plug wires with grounds
- Integra Type R rear seats into a EG Coupe
- Need help choosing differential
- Exhaust note
- dash cluster
- 92-95 hatchback OEM
- EK or EG body for built GS-R N/A...?
- No Heat Again !
- Where can i get a o2 simulator
- engine swap
- gsr swap, any track times in ek's?????
- cx, dx, vx. hx, lx, ex? si? wtf? what is the diff?
- integra gsr seats in eg?
- excessive smoke
- Where can I find EG OEM foglights??
- Performance street tires for 13" steelies?
- Temp Of Carge Pipe
- which tires for my 16x7 40 offset c8's?
- Anyone Used These
- Parking Brake problem
- Where to find Type-R lip for EG?
- my front wheels are scraping
- ctr steering wheel into a 91 hatchback
- Size of Front Swaybar on 93 Si
- redline fuel cleaner
- weird sound!!
- CRX lca = ITR lca?
- Coolant loss.
- JDM ITR Steering Wheel in 92 VX
- 96 civic ex
- dc twin cannister exhaust
- Civic si coupe model car
- Need Help Quick
- civic Si owners?
- Just picked up a Fluidyne Radiator and Fal fan today for 200 bucks
- 99-00 conversion
- EK swap throttle cable question
- How Much Do You Think i Can Sell my EG for???...
- looking for b17 crank, please help!!!! and a tech q inside too.
- Kumho tires
- JDM Ohlins coilovers
- help with my stereo system!
- Post request thats lost
