View Full Version : Honda Civic / Del Sol (1992 - 2000)
- rsx type-s muffler on 97 civic lx??
- Shift Knob Thread Pitch
- motor seized up after getting off the dyno
- Cold Idle problem - fitv?
- 96 civic sedan buddy club rear bumper - Will it fit a 94 Del Sol or a 97 Civic coupe?
- 96 Civic/D15b swap - CEL code 4
- Shift knob question
- gsr bad head gasket i think
- P0740 check engine light problem
- B16a swap
- **STOLEN CAR** Black 96 Civic coupe in Chicago (pics)
- ek with b18c will not start
- 4 door ek awd conversion
- Si versus non-Si - Difference in parking brake handle?
- will 13 inch vx rims fit a 95 civic lx?
- clock and radio issue
- help with gauge cluster lighting
- B18B swap fuel line questions
- Mini-me - bottom end 140k, top end 80k - Seafoam okay?
- what transmission do i have
- oil on spark plug
- VA Emissions w/ JDM Type R Swap
- stalled while driving
- Short Ram Intake
- starting build need help
- eg cluster bezel
- 95 del sol S code 9
- 92 Civic CX dash clock
- Vtec Solenoid question w/ pic?
- 95 civic ex coupe brake lights won't work but running lamps will
- b16a3 rebuild kit..
- Will the EX speedometer mechanism work on an SI cluster?
- which ecu is better
- Funny noises from the D16Z6
- Cel 22, d16y8, Vtec pressure sensor help
- 92 eg shifter fork problem..help!!!
- d16z6 no start
- throwing belts
- B16A3 Del Sol Vtec Solenoid Picture?
- Is my heater core the problem?
- 10A fuse 15 keeps blowing on 95 Civic
- EG Condenser fan
- Car has no power cel on not showing codes (solved)
- *Help* Keyless Locking Not Working
- b18 swap starts but sputters?
- personal wheel question
- 92-95 Honda Civic Variations
- changing cv joint. 95 civic ex
- *NEED SHIPPING HELP for complete interior FROM CANADA TO NY*
- Y8/Y7 Mini me - How much horsepower and torque does this swap have?
- dual vtec d15b idle problem
- WTF gas tank issue help plz
- Temperature Gauge Random Spikes
- Clean Grill for my 2000 Civic DX coop
- d16z6 - what fits what doesn't for increasing hp?
- gas light. 94-01 integra cluster into 92-95 civic hatch
- boost or n/a power?? old timers chime in...
- What engine do I swap into my 97 hatch?
- 98 ex coupe - fitment questions about 97 dx exhaust
- Would a jdm d15b motor work in my 95 lx?
- eBay spoon mirrors - Will the blue flim have any effect on dimming the lights?
- Removing valve cover o-rings.
- car wont start???? i get fuel/spark
- Obd2 to Obd1 Distributor Jumper Harness Wiring Diagram?
- How do I remove stains from my carpet?
- 00 Civic DX coupe - How fix paint loss from metal door trim near window seal?
- EK climate control issues, need some help
- Vtec Solenoid question B16A3
- D series aluminum radiators with 1.1" outlets
- Molding interior.
- EJ1 with B16 swap - What driver-side axle do i get?
- 91 hatchback/D16Z6 swap/OBD1 - inconsistent idle
- Block guard
- Mugen Ferio Wing
- from argentina! hello!, swap b16a2 into eh3
- 92 Civic won't start - fuel pump doesn't prime
- looking to turn my 93 fodo LX to SiR help?
- BEST SWAP FOR MY EK!!!!!!!!!!
- Who is the OE distributor that makes the glass (windshield) for my civic?
- BARLEY SHIFTS INTO REVERSE HELP ASAP PLS
- 97 Civic - How to properly bleed the clutch fluid?
- H-Tech Tein Lowering Springs with Stock Struts on EK?
- SPEEDHUT GAUGECLUSTER HELP!
- 97 EL Front Passenger window won't close
- D16Y7 jumpy idle after IACV cleaning. HELP!
- what website should i order motor from?
- Brighter Cabin Light?
- boosted b20 rev problems
- ring flange for exhaust?
- 1997 civic coupe el swap
- 93 del sol with B18a1 swap - What is the correct axle to use to stop the shaking?
- windshield moldings
- Do 99/00 civic si rear seats fit in a 96 civic dx coupe?
- eg2 cluster km to mph?
- Speedometer gone rogue
- How long can you drive with two broken power steering boots!
- No heat in my EJ1?
- "Air" sound coming from back brake
- d16a - anyone know the specs to this motor?
- Distributor compatibility questions
- Automatic Y7/Y8 Head Swap
- need help! cf vis trunk/latch 99 civic si...anyone ever swaped trunks? please help
- 94 civic si/B20 turbo - heater problem
- Swap for del sol - What shift linkage?
- HELP? Ignition problem maybe??? 92-95civic
- Transmission VIN number?
- Draining battery
- Where is the service connector (cel code checker jumper) in my eg?
- b18 swap in civic - CEL code 14
- d15 Bogging, no CEL, sounds strange at low rpms.
- 99-00 Civic Si
- 16a6 into a 95 auto dx will it work?
- 98 Civic - Please Help ASAP! Engine tapping continues even after valve adjustment
- Will NGK blue plug wires from B18B1 fit on a D16Y7?
- b16a timing marks
- Just got 2 CEL Codes. P0700 and P0740. Help on fixing them please.
- Merry Christmas and Happy New Year
- Rear windshield washer part number??
- D16y8 wire harness help....cant find 02 sensor connector??
- new project b16b eg hatch!
- Main relay kill switch quick question
- Putting H22 in a 97 Civic DX - Resistor box and bracket questions
- Can't set ignition timing -1993 civic dx 3dr stock
- just bought a del sol need some quick help.
- d16z6, vacuum hose size?
- VTEC Head Swap
- tach gauge cluster help!
- Rear Far Left Lamp is $85 new from Honda, cheaper replacement?
- Question about using lucas in my civic....
- B18b swap in eg throttle cable questions
- intake manifolds interchangeable
- engine vibrates at idle unless heater is on
- 92 civic clutch bleeding
- What's a type r header worth?
- Block cracked where the oil pressure switch goes in - OMG!
- TL problems....uhhhhh!!!!
- cel code 17 please help.
- fuel pump not priming
- Engine flooded with fuel and now won't start
- 92 Hatch CX- Clock wiring
- any infor on edm headlights for a ek 96 to 98 how to wire them in
- 99 EM1 idle dipping to 200rpm and dying when stopped
- Testing/Replacing ECT Switch...
- tie rod replacement, help?
- 96 lx - blinking CEL and codes 65 and 71
- i wanna do a swap "help"
- 98 OBD1 Swapped Civic Problem
- over heating problem
- Diagnose lower ball joints? 1995 honda civic ex
- Steebhouse's first thread: ''my dream''.
- B18A1 head . what can i pair it with?
- B-series VTEC swap for ej civic
- 93 eg y8 swap problems
- Who the hell Glues a distributor rotor on?
- Which cat/test pipe do i need?
- Where to get an OEM power mirror plug?
- 99 civic lx build
- Double Din Headunit?
- Ideal to Modify oem Civic si (em1) cat-back?
- B20 Question
- can i only change 2 struts in the back and leave front stock struts?
- 99 dx hatch water leak... help
- 97 HX bogging out/stalling out..HELP!
- How to: Depin 2 wire CKF to 3 wire
- Links for oem knobs pls
- 94 Civic B16A swap, blowing alot of black smoke.
- Speedo Quit Working
- Help with my vtec controller on obd2
- 96 civic/b18c has 2 cracked pistons - What do i do?
- Windshield Wiper plug after attempted car theft
- Where do I find a 12 volt wire hot all the time or only hot when car is running?
- First Time Wire Tuck, Help!
- b18b1 timing main belt
- PLEASE NEED HELP ASAP,THANKS
- Idle problem.
- b20 starting, ign. timing, and map probs
- automatic transmission civic 97
- Rain Problem??
- 1994 lx stutter, sputter, jerking and light smoke during acceleration:
- obd2 trans on obd1 civic(auto)??
- turbo question...
- turbo del sol problems! HELP!
- 142k mile 99civic Throttle Body Cleaning???
- Fans not coming on already tested temp sensor with test wire
- OBD1 D15 in a 96 civic?
- exhaust for ek coupe/sedan same as hatch?
- How much is my jdm (km) gauge cluster worth?
- 1998 dx hatch, rain puddle + driving through it = check engine light
- Stock 99 EM1 - p0172 & p0170
- coolant leak but no visible leak!
- So what exactly is an Si?
- 99 Si cluster in 97 EJ8. Tachometer reads 1k low *searched*
- 2000 Civic Foglight Install Question (where to cut the bumper)
- Car floods after sitting for a while, sign of bad FPR?
- b-series EG guys I need your help to mesure something for me...
- obd2b B16a2 into 98' civic EX Wiring
- Can't tell what brakes
- 5 spd si tranny? how do i find out?
- got an ebay exhaust, how bad will it sound, link inside
- St front sway bar install on eg hatch help.
- Del sol or civic ???
- B20B BOGGING DOWN. I NEED HELP!
- Where to buy black exterior door handles for 93 civic sedan?
- My EJ2 Build
- the noob's y8 swap!
- B18b swap axle questions, help asap!
- wont crank when trying to start
- Brake caliper issue, seized?
- Jumping MPH Needle??????
- Headlights wont work! HELP!
- Wireing up the dizzy woes...
- civic d15b engine knocking issues
- rhd heater core will lhd work
- EJ6- Transmission diagnostic help!
- 97 civic ex coupe window problems
- 97 civic obd2a bogging Need help
- 00 Civic codes P1399, P1298, P0135, P0141, P1768
- ecu issues after ls swap into 98 hx
- Are hood sections of nose masks (bras) interchangeable?
- someone tried to steal my rims. ALARM SYSTEM?
- Bird under the hood AKA belt problem???
- b16 02 sensor question
- Knocking/Ticking???
- flooded with rain
- Climate Control Lights?????
- 1.7 vtec into an eg or ek civic
- cold start problem! please help
- EG Hood Question.
- Engine gets hot after removing thermostat
- 93 civic hatch with LS swap. CAR WONT TURN OVER ISSUE
- What intake manifold for a single cam?
- Engine shut off in the rain...
- Any difference in 96-00 civic pedals?
- possible tire issue??
- **White & Black EJ8 Thread! Post pics!**
- Leaking coolant from ?
- 4x100 Center bore question
- Quick d16y8 head gasket question
- 97 HX braking options?
- would a d15a6 motor work on my 95 lx motor?.
- 96-98 Civic SiR
- AEM or eBay intake?
- Quick 95 Honda Civic inner tie rod boots question
- 1995 civic ex coupe - Does the engine have VTEC?
- 96 civic coupe Short Shifter Install
- E-Brake dash light
- Does a p28 differ from a dual cam p28?
- HELP 96 EK STARTS THEN SHUTS OFF
- quick question regarding k_series
- Idle issue after Z6 swap
