- Best red for paint.
- For Sale: 2000 Honda Civic EK9 Hatchback - Black - Hooked up
- eg hatch wheel ideas
- Temp question
- VAFC question
- Clutch mastercylinder????
- 92 95 EG civic SI hatch gas mileage
- Rear Camber kit
- Replacing the wiper intermittent control module 97 civic
- shorter final drive,yes or no?
- b16 head w/bent valves, sell as is or fix & sell?
- Oil leaking from rear strut?
- Power side mirror wiring pwning me ... >.<
- $50 TO ANYONE WHO CAN GET MY CAR RUNNING
- How to install JDM Climate control
- y8 dizzy on z6??
- anyone selling a complete gsr or b16 swap?
- apexi ws axle back on greddy piping?
- I want to end all D-series oil pump arguments!
- Catalyic Converter Problem
- Using del sol 1992-1995 SOCH VTEC ecu on H22
- civic cx regulator on ls motor?
- ex intake manifold for HX?
- b18b injectors??
- Anyone can help me please???
- APEXI RSM WITH G SENSOR HELP!!!!!!!!!!!!!!!!!!!!!!!
- Headlight adjustment technique?
- Window Rail? The roller's rubberpeice is broken so the rail hangs LOOSE!
- Need help with suspension
- 94 b16 auto to manual swap
- *HELP* AXLES for 92 gsr hatch???
- HELP PROBLEM: idle goes up and down check engine light reads IACV on swapped Vtec motor
- at to mt
- 95 Civic coupe temp gauge Not work
- NEED HELP MY CIVIC IS BURNING UP FUSES LIKE CRAZY!!!!!!!!!!
- PROBLEM! K20 | EK | 5Lug Conversion
- 89 CRX tranny into eg coupe?
- What kind of gains should I exspect?(Head swap w/other mods)
- HELP. SPEEDOMETER
- Exhaust Questions?
- Brake problem with steering angle?
- D16Y8 cooling problem......NEED HELP!!
- shift light
- honda mechanic apparel
- EG cable tranny
- I reinstalled my power steering and I am getting a big leak
- NEED HELP!!!!
- switched odometer / cluster?
- civic ex oil leaks
- WIre colors
- Car never heats up
- What does it mean when you say EG and EK??????
- sanp axle in my sol w/ gsr swap
- b16 valves in type r head
- off throttle grinding
- gsr swaybar + si endlinks = issue?
- Weird Problem...
- leak question?
- slack in my 94 ex.when i let on and off the gas. i kan feel a
- a quick clutch question
- Milwaukee Wisconsin Tuning shops
- how much is a knock sensor from a dealer?
- integra LS turbo
- motor went bad
- my car overheats when idling and siting in one place but doesnt when moving
- what sensor is om the bottom of the intake manifold?
- if the check engine light is on does it mean vtec will not work?
- Will 99-00 Si side skirts fit on a 97 EK???
- How much of a difference would cams make?
- ACL bearings?
- Help finding a post
- ------h22a---nitrous------
- Miscellaneous Problems...
- will this fit in a civic
- Y7/Y8 mini me question
- do 92 civic cx's come prewired with vtec?
- wheres the cheapest place to find a vis hood for a 92 civic CA or internet?????
- WHAT ECU DO I NEED FOR MY 92 CIVIC WITH A ZC NON V TEC SWAP
- Problems with my coupe
- Why does it take soooo long for my car to warm up?
- Cant get into any gear besides 3rd at a dead stop
- HELP!!
- power folding mirrors
- Anyone in IL know where I can get OEM door hinges?
- JDM GSR - USDM GSR
- Dash light out
- where do i get some internal bolts?
- willl a p28 plug and play on a d16 y8
- 93 Civic CX Vibration Under Throttle 70km/h and up.
- Hood latch problems
- Car stalling for no reason!!!!!!!!!!!
- Stock 99 SI springs
- Is this Right or am i just in a WORLD of troubkle HELP!!
- WHAT DO DMV INPSECT FOR VEHICLE INSPECTION
- solution for seat tear?
- saloon front bumper on a h/back
- turn signal not working, hazard do!?!
- what alternator?
- Door panel insert ?
- Hunting idle y7/y8 mini-me, also slight hesitation.
- what kind of bumper is this?
- Tire Question...
- wiring a stereo?
- wierd overheating issue
- how can u tell if a header is a Type R?
- del sol gsr
- looking for flywheel bolts and clutch bolts
- What's the bulb size for a 94 civic
- 96 honda hx sloppy shifter
- how do you remove the automatic shift cable!!!!!
- Del sol rims weight
- lip kits.
- What Cluster is this??
- B16A swap in a del sol SI. What hoses do i keep and need to buy?
- help project/dream car
- Next move suspension
- y7/y8 timing issues
- Timing problem
- Ebay K&N Filter - fake or not fake?!
- Car making wierd noises...
- Can ITR fuel tank be fitted on a EG without any modification?
- EG fuel pump lph?
- Im on my 5th distributor in a month
- Need help on identifying part
- ls/vtec
- Can't get my gauge cluster bezel out....any trick to doing this?
- what header fits ls/vtec?
- side markers
- what setup is this
- Losing Coolant :( Any ideas?
- mini me question......
- Tryin to put on main pulley need a diagram
- will a usdm rear itr sway bar fit on a ek?
- shaking?
- Blown Engine? Need Advice
- camber kit or not? that is the questioin
- I managed 44.3 MPG out of the 97 civic
- Largest saturated injectors?
- floor mat Grommet
- starting problem
- 95 dx with ls HELP!!!
- all gsr civic guys.....question about vtec solenoid?
- EK DX + OBD1 B16a = What Exhaust?
- civic radio code?
- rings or seals?
- need help on my vtec 2000 y8
- d16z6 exhaust set up???
- AEM ignition
- Loud ticking coming from motor.....help please!!!!!!
- Distributor repinning OBD1 to OBD2 !@?!@?
- Anyone have a Skunk2 Chiped ECU?
- map sensor removal?
- Poppin the fuse on the foggies.
- Integra rear seats in ek question
- cleaning the intake manifold???
- arp head stud torque settings
- h22a nitrous!!!!!!!!!!!!!
- What can i use
- DIY : Causes of failed smog / emissions tests
- Im New to civics and i love HP!
- Single Cam Problems in tm Hatch :0
- where can I get CTR pics?
- *another* what should i get question
- secondary o2 sendsor wiring...please help...searched...
- Swap help vx into Dx.
- LHT performance?????? best cams for b18c1
- who installs Lsd?
- I can't start my car!!! Please help!!!
- are tenzo r short shifters any good?
- tein s-techs for ground control coilovers....trade?
- Need website with step by step engine removing for 00' civic
- question about kyb agx's and my springs....
- Auto to manual swap problems
- Where is the IACV on a stock 99 civic ex???
- s tech springs for a 92 civic hatchback any good?
- Gauge lights not working
- b16a2 ?
- How to install a chip for a p72 ecu
- b18b1 ls ?
- OBD2 check engine
- anyone know anything about OHLINS shock's ??
- Help with shocks!
- what does carb pending mean...
- Spoon Mirrors!!!???!!!
- radio serial # question
- does anyone know where to find
- parts that dont work / suck part II
- Will the d15b7 camshaft fit d15b8?
- speedometer
- Is it easy for a del sol
- How 2
- y8 running bad...??? please help!
- oil ring/new valve seals
- Header leak on sol.
- Rear disc question SEARCHED
- bent frame need a sheel of fix
- need a cheep frame shop
- y7 head to a y8 intake maniflod
- OEM Type R LSD Question
- Del sol climate control
- Compatible Transmission QWuestion
- 1992 Civic CX Cranks But Won't Start....Has spark and fuel....
- Car fires up for 5 seconds then dies after B16 swap.
- Skunk2 Fuel Rail
- gas tank?
- Who is this installer????
- tranny goes into gear but doesnt respond after disengaging clutch
- D16y7
- HKS Hi Power experiances
- OEM Keyless Entry Questions
- i need a color code. searched.
- Power Window Trouble
- Need help coolant flowing into overflow but not back
- need help reguarding the CTR cluster
- 95 civic si "optional" cd player
- D16z6 into delsol s 2
- front control arm question on a 2000 civic?
- Thump noise when braking
- Question for Skunk 2/Illumina owners
- Need help on sunroof.
- loss of hp or a + for backpressure
- eg condensor compatible to ek?
- Someone help with this stupid Code 14
- d16y7 or d15b
- installing HIDs... help
- help with radio install!
- Rear Lip
- Wierd "Knocking" from front suspension
- Tire fitting question
- spark plugs
- Anyone have a schematic of coolant system for 98 Civic
- bleed clutch - help PLZ, need this done fast :(
- Best LCA's to get for an EK?
- Searches Engine Infos / picture / Technical data over the JDM EK3 ( 3-StageVtec )
- what sensor is this
- Need help please read.
- AUTOCROSS/TURBO D SERIES QUESTION...
- Quick Exhaust Related Question...
- WANTED:D16y8 SWAP a.s.a.p (Chicagoland)
- Anyone drive automatic transmission?
- best cold air/short ram intake for lsvtec
- EG Trailing arm replacement issues. Help!
- interior swap ?
- Idle and odd wiring????
- smog station said my car was canadian.
- RSX calipers upgrade.. anyone?
- Is Ractive any good?
- pic request black hb on super advans black and blue
- What's Happening?!
- BEST CTR front lip replica
