- the mini me runs
- 99 si loss of power
- 94 civic wont go in gear??
- fast Camshaft question...
- Help... need good links to change front breaks on EG civic.....
- any suggestions on coilovers??/
- ap1 steering wheel in ek?
- Mini-Me Swap Help!!!
- Catalytic Converter HELP
- EG6 power lock wiring diagram and alarm install information
- Boost on stock internals
- Driver key-hole, what do I need to replace?
- Wont Start After Changing Head
- trying sumting new....
- Can't get 93 civic to run right. PLZ Help
- Deep Dish Rims help
- best way to tune 2000 si?
- HELP! How to get car that wont start off car dolly!
- smoking petty bad dunno what todo
- HONDATA S200 PROBLEM
- Code 45?
- need help on a b20 vtec?
- 98 civic ex no spark
- Help hooking up iacv from auto to manual. Please help!
- please help! b18b1 swap into 1999 civic ex a/c help
- exhaust question
- Picture request fmic on eg's
- 94 civic vx what do i need 2 install B16A GEN2 obd1 ?
- IACV Question
- My A/C belt is slipping on my 97 civic lx.
- If Anyone can Figure this out = reward
- Test pipe+CEL elim=tight fit
- Intake & exhaust. . .
- compression question
- [B16-B18] How to install a OIL Temp on the engine ?
- Info needed about a B Series Swap
- Power Windows!! 1998 honda civic dx!!
- d16z6 oil pan question....
- SRS code 92?
- suspension question
- parts from eg to ef
- 92 civic dx hatch won't start
- window regulator
- Canada, US or Japan
- Where can I buy an Exedy Clutch in the DFW area?
- Eeffect Apparel's V6 EG
- Aftermarket Horn
- b20b swap help
- vitara pistons on ls rods d16 help
- Question about SRS and Horn
- 97 to 00 front end install
- USDM Si Vs. JDM D15b Tranny
- B16 more power
- B18B1 accel hesitation problem
- gsr 4 door interior in EG 4 door?
- stupid vss! WIERD SITUATION.....
- b20v or lsvtec?
- engine ecu/harness questions
- Noise from tranny
- How-to: D16y8 Rear Main Seal
- 1993 Civic with 26,000 miles, should i buy it?
- Overheating issue
- hasport mounts
- d15 tranny on d16
- Domani CF hood
- new front lip
- Seats for Big Guys
- diagnosing help please.
- A/F Gauge wired but not reading?
- Slotted or cross drilled?
- ecu question
- 2000 Civic Si brake Calipers vs. 1997 Integra ITR Brakes
- d16y8 knocks at low rpm
- P28 ECU into OBD2 car?
- coolant leak issue
- Need help on ignition timming
- question about computer
- motor identification help please..
- how to clean AC fan inside cab?
- what speed does 1st and 2nd gear take you up too?
- lost motion holder. reply fast please
- D16y8 header HELP
- 92-95 eg exhaust measurments
- first time mini me
- automatic ls into a auto eg.
- 94 LS Motor Question!!!!!!
- SOCAL HONDA/JDM MEET TONIGHT!!!! EL MONTE
- To paint, or not to Paint??
- please read new to site and need help
- b16 bottom block and gsr head hoses
- b16 block Q
- NEED HELP ASAP
- Wiper motor
- Windshield wiper linkage assembly broken
- civic/gsr acting weird after recovery
- Super ALARM SYSTEM NEVER GET JACKED
- HELP PLEASE!! 94 Civic LX Turns Over but Wont STart!!
- i need some eg/ej help guys.
- ZC pistons on B7 block
- Will a Map Gas Torch Cut a Nut?
- Trying to learn more about my new car.
- ticking from inside the spark plugs why???
- 02 sensor wire rapped around axle big problems!
- Windshield wiper arm asshembly clips
- better gas mileage out of an eg
- obd1 HELP!!!
- Belt squeek help??
- ASR SUBFRAME VS LOWER TIE BAR?
- EG BODY QUESTION
- motor mount broken??
- Does the VSS control Odometer as well?
- Help joining tranny and block
- Do 1994 EXs come with no power lock or windows?
- What happens if....
- eg 4dr lx turns on and cuts right off after like 5 mins
- SOLID CEL help
- Remanufactured Calipers from Majestic Honda
- 96 civic hatch d14 CEL 16 "injectors" Help Needed
- CAT AND APEXI N1 EXHAUST PROBLEM
- 94 Del Sol VTEC Value
- ek hatch question
- is it worth it?
- OBD-I computer cable
- Gas gauge decided to stop working!
- turbo help please!!
- New to cars, would love some help
- intake and exhaust
- need help...steering wheel is locked
- NEWBEE NEEDS HELP IN ORLANDO !
- wheel restoration?
- Kings Bearings made of Tri-Metal or Bi-Metal?
- Need Help with new motor
- 96-98 harness in a 99-00 civic
- pictures of polished wheels on silver ek's???
- 99-00 stock radio in my 96-98 civic
- running but stalls
- Ex Wiring Harness
- Throwing codes: IACV and Water Temp Sensor
- b16a with out an o2 sensor
- ring lands and piston rings
- Flaking headlights?
- dealership or napa crank pulley?
- Dent Removal shops in Socal?
- Best Power Programmer?
- Z6 head on a Y7 block?
- which coilover kit should i get for my ek?
- eg fender pull DIY
- help with obd1 harness to obd2 motor!
- possible bent valves on 1.6 del sol
- 99 civic si automatic
- injectors
- Clutch master cylinders all the same in civics?
- P28 ECU A01 -> A02 problem
- D16Y8 Head Gasket Job Questions
- 95 EG coupe trunk fitment
- 94 Del SOL
- ACL vs. Kings Bearings
- Steel cable?
- fender bender Hood stuck
- 99-00 Fogs
- Little problem...
- Car shakes at 65 and over? help
- 1st 2nd 3rd 4..... uhh 2nd shit!
- stolen coupe
- d15b swap
- how is the JDM head liner different from USDM?
- Running like poop maybe internal fuelleak
- 99 DX Hatchback 98 D16Y8 Wiring harness Problem
- MidPipe Replacement Options for stock EM1
- Calling all Alignment experts. UPDATED! Scanned Alignment Numbers. PIC INSIDE
- Quick question about BAR?? NEW RULES??
- lug pattern
- Hit by SEMI... need help
- want to upgrade camshaft, valvetrain recomended?
- STOLEN BLACK EM1!!
- 2000 si cluster swap
- new to HT (veteran on honda)
- ek front lip?
- NEED HELP!! EG brake lights are not working....ideas??
- Need help with 97 GSR in 00 EK
- quick opinion for my 97 civic ex?
- 95 civic manual to power convesion
- Need help hookin up my halo lights!?!?!?
- power to manual windows questions.
- 99 civic si ?'s
- ARE DEL SDL STRUTS THE SAME AS CIVIC
- Engine problem on del sol with gsr engine!
- need help with a swap
- del sol leak
- Can this cause your shifter not to feel right (like popping ?)
- Civic si 00... Front end conversions
- just bought my first civic
- WORKS BELL
- Son of a Steering
- hyrdo clutch line help!
- valve cover bolt broke
- d15z1 in a dx vtec wiring
- Dream Del Sol
- Quick ecu/performance question
- engine type
- 97 civic lx trans issue help plz
- what do you use to clean b16 valve cover?
- new 02 sensor check engine light still on???
- WHATS A BETTER CIVIC?
- How many of you have weighed your coupe?
- P73 ecu question
- Need to get new axles, dunno which one to get
- CEL Oxygen Sensor help....
- cfk sensor problems HELP
- Help with my 94' civic ex
- camshaft question
- Tire size for stock steelies?
- 700hp for sale
- New to me Sol in the House
- people that dont use fitv help me out
- boosterless master cylinder
- gsr swap in del sol
- Hitting the junk yard
- Pre-wired Stuff
- eg6 jdm cluster question???
- loud ticking in motor
- B16: Strange problem
- ok taking a motor poll
- can someone help me
- how can i get my civic to throw a cel?
- Not rev-ing past 4k?!
- Car shakes violently when accelerating... why?
- chassis tearout with ASR subframe brace
- 98 civic ex Idle air control valve problem! Which plug do I plug it into?
- Electrical Question
- Having problems with my sway bars
- rebuild gasket sets 3
- ecu harness wire gauge and what heat shrink size
- 96-00 weight of Stock Hatch vs C/F Hatch with review
- cel code after code after code
- Valve adjustment on ZC engine
- 00 si rolling shell worth?
- EK Interior Question
- spark plug wires
- Missing Wires On HID kit.
- TPS? chugs only when warm? H22a
- 2000 Civic Si engine swap help
- How can i tell the year of this engine?
- what motor mount do i use d15b2 block d16z6 head in 93 civic ex
- chipping my d16
- Will not rev up after"B16 swap"
- Help not getting any fuel!!!
- A/C system..Low side...High side???
- Honda domani
- any good seat covers for an 00 civic coupe?
