- SOcket Side marker
- how reliable is a d-series turbo setup?
- Civic Camera Bar
- Brake upgrade for 95 coupe
- what size fuse for 95 sol si brake light?
- which engine to pick?????????help desperate need of help
- What cat to use on a b16a swap into eg wih apexi exhaust sytem?
- turbo fitment with integra fluidyne radiator
- City lights for our EG's...!!! (calling all ppl who have them)
- I need your guys help(engines)
- JDM exhaust manifold
- Tire Pressure
- Problem with my clutch
- Info Light
- Need new motor in Wa
- creaking noise from roof of del sol
- GSR rail fits ek with 3 bolts?
- PLEASE HELP ALL H-T MEMBERS DIG IN AND HELP!!!!!
- any body got a mugen air box in their EG?
- How to take off steering wheel?
- Just letting JDM Del Sol peeps im parting out my SOL
- <<<< Where can I buy a carbon fiber trunk? >>>
- **WANTED CASH IN HAND** civic with CTR or ITR or H22 swap PA or within 500miles
- wiring up vtec in EG. JDM d15b
- Yo
- LS MOTOR OR JDM D15B IN EG?
- motor?
- EG power window switches dead?
- JIC Magic Exhaust
- b20 with b16 head
- Need your advice, and your opinion on this EG
- need help w/ piston Question SOHC
- Trying to install power windows......
- DC5 VS EG6
- anyone heard of boring out main oil galleys?
- will a b16a2 jackson supercharger work on a b20 with ls head???
- O2 sensor ??????????
- where to find right color?
- Steering wheel moves left and right?
- does ur honda do this???
- Stronger Tie-Rod's
- jdm styled white eg hatch pics?
- help! plastic shield under bumper coming off...
- Guage Cluster
- best exhaust piping size ...
- eg exhaust to 99 coupe
- Autometer???
- need help for a friend
- Which cam for my Y8
- EG tailights...can you remove the orange part?
- EK drain plug
- do you like TANABE?
- please help posted in hybrid but no response
- Emissions Questions
- Xotic Motorsports Dyno Day (eye candy)
- **ENGINE QUESTION/HELP***
- xotic motorsports dyno day
- Ball Joint Ques....Searched
- EG and EK LCA?
- Need Help identifying injectors
- jb weld on exhaust system
- throttle body bore?
- Headlights won't turn on
- Struts for Neuspeed Race
- Rim Colour, PLEASE HELP
- 2 Concerns with Apexi N1's on a slammed car?!!?!?!?!
- Eibach pro kit springs or Tein S-tech springs~which is better?
- 3 Choices...HELP!!!
- car meet in MD
- what kind of rim do I have
- too much weight not enough motor
- Ac bracket question????
- Steering wheel clicks when I turn?
- ECU is HUMMING
- i need to pick a good tire.
- Z6/Y8 head on VX block?
- Who's on Tein Basics??
- headlights dim when I roll down a power window ??
- power steering
- 2.5" drop ona EG
- what is ur input on this hood?
- weird idling problem...
- Blue smoke when gearing down
- comptech sport spring rates
- difference between wiring harnesses
- How to maintain sunroof?
- Will this fit the 1999 Si rims?
- Sorry, another newbie question..
- 9.5 inches rotor up front w/ rear disc conversion, 15/16 master + Teg pv...need answers.
- Best place to find amber corners.
- Carbon Lip for 00 Si
- RIGHT HAND DRIVE
- Is magnaflow cat-back a good choice?
- shift linkage pin on tranny....
- JDM rear LCA
- CHECK ENGINE LIGHT
- Wheel Powerd Coating
- Axle Compatability
- 150$ Where to spend it?
- LS VTEC
- 99-00 si or delsol a/c bracket wanted...
- OBD conversion questions..please help??
- new purchase need help
- Windshield Wiper Part
- anyone have hookup for Del Sol weather strip?
- Paint Curing
- clunk noises when shifting...please help
- Hood Lock Hole Placement???
- intake leak
- Help with my Integra Seats
- ABS???
- Chassis codes
- car just dies after swap....need help
- Main relay clicking and tack jusping everywhere!?
- usdm B16 into a 1992 dx hatch
- what motor to pick
- Another happy GM Syncromesh user.
- Fuel Filter problem
- how hard to change pistons!!!!!!quick!
- WYOTECH, has anyone attended?
- help; integ dash and cluster into an eg..
- Horn Help! Already searched
- si rear section to thermal
- I'm about to buy some tein s-tech shocks? need input ASAP!!
- what do you think? 5zigen exhaust for a 95 civic coupe?
- Is this the right rear swaybar for a EG Civic? Please look!
- has anybody heard of dropzone coilover's?
- LS tranny with a 4.4 final Drive?
- RSX leather rears into my 92-95 SI hatch....
- Are Neuspeed springs good? anybody own a pair or know anything about them?
- Quick Valve Cover Gasket question. Searched
- 95 Integra GSR Throttle body
- Upper Bushings on Control Arms...
- Anybody know a good ignition timing for my D16y7?
- my exhaust!! what cha think?
- b20vtec hatch,is it worth it???
- can someone please run a carfax for me?
- anyone tried topspeed products??
- Alarm System
- Where to get new intake and exhaust manifold studs?
- zex 59300 cam timing
- B16 YS1 Tranny
- "ignition q's?"
- compression testing????
- Look what I got for $300
- Civic lip kits
- how much would it cost to get a flywheel and clutch installed?
- I need the plug that the VX 5 wire O2 plugs into. Anyone have one?
- new dyno run
- muffler problems
- D16y8 pistons in D16z6
- B16 YS1 Tranny
- check engine light & keyless entry
- Steering wheel doesn't lock anymore...
- Where is a good place to buy oem parts online?
- 96-00 civic coupe roof lining fit into 96-00 ek hatch
- 3rd brake light
- Japan EK minor BlinG.
- 1993 Del Sol Trunk Plans
- i wanna advance the timing for my engine...whats a good setting and does anybody know what it comes
- Project Acura 1.6EL Build-Up has begun
- good tires for VX rims (searched)
- My eg needs a lip!
- DYNO RESULTS: For my disappointing D16Z6
- EG Civics - how far does your sunroof open?
- Any use H&R Shocks?
- Has anyone tried?
- turboed my civic and wrecked on my b-day
- aka_ricerocket > pics
- Conversion to a DOHC Vtech motor!! HOW TO??
- I DONT GET IT~~~!!!
- keyless trouble
- another new guy!! pics of my ride.
- Can any civic owners confirm I've been screwed (I got a b16 head instead of b18c5)
- Whatcha Think?
- NEX full coilover system? good or bad?
- I NEED CIVIC FACTS PLEASE!!!
- Hey! nice to meet you guys........
- will a gsr backseat fit in an EK?
- 00 si dash into civic hatchback cx ?
- woot new toys for the hatch
- keep a/c or not?
- anybody running buddy club racing spec damper?
- woohoo lookie what my bid just won on ebay
- What is needed to make b20 complete?
- AEM Cross Drilled Rotors... 92-95 Civic...????
- Belt Tension - what is too tight??
- What are my OEM radiator optios in my EJ?
- POST UR EG WITH ITR SUSPENSION N RIM!!!!
- yO what does Ferio really mean???
- a/c removal
- civic ex-t vs. jetta 1.8t
- removing dashboard in a ek?
- Anyone put CTR pistons in there b16a2 with the stock rods?
- VSS problem (search but havnt found the answer) HELP!!!!! HELP!!!!!
- mounting hardware for OEM CTR rear lip
- This may be a stupid question, but.... (B16 internals)
- Are Tokicos any good?
- anyone bought a swap from hybridrevolution.com
- Back From The Track
- GET REAL VISIONS FOR $40 SHIPPED
- VAFC or Vtec ecu
- cold air intake question
- Picture Request: Apexi N1 on Sol
- how fast?
- cars cuts off at 30mph need help
- Does heat wrap help?
- TOKICO Blues
- pics of new shoes and a few tire questions?
- anyone have a pic of an eg with city light??
- What the best type/brand of motor oil to use....
- Buddy Club wheels
- Back in Black!!! (White really) :)
- track times...96-00 civic w/ b16a2...post em
- h22 fits in 96 civic right
- Del Sol B-pipe
- 1/2 red 1/2 smoked tailights on 99-00 SI's ?!?!?
- i need quick reference. on brake master cylinder
- CTR/ITR 5 lug conversion on EG.... questions...
- www.FixaRim.com any one have any experience with them?
- Shock application question
- where can i get cheap LCA's?
- eeky EK cluster question...
- cheapest place to get fluidyne radiater for crx
- Type R resonator on a EG?
- EG Stock Front Bumper... Mesh, how to....
- replacing oem LCA bushing on ek's
- 03 SI Seats in to EK
- 00 ex secondary o2 heater pinouts on ecu
- advance or retard
- Trivial: Horn Stopped working
- clutch master cylinder HELP!!!
- Del Sol Driving Lights Question...
- Integra dash in EJ, looking for how-to.
- 98 civic hatch back middle ac vent..please help
- My OEM HID retrofit: BMW 5 series D2R
- will i see any gains doing this?
- HP of a civic
- ex guages in cx
- Oil and Fuel Additives... Do they really work???
- jdmshit carbon fiber hood - gap on side - need help..
- how can you tell??!!?
- Length of AEM V2?
- ITR Intake Mnifold and TB install...
- what size pipe/resonator for type R muff setup??
- Brakes Pulsating... Problem??
- 92 cx engine problem.
- knockin? need ur guys opinion
- Hood from wrecker painted and bolted up
- charcol canister emissons hose routing??? HELP
