View Full Version : Honda Civic / Del Sol (1992 - 2000)
- colorado installer
- Timing Belt issue PLEASE HELP
- AEM Adjustible Cam Gear
- Rejected! what am i going to do?
- INDIVIDUAL TROTTLE BODIES?
- Speedo not working
- Bad e-brake.
- b20 or b18
- RSX Seat in an EK
- Civic H2B, advice
- Who sells 92-95 Civic Flared Fenders?
- floating motor
- 6 ekpedal kit
- STOLEN SOL IN MYRTLE BEACH!!!
- modifying eg/dc rails to fit ek civic
- After Market Cams w/ stock valvetrain
- why wont my car go pass 4k rpm
- o2 sensor what for?
- K20A2 swap
- E Brake trigger
- Question about Greddy FCU wires
- can i put an h22 in my 94 civic ex
- Stock 99 Civic Si Exhaust Specs?
- D16Y8... how much power can i get out of it?
- WHERE TO BUY GOOD PARTS ON INTERNET
- ek swap??
- i paypal $$$$$ if you can FIX MY CAR!!! damn Gremlins!
- EK HATCH
- P2P ECU
- I'm new
- Just bought a b18c5 for del sol...!!!
- ignition problems
- Will EG rear seats fit into EK?
- 98 ej8 tranny swap, seals?
- engine swap
- 2000 honda civic dx-------------acura rsx
- apexi ws2 universal NA sound
- ST Front Swaybar Install Help ...
- air fuel ratio gauge...
- Speed Sensor!!!
- wire harness B series
- STOLEN CAR: NORCAL 96 MIDORI GREEN EK HATCHBACK :(
- itr or si
- Low beam on all the time?
- 1995 eg hatch: built ls-vtec or turbo d16?
- Ebay Dizzy ...
- THE ACCIDENT!!!
- ls/v question
- will ep ctr carpets fit em1?
- Secondary o2 sensor?
- master cylinder
- firing order
- honda meets in maryland?
- Intake help please!
- MY 2000 SI
- battery corrosion...
- Tranny starting to fall off..!!!
- need help installing fog lights jdm on my ek
- Best cam for high boost
- Different B20 motor for a B20v does it matter?
- D15b7 to d16y7 Swap : Rough idle and questions about manifold compatibility
- map light wont work!!
- QUICK QUESTION! (Rear Coilovers)
- oxygen sensor problem.
- What rims is this?
- fuel pump
- suspension question!
- rear disc brake question
- check engine light after header swap
- turbo question
- what kind of clusters fit on a EG6
- TPS
- Needed some tech. info?
- NEED HELP.....EK
- strange rpm !
- Car shuts off ...
- turbos
- D16z6 won't start please help!
- Hey i need a whole new exhaust system from the headers straight thru..
- ht check engine light on ek
- gauge lights and tail lights broke
- b20 out of a crv going into a 2000 civic ex
- z6 tranny
- reving problem
- AXLE questions NEED HELP
- My EG is missing a rear sway bar.
- b16a project CX .......I have a few questions about the mount brackets...?
- error code p0420
- sexy EG idea
- quick qeustion , CEL light , yes or no ..??! b16a2
- brembo blank distributor in SD
- stripped ARP head stud?
- ? about swap price
- Fix ECU Code
- manifold cracked
- H22a swap into EG? shiftlinkage and mounts.
- fuel injection cleaner....
- b18b1 head question
- radiator... will stock fan fit
- Fule line jammed !! need help
- My engine has detonated!!
- eg sideskirts
- removing outer tire rod from threaded shaft issue, techniques?
- getting ready to buy my motor!!!
- d16y8
- header question
- Finally in here
- Blew my b16a2 :(
- question about eg foglights
- d15b vs d16z6
- TORQUE SPECS ON D-SERIES
- checking codes
- Evasive Motorsports
- New crack on the exhaust leading to CAT
- JDM p07 ecu??
- Bottom Motor Mounts 95coupe
- Help.
- Rules For This Exclusively TECHNICAL Forum
- how often do you change your rear pads?
- megan racing header question
- City Lights
- Part Number help....part from rear hatch.
- CX to DX
- weire noise..........on ek
- HX oxygen sensor
- Whats your car idle at ?
- anyone here of these?????
- Pistons Poll For the D16 - the Daddy of the blocks =)
- custom carbon fiber
- cheap, easy, often overlooked upgrade
- TURBO AND A/C
- VTEC PROBLEMS.
- tps interchangability
- Hard time finding !!!
- z6 intake mani on y7
- d abreak pad question...
- short shifter with a h22 swap in my eg
- jdm d15b cam on a d15b7?
- Will I need a o2 sensor simulator if I am buying headers and a high-flow cat?
- z6 crankshaft on a y8 motor??
- 96 civic rough idle and CEL
- what needed? 92-95 civic swap from d15 to a d16 sohc vtec
- need help finding fuel pump power wire
- Where can I get this oem spray paint!!! Painting sideskirts and molding....
- ecu question
- Which ARC Splitter for my civic????
- :: anyone run skunk2 pro cams in b20v w/ JE Pistons ::
- EG FORSALE CHEAP GSR SWAP (sorry guys...)
- Engine swap choice for my 97 civic ex coupe... Need more info on my potential choice: b18b
- Worried about your car being stolen, or have you caught someone trying to steal it?
- b18c vafc is better than a chipped ecu
- vafc on a b18c
- 1997 Civic???
- IDELING HELP PLEASE !!! ?
- Noise from right rear wheel - need diagnosis
- ek with gsr.........
- I NEED HELP! swap problems
- i need help with my ek
- am i getting ripped off?
- turbo b16?
- rsx or ep civic steering wheel into EK airbag mod
- ICB?
- ABS light
- City lights? huhhhh!
- eg front lip
- Start up and idle problem?
- injector obd1 or obd2 HELP!!!
- how many omni rear camber shims do i need to use?
- Installed tach
- Need a Tuner
- any ideas for my ek?!
- What should I do next?
- White smoke out of exhaust. Could it be because of no catalytic converter?
- Parts list for D15B8 to B7 Head Swap
- Help! Steering or Alignment issue. Trying to diagnose.
- FPR Question
- Need help finding some parts for my EG
- what sensor is this (96 civic ex)
- Please help a noob!
- Today I joined the club: 95 B18 civic hatch
- Interior Question
- ok got some new questions
- ** BLOWN HEADLIGHTS **
- TL back seats in eg
- control arm
- grinding noise
- Cluster fitment
- b16a shift linkage
- main input shaft bearing part# 4 96 dx
- light problem
- 1995 civic si?'s
- Difference between D16Y7 and D16Y8
- Should i buy these? Difference between ebay and autozone gasket kit?
- o2 sensor ???
- wtb rims in ct
- To all DEL SOL people...Help Please!!!
- varify search please: a d16z6 vss same as b18b vss?
- Question about my Si's transmission
- wire harness for manual
- Suspension Problem (?)
- Sup guy identify object i know its a manifold just where does it come from???
- How to remove moisture from the inside of my tailights?
- sway bar noise?
- JDMlyfestyle
- 92' Hatch STOLEN!!
- Neptune RTP came in!!! YAAAYYYY!!!
- clutch??
- Modifying Seat brackets?
- Help with parts
- A/C removal
- honda hatred
- 92 Civic Hatch Swaps
- 2door/4door eg front end difference
- What size bolt / washers would I need in order to raise my car hood?
- NEED HELP ASAP!!!
- jdm or usdm?
- Civic Rear Bushing/brake noise?
- Fule pump not turning off
- School me on Honda engines... plz
- Greddy Turbo charger at 7PSI, or JR super charger?
- 97 EK LX question?
- hid ballast double fire?
- ABS swapable?
- motor overheating
- searched - 4 wire o2 sensor to fit 2 wire HELP!
- tune for flames?
- GS-R VS. Poor Man Type R VS LS/VTEC
- RSR Products
- Dupli-color trim Paint???
- Axle question for swap. Check it.
- Black Hatch with ITR front end
- Clutch Pedal is on crack, and a little bit of heroin n weed....
- Anyone know a place for brake/light inspection in so cal?
- Strange Gas Leak
- Check Engine Light in second gear
- B-series oil pan question
- Newcommer
- changing driver side top mount bushing
- Gasket Question
- question about rims (mounting and balancing)
- d16y8 header on a d16y7?
- ***ECU dead?!?!*** Help me figure it out...
- Trunk hard to close. 00 EX Coupe.
- # 2 missfire
- rear disc conversion question.
- EG + K20.... what exhaust will fit?
- o2 sensor??
- low idle in cold weather
- Why did my quarter glass randomly shatter?
