View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Steering Wheel Vibrates!!!
- what wire for dash lights?
- LS-V swap need help!!!
- point me in the direction of.....
- engine dies after startup
- What is the best swap for CIVIC? -----B or H-----
- troubleshooting a 93 civic 2dr coupe ex no FIRE
- Clutch Shake
- Some AC questions, regarding D and B interchangability and a JDM y0 question
- what is the best suspension for my 96 civic coupe w/d16yy8
- B16a swap questions.
- B16 vs. B20
- keys
- stroking b16 help
- motor swap help!
- NEED HELP PLEEASEEEE civic a/c system
- fuel pump experts!
- tach wire location,92 hatch
- VTEC
- 97 del sol exhaust help!
- more dynos!!!
- Radio placing question EK
- non vtec head to vtec not a mini me though
- 95 civc dx to obd2 motor
- EG-EK B16A WIRING
- PS ?
- cleaning injector resistor box?
- DIY cooling plate
- B18c1 swap in EG with p28 IAB question
- Compression question??
- Transmission Problem(s)
- AUDIO REWIRING '95 civic EX
- will a crx aftermarket fuel pump work in a EG?
- CTR vs EK HATCH
- 98 CX hatch front and rear brakes converted to Integra
- civic si turbo, but radiator fan is too big?? hits turbo, please help!!!!!
- civic type r pedals
- how to identify this computer box???
- EG hatch with h22 help!!!!!!!!!!!!!
- skunk2 racing coilover kit question
- why is my idle so low???
- EG civic knuckle same as DC2 / ITR ?
- d series tranny and b series tranny
- Wierd Smell
- need help installing safc version II
- need some help!!!!!!!!
- grinds when shifting into 3rd and 5th???
- Hi all i just got my first honda!
- 6.5's in a 00 Civic?
- rings or headgasket?
- prelude seats in 2000 civic coupe help!!
- gsr swap blowing smoke!
- Horrible alignment issue after rear disc conversion!
- loud chatter noise in gear driving 99 SI? (searched)
- Quick Header Question
- 92 Civic Bumper Question
- Swapping Chassis Harness
- this will make you laugh hardcore
- PRO CLUTCH?
- honing question
- $50 Ebay header?
- is it worth it to drop a base model K20?
- Droped EG= more body roll?
- fuel pump ratings!!!!
- need wiring diagram for fuel pump!! either electrical prob. or dead fuel pump
- d16turbo vs all motor b16
- Vtec problem: cel then no cells??
- WTB: 92 CIVIC Rolling only
- I searched but can't find help.. idle problem with A/C.. HELP!
- EG Si Odometer and Speedometer issues
- where does this line go?
- Speed Sensor/ Fuse Problem
- Blue Smoke
- where to mount msd sci ignition
- door trim
- Guage Cluster/clock/turn signals not working at all, need some help please
- clutch
- Gas meter floats alot
- .... ALREADY searched... ? 00-99 EK fog switch color....
- 98 integra lower control arm
- if u had 2k to spend on a stock 97 ex coupe .. what would u do?
- oil pressure vtec
- opinions please...
- CAR DIED!! 2 Major Codes - crank position sensor , top dead centre sensor #4 / #8
- Anyone order from JDMCARS.COM before?
- Where can i buy Laminex?
- 1.6el exhaust on a ek hatch?
- 99 master cylinder on 92 civic?
- vtec controller
- What do the turbo cars run in 1/4?
- Ever Welded Pulley to Crank??
- Finding out what Year Engine
- Help diagnose - 98 stock civic, Noise coming from wheels when turning
- bought a hatch and need help in a lot of areas....
- Doors and hatch for sale
- Engine Buildup Questions? & Suggestions!
- GSR Blocks and B16A head... need help with internals...
- Conv harness not a/c compatible??
- RHD...Is it worth it?
- Does anyone have a rack & pinion bar from a type r?
- Engine Q
- Rear Eg Sheetmetal
- y7 haed on d15b7 block will it work?
- exhaust question
- The Perfect EG sedan!
- b series injectors in a y8
- Cruise Control light stays on, but I don't have cruise control lol
- Rear Driver side is lower then all the rest?
- 99 Civic Si into the 13's
- stock bore for d16z6
- hood latch ?
- at high rpm my car sputters ???
- y8 head on y7 block
- GSR swap i/h/e + 2.5" straight back, why is it so quiet
- 92-95 civic Rear disk swap question.. Need to know about Suspension..
- Rebuilt motor, oil pouring out when I started it for the first time
- Where do I buy this?
- 1992-1995 EX brake question
- thottle bodies
- clutch for b series
- f1 race car exhaust
- Need Honda expert on this one...
- pcv valve location?
- What MPH at what RPM??? like 55mph in 5th gear whats the rpms
- cel 43
- 102 ron. is there much point
- should i use a 99 si brake master cylinder or get the correct one?
- Civic EX and Sol SI tranny question...
- what throttle body gasket to use for 92 b16
- OBD0 b16 into delSol w/obd1 harness; Plug unused??
- which clutch to buy
- HELP...CEL CODE 4..CAR IDLES FUNNY...
- New SH!T for my sleeping beauty (teaserrrrr shottttt)
- Wirein!! 96 civic swap with jdm b18c
- Anybody need some seat brackets?????
- Do I need a by pass valve?
- Bracket / Rails for Corbeau Seat FX1Pro
- install: power steering rack
- Very quiet, constant ticking on em1...not lifters!
- Smoke Coming from under hood and exhaust lots of smoke
- knock sensor needed or not???
- What would you do?
- what intercooler piping will work and you can keep your jdm fog lights???
- lowering springs for stock struts?
- VSS problems after clutch install?
- IS hot weather cause for funny starts?
- Tps code questions,can it be adjusted?
- Where to buy t- for mech. oil press. gauge
- D15 Gurus Answer plz
- WindShield FRONT NEW !!
- computer code.....
- Shoppin for civic
- Ok to by a used a/c compressor
- Trouble with cam timing and timing in general.
- Brakes gave out!!!
- EG6 brake conversion, whcih wheel bearing to use?
- window stuck on 99 si...need help asap!
- auto to 5 speed
- Does anyone know what kind of these springs are?
- vtec???
- Is this bad?
- Quick Question regarding years & body
- Tranny experts!!!!!!Syncros bad?Clutch or what? I did a search please read
- which a/c compressor do i need? 94 delsol vtec
- just bought the car...
- How does this happen!! (y-80 trans)
- Power steering rack leaking on 92 civic dx... please help
- Is this for real? Got it out of my EJ project.
- Fuel Pump????????
- Is this ECU OBD2a or OBD2b?
- boomslang adapter
- saving gas?
- What is OEM throttle body gasket made out of?
- Replaced pass. axle, now alignment pulls right?
- ok to fill different oil?
- Problem
- Cable D16a6 SI transmission into a EG civic... Please Help me ... !!!
- Identifing LSD!!
- Climate Control Removal Help!!
- Emission guys...ebay high-flo cat converters?? or are they just useless resonators....
- hrm alternator problem
- HELP PLZ ANYONE that knows about civic's///PLZ!!!!
- Different Tranny's?
- JDM EG6 cluster problem
- over fueling???
- B16a2
- under gas tank exhaust pics please
- Just HAD to share this one!
- vtec wiring question
- front and rear weight of a 1992 civic hatchback
- wats going on
- Are aftermarket lower control arms nescarry? Read further...
- Should I wait for a OBD1 ecu w/map for my car I/H/E only 00 Si
- Ecu fuse blows
- part number trouble..
- SIR doors on 96 civic hatch
- sohc vtec
- itr cams into a b16
- CEL With Code P1508. Please help ASAP :(
- FREE $50 TITAN POKER ACCOUNT. NO DEPOSIT!!!!
- Install suspension, driver lower then pass?
- quick question about vtech controller uninstall
- does any body know if they make an intake manifold for 1998 civic hx
- Spoon Calipers
- OEM Plastic wire tie downs?
- MisFiring
- window problems, what could it be?
- 96-97 ITR steering wheel fitment???????????????
- valve cover problem
- am i having a problem w/ my ex tranny or am i crazy?
- mismatching tires
- engine damper
- USDM vs. JDM Window Visors
- wire harness
- Blown Wiper MOTOR: Need Help
- help bad clickin sound.
- Fuel Press. Regulator Gauge leak...
- field vtec controller .anyone with a wiring diagram for a 96-98 civic
- where to get a good set of motor mounts?
- Engine almost stalls...
- 00' si needed
- H&R Sport Si or Non Si ???
- What all would i need to install the stereo into the cup holder area place?
- syncros again!
- j30a swap
- tranny ?
- Crunching sound when clutch engages?
- just got my first civic
- 02 sensor BS!!!!
- HELP: A/C swap in my EK
- 98 Integra GSR armrest in EK hatch?
- Single Cam + N.O.S.
- Brake's
- LS Swap
- How do I installe Honda Access Window Visors on my EG?
- overheating..... need help
- What kind of swap
- pulling hard to the right after lowering
- D2 or Tein Super Street
- blown head gasket - getting new motor
- Daily Driver
- i got a gsr motor and i need a new tranny...whats better b16 tranny or gsr tranny?
- what is up with my engine?
- cleaning corner lights
- Quicker car by taking alternator belt off??
- CRX HF 8-valve cam into a 92-95 CX 8 valve head?
- does any one know if they make an intake manifold for 1998 hx
- will 1998 ex trany help any on a 1998 hx
