View Full Version : Honda Civic / Del Sol (1992 - 2000)
- How to change Spec-D Halo bulb?
- budget build,
- Help!!! ac belt smoking/motor is overheating!
- (pcm) powertrain control module help!!
- 05+ Acura RSX Type S Muffler fit on EG hatch?
- car shakes when braking
- P1457 code problemo
- SI CLimate control and Cleaning the engine bay?
- Seats
- d16y8 leaking oil -help!- video
- valve adjustment on stage 2 crower cams.
- Need help, questioning Type R steering wheel fitment
- P.O.S. Tires
- 4G63T into EK coupe questions.
- running jus a lil bit hotter than normal
- HOW TO INSTALL A STARTER B16???*HELP*
- Something really Wrong!!
- broke bolt off in rear suspension
- Ek type R CF lip What do you use to drill holes?
- New Here..
- cutting your stock springs?... to lower your car
- obd2 harness longer than obd1?
- possible to open door panel with door shut?
- 99 civic's tires
- !need a walk-thru on replacing stock pistons with high comp.!
- Clash Of The Civics - VIDEO
- B18C5 into a 97 Civic EX
- Oil in Intake
- P1607 Code Help!
- car won't start, battery over 12v, turns over...
- B18B swap wont start!
- 94 civic d16z6 PCV Valve location With PIC
- 205"50"15's problems
- Best spark for high compression?
- Help me with my dilemma
- race questionsss
- bad temp send sensor
- Lost heat in car????
- kind of excited, finished my headlights
- this is getting to be sad
- which x bar
- busted hose
- taillight 2dr and 4 dr swappable?
- Blower Motor help
- WTB: TURN SIGNAL LIGHT 99-00 hatch
- 94 Civic D16z6 spark plug tube seal question with PIC
- Perry Hall/White Marsh, MD Car broken into
- are there eny problems with exedy stage 1 clutchs
- JDM OBD1 B16A Vtec Solenoid Gaskets Part Numbers
- What is the diameter of the fog lamp in 99-00 Civics?
- eg power window conversion with ek parts???
- Car can't hold HEAT...Need HELP!!!
- wheel cylinder replacement????
- h22 into an ek coupe
- d15 crank pulley bolt
- swap bogging now dead
- Good Place To Buy Parts.
- spark plugs
- Y8 intake manifold swap
- quick temp and tps Q?
- engine build q's
- smoking still after replacing valve stem seals
- climate control lights
- Why do you swap engines in your Del sol?
- 93 honda del sol HELP
- modification program
- 95 Civic EX wiring harness
- Eg custom exhaust- What setup
- Just wanted to say
- foglight housing
- Pulling a D15b7 & A/C
- 200k mi: is this worth it?
- Climate control problem with my DD. Need help ASAP!!!
- injectors
- RPM's bounces up and down a few 100 while driving?!!
- bad gas mileage.....=/
- ein springs backwards?!?!?! HELP
- Do I have Hasport axles?
- removed A/C, no heat or radiator fan???
- strange noise from engine compartment on high speed
- major issues with wife's '97 1.6 sohc vtec
- redline problem
- 92 EG SI HATCH- HELP COMRADS!
- Random wiring question.... fuel pump related
- stange problem
- Power Folding Mirror Wiring (But with an integrated relay?!?)
- how do i fit integra rear seats in my civic4dr?
- running on 3 cylinders?
- replacing del sol gauges
- is 96-00 civic alternator work for 00-99 civic si?
- Timing belt?
- spoon vs. SpoOgeN
- *96 Silver Hatch stolen*
- 2000 Civic EX Brake light problem need some help asap!
- axel help
- Will a Accord distributor fit a Civic?
- Del Sol Seats in Civic and Vice Versa?
- disabling oil pressure light ?
- HELP!!! fuel pressure at 45+ with B&M guage!!
- 2000 Civic Coupe: Type R rear lip installation?
- GSR vs. B20vtec on a 2000 coupe
- Z6 Swap...issue with belt Whine/Loss of Power
- random swaps for eg's and ek's question
- b20 into a eg hatch
- 99-00 Civic Fog Light Install
- Need help cutting bumper on 98 ex for depo fogs
- Does Window Motor from Civic fit Del-Sol?
- Is the replacement ECU compatible
- 08 Si seats into EK
- thread size on seat bolts?
- ABS or No ABS
- p28 in a 98 ej8 ques....
- Integra Front End on a Civic
- which ecu
- motor surges
- HELP! LSVTEC SWAP 2K RPM HIGH IDLE - FUEL PUMP WONT KICK ON!! HELP
- Diffenrence in moldings?
- DB Integra seats into my EK hatch
- Head light dim + HIDS
- what is the right fuel pressure?? quick question
- Honda Civic 92-95 EG/EH/EJ OEM Cruise Control Install Guide – Manual Transmission
- As much as possible.
- Motor throwing out oil....????
- recaro seat question
- looking for an aftermarket exhaust.
- ek carbon fiber trunk help!!!
- rear camber washers on eg
- idel problem
- 93 EG Si Hatch need front brake upgrade information...
- 95 coupe WONT REDLINE ???
- skunk2 springs
- Mugen Rails on DC5 Recaros
- Loud noise from Rear axle at high speeds
- NEED FOG LIGHT INSTALL TEMPLATE for 95 civic EG
- p2t or p72 for inspection
- HELP!!! just got a new project and no lights on the dash
- Should I replace my CV boot
- vibrating exhaust when it rains???
- gsr head help..!
- what wires should i use??? suggestions!!
- How to install cams?
- selling someone z6 motor for there dx? problems?
- Trying to put cruise on a 97' dx
- Factory mounts vs aftermarket?
- Question about tune ups (real stupid question)
- what harness do i use
- Brake lights stay ON with CAR OFF HELP!
- need help want little info civic 96hb
- 200 civic lx auto swapped to a b16
- Can someone show me a pic of coolant in your oil?
- What intake are you running on a gsr swapped EK?
- I need some headlights
- Rear GSR Leathers into 2000 Civic SI?
- p28 issues please read!!!
- ej2 GSR redline at 6500 RPM?
- Car hit by a RPG, now time to part out... A couple of questions.
- what is this car?
- New to the honda brand, swapped del sol
- Will a Rear-Disc Conversion from a DA fit EG coupe?
- funky idle please give advice
- stupid question
- What are these relays and wires for???
- Honda Civic 96-00 undercar fuel line exact size
- CEL?? Exhaust related
- how to: replace door lining
- b16A2 swap problem....wont fire
- oil drain plug size?
- obd2 distributor question.
- 94 civic coupe exhaust
- Custom Gauges? Do tell!
- main relay
- Options for D16Y8 replacement
- Acceleration Problem and Popping noise
- HELP! Just installed B16A into 00' Si
- Steelies on 99 si?
- engine burns oil... reccomend diff. brand & viscosity pls
- sus. problem 95 civic fourdoor
- -92 integra SEATS into a 96-98 Civic-
- help under hood fuse box 97 civic
- Simple question for you northern peoples-EM1 related
- Civic just dies
- Dash lights
- boost problems...
- How to check for Genuine Distributor
- Check Engine light not coming on??? (not bulb or cluster)
- battery drain
- Want To Buy 1992-1995 Civic Coupe Shell
- !!!!SIMPLE QUESTION!!!!***EG GURUS***
- Make the ticking noise go away!
- Turn signals not wokring but Hazards do
- out of plain curriosity...
- Anyone in Southern Cali (preferrably) offer GOLD dipping services?
- EG axle back fit on a EK
- (n00b) got a D16A SOHC non vtec can I do a mini me swap with something and get vtec?
- eg hatch bumper skin on 4dr?
- integra seats
- My new JDM SiR
- 1996 ek Drips Coolant - Bum Water Pump?
- What seats are these? **EG Guru's chime in**
- car stalling
- obd2 d15b swap info
- DB seats into eg hatch?
- JDM Civic Hatch SiR bumpers...
- ls/cr-vtec vs poor mans type r
- JDM Civic Type R Interior color....
- Need help! Brake/hazard light issue.
- 95 CX o2 sensor help
- Very Strange Stereo Problem
- To bore, or not to bore?
- heater controls
- koni/ gc install
- Help - removing side moldings
- DEL SOL HELP..
- LIGHTWEIGH FLYWHEEL COMPARRISON ?? experience ?? HELP
- idle problems
- Howlong is this tranny compared to si or vx ? TRANNY QUESTION ?
- d15b7
- wierd sweeky when extreme cold weather from the engine(from the timing belt area)
- dim lights
- Help - finding a skidplate
- <<Brakes problem>>
- help! turbo 99 si problem!
- quick question
- Car wont start need help
- pic request
- 98 Civic Ex with drum brakes swapping to rear disc & keeping ABS **Questions**
- !!!!!!SIMPLE QUESTION!!!!!!!!
- Would these fit my rims? HELP
- Getting New Suspension
- best way to break in a new motor.
- idle and cel issue 98 ex. Yikes
- Ferio Thread
- Injectors cut in and out. H22a swapped eg
- 4-1 or 4-2-1?
- quick question on 96 hatchback
- car starts for 2 seconds then dies (HELP!!)
- lag at 3k swap problem searched
- b16a2 oil pressure switch block thread size ?
- Problem with idle
- cant post pics why??
- 97 dizzy
- crome? HELP!
- 99 CIVIC SUSPENSION Question
- Help - removing bumper stoppers
- HOOD WONT OPEN
- Are all B-series starters the same?
- Oil change capacity '97 HX
- cant go farther than 4-5k rpms, sluggish, help!!!
