View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Will a d16y8 lsd tranny replace d16z6 tranny?
- 1996 Civic Coupe Knock Sensor (D16Y5)
- ECU question
- Axle fitment issue
- d16y8 and d16b help
- Del sol/Integra Springs
- Im stumped. How do you check fuel pressure eg hatch
- Best d-series head?
- Indtroduction
- D16Y7 ECU questions
- FML my hood won't close.
- pos car runs fine not moving but after you drive it for 5 secs acts like starvng4 gas
- Sound when braking.. bad rear axle?
- any one got one of these they dont need any more
- Need help with driveability problem.
- Wanting to Go Ls/Vtec in the EG Hatch!!!!!
- engine problems i need help
- Squeaky EM1 front suspension
- Car randomly starts after dead battery
- b16 swap??
- CEL..counting flashes to get code #...
- H22a smog fail due to VERY HIGH CO, HC.. runs perfect tho
- How to reset your srs light diy!
- Jdm OBD0 b16a into OBD1 Eg Hatch Questions
- Wheel Bearing question
- ek sedan roll bar??? Help!!!
- piston hittin cylinder head! ????
- REAL QUICK: Motor Mount bolt size and length
- Upholstery Fabric Spray Paint V.s DupliColor High Performance Vinyl & Fabric Coating
- error 18, 54 and 61
- plugs and plates
- *NEED ASSISTANCE* Thermostat housing related
- emissions help, cat
- Fuel Pump? Whining! 99 EK
- ported polished head, stamped by JG Engine Dynamics - pass BAR/smog?
- FML my car died.
- power steering after swap
- Will EG or EK piping fit on my EJ??
- fuel problems?
- MINI ME!!!!!!!!!!!!!
- My Pre Face Hatch
- Civic Running Very Hot
- Starter won't engage
- CA BAR swaping from ob1 to obd2 motor questions!!!
- rpm bounces up n down at 2500
- RSX Type S muffler on an EG?
- What should i do?
- Painting interior this winter break
- Engine Smoking Oil
- EGR???
- f@$%^&* surging
- Fixing Threads on Seat Bolts
- Megan Racing oe exhaust on eg
- DOHC VTEC engine harness for 96-97 delsol?
- hx 5 spd swap problems
- I have a 95 civic 4 door now. What swap would be the easiest? I want to put an H22 in
- engine code help
- swapped a 1.4 to a b18c (fuel pump)
- H22-ek linkage and hoses?
- Found a 2000 Civic Hatch
- wait, there's only one shims per side / brake caliper right?
- HELP! Cable disconnected from Trunk Latch. Advice?
- well HT im back heres my build thread
- FS/FT Purple H22 EK
- Bride short shifter
- Shaking at acceleration!?
- Transmission Question
- OBD2 to OBD1
- eg with carpet or no carpet ?
- driving with no vtec
- NoObIe HeRe!!!
- Help with Raybrig Rear License Plate Garnish ? Plate Holder for EK?!? -PICS INSIDE-
- Water temp gauge UP and Down
- Can someone help me identify this 3 wire plug
- Sputtering Problem???
- Mini Me swap problem
- Will a cx ecu run a D15B?
- 96 civic clutch question
- Head Gasket issue
- 1995 VX Side Skirt Screws
- 93 vx cutting out
- MY civic wont start!!!!
- clutch install..
- 1994 civic hatchback start problems!
- could i put ef struts and springs on a eg and vise versa?
- obd1 to obd2 wiring problem
- Car idles at 1500rpm
- 95 eg hydro clutch, clutch pedal adjustment.
- s2000 gauges
- Can an EK invert its stock tie rods?
- SOHC Supercharged??
- 94 Civic DX Coupe - Brakes...?
- the correct CEL bulb size...
- my sol wont start wont crank just a click
- jdm 4 dr cluster
- what seats will fit
- am I supposed to cut these?? 99-00 dash conversion
- VAFC problem
- WHAT EXHAUST??????
- 96-00 Antenna on a 92-95 Civic?
- ecu
- ported blox manifold
- Anzo tailights oem style
- speedo issue after swap (searched)
- B16 Turbo HELP!!!
- which computer would run better with this setup?
- B18's and vtec
- chipmunks in engine bay and inside car?!
- d2 coilovers
- camber kit
- New to HT, not new to Honda's
- del sol subframe...HELP
- opinions please...boost soon to be d15b or h2d swap??
- Issue With Brake Rotors Warping
- Lightweight EG 4 door questions.
- engine stopped fireing while driving 93' delsol
- Hi all new be here looking for help!
- can anyone tell me the difference in the brakes
- brake pedal requires more push than it should?
- swapped 99 honda civic PROBLEMs
- Running temp/heat issues
- 97 y8 block on a 99 y8 vtec head?
- Sway Bar
- help with eg mounts
- heater problem
- Del sol door problems
- EG VTEC SWAP HELP????HARNESS
- JDM ash tray
- D15 to Y7 swap???ECU?
- Turn signal acting weird
- Planning Renovation, Need Input
- Finally Dumped
- Supercharger prob
- NEED URGENT REPLY IN REGARDS TO HINGES!
- Good All Around Tire for HX's
- '98 EK weird heat/ headlight issue...
- Bogging Issues! Need some Input!
- Getting spring grinding noise when turning wheel?
- Rods/Piston
- DOHC Dseries in my eg
- Buddy Club Seat Question..
- Help b16a2 won't start! (Stolen Recovery)
- 4 Dr. Corner lense on 2 Dr?
- 96 civic VSS problem with dimming lights
- MAP sensor from a differant engine okay?
- read sticky on CEL, quick question on the #4 step
- R-Speed.com?
- EG Hatch DX Cigarette Lighter Question
- Code 63 (Secondary oxygen sensor circuit) fix?
- Cause and Fix for milky residue on oil cap in cold climates
- New to HT, got a del sol
- Civic steering leak, where to start?
- Possible CV joint problem, need some advice
- Compression info
- Any good books on Honda EFI?
- tranny wont go in gear
- help reading CEL code...
- Stole my car for a joyride!
- Which shifter bushings should I get?
- Quick coolant question.
- Just checking...
- Need help car wont fire
- instrument lights.
- front suspension question...loose steering
- sunroof replacement....(ive searched)
- Rear Quarter Glass Install - EK Sedan
- sorta new but not...lol
- manual to power windows ???
- OEM Jack Location for EG Civic
- will 98 coupe parts fit on a 95 coupe?
- Are the doors the same???
- Need help with part #'s
- 93 civic EG sedan...CAR WONT REV OVER 3,5..help
- D15B vtec setup
- What's wrong?
- Any way to "fix" a stock steering wheel....
- cluster question
- what is this little dingus...?
- Will ITR rear lower control arms fit EK?
- CIVIC rev limit 5700rpm
- d15 SES light after idle adjust
- Whats up HT! New to this, Suggestion to engine swap? (+My story)
- DAMMMM
- a6 crank z6 block y8 head z6 camshaft and gear timing issues
- 2000 dx harness problem
- BLOX Spherical Trailing Arm Bearings
- Spark plug wire keep poping out of cylinder NEED HELP!
- What is the order of the spark plug wires for my 94 civic ex?
- 99 Civic EX Headlight problems
- Help EM1!!!!with whinning noise fuel pump???
- EK Seats
- Help:Auto 96 ex harness on B16a2
- timing belt question?
- help! clunking sound
- turboing d16z6 motor need help!!
- Civic future mod list, input needed
- d15z1/y8 mini me questions
- MiniMe question
- Question for the EK guys from a dubber. (Fog Lights.)
- OBD2 or OBD1??
- need help with motor mounts
- wierd electrical problem
- rear suspension help!!
- axel boot
- Questions
- delsol locked out
- Door Lock problems need info
- No Power After 4k rpm
- Spoon Replica Power Mirror Wiring
- D16z6 crank into a d16y8
- OEM big brake upgrade
- need help asap
- 99 ek tranny swap help needed
- Need a little help
- Help - Car not starting
- zc vtec.. from what car?
- in need of some wiring help
- Bad Headgasket?
- d16 swap headers tooo short???? help
- 1992 Honda Civic DX engine knock
- 96 ek no start..
- Fuel Tank pressue CEL.
- 98 Civic Mini-me Hunting Idle
- ek B18c1 swap mount issues help
- p0700, wont pass emissions, but what if??
- b swap shift linkage problem
- Something really new to me,after a great deal of stop and go driving the car lurches,
- b20vtec question
- Steering wheel question
- Anyone have the part# for D16Z6 rear main oil seal?
- Front LCA Qestion.
- radiator fan probs
- ek sideskirts on eg
- Help..p0505 code
- removing stock gauge cluster
- grinding noise while turning left
- 98 Honda civic over heats, now throws constant cel. Ect ect
- What is too old to be driving a hatch?
- which ecu to use???
- Torque Specs
- 96-00 Exhaust On Eg Coupe?
- vtec oil pressure switch connector
- Horn and brake light fuse keeps blowing. Help
- New Member !
- putting ac into a 98 ek coupe gsr swap
- dual cam D series in eg?
- Did I get a good deal on this car? 2000 swapped civic ex
- California CARB Parts information
- please help 1996 ek hatch swap ?
- Looking for a VX rim. help plz :-(
