View Full Version : Honda Civic / Del Sol (1992 - 2000)
- ctr n-1 pulley
- B16A Head, Vtec Parts Into A D16A8??? Issit Possible
- smoke when its cold?
- NEED HELP WITH GAS PEDAL PLEASE
- where is the diagnostic plug at on my EK?
- This may be a dumb ?
- Anyone have a link to green-bottle HB video?
- HELP...need help troubleshooting code 43
- New Engine Came
- bov sound..but no turbo?? help
- SPARK PLUG WIRES????
- Need Help (turns over no start)
- Cusco licence plate relocator
- What is the best rear brake conversion for the EG6
- Brakes makin a weird noise :-\
- JDM D15B
- people from ct
- power windows?
- Where can I find cheap OEM headlights?
- Speedometer seems off
- Rod size
- amber corners or stanly clear corners
- MOtor Mount..
- steering swap?
- hondas steering real sensative, or do i need an alignment?
- o2 sensor question
- quick question about h&r springs
- Will Integra mirror glass fit in JDM CTR folding mirrors?
- New Piston Questions
- Ratteling Noise?
- Tranny removal problems driving me nuts!
- OBD1 Distributor onto OBD2 Motor
- Flywheel Question
- OEM headlights
- got my blades . .
- Autopower Rollbar - Hatch vs. Coupe
- Inline Four Rip off
- Crappy Radio Reception and loose center rear mirror
- .....I searched....headlight removal question.....
- interesting LCA product
- B16B Hatch wanted, or maybe even B16A2 engine
- NEED ADVICE!!!! Why am I getting a #10 code!!? Is my AIT Bad!?!??
- Stock tire size...
- SOHC VTEC Head swap with D18 block possible?
- EK Mirrors... Can you change a power mirror into a Manual mirror?
- Need help locating a wire for alarm install
- Sluggish....then power
- Auto 97 D16y8 intake/exhaust manifolds on a manual 95 VX????
- Brake Lights dont work!!
- Question about b16 swap...
- Anyone know how to bend metal? (tie bar related)
- J's Racing Intake Will it Fit in my GSR hatch?
- 5$ paypal to the first one that can solve this, seriously. vtec not working only at track.
- Engine rocking back and forth...what to check out? EG hatch / b18c
- strange rpm issue after a long drive....
- umm a problem with swap need help please
- Will my fat ass fit in these seats?
- gapping spark plugs
- apex'i n1 vs. greddy sp2
- speedo very jumpy
- clicking noise
- Map Sensor
- EG trouble ecu code.
- tanabe sustec pro s-oc type2
- someone help....idle issues (searched)
- type r ecu help?
- is there anyway to find out the width of a rota rim besides measuring it..
- injectors and trotte body's
- Clutch Problem - freeplay with pedal
- NNED HELP WITH SUNROOF
- 92 Vx hatch wit 93 dx motor..Having problems repeatidly..
- Blew Head gasket ! Need temporary fix !!
- Clutch / Tranny experts need your help!
- car wont start 99 lx engine
- Going from a 98 h22 usdm to a 92 h22 jdm, Need OBD help!!!!!!!!
- Test-Only Smog
- Where do I find ECU plug in 2000 civic EX.
- rattlling noise coming from behind pedal area...
- Exhaust temperature
- squeaking noise in engine
- Ice Cold A/C
- charging system?
- ANY 1 WHERE 2 FIND DELSOL HEAD LIGHTS???
- interior question
- Rear fender rubber trim...good or bad?
- Are all b series....
- where to find a motor
- Del sol wont start!
- valvetrain help!!
- Rear LCA Problem
- Cali guys: What is a good CARB legal exhaust for turbo?
- stock spring rates on 1994 civic EX coupe?
- Has Anyone Ever Re-pinned an OBD-IIa wire harness?
- comptech vs apexi header
- 99 Civic JDM Headlights
- o2 sensor.. what's the different.?
- Radiator: Not a civic, but still a honda
- Location of Idle Screw
- Need help on ECU Wiring.... Please??
- Melted intake air temp sensor
- Broken door handle
- Poor Gas Mileage--
- Spoon duckbill spoiler replica on ebay? any good?
- ebay traction bars? vtecnician, any good?
- This Question is for all you out there with Golden Eagle Sleeves..
- Y4G HELPPPPPP !!!!!!!!
- camber adjustment in GS-R front end?
- How to fix cracks in carbon fiber?
- Alarm Problems
- smog in CA.........
- I need a Sway Bar
- Going Rate for EG paint job?
- Comptech sway/tie bar...will T1R exhaust clear?
- heaviest oil i can use?
- where do I check for thermostat in 00 civic EX
- EF camber kit on 96-00
- 00 CIVIC EX GSR SWAP, NEED OPINION PLZ
- Whats my car really worth?
- vtec controler
- strange sound.....
- eg 1995 civic si
- this is a odd exhaust question
- My stinky honda
- JDM citylight help!!!
- 00 si with skunk2 cams
- ONCE again SPARK RACING COMES threw
- GSR Interior in EG
- My accident with my stupidity
- Blew up a 2001 Civic EX... What would you do?
- What del sol wing is this?
- 25th aprl FAMOSO raceway...WHOS Going???
- Couplers, hump hoses and reducers
- Oil Change Questions.
- gsr obd1 O2 sensor wiring
- 205/55/15 on 99-00 Si Wheels
- Shift Linkage and a cut cable
- whats the diff between 98 hx and 98 ex engine?
- O2 Sensor In Cat Socket Size...
- EK rust
- need a car
- Tips for using Torx sockets?
- FREE CARFAX for the first 6 peeps to respond
- Rear Disc Conversion for VX hatch
- what brake lines to purchase???
- accord front end on a EG hatch ??...
- OEM Autozone Spring Compressor.....
- ::EG hatch wiper and antenna cover questions::
- 4dr Civic needs heart! Which one?
- teg mirrors on a eg hatch
- Calling out Slow91Hatch
- header wrap---how cool does it stay?
- info needed
- A/C Problem
- Oil...or lack thereof.
- gauges and thier pods..
- honda es civic
- EG + water in the road + lightpole = one F**KED up civic
- What damage can blowing your headgasket do?
- rear engine mount bushing bad on 95 ex??
- Autometer water temp gauge, which wire to hook up to?
- hi flo cat, test pipe, and kamikaze header
- Skunk 2 Coilover Question?
- Prelude guy here. need help with turbo civic!!
- h&r sports / h&r race
- cheap race mods 1997 honda civic ex sohc
- which way is the es oval muffler suppose to face?
- gsr strokers?
- How to remove the rotors...
- cheap and easy way to lower emissions help
- Exhaust fitment.
- CRX to Civic Dash?
- Which clutch
- DIY Porting?
- Couple more suspension questions...
- Si Rims for sale?
- Please Help Clutch Problems.....
- Which is better to drop on a 94 Civic, an H22A or B18 GSR JDM motors?
- Look what the nice UPS man delivered today...
- Do all clusters work when you buy them?
- Replaced a motor mount, gained a nasty vibration...
- just broke my lug bolt stud
- 2000 head 98 manfold...is this a problem
- Waterpump decided to go....
- how hard is a clutch install for a newbie
- dx to gsr wiring
- D series bottom ends...
- troubleshoot THIS!
- Car Blew a map code...Blinked 3 times quickly...
- What fuel pressure?!?!
- engine reving up and down at idle.
- Need help asap
- Help - Import Related Problem
- need valve clearance for 92 civic cx
- What ECU for eg23
- Window crank broken. Will EF crank work on EG?
- Howcan you tell if an ECU is bad? Car still not running.
- GSR motor swap motor mount
- can i get my rims polished?
- my car takes forever to heat up
- 98 Honda Civic HX
- CEL (1999 Civic EX Coupe Manual)
- my ebrake.
- HELP PLEASE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!SWAP HELP!!!!!!
- Is the D15B7 cam pulley the same as D16Z6??
- Comptech Intake?
- what throttle body gasket fits?
- Dual Halo Projectors - Good or Bad?
- desperately need some help........installing RSX seats in 93 honda civic hatch back
- Aftermarket 96-00 Civic EX Short Ram Intake Installation, need advice
- 96 honda civic fuse box diagram
- Frustrated with coolant hose...
- sis got in an accident, some help please
- Civic Shopping
- Moroso Vs. Stock Oil Pan
- Type R swap in 1996-2000 Ek coupe
- Wheel offset ??'s
- need an opinion on something
- Bad Car Sale
- check engine code signal= 10......
- new gauge cluster
- how to remove stock cluster from 97 civic hatchback and how to wire in another cluster that shows rp
- breaking in engine?
- need help on 94 VX
- Installing ACT clutch in my D16Y8 tomorrow...first timer, any tips?
- parting out 95 ex
- 99 eK: DIY HELp: Front Wheel Bearing/Hub
- Broke Therostat Needle....What To Do
- Do ignitions make that much power?
- brightest bulbs
- Did I get the full emanage kit?
- itr injectors in a b16b?
- Bent Valves?
- suspension help please
- what engine?
- Motor swap suspension ?
- Does anyone know the referral code for TireRack?
- need you opinion in suspension
- can somone do a vin number check for me?
- Hi guys i need differences about seats
- Type-R TB on a D16Y8 IM ???
- what lips fit on a delsol
- starts for a second minute ?
- Someone help me in WA area
- Hondata for p29?
- Those of you with an EK
- CEL on my civic
- good progressive rate coilover springs?
- b17a1 in an eg hatch!vaccum leak?
- Is the Helm Service Manual for me?
- Wiring for projectors?
