View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Seat bolts
- 2000 Civic EX (automatic)no start problem. HELP HELP HELP!
- 96 LX brake pressure issues *PLZ
- NEED HELP
- 96 EK - Engine bay hardware replacement
- Upcoming tie-rod replacement advice needed
- Honda Civic Ek Manual Window won't roll down
- Civic Si vs Integra LS
- Mysterious knocking noise(video)
- EJ Engine - Need some advice
- steering severely stiff after flood waters!!!
- 1996 Honda Civic EK1 SRS Light (AUS MODEL)
- Lower ball joint removal - Damaged Thread
- 2000 EX CEL and SRS light on, no codes
- JDM d16A block with usdm head swap.
- 97 del sol proportioning valve
- HKS Oil Temp Sensor Adapter
- '96 Black with OG gold wheels.
- What parts to change in eg AC to make it work and last?
- Will 1995 Honda Accord moonroof fit 94 Honda Civic ex coupe?
- PLEASE SOMEONE HELP ME WITH MY 2000 Civic ex
- 1994 Honda Civic hatchback CX
- Best brands to look at?!
- 96 civic power window/electrical issues
- Engine Code 8 & 9 Still Persisting after dizzy change
- What obd is my ECU???
- B18c4 to ek2 wiring issues
- 96 Civic EK - Exhaust bolts unscrewing
- HELP!
- B16 weird noise after start
- H22a4 swap into eg coupe I need help
- Help with ECM
- Rear trailing arm bushing - drum vs disc
- What blocks will a D16z6 head fit onto?
- Engine Torque Damper B Swap EG (Discontinued?)
- HELP!!
- 98 civic body but obd2b electrical wiring and engine
- New hand brake cables too tight
- '93 del Sol S Auto: Cranks but No Fuel, No Spark, CEL On
- Really strange problem - 99 em1, fuel pump won’t prime with obd2a ecu
- 96-00 civic clip broken
- Is the door jamb on the Del Sol the same as a regular civic?
- Power window issue
- D15Z1 install on D15B7 non vtec auto chasis, any advice would be helpful
- 96 Civic EK - Protecting harness plugs from environnement
- 1992 civic hatch no crank, no fuel pump prime
- P/S Rack
- Need help with clutch pedal adjustment
- SURGING HONDA CIVIC 96-00 d16y8 ?
- 2000 Honda Civic EX Thermostat housing
- ecu to o2 sensor wiring diagram d16y7 auto po132 cel.
- 1999 EM1 - Legend GS calipers / Mini Rotors / Hawk TSX pads / Which caliper bracket?
- JDM Front Fenders for EG Coupe/Hatch
- exhaust recommendation
- Rewire CPU ODBI to ODBII
- 99em1 - JDM B16A gen 2 motor - wiring annoyance
- 93 SI hatch build over time
- Ignition Timing
- Help! Mini me swap crank no start!!
- Y7 to Y8... is it even a Y8!?
- Cruise control resume/set red wire
- fuel control issue
- FREE 95, 1.6 dohc del sol
- Loud cheap exhaust manifold
- Upstream 02 sensor on DI6Y8
- Missing info from helms
- Condenser fan
- Front end assembly
- 93' Civic No running lights nor turn signals
- 2000 civic w/ 1997 harness and ecu
- 93 delsol S2k tail light conversion. HELP NEEDED!!
- Stereo surround 99 civic hatchback
- New clutch questions
- Questions about eg arm rests
- JASC 99 em1 si build
- Shift linkage question
- Parts interchange
- D15b7 block with a d15b8 head
- oil leak between head and block on front right corner near oil resturn passage?
- 1999 honda civic headers
- d15b7 intake gasket - idle (solved)
- Battery Issues?
- Engine check code 8 and 9 Issue
- Random Misfire (only under load)
- Advice/Help Needed P28 on non vtec Engine
- Guage cluster 94 honda del sol
- 92 civic sedan rear lower control arm
- 92-00 eg b18b swap no spark
- Adjusted the clutch pedal throw and now I have no pressure in the pedal
- Knock sensor
- My 92 Civic Restore Project (a/k/a Grey Ghost)
- New Daily - 96 EX Coupe 5M
- Civic moves/pulls when starting it up and it's in neutral
- Hazard lights not working
- Radiator replacement question
- New Project (97 DX) - Hoping for insight from people who have been there/done that
- S40 Dissasembly - SHAFTS stuck in case
- Power steering gone in 1994 civic si
- D15b misfiring issues
- Need Advice help ASAP
- 1995 HONDA CIVIC LX
- D16 Head Swap
- timing belt change now too advanced and PINGs
- F23A1 and 5 speed Swap
- Help
- Crv awd transmission in the back of a civic
- Idle surges
- Ek Engine harness question.
- I need help!
- Civic 2000 HVAC Blower Fan Relay
- Black smoke low mileage
- Civis 1998
- 99' SI Rear wheel hub assembly!!!
- Which engine oil?
- Bent Front Jacking point Civic 1996 Hatch
- Clutch pedal soft then hard to press towards the end
- P1457 Code 99 Honda Civic Lx
- Need Help b16 is breaking up and stuttering
- 1996 civic ex speedo
- No speed signal at ecu
- Power loss/hesitation P1362 code
- Hondata s300
- 98 Civic EX - Oil leak and other questions
- Is there a way to fix this steering u-joint? The upper one.
- Civic 95 stalling while driving
- ADVISE NEEDED FOR MODS
- 2000 Honda Civic k24 budget track weapon build! (Build in progress)
- Part number for antenna hole and the nut Civic 2000
- My first 1994 Honda Civic VX
- 2000 Honda DX (special build issues & goals)
- Can I save this hatch!?
- 2000 Honda Civic k24 budget track weapon biul! (Build in progress)
- 1995 honda delsol s 1.5l non vtec
- JDM b18c ITR in 00 ex civic
- Mesuring Mainshaft Thrust clearance with new mainshaft
- Mystery oil leak
- 1997 Civic Misfire
- 2nd Gear Popping out on an EG4
- Summit racing roll cages
- Camshaft Leaking after 4th Trip to Auto Repair Repeat Offender
- civic ek 00 no crank no start strange electric issue
- Odd oil change question
- DEAUSTCHWORKS 400 install 98 ek coupe
- Random clicking in relay?
- D16y8 No start, has fuel/spark/compression
- 1992 VX, MT lube
- Intake manifold sensors
- Harmonic balancer broke off and left piece inside
- ECU for D15B VTEC?
- 93 Del Sol blinker issue
- P06. B18a1
- Need your thoughts
- Part Stores
- $For Sale/Want to Buy$ - 92-00 Civic/Del Sol Parts Only (NO COMMENTS ALLOWED)
- Best Security for 2000 Civic Si
- 98 civic - Weird engine noise, hopefully video will help (solved)
- skunk2 short shifter question
- paper clip trick works but new switch has no effect
- Help! 99 Civic - Wiring Nightmare - No Crank
- Honda PS Pump Pics
- Ej6 coupe d16y7 turbo or b16a?
- Unknown vacuum hose, help identify.
- Clutch problems d16y7manual
- 98-00 cx and dx hatch interchabable trunk/hatch?
- 2000 Honda Civic DX No Crank, No Fuel Pump Prime.
- Clutch problem
- Cluster problems
- Should I do a muffler delete on my Del Sol
- Need help
- Smell from car after reving high RPM
- Aftermarket Part Brands
- 1996 Honda Civic Throwing P0452 Code
- Oil pan stripped!!
- Would 95 civic dx transmission work for 95 civic ex????
- Question about Engine Swap
- Vband clamp help
- What's easiest eg chassis for b18c1 swap??? ( First time swapper)
- A program for shuting a car off
- Does 1320 not make d series headers anymore?
- Honda P/S pumps
- d16y6 on a p2p ecu
- S40 Rebuild, cleaning inside recommended products
- Climate Control Lights Don't Work
- 2000 Civic LX won't start
- 1996 Civic Hatch Spindle Nut size 22/32mm
- 97 civic EX power drain help
- 1998 civic si coupe manual trans no reverse lights
- 99' Ex Coup, FIRST CAR, Broke down after 2nd ride, PLEASE HELP!
- Need floormat measurements
- Does Rear main oil seal rotate with the crankshaft ?
- very high idle! (3000 rpm!) help?!
- ARP head studs in Y series block info
- 1998 Civic LX VSS Sensor Problem
- Clutch pedal free play (slack) is 0?
- Brake lights aren’t working!
- How 2 Bench Test : Honda Civic | Vehicle Speed Sensor VSS
- Honda Civic 1997 Hatchback DX/ Rear window defogger not working properly
- S40 Transmission - Spring loaded steelball purpose
- Will a catback exhaust for ex fit on an hx
- 96 Honda Civic high idle issue
- Horn not working after engine swap
- Honda del sol proportioning valve
- 92 Civic cx blinker/cluster problems
- 94 del sol acg problems but no blown fuses
- Vitara D16y7 intake and injector help
- Speedometer problems
- Questions regarding the minime swap
- just bought a remote start for my 2000 civic EX 4door
- d16z6/y8 high comp build questions
- P04 ECU hondash, is it possible?
- Torque specs
- at wits end have no clue
- 1995 Honda Civic D15B7 Engine Coolant leak
- Is the rear main seal How To possible without removing the oil pan?
- Hood Alignment Issue
- Body conversion 1996 to 2000
- Not sure what to do.
- Carbon Fiber Hatch Question
- 98 Civic CX won't crank
- 2000 honda civic ecu/ecm
- 98 civic Dx door unlocks then locks again
- Civic 1996 Clutch housing broken
- LCA bolts
- Dimmer switch wiring
- B20 VTEC conversion?
- Keys witch busted.
- Harder to shift into gear once car is warmed up
- Low oil pressure on warm idle, new build
- civic 96 ex drop severe RPM if put in drive or reverse
- I996 Honda Civic LX
- Cluster swap issue 6th gen hatchback
- Fuel Hose leak on 98 civic sedan ex
- Weird camshafts
- Different mirrors for Civic Ek 2/3 doors and 4 doors... interchange mirror fixation?
- Fuel injectors - D16Y8 - 2000 Civic Ex
- 96 d16y8 engine, ecu and engine harness in 2000 honda civic dx
- Installing dc2 abs into 00 civic ?
- Oil Consumption Issue
- 1998 Civic LX sputtering and dying
- Tach for RPM on DX
- D15Z6 (European version) Trouble understanding EGR SYSTEM
- Rear Suspension Bolts
- How to check Lambda sensor
- Looking for a good D16Y7 engine in NJ for a swap
- d16y5 with d16y8 head ??
- Compatible seats
- HONDA CIVIC ECU 37820-P06-52 PODE SER SUBSTITUIDA POR OUTRA ?
- EG 1993 POOR FUEL CONSUMPTION, PLEASE HELPPPPP
- Ecu
