- wanting mild boost
- GSR in a EG
- d16z6/ d16a1
- Lip kit question...
- SiR conversion?
- Dent on bottom of quarter panel: cut-and-weld or hammer it out.
- car wont start
- harmonic balancer
- 97 civic dx with y8
- is their such a thing as this engine mount kit?
- CTR MIRRORS
- Is it stupid to convert a k20 into an auto o_o
- 97 ex intake manifold questions
- no spark at all
- Gsr Or ls Vtec
- high rpm code 43 and 22
- h22 swapped eg w/ ac?
- ?????? about a 95 civic ex
- AICV Block off plate.
- Car sputtering? Wrong type of GAS, or fuel filter?
- d16z6 cr
- bsd tie rod ends??
- newbie with imortant question
- help with speedlimiter
- Map sensor
- RSX seats into EK. comfortable...?
- VTEC Question
- tailight problem
- Unplugged wires by ECU?
- hey guys can i put my ls rods in my sohc
- b18c6 into 94 vti
- finding 99-00 civics?
- rear bumper removal
- Are EG and EF Main Relays Interchangeable?
- Dumb cosmetic question
- URGENT ~ HELP!! Do I need a Non ABS Booster for my rear disc
- bisimoto h22 transmission for d tranny
- Help with coilovers? theyre frozen
- - Doing a Compression Test.. No timing Belt.. some Q's -
- Weird problem with dash lights going wild
- what else do i need/should do when i swap my motor?
- 37760-p00-004 engine coolant temp. good for B16A2 obd1 ?
- "97 Honda Civic parking brake problem - Help appreciated
- Made 138 on the dyno
- Who makes the best headers?
- EK hatch Mugen twin loop fit on an EG hatch - pics? difference?
- turbo help
- edelbrock IM
- Bleeding brakes
- where can i get a new engine harness?
- ANyone know where I can get the amber bulb covers for lights?
- fuse box under dash and alarm problem
- draining and flushing coolant out of block!?
- Integra RS brake booster + MC versus 1991 civic ex MC
- question?
- ####Is Acura a japanese import company or a USA company
- had a question about a tranny code
- B16 head bolt torque specs?
- Odd Wobble grimlin....need some advice
- D15 92 - 95
- Need Some Advice on Brakes
- Axles and Damper Fork
- mintyyy ek for sale
- new motor deosnt start
- auto to manual swap....do I need this guy>?
- EK: How do I fix the sagging EJ8 rear bumper?
- 95 - 98 honda civic sedan HELP!!
- SOHC parts
- Rear Calipers getting stuck?
- Help
- obd2 gsr to obd1
- AIR INTAKE
- Transmission Swapping information
- d16y5 head swap questions
- B18C1 INTO MY 95 COUPE
- Has Anyone Tried The Eibach Pro Street S ??
- ek side skirt on egs? pics post them here
- buddy club v-con vtec controller
- 1998 Civic sedan - driver window hard to roll down
- Hondata Intake manifold gasket.
- Brake light help
- 96 CIVIC HELP!!!
- folding mirrors...............HELP WIRING????????
- HELP!!! constant reving.....
- B18B Swap Into 95 Civic DX
- '99 Civic DX Automatic Transmission replacement..How To's? DIY's?
- tapping valves
- The fluid doHELP - brake pedal falling down after stepping on it
- setting timming
- AIT Air Intake Temp. Sensor question
- 1.5 head
- ebp?
- Tranny seal...help out guys
- HONDA DEL SOL JDM HELP!!!!!!!!
- z6 bogs
- eg ek rear seat
- Having a bitch of a time getting the harness plugs off!
- b18 gsr motor
- Noob! how to remove ecu pins
- tranny
- got my leak fixed
- need some help please
- how to swap a d16z6....
- After Timing Belt - Low Idle Issue...
- d16z6 swap info....
- AEM EMS 1020 box problems??
- K1 Drift LIP
- D16Y7 maybe ?
- Ballast mounting positions in EK?
- Stripped oil pan bolt, new oil pan?? what are my options
- HELP! JDM GSR!!
- my f**kin brakes!!
- Installing shocks/springs - questions
- any good motor importers in So.CAL? Kawatnabee I belive is out of biz.!?
- best swap parts to use looking towards the future...
- rough start and wierd idle please help
- d16z6 starting trouble
- smoking when car is started
- gas question
- eg folding mirrors((((I need help))))
- NRG quick release kits....
- automatic to manual trans? (how difficult)
- OBD2A civic harness doesnt work in 99 EX?!
- How to Remove paint/primer spray
- do EG rear LCAs fit DAs and vis versa?
- EG rust problem *searched*
- obd0 motor into obd2 car?
- Planning an engine swap but which engine?
- HELP PLZ!! CAN MY MASTER CYLINDER BE BAD? HOW CAN I TELL?
- I got a check engine light and 3 codes!!!!
- projector retrofits?
- EM1 seats in an Ej1 ?
- IN NEED HELP REAL BAD
- Where does this hoes go on a d16z6?
- del sol 5 lug conversion help (URGENT)
- civic parts
- Em1 rear seats into my 97 hatch?
- password 96-98 ek foglight help
- Installing GSR strut bar on ek?
- my B16 turbo project
- passenger side axle not sitting flush
- Question with tranny!
- Car really boggy.. anyone help?
- oil indicator light
- anyone here have a momo wheel with jdm type r horn button
- DIY!! how i can clean my b16a head to shine???
- Hood rattling.
- tach lights wiring question
- Hasport axles slinging grease
- Can anyone tell me where this hose runs to? Pic included
- 99-00 si owners with passenger air bag tray
- goin obd1 from obd2a????
- HELP!!! Best LS-T Setup
- 93 del sol for sale or trade
- b18b ls manifold question?
- clutch slip...
- Installed my hub and quick release(wheel is crooked)
- my cluth seems to have went out
- who makes...
- Code #22 Vtec pressure switch, only on highway.
- How to restore your once clear headlights to LIKE NEW condition (EK) or any clear headlights.
- quick question about 99-00 ek power window conversion.
- JDM B16 SiR II swap in EJ1 Map Sensor + Knock searched...
- What a/c and Cruise control willl work in my Del Sol?
- Online Stores
- *Help Please- The Tip of my Catylic Converter Cracked*
- broken thermostat
- Any harm in a little loose valve clearances?
- del sol question
- turbo manifold question
- Slight Brake Vibration Between 80 and 70km/h
- mud flaps
- speedometer jumpin around??
- help needed, tailights wont turn on.
- 92-95 EG Black Interior
- Big EK SOCH issue
- tenzo r seat brackets
- Problems with '94 Civic
- How do ACT xtreme pressure plates look like??
- Tranny problems?? HELP
- How to make SOHC faster?
- gas upgrade
- jdm speedlimiter?
- itr whp
- excessive cooling system pressure??
- What is the widest wheel an EG can handle - in 16" form?
- HELP!!! PASSENGER DOOR WON'T LOCK!!!
- 99 Si rear wheel bearing torque
- D16 trans help
- civic fuel lines clogged?
- HELP!!! Weird pressure plate problem!!
- Vtec wiring
- B16 throttle body on a D16 IM?
- Car idles but bogs and dies????....
- largest / tallest tire that I can fit on a eg civic hatch
- Benefits of blaster external coil
- HELP! EK Air bag blockoff tray
- What Does Code 15 "Ignition output Signal" Mean....
- Resontars - Exhaust
- dumb question
- never heard of this header before...
- Clutch Master Cylinder?
- high idle speed
- 170 dyno is that right for what i have
- 95 hatch electrical problem
- NRG QR Question!!
- Buying GSR used strut bar, what should I look for.
- EK Armrest
- Quick Exhaust Question...
- Tokico Hp's with Tein S.Techs
- 00 civic gauges
- Clutch grabbing question
- Quick Question, Z6 intake manifold on a y8 block
- 98 civic swap
- Unstable Steering, Very Loose Steering Wheel
- My Swap...Intake ?
- Need 3rd gear synchro and press.plate. Where can I buy them??
- auto to manual conversion???
- brake master cylinder question (URGENT)
- Why spark plugs fail? 92 Civic w/ B18b
- Need some advice on what to do with my 95EJ1
- 1997 Civic EK hatchback Stolen out of driveway OC garden grove
- Question
- Cam Shafts in Coupe????
- Civic wont start, injectors not getting power.
- GSR Leather in a coupe??????
- Rear Disc Brake Swap... HELP!!
- worn/torn front lca bushings?
- Colorado Connection??
- What intake for jdm B18C gsr swap in a 99 dx coupe?
- 96+ civic front sway bar difference
- My 92 Hatch has Died !
- broke down
- Motors running really lean... new cam = bigger injecters?
- coolant lines on back of z6 block??? where to?
- Probly a Stupid Question but need a answer:)
- 3" exhaust on EG
- HELLA HORN INSTALLATION ON 92-95 CIVIC EG H/B...
- i cant find a turbo cam for my z6
- D15b or b7?
- -- Clicking from ECU??
- Help with car in safe mode
- Need some help with a weird noise.
- Instrument Cluster Lights Out
- WTB 99-00 si fog lights
- odometer forward with vss signal?
- New HONDA Ignition Distributor. Ignition Module, Ignition Coil - From Taiwan No.1 maker
- unused car not running great
- Will a D-series AEM V2 fit a B16 EG?
- best brake set up for EK
