View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Del Sol dash swap into 95 civic
- OBD 1 turbo kit on OBD 2 car.
- Correcting Fuel Pressure?!?!?!
- foglights turn off when i brake.....HELP!!!!!!!!!!!
- Will Integra headrests fit Civic seats?
- Looking for a Wide Body Kit for a 95 Civic HB
- ZC in DX hatchback?
- "Wheels pulling on uneven roads"
- Mugen Spoier for a Del
- wiring problem
- H22a in a del sol
- what year/model are these?
- carbon fiber hood
- ??MAHLE RACING PISTONS??
- HELP// Is this a 99 Si Brake Master Cylinder?
- The window always falls off the rails. In my EM1
- what to do when hood holes are stripped?
- Who knows this part number????
- VX block
- ACT disc question
- Spark plug issue
- JDM GSR in EG Hatch 1/4
- 99-00 Si Moonroof Switch Light Up Amber?
- sohc vtec questions
- LS internals on dohc ZC?
- need help asap! front brakes
- compression test
- Those with miata wheels, i need your help.
- vacuum reading at idle?
- Where to buy?
- Top shock mount bushings
- d2 racing coilover set up
- Leather Seats
- help!! install brake rotors
- Help! When my air turns on, it smells like elephant @ss
- 150,000 miles
- 94+ teg DASh in a EK
- question on omni coilovers
- Carpet
- Car wont move
- post pic....
- weather strip window thingy
- is this a good engine swap?
- Advanced Timing affect Emissons?
- tach reads much lower than this morning
- What rear disks will fit on my car?
- Request Spring Advice
- a/c blows..then stop....
- eg hatch
- Rear disc for my EH
- help, brake pedal has alot of travel
- d16y8 w/d16a6 crank, rods and pistons?
- z6 oil pan...will it fit a y8 block perfect?
- 5 speed / automatic swap wiring
- boosted y8 12 psi, valve timing and ignition timing
- glove box del sol
- one last q about the b16 swap!
- Which radiator hoses fit best w/ B18 swap in a EG?
- Honda Civc CX d15B but Vtec inside?
- d16 and cometic headgasket
- rims looking to buy
- axle trouble Wont lock in
- lug nuts for rota's
- hydro on gsr tranny
- for sale altezza tail lights cheap
- Is this a deal or what?
- questions about civic 93 front end on 93 civic sedan ???
- Need help hooking up fields vtec controller
- need upgrade advice
- Will a D16A6 oil pan fit on my D16Z6?
- Will 2002 civic si floor mats fit in a 92-95 hatch?
- An Exhaust Resonator Question?
- b16 aftermarket header
- motor won't crank....searched...
- b16?? ima newb
- b18b del sol drivetrain swap
- Difference in cabin wire harness 99-00 DX to EX/Si
- best way to go all engine?
- distributer (SWAPING INTERNALS)
- VTEC not working....?
- will a 98 gsr shift linkage work in a 93 coupe w/ a b18b???
- Parting out 95 civic ex
- lowering my del sol?
- Exhaust dump for na h22 civic?
- OEM tach being off?
- RSX Dash in a Civic
- What is an intake temp. sensor????????
- Cluster Bulb Help
- Integra dash into 94 civic
- how easy is it to replace a clutch??
- What Kit would go best on....a 95 Civic DX HB
- I need some basic info...
- +38 offset correct?
- legit site???
- Anyone know where i can find a EG foglight lense?
- genuine OEM Honda parts online...don't know where else to post this
- Ground Wire Diagram
- Cam Seal Replacement
- what is the 2003 civic?
- third stop light
- Lets here civic shag stories..
- VIN Code - can anyone help
- Civic has starting prob
- lots of CEL codes going off, please help.
- High gas mileage.
- Help!
- s2k seats in an EG
- Bad Alternator
- Final Decsion !!
- K20R powered EG runs 11.31 all-motor
- driving probs!!!
- where to get stock jack
- Crappy Gas milage...
- Looking for some NON CF duckbill wings for EK...need advice
- option audeo console beige part #
- quick ?.... Regarding ac hose searched with no luck.
- How to read a Motors year
- looking for a d16z6 with less than 40xxx on engine
- Same gas doors?
- What do you guys think about redline MT-90
- HOW FAST IS??
- fitting dC5 calipers onto ek ?
- [FAQ]Lots of Swap info for your EG and Del Sol
- vents blow only hot air
- Shakes when it idling
- JDM Fogs for Sir
- Hidden delsol antenna
- y8 tranny with gm synchromesh questions (kinda long)
- HELP!!! Power Surging problem??!?!??!?!
- I need a ricer Test Pipe
- camping in the civic
- 04 si, need help
- VTECH question
- AC compressor question
- jdm gauge cluster in 96-98 civic dx hatch???
- d16a6 cam in d15b7 valve lash settings?
- Sonar replacement bulbs for the projecters lights
- motor mounts???
- Car fax please ?
- Which helms manual to buy for a 94 del sol???
- Need del sol helms
- hit rev limitor in 2nd..... now car is acting up..
- HELP ME PLEASE!!
- What are some times people have ran on here in a Del Sol w/ Turbo?
- help needed shipping price
- Need Fuse layout 1993 Del Sol S
- Installing Foglights onto 92-95 civic...
- NEED Wiring diagram for a 94 del sol VTi gauge cluster (UKDM)
- which one is the ECU fuse? FI E/M or IG 1
- Atf instead of oil!!!!!
- Will 1999 and up civic tails fit?
- 96 sohc vtec head on 93 vx 1.5
- Jdm headlights
- Your 'ideal' setup for your hatch?
- shift linkage needed
- tranny swap starting problem
- engine swap in california
- help with civic inside fan blower, horn ?, and wiper delay not working?
- Truth or legend?
- what engine comes stock in a 93 ex?
- Anyone got a eg dash for sale?
- How to replace balljoints
- 99-00 civic bumpers fit 96-98?
- DC2 Vs. Eg+
- H&R Cup Kit Question
- idle problem please haelp
- does EG traction bar will work for a del sol?
- A/C compressor
- Need Help no Air is coming out of my A/c vents.
- What's my best option?
- hid's
- Help wid Car
- New to the site
- B18C obd2 into EG obd1 .....????????
- New tranny...
- throttle cable question.
- interior ideas..have anything?
- CAMS! CTR vs. ITR. Which is better?
- Anyone know OD of the hub from a 92-5?
- Seperating Axle from tranny
- install jdm sidemarkers 94 coupe they dont blink w/ turn signal help
- help with MSD cap and coil?
- warm up noise
- megan muffler
- Looking for some Input please
- Future Potential* Need some Input
- hood latch
- shift linkage
- Civic Evaporator/ Integra Evaporator
- Wiring diagram for turbo timer
- climate control guestion?
- anyone know where i can get a b20z i only seem to find b20b
- ls swap in a coupe
- how much does it cost to have ur flywheel lightened?
- The Lysol Trick
- JDM B16A engine swap guide for 96-98 Civic DX hatchback
- obd II o2 extension Gauge wire question
- Naugatuck, CT residents 06770 help me if you can buying an ek from your nearby dealership
- had a question about 96-00 civic 4 door sedan trunk lid please help
- jdm sites
- Looking for Ideas on my 92 civic hatch project
- NEED HELP QUICK!!!
- d series bullet proof
- help: when i turn on my a/c during the HOT day the car shuts off during idle.
- painting / powder coating calipers
- 96 civic hatch rear sturt....
- where is the fuse for the speedometer guage found on a 92 civic sohc with tach
- whats wrong with this car?
- Flywheel Warp?
- What tires size?
- Newb here from Denmark
- Cap and rotor killed the Civic?
- buying b16, have a few questions
- Car Stolen or Towed ?
- are 97 civic headlights 9004s?
- what exhaust are you guys running on your del sols
- Buying Honda Del Sol
- how much for head swap?
- tranny swap
- Sensor/Fuel problems
- Couple questions !!
- Want to paint tail lights....HELP!!
- D16Y8 tranny
- helms!!
- can a cai from and itr fit eg
- del Sol e-brake cables
- 5 lug question
- Z6 block passing smog?
- Seat Belt Question - '97 civic coupe EX
- Clutch Problems
- no vtec????
- ecu code checking on my 2000si
- Steering knuckle from 96 dx to 99 si....will it fit?
- ***SRS QUESTION*** (i searched)
- I'm searching a EK9 VIN
- fuel pump
- Honda Civic LX 1998
- inspection plate
- Korbach Frame Locks Tested - fwiw, they work.....
- eg electrical issues
- One side closer to my quarter panel than other? /shrug
- clutch/tranny problem HELP PLS
- headbolt need advice
- need to identify seats
- need help on vtec head swap asap
- Problems with my Apexi exhaust install!?
- How do these engine internals look
- p28 ecu codes?
- new headlights
- HHELPP 03+ spring installation on civic
