View Full Version : Honda Civic / Del Sol (1992 - 2000)
- 92 Civic Oil Pressure Switch (Can't get connector off)
- EK airbag delete tray into EG
- 1997 Civic CX alignment issue
- IACV troubleshooting.
- 98 ek condenser fan help
- 98 civic dx with d16y8 swap. Downstream o2 sensor wiring fix!!!
- Wiper Malfunction 94 dx
- opinions for my eg
- GSR/ITR steering rack swap questions.
- My Build - 98 Civic Coupe EX w/ B18A1 swap.
- 2000 civic ex with z6 block and y8 head & p28ecu
- b20 VS boost.?! HELP
- how to check if i have a bad transmission mount?
- 11-2 IMA circuit voltage high
- Different shocks on each coil over?
- Power Window Issues
- CEL on but car runs fine
- Comparing temp gauge readings on 95 civic
- B18b1 spark fuel and compression no start
- B16a sputtering at low rpm
- EJ1 performance questions
- Swap issues in ej8
- D-series MAP on B-series ?
- Hasport Mounts in EG
- Need help figuring out what brakes are on my car
- 98 Civic Speedometer Acting Weird
- OEM vs keihin vs aisin vs gates water pump
- Ideas
- Brake/Horn 20 amp fuse repeatedly blowing?!
- Bolt size for the A/C Bracket on a B swapped Civic.
- my ej8 so far, suggestions
- After header install, CEL on ex
- 92 eg hatch misfiring
- Need Info: Proper Valve cover Gasket for D16A
- Broken wires at driver's door. Fix?
- OBD2B to OBD1 questions
- Strange noise from alternator area
- eg hatch on xxr
- D15B - blown head gasket and top of cylinders chipped
- 93 civic stArts then shuts off
- '99 Civic Won't Idle
- 96 cx hatch with y8 swap very loud rumble
- HELP axles problem gap/leak
- My Track Car Build
- Slow/lags/low response JDM d15b y7 head
- 2000 Civic SI no spark
- Oil Leak EM1 with picture
- MAP voltage problem
- Help with '94 Del Sol stalling
- 99 Civic - Idle and transmission questions
- Intake manifold cruise control port problem
- 98 civic ex crank but no start
- 93 civic/D16Z6 - need help replacing engine wire harness
- 95 ex - door molding and trim parts help (confused by oem Honda parts websites)
- 97 Del Sol Si - no crank, lights yes
- 93 del sol not running correctly
- 98 civic si d16y8 drawing power?n neeed helppp
- auto to manual conversion
- CEL 8 - Wiring Issue? - OBD1 GSR in OBD2 EK
- 98 Civic Ex - overheating in the red
- Car won't fire, searched and have troubleshot - 93 Hathcback B20 swap
- Oil light flashing
- Making progress with my 96 EJ6
- [Question] Will the 94 civic sedan dash harness work in the 93 civic HB?
- My 97' Lx Build (progress?) Thread
- Lights dim with increased throttle %
- Motor dies and restarts itself while driving - 97 Del Sol B16A2
- 99 Civic/b16a swap/P28 chipped ECU - Georgia emissions nightmare
- 96 civic missing and running rough. at my wits end
- No Heat
- can b2 camgear fit z6 camshaft???
- 97 Civic EX Automatic Shift Solenoid
- 92-95 EG EDM headlights and rear foglight install
- obd2B dizzy to OBD2a dizzy harness HELP! d16y7/8
- Jdm d15b vtec redline
- Secondary o2 sensor problems!!!!
- EG hatch with D16 and OBD0 ECU - fuel pump won't prime
- 00 Civic EX ECU with D16A6
- valve question
- 97 cx hatch how to remove headlight
- Civic suddenly doesn't want to start
- Real/fake Recaro
- Do I need a new harness to use an obd0 motor on a obd1 car?
- Any benefit to adding an air intake and exhaust to my d16y7?
- Question about dc header and carb numbers
- 2K Civic D16 - O2 sensor interchangability
- my own track thread, 97 LX sedan build thread!
- How to get the most out of an automatic vtec?
- 99 civic ex - head gasket, radiator, code 9, and high idle issues
- 96 Civic overheating!!!
- Where do I find a low style shift knob?
- 99 Civic DX - Speedometer Not Working after tachometer installed
- 1995 Honda Civic CX Hatch Bucking Problems at Very Little Throttle
- 98 Civic/B20 block/GSR tranny - which motor mounts?
- Swapping 95 ECM PCM (solved)
- 00 civic si was fine now computer malfunction and other codes
- Car sputters at idle/driving?
- Need help identifying JRSC fitment
- Can I use a d16y8 head with a d16y7 ecu?
- XXR 522 wheels on eg hatch?
- 97 civic rear lca bolts - where to find them?
- 2000 Civic Ex misfiring, codes p0300, p0170, p0171
- 96 Civic DX - Can I swap in any cluster from a 96-00 civic??
- Distributor Rotor Stuck on
- 97 civic cx - exedy clutch kit from gripforce???
- Timing belt bounce at idle? Video included.
- Ground control coilovers 330F/600R
- 93 civic ex start problem
- Installing a new dizzy..
- 97 Civic Pothole Victim - Rear Lower Control Arm
- Can I swap the EX cruise control light module into an EDM cluster?
- 98 Civic/jdm b16a Gen2 swap - rad fan is an idle issue
- Need help with replacing my d16y7 with a D16a
- 94 si died and came back
- EK D series to B series SWAP !
- 1994 civic ticking noise
- 95 civic - horn wiring after installing nrg quick release steering wheel
- 97 ek ls/vtec...no cel. no spark.
- Is there brackets to the EG JDM double din
- Installing 99 civic ex automatic shift handle!!!
- EK Coupe rear disk conversion...
- 99 Civic EX trouble shooting... Tranny?
- Slow/Long start when fuel is low
- 95 civic EX - How much horse power?
- oem traction control
- Z6 Head rebuild
- 95 DX Harmonic balancer fell off and not sure what I should do.
- 96 Civic EX - Charging problem
- 00 Civic DX/B20Z2 swap - Bogging issue
- 93, 1.5 civic will idle but not drive above 2k RPM
- been searching everywhere if need help wiring a primary 02 sensor on a civic si
- b16a2 head with b18c block -- any CA smog issues here
- Ctr ek spoiler fitment issue
- How to adjust door to body tightness? 2000 EJ8
- Broken Valve Cover Bolt - 94 EX Coupe
- Clutch Hydraulic Problem
- Dat honda rust doe.
- Problems going crazy 00 civic with d16z6!
- 2000 civic Si CEL, high idle, jerky
- Clutch pedal assembly in automatic Eg? B18c in process
- valve lapping question.
- 94 dx coupe rattle/knock over bumps
- TDC Sensor Code 8 After Installing New Dizzy
- 92 Civic/JDM B18C swap - Idles lower than usual while cold
- my 96 ej8 needs a crown royal boot
- d16 y8/z6 mini me in ej8. Help!
- 2000 honda civic dx 3 door coup owners!or equalivent.
- installed megan springs need help
- Clear CEL code without resetting ECU
- 97 Honda Civic HX - car turns on, but have to keep key turned to stay running
- '98 harnes in '00 civic
- Y8 manifold on y7 head
- Em1 99-00 cluster into a eg 92-95 civic
- d16z6 harness b20?
- 1997 Honda Civic Lx Engine?
- 94 civic coolant fan fuse keeps blowing
- 93 vex gsr swap starting issue
- 92 civic cranks but no start help please
- 6 month driving hyatus
- Civic with gsr swap - engine starts, then stalls and rotates backwards
- Civic 4 door gsr compression test and running issues
- smell exhaust in the car
- 95 civic gsr not starting after flywheel change
- Exedy Flywheel?
- 94 civic ex wheel stud replacement! Please help!
- 96-00 sedan to 96-00 hatchback: What parts are interchangeable?
- questions about modifying d16
- Tachometer not working
- 97 civic dx - How can I prevent thieves from unlocking my doors?
- 97 Civic vacuum leak problem after removal of cruise control
- 94 Civic EX won't start after mini-me
- 96 Civic: Repair or move on?
- Harness issue - 96 hatchback with complete em1 dash harness and engine
- 94 civic lx 5-speed/d15b2 swap won't go over 3500 RPM/25mph...
- EM1 - gauges not working after cluster and dash harness replaced
- Hood different size between a ex..dx... Or the other models???
- OBD1 motor in OBD2b Car - wiring and distributor questions
- z6 trans internals fit in b7 casing?
- 1997 Civic LX no air from dash
- 93 civic auto with 2000 y7 longblock swapped. No spark/starting.
- 00 Civic EX Noob build plan. Comments or ideas?
- Not really sure what this disconnected pipe in the engine bay is...
- Lowered del sol - Better tire sizes and springs?
- 1995 eg hatch - changing step gates
- Trying to install front upper control arm bushings - tips/tricks?
- D16Y7 Still white smoke after Head Gasket job
- 93 civic DX/D16 swap - what Civic ECUs are compatible?
- Civic (eg) to Integra (dc) suspension questions
- Ignitor & ICM failed, aftermarket OK?
- 97 civic hx vtec 5spd - slipping clutch?
- 95 Del Sol: Climate Control lights stay lit?
- How do I flush my coolant on a 95 DX w 1.5L motor?
- Pressure washing Cylinder head?
- No brake pressure when turning
- Oil leak 97 civic ex coupe v-tec??
- 94 Sol: Need Torque for Ft LCA (seperated)
- 97 civic DX: Can I use a P2F cylinder head in place of the P2A-7 head that is on it?
- LCA bushings remove/install with HF press?
- ac belt
- 98 Civic HX coupe - Passenger Power Window won't work
- SI cluster gas gauge isn't working
- 99-00 Civic hatch with em1 harness - need help wiring the resistor box
- help getting del sol running
- Valve spring D16Y7 into D15B7
- Difference in Civic JDM VS Thai
- ** Would EK side mouldings fit a EJ8 coupe **
- Oil for 95 civic d15
- crazy japanese throttle body
- 95 Civix DX, L turn signal is dim and blinks fast, and hazards don't work.
- 96 Civic EX, cranks but no start
- 1993 Civic Si Tail Lights Staying ON
- 2000 civic si(canadian/ ex in usa) heat on driver side none on passenger side
- HELP! Another Headliner/ A-Pillar Question!!
- Power Steering Delete? Help!
- JDM D16a pulley ?
- Power Steering Question (Need to Disable it)
- 96 civic lx won't start after it rains
- Front LCA bushings, same for single piece and 2 piece arm?
- Sway Bar "D" bushing lip orientation
- 93 Civic - no spark and fuel pump won't prime
- How to remove liquid from head bolt hole?
- 96 civic sedan - manual to power window conversion
- 2000 Honda Civic Si no start but cranks. Tried everything please help
- Civic/GSR swap - low idle and runs rough
- 00 Civic EX puffs at low speed and rough idle
- 94 Civic is being a jerk
- 1996 Civic no spark doesn't seem to be the igniter or ecm
- Finding correct AC bracket for '94 Sol w/B18A1
- White smoke coming from exhaust
- Steering Rack noise question
- 99 Civic - Question about ignition timing
- 96-00 Civic Backspacing question (searched)
- Need help replacing the exhaust on my sols
- D15B timing issues this morning :(
- 92 Civic in limp mode
- 1995 Del Sol Dies after crank
- 95 civic 1.5vtec timing belt?
- suggestions for a good torque wrench?
- Cusco pillar guard bar fits eg9
- VSS not working - easy fix
- 3 wire to 2 wire iacv problem
- Under spray in a can... does this exist/any good ?
- 95 Civic EX 5 speed - Code 17 TWICE? Is this witchcraft?
- proportioning valve channels
- B16a2 head gasket
- 96-00 coupe quarter panel available?
- Engine Loading at Idle D15B Hondata
- 94 Del Sol randomly stalls
- only cylinder 4 firing
