View Full Version : Honda Civic / Del Sol (1992 - 2000)
- MUGEN PIN STRIPES?????
- some del sol model questions
- 96-98 Front and Rear bumper cover confirmation?
- jdm mirrors HELP
- urgently need carfax!!
- ITR to EG - Driving Impressions
- SMOG stickers??
- check engine light fraud!
- Ready to build an ALL MOTOR D Series...
- Hawk HPS pads question?
- 92-95 civic A/C condensor quick questions! HELP PLEASE
- Am i missing something? H22 in eg? Shifter assembly.
- Help need to get this stuff off
- Auto Trans Regear
- Any difference between the 2000 Si Grill and the 2000 CTR grill?
- 92+ Civic owners, what non-HID bulbs are you using?
- How much to paint the non painted stuff on factory 00 Ek?
- Well, check engine light help please...
- Problems with a B18C1 swap
- checking cel on obd2 with resistor box
- Archived Pics dont work: Side Mount Intercoolers on EG's. Anyone got some pics?
- Hot ish... "Wood" you like to see my car....
- Please help with smog problem...
- Need new thermostat?
- WTB: Del Sol seat w/blue stripe
- eg fog light installation link help!!
- how much do you think I could sell my car for?
- how to repin ODB II P72 ecu
- How fast will this go?
- New suspenison squeaking...
- 4-2-1 or 4-1 header??
- vents
- vtec bugged out speedo.
- ticket ?
- How hard to install power door locks???
- Jimfab bars + B series engine
- Will Autometer pillar gauge holder work w/60mm gauges?
- Price paid to swap motor???
- Axle Problems (DSS)
- Del Sol Owners?
- Tanabe Racing MED. B pipe with what axle BACK
- Trans Question
- will a 1990 ls engine fit in a 92 vx hatch
- Apexi or DC Sports Headers???
- What do you all think about this trade?
- OMG I don't know what to do anymore. Can someone help me 99' GSR in 00'EK hatch code 74
- Apexi V-Tech Air Flow Converter..(VAFC) HELP WITH SETTINGS
- My car does not change gear properly
- ITR rear seat woahs...
- Help what does this noise mean?
- D16y7 going in my 99 dx... help me setup
- (D-series) engine squeak under load - NOT Belts or Pulleys - any ideas?
- D16z6 crank in D15b7 block???? pros cons, problems, need information.
- What is wrong with my car? ---> HELP!
- LSD question..help me out guys
- Will a Del Sol Dual Core Radiator fit a 99 Civic EX?
- calling all CT guys!!!!
- 92 EG IACV b18c1 HELP
- Wheel Offset
- TRANS FLUID???
- Shifter Bushing Install
- Pic Req: N1 cat-back on 5th gen coupe
- B18B1/gsr trans VS. b18B1/ itr trans
- will a gsr rear sway bar fit a EG4 (ITR LCAs)?
- b16a Civic running Type-R ECU
- Install a computer cooling fan into engine bay?
- Is a 27mm rear sway bar too big?
- Shift linkage question??
- help car die out today
- Planning my EK project, give me some tips
- Hugest pothole ever broke coilover perch today
- smaller oil filter better for building up oil pressure?
- 00' EX tranny for work me?
- Apexi Headers.....
- d16z6 MAX WHP on Stock rods/pistons.
- New exhaust, Tsudo, pix & review...
- Testing the waters...How much do you think this hatch is worth?
- JDM Del Sol Gauge Cluster Install
- ACT 6 puck longevity
- What kinda lip is this??
- Wierd Odometer problems......
- brake system
- WHAT DOES EG, EK, AND EF STAND FOR.
- im gonna b in the lower part of Indiana this weekend(anyone from around there?)
- How much am I looking to get?
- GSR sh1t
- SRR Control Arms
- new d15b vtec possible headgasket
- What do u guys think?
- Acura 2.8L into a civic?
- What do u think
- 99-00 Dash into a EG hatch?
- Wanted a price quote
- What will I need? (installing new parts)
- REALLY bad noise?
- New carbon fiber maker they make everything!!! FEEDBACK ???
- ZC pistons in a D15B7???
- White smoke from the hood?
- ::i need Rota info!!::
- Bushings
- what do dealers do for fuel injection service?
- skunk2 sohc vtec cam?????
- Question - 95 Ex Coupe rolling shell $$$$???
- GF's Civic finally on the road.
- My new Intake Manifold for my D15B. (pics/Tech)
- Which Intake?
- 99/00 Si suspension = 94-01 GSR suspension (brakes)?
- Qstn about headgaskets?
- Stupid Question...
- should i buy?
- How To wire del sol aux lights to come on w/ park lights?
- Am i asking to much for my car???
- is it worth it??
- Spoon B-Pipe...
- Verify this CTR intake cam? *PICS*
- reccomendations on a set of springs....
- Who has a B series + jimfab traction bars in an EG?
- Replacing O2 sensors 97 civix DX coupe
- seized bushings
- truth about road gunk in my coilovers
- Energy Suspension Shifter Bushings
- b20
- how to install the side skirts from jdm shit
- shift linkage from del sol
- Center caps
- oil pan?
- Lights won't come on......
- ac question
- 0-60 and 1.4 times for ctr
- anyone have the ctr wing from jdmshit?
- Upgraded Final Drive for D16Y8 Tranny????
- Neuspeed strutbar with stock GSR-will it both fit??
- are 99-00 ex and si seats the same?
- My DIY stainless braided clutch MC line..
- Anyone replace their PCV Valve?
- Complete this sentence: Before I take my block to the machinist I need to have.....
- Power Steering Pump
- Can I use the Delsol ebrake cable?
- JDM SiR cluster in EJ AIRBAGS?????
- Can Some1 ID my Trust muff?
- N1 B pipe with what axle BACK???
- 98 Civic CX repalcing calipers
- exhaust for b18c1 swap
- Anybody know how I can pass inspection in NJ with JDM B18C swap?
- how to fix window coming off track(small write-up)
- new suspension creeking..
- Type R Bar by Steering Rack?
- is it worth it to...
- civic console
- is this a good cam set up?
- Where to start.
- what size muffler for ek?
- No reverse in H22 EG hatch...anyone else had this problem??
- cold air intake
- help with eg wing
- D16Z6 INTAKE MANIFOLD
- D Series Crank Question :searched:
- My Garage Sale!
- front upper strut bar for 02 civic lx
- where can i buy a cheap intake for 99 ex
- Funny Click/Knock sound when Starting
- help?... please?
- another.. rear brake conversion problem
- 99 Electron Blue Civic Si STOLEN 9/1/03 in KNOXVILLE, TN
- toed out?
- intake mani flow
- How to sell my car?
- d16y7 parts!!
- mounting V-afc
- muffler fitting problem on EG??? Help needed asap.
- Funny noise when I turn
- any one know how to install gsr rear disc brakes on a 92-95 civic coupe ?
- t1r titanium exhaust?
- Carbon Fiber Moonroof?
- skunk 2 drag springs
- Can we say Hack?
- Hybrid guys: Whats your weight?
- racing seat cell phone holder?
- Noticed Greddy Turbo Kit for 92-95 Civic Sohc Vtec = no BOV...why?
- does any have the jdm type r style racing seats ?
- New pics of the H22 VX -- GSR dash done, 5 lug almost done 56k killer
- For those of you with auto vtec?
- doors wont open on sol!!!!!
- 92 hatch gsr/h22
- Car starts, dies and then won't start for again for a while...
- do the jdm 92-95 civics come with orange/amber front turn signals?
- NEED Carfax PLEASE.
- Those of you who have replaced bushing in the rear LCA's.
- Major Vibrating at 60mph then braking
- type r style rear lip wiht world sport exhaust???
- CRX.... Good deal???
- any potential for y7
- Is it possible to drop a K20 in a civic hatchback?
- Retiring N1...any comments about this setup
- Just got a new '03 NBP d17a2 Civic (daily driver)
- b18c bottom end and turbo
- d16a6 or d16z6?
- Lookin for b20 info/ tried search
- Please Help! Skunk2 D-series intake manifold
- Magnaflow Exhaust Recessed Too Far
- which thottle body?
- Polished my Valve Cover Today...
- Quick Ratio Manual steering racks from Moroso. What happened with that?
- Engine help please
- getting closer and closer to swap.
- tailgate light problems...
- Steering WHeel Help
- Request: Jimfab motor mounts installed pic
- Intake manifold came like this :(
- HELP: exhaust for hatchback
- HELP: will i rub with htis setup
- obd1 gsr - hooking up vtec help
- 94 Cx hatch weight?
- homemade heatshield / heat transfer.
- teal green civic owners
- 1/4 time for b18c5 swaps
- d series tranny
- Running OBDI conversion.....need to go back to OBDII ecu temporarily
- b18c swap - a/c bracket needed with no a/c
- used OEM headlights?
- a new cam
- KYB AGX Setting......what do you guys have them set on?
- EG acting funny
- wiring for jdm itr srs steering wheel into eg
- how much would a ..........
- Recaro seats
- Whats should my Fuel Pressure be at in my 00 Si
- Best Turbos for a B15
- d16y8 in 90 CRX DX
- cluster question
- B18b total volume for transportation ?
- 92 civic fuses layout?
- hellllllllllllp
- IACV
- Sway Bar
- ls cluster into a eg????
- 88 to91 crx- prelude wheels (blades)
- H22A4 into Del Sol Anyone?
- Brake question
- whats the difference? 96-98 99-00
- New Shots Of My Sol
- Need opinions
- question
- Apex N1 what are your thoughts ?
- can someone put in my remote start for me?
- D16z6 died last night. Is there any hope??
- Check engine light?
- Need some help in restoring my Ek
