View Full Version : Honda Civic / Del Sol (1992 - 2000)
- No heat!!!
- climate control problems
- jdm wheel
- 00 civic si bumper
- edelbrock
- HOW to install aftermarket cam gear ?? WTF ? woodruff key ?
- Need help, CAMSHAFT , Diagnose , ? {can i still use} ??
- Just bought 94 EX coupe, TRAnny problem?? HELP?
- need help in jdm taillights
- exhaust question
- k20 type r swap into eg coupe
- A little help on motor choices..
- 99-00 Si cluster into 96-98 ek
- Steering wheel noise
- thermostat housing
- Confusing idle/throttle problem
- skunk2 intake manifold
- looking for jdm tow hook deals
- hey fellows can u guys guess or verify this tire and rims size ?
- Looking for a B18C GSR
- Need help w/ O2 sensor wiring on B16A swap 93 CX
- Ek jdm fenders? where and price you found them at?
- qestion about camber kits
- where can i buy a distributor harness?
- Eg springs/shocks
- 92 civic si manual tranny oil?
- skunk2 springs rubbing?
- ***not going into gear feels like its in neutral***WTF
- Del Sol wont start
- Good obd1 ecu for stock b16a2 swap
- D16y7 heat shields
- will 99 dx hatch fenders,and hood fit on 96 ex coupe?
- prothane bushings
- B18b1 O2 sensor
- repainting my valve cover
- D16Y8 intake manifold on D16Y7 motor?
- 2000 Civic Eletrical Problems after Dash removal
- New to Honda, need ideas for 95 DX coupe
- window tint
- Lots of White Smoke...
- car stolen busted ignition replacement
- OBX LSD in a 2000 SI??
- Cam timing help!!!!!!!!!!!!
- Eg hatch: idle control help.
- I hate V-Tec!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
- EK9 Fender question
- Secret scratchers, not secret santa....
- why does my car wig out when i jump it?
- 98 Civic + Momo Wheel
- idle adjustment?
- Exhaust question
- 215-50-15 rub on civic?
- Will These Trunk Lifts fit????
- I hate theives!!!!!!!!!!!!
- Question EJ6 97 CIVIC MANIFOLD D16Y7
- need some help with my cluster
- 92-00 suspension components
- eg hatchbacks 92-95pics only!
- tires rubbing!!
- Need help on timing!!!
- Tranny on eBay
- EG foglight install
- Name of extended short shifter
- 94 Civic EX MTX - clutch destroyed?
- any1 in the bay area need a distub dx.ASAP
- Electrical Load Detector
- (SOHC) D16z6 Tranny help!
- slow b16!
- CKSF sensor questions??
- h22civic owners
- 00 SI o2 sensor problem
- wtt: shaved del sol doors for stock door
- airbags yo
- Which resonator or cat?
- cluster lights?
- A little header identification help please??
- quick question for the vets
- Fixing vss
- EK C-pillar B-pillar bars
- eg6 cluster in 92 cx
- Exhaust question: Greddy Evo2 to a Sp2?
- retard or advance timing?
- Part Numbers
- Low idle w/ H.I.D.S ON
- squiggly tach at high rpm only
- How much is my car worth?
- Hid ?
- How to remove CF cluster bezel?
- 1995 Honda Civic LX 4DOOR drums brakes to disc brakes conversion
- surging prob. PLEASE help
- How do I access rear sunroof drainage holes?
- HELP! Possible clutch problem?
- B18C1 help
- p06 to a p28 ecu?
- 99 civic si mudflaps.
- Bolts that the valve cover bolts to are stripped
- 92-95 OEM front lip fit 95' Sedan
- Trading my "mini-me" Del Sol for 92 hatch. Looking for input
- B18b
- transmission question
- GS-R sway bar on to an EK?
- oxygen sensor code 01 (extended wiring)
- EG6 Audio Console
- Tranny ID number
- 93 Honda Civic EG9 is it worth it?
- anyone used acc auto carpet? how is fitment compared to honda carpet?
- Hard To Move Lever From Park To R, N And Drive Help!
- hey everybody im new to this site
- help with bogging
- apx afc neo,, need help
- 1999 ex's tire
- AEM V2 Install Help
- Best battery?
- How to test my engine light with a OBD1 ecu
- EJ COUPE MUGEN WING??? where???
- gauges inop
- need helpe on my new engine coming in.
- spoon ek cluster
- sound from my tranny need help!!!!!
- Ebay headlights?
- c.f. trunk
- Clutch Suggestions (2000 SI with Vortech H.O. kit)
- Shocks what the best bang for the BUCK!
- Midwing Installation
- I think it's code 67??? Video Inside
- civic dead, need help.
- cruise control question
- wanna put an 2000 front end on my 98
- dohc zc into a 95civic coupe
- 98 kick panel fuse diagram
- need help with an s1 b16 tranny
- Need Help Tuning DOHC ZC
- no reverse lights
- weird atarting problem
- need help removing dash 92 civic hb
- problem with the heater...
- Help me with my new D15B
- input shaft bearings
- Alternator not charging. 92 civic
- 96 civic in accident now wont start????
- B16 vs B20 on nitrous...
- Cigarette lighter high voltage
- how to put aftermarket tachometer in cluster (Ek)
- anything else needed after IM install?
- what engine
- k20a in a 93 dx
- code 14 IACV
- Turbo a D16 Help?
- H22 93 civic BAR-Where does this valve go?
- what is this called??
- Gauge Cluster
- Got my EG broken into.
- K20 info all of them all spec
- no pressure on fuel gauage
- Whats D16a6/z6 compression ??
- Help! 97 Ek Hatch low mpg?
- turbo kit good or bad for my civic gsr?
- Type of air filter for AEM CAI
- gauge cluster
- Mini-Me Question, ive searched, i cant find my answer. TIA
- HELP! Bumper bolt stripped
- what rims to buy
- engine rebuild cost?
- will clutch fluid flushing fix this issue?
- Noise when starting
- H22 euro-r
- No Turn Signals, No Hazard...
- Del sol Master brake Cylinder
- Jdm cluster door indicators
- Obd2 motor to obd1?
- z6 mani on y7
- How to install rpm gauge
- annoying oil leak.. sensor is stripping. what to do?
- Stock gsr compression?
- NEED HELP! ls/vtec stalling when warm
- Another problem
- rear bar parkers.
- Shift Knob Lock Nut
- z6 CEL after 6000RPM
- Mount problem/Question
- Replaced Rack and now cant get aligned!
- just want to make sure
- itr pistons..can i go turbo????
- question for skunk2 lca owners
- all motor sohc info
- Recommend a place for me to get my timing belt replaced? (So Cal)
- turn signal keep cutting off deck...need help!!
- where to Check my vins numbers ?
- vss problem
- mor help on springs for 98 CIVIC HATCHBACK!!
- Detachable steering wheel question...
- GSR Cloth seats fitment on EK?
- Looking for hx rims
- Apex'i WS2 Exhuast
- Steering wheel removal
- motor swap wire harness q
- Del Sol Seats + CTR Rears
- h22 euro-r
- 2007 civic si seats in a eg yes or no
- H22 axle question
- Mods
- Sweet A## rims for my 1993 Del Sol...........
- Possible Main Relay issue? What do you think...
- sry but i need help with pics.
- engine swap problems
- Need corner light wiring...
- PW and PM Quick Question
- OBD1 Jdm Gsr Engine color code HELP!! *Please read*
- EG non-si... swapping in jdm GSR and using sohc si harness... few wiring questions
- Honda center caps
- Blinkers work but parking lights dont.. WTF!
- timing off?
- CTR Pulley & the Bad
- Integra: dash, center consol, door panels, cluster ect
- my dream hatch
- 9,500 rpm D16 sohc ?? WHAT
- cam noise?
- Acura 97 1.6 EL primary O2 sensor compatibility
- Ls/Vtec, But not Vtec
- grinding/cluch problem
- RPM vs. Heater???????
- how to retap a crankshaft thread
- car over heating....
- 1998 EK CX 5 lugs conversion~
- Axle stuck in tranny, this happen to anyone else?
- Broken crankshaft bolt!!!
- d16z6 swap ECU question
- Speedometer not working?
- question about mounts
- 1993 Civic DX running hot/water leaking...
- Nose Mask Durability
- need help!!!
- engine bay...
- Needle Bulbs
- Fuel Filter???
- Changing water pump on 93 civic dx
- Stolen car
- Civic Hatchback Inside Brake Lights? (EG/EH)
- Checking for keyless entry...
- ek hatch, Gsr swap, actin up....Need help
- window not going up
- k24 swap in 95 del sol..need help figuring out shifter set up
- Failed EK auto theft attempt
- rear disc swap help
- Best HP set up for d16z6 turbo
- Radiator "fix" + screwed by the shop
- idle drops to almost 0 than jumps
- b16 turbo
- BACK in the honda game em1
