View Full Version : Honda Civic / Del Sol (1992 - 2000)
- 99-00 climate control into a 96-98 EK
- Who can Tune Apexi Power FC?
- WS Vs. N1 Piping?
- breaks acting funny
- turbo for d16y7
- Omipower coilovers?????????
- Distributor bearing
- EM1 question about seats
- HELP...THREW A ROD!
- 96 Civic S40 Transmission Problems
- CD plaYer Prob.
- Help with CEL and sensors
- Slooooow passenger window
- Broken Key stuck in ignition cylinder.
- Wierd start problem after getting gas.....
- P1457 code?
- Which integra rear seats will fit into my 97 4 door Civic
- i need a 90-91 4 door civic....5spd
- vafc is it worth it ya or na
- heater and air controls not working, or mirror controls
- codes
- Intake and exhaust for '04 Civic
- All Motor b18c
- Cam Gear Questions
- whats this on my Throttle BODY?
- projector head lights (angel eyes)
- speedometer stopped working
- Someone help, check light throwing code 20
- give me some imput
- How much would you pay to have your swapped car BARed?
- need ek some one sell too me
- k20 swap for sale for $3500 located in southern california
- sunroof has trouble opening
- ? about putting integra front swaybar on 92 CX?
- clutch problem
- How can I check timing in my car?
- climate controls
- replaced engine no wont rev over 3 grand
- i'm new ...help me out
- thinner headgasket for d-series???
- Help me clarify this wiring chart!
- Braking Problem/Rotors Problem?
- b18 specs
- How big is the muffler from the 92-95 si? 1.75 or 2?
- Exhaust size help...
- my 2 weapons
- Japan Honda vs. USA Honda???
- ctr valve spring question
- b18 into Eg, yes...Eg into teg???
- JDM 92 Honda Civic EG4 D15B Rear Interior Conversion
- lowering the car today
- quick question
- Nutty-ass idle problem...
- Cutting Stock Springs To Lower Civic... Good or Bad?
- Big Suspension Problem
- 00ls eg swap ?
- Shop?
- Speedo...
- EK Si 5-Lug Anyone Have Write Up ?
- fuel pump /swap question
- Starter Solenoid Help....
- wierd noise in ek
- rear bumper question
- Check out my modded FPR
- TECH QUESTION: Rear lower control arm Install?
- 14" rims on a 99 Si
- white leak???
- California legal headers
- trying to decide
- transmission swap
- Prelude 325 injectors???
- hyper voltage system
- Good place to buy a 255 walbro fuel pump?
- need help so frustrated w/ sidemarkers!!
- Omnipower Coilovers and Koni Yellows
- 99 GSR dizzy with swap in my EG? plz help
- possible clutch or tranny problems
- MAP sensor code problem.
- Head Gasket Fix and Problems
- K series into my 99 hatch
- Cant find it
- Help Broke Bolt off in engine head!
- Bork3d exhaust
- RESETTING MY SRS LIGHT
- Problem after Disk swap....
- anyone ever heard of eagle alloys?
- Wanted: streering wheel pics...
- I WANT TO KJNOW WHY I GOT LOCKED I JUS WANT TO SIGN ON IN MY NAME ON MY FRIENDS COMPUTER
- UCA or LCA
- megan racing muffler... any good?
- NEED TO KNOW ASAP HOW TO LOG IN ON SOMEONE ELSES COMPUTER. AND DONT TALK TO ME LIKE IM STUPID
- SRS Light????
- EK 4pt bar$$$$
- 93 hatch w/gsr swap, SUSPENSION PROBLEMS.
- D16Y8 Cam shaft Q's.....
- Quick Question from a newbie to the revelation called HONDA
- Exaust question
- what console is this
- HONDA SUCKS
- did i do my ignition timing right?
- tach problems and have searched
- Gun shot exhaust????
- Civic broken into..add me to the list..
- HELP! QUICK QUESTION...
- Another Korbach review. (Not all its craked up to be)
- drain location on ek radiator
- please help...i need info fast
- weird looking gsr head? HELP...
- Cai question
- INjector wiring questions....please help asap -
- need help
- help! CEL 9 popped up in friend's car
- Rally Civic
- hatchback interiors
- ELD?
- shift linkage install question
- will 95 civic front seatbelts work in a 97 civic?
- Any B17A EG's here?
- I have Tokico Illumina suspension: is it ok to leave it on five in the front?
- when can i use PM's
- What suspension on a delsol?
- Nology Ignition Coil
- Looking for a full titanium catback....
- my new project car
- titanium piping?
- Jumpy and gapped Dyno graph...
- Help car wont start!
- adjusting the fuel pressure and fuel pump died?
- what's the valve clearance on a 95 civic ex?
- need help finding lsd ..itr?
- Speedo problem
- stock 0-60 time
- Shocks and springs...
- Where to get timing check
- a theif got what he deserved
- best cylinder head for a d16y7?
- Help!!!!
- Check Engine code
- gsr cluster??
- I found an automatic engine.. but i have 5sp.
- DYNO/TUNING SHOPS in IL.?
- obd1 to obd2
- b16 topend help!!!!
- How much can I get a Eg for?
- Candian SIR's OBDII is it the same as U.S Version?
- Help to get door panel off?
- help me please, b16 problem
- Will a 99-00 Si airbox and intake work in a 96-98 hatch w/ b18c5?
- Hot... so very hot
- For all of you that said to me that......
- Quick easy post, i need ot change my thermostat how i do it? and a quick thermostate problem...
- would 90-93 integra rear trailing arms and brakes fit on my eg?
- yet another seafoam ?
- which REF STATION should I go in S Cal?
- ls OBD1 into 96-98 Hx
- take out the cruise control button?
- CAR FREAKIN OUT! HELP!
- eg rear speaker
- 1993 Civic Ex axleback exhaust
- How to clean D16Z6 block
- i'm a newbie with a D15B7. Please help!
- Headlights problem low beam not working high beam works
- 2004 civic seat swap with acura?
- what seats would fit a del sol (civic, integra, etc)
- will a 99 civic si bumper bolt on to a 1997 civic hatch?
- D16z6 spark plug gap question, distance????
- No fuel?
- Time for a new ride....
- H22a?
- CV BOOT REPLACMENT HELP
- D16Y7 Auto - B16A2 Manual
- y vtec?
- is a d series non vtec engine worthless?
- Squeaking
- Cold Air Intake
- EK9 5-Lug=USDM ITR 5-lug Correct?
- SPOOOOOON calipars.......
- Hatch skirts fit del sol ?
- can't build pressure in my hydrolic clutch
- towson maryland meet anyone?
- 96 honda civic d series
- Tail light problem.
- from regular to synthetic
- what markings are on a 92-95 ex/si sohc tranny?
- what models came with side moldings?
- Seafoam fun
- need horse power for a d16 non vtec
- Anyone have Tein-SS and live where it snows?
- Suspention Trouble Shooting
- honda civic 03
- City Lights
- d-series bored sleeves question?
- Water leaking in hatch tail lights fix
- oil
- Liqiud coming from exhaust?
- weird idle....wtf???
- Best way to flush coolant system?
- EG tranny problems
- brembo blanks
- Del Sol Wheel Weight, I searched
- Anyone have information on Team Empire or Vista Empire??? Car stolen.
- I am having starting problems with my 94 EX need help.
- is this a good deal?
- Del sol vtec transmission
- Civics Stolen in Charlotte -- University
- winter performance
- Jack Stands on all 4?
- Could someone run a carfax on this Del sol???
- WTB cheap civic hatchback 92-97 let me know something please
- 99-00 Front end?
- camber
- Coupe makes Squeeky Noise evertime I Hit a Bump. ????
- tie rod 93 civic EX
- Suspension Techniques Drop/Lowering Fork
- removing o2 sensor
- Speedometer issue
- my 2 weapons
- where r allllll the cheap hatches at lately????
- Chasis code help..
- Puting integra seats in a EG
- where to buy ITR 5 lug conversion?
- SMSP header
- it wont fit
- where is the EGR valve in '93 Civic EX ?
- Water Pump tube how the hell do you get it off?
- Wondering if anyyone makes a powersteering removal kit for my car i have a ek
- Wondering what the best aftermarket radiator is to get for a ek civic
- Lost my Key..help?
- Smell coming from air vents
- Skunk2 Stage 2 cams on stock 00 civic SI. Can it be done?
- B18C5 Questions
- Domelight and wiper not working - 1999 Honda Civic
- LS/VTEC TIMING
- can i use a y8 mani on a vx head?
- starting project.
- This is a little fishy to me....No tech just a heads up.
- Distributor Wiring Problem (8 wires and 9 wires) HELP!
- different idles during the day and night
- Auto to Manual: Clutch/Brake Pedal Assembly
- poopy vtec and CEL 3 on swapped gsr
- mini me swap question with pistons?
- clutch slipping help..
- Offset help.
- where can i find a performance cam for an hx
- How much does a 1996 civic hatchback CX weighs STOCK
- Poll: to rebuild or sell
- quick question......
- Wiring a 5" Auto Meter Tachometer into a 1992 CX???
- What makes the JDM ITR shifter\linkage so good?
- This dosen't look good...
