View Full Version : Honda Civic / Del Sol (1992 - 2000)
- need torque spec on b16 motor mount bolts
- Gold Civic Introduction
- Do i need to add vtec wiring on type r
- itr oem: header, exhaust, intake manifold, cams on b16
- Stolen Civic
- h22 or ls/vtec swap in ej1
- Suspension question
- Is there an easier way to change springs?
- My $400 92 civic shell find!
- timing belt
- Intake manifold advice please
- Buy or Upgrade
- 93 dx...( fan stays on all the time )what to look for?
- Question on Harness/ECU
- prewired for vtec?
- eg interior pic request
- turn signals wont blink and no gauge in dash is working
- removing timing belt cover
- B18 Timing Issue/Question "Where to line up marks"
- eg with b18c1 a/c question
- 2nd Gen GSR seats in 96-98 Civic EK
- which wing/spoiler is that? EK
- Black molding near driver side + passenger side
- SRS light help
- timing belt change help...cams wont line up please help asap
- idle and tachometer issues. please help.
- d16y7 gasket kit on y8?
- Del sol camber kit install help needed
- motor mount install
- crying engine bay ??
- 96-00 EK Hatchback Interior Quarter Panels.
- d15 - B16 Motor Mount Questions
- left or right for driver side handle?
- 99 Civic..sudden loss of power??
- My 95 EJ2 coupe
- has anyone replaced front bump stop?
- Saw botom half of a motor turn without top half turning. Damaged?
- b16 eg wiring harness problem??
- front component speakers
- Tinting sunroof
- half shaft bolts
- Hissing Sound from behind water pump
- 95 Si Shaved BAY
- What's the difference between P07 A00 and C00
- 1992 civic si vs. vx weight
- Need help sourcing instrument garnish
- Whats the difference bewteen these ECUs?
- Where to buy 99-00 oem fog light covers?
- need info on crankshafts
- need help with brake conversion
- CTR wont start!!
- Wonder how much mt em1 is worth
- car wont turn over just clicking....
- Throttle-off lag in my '93 DX (D15B7)
- I just dont understand the whole EJ thing?
- Is an ebay exhaust worth it???
- Im Swapping d16y8 with d16z6?
- Sensor Question? Interchangeable ? MAP TPS?
- Swapping B16 in my sol - wiring questions
- ej8 96
- Will a DC2 Mugen Twinloop axleback fit an EK4?
- obd1 b18c1 into a em1
- 95 EJ1 Coupe EX Suggestions
- XTD racing stage1 clutch or an Exedy?
- ac question on b16a2
- 92-95 Manual Pedal Assembly Question
- Sensor Or Cat?
- mph not workin
- need help with b20b engine swap
- need help with 93 del sol speedo MPH not working
- 98 ex B16a swap
- EVAP on B16
- priced LSV? HELP!
- 3k+ cold idle
- My harmonic balancer came off when I was driving! WTF?
- Stolen 2000 civic si =(
- CScivic22 Build Thread
- weird noise trans maybe?
- auto / manual ignition - difference?
- 95 civic coupe exhaust for 97 civic sedan?
- i got power but it wont start
- y8 b7 mini me not working, can i get some help plz
- What DO I NEED to REPLACE for a 60k Tuneup?? EM1
- Mini Me Swap.
- help
- F1 Stage 1 Clutch vs Exedy Clutch?
- Help me Decide Mini me or what....
- Best cams for the buck
- 2000 Si - oil pan stud tq.
- **PICS**Put Type R Intake Manifold on with unknown hole that wasn't on the stock b16
- Whining noise from cluster
- Timing Cover question
- D16z6 head on D16y8 block, few questions...
- bogging and hesitation with fresh b20
- CSF Sensor OBDIIA
- Is 94+Integra ABS Master Cylinder Compatible with NON-ABS EJ8?
- Auto-5 spd car won't start
- car dies...
- P.O.S. Stock Radiator
- Can't open hood
- does any one know a good body shop in chicago?
- photoshop request
- question on jdm b16a???
- 91 prelude seats in a 92 civic hatch?
- will a d16z6 tranny fit a doch zc motor?
- 1993 headgasket change question
- 1993 Del Sol Aux. "Lightmare"
- 1997 ex with poor man type r
- What tires?!
- d16z6 fuel rail on b16a
- Widest rim size?
- Help: Viper alarm/Civic wiring 97ex
- help me
- car wont go past 2k rpm
- B16a valve lash setting?
- Speedometer and Cluster Light Don't Work
- Need a shop or someone....
- HELP OBD2A to B HARNESS
- engine swap poll
- D16Y8 crower cam, stage 2 63442Y, will it work in d16z6???
- 99-00 ek hatch how much hp does it have?
- A/C Switch Help?
- weird idling issues
- Spark Problems
- Can this be done SI to S
- CEL Code 22 D15B
- hello (:
- Civic EK4 SiR Head Lights
- 00' Si is it a 2 row radiator????
- 2000 civic si running problem (uk spec)?????
- getting the monster back.
- Running no thermostat while performing coolant flush?
- What do i need for this?
- Trouble Starting
- y8 on b7 mini me not working need help, sorry
- vtec engagment
- Bumper height of civics?
- shift linkage ?
- CTR interior questions
- ASR Subframe Brace
- 99 SI vtec loud but doesn't pull.
- vtec wiring
- 1993 civic VTEC spool solenoid valve
- ID these lips
- Car drives sluggish pls help
- 94 hatch starts than dies
- Fuel Pressure
- Looking for some clean pics of EJ1,s
- Manual Swap
- Need some help, starting issues
- Need Help Car will not passs 6500 rpm
- hot tank? honing and bored?
- I need your opinion on these Struts... PLEAZ
- question about sanding valve cover
- Integra door panels into civic
- bent frame
- how hard is it to build a motor
- identify prop valves
- Distributor Compatibility between 92-95 1.5 and 1.6 motors?
- Dilemma with headers
- Header installation question (pics)
- b16a2 into 96 dx hatch: obd2a-obd2b question
- engine swap/ideas** need ppls opinion
- ek hatch side skirt fit coupe?
- thought i would get a better response here. fit for dd?
- What mud guards are these?
- 97 DX Manifold Converter Torque Values???
- Automatic Dizzy in Manual Car?
- 1991 Honda D16A6 build
- Header help fast
- motor mount bolts broke in block
- abs control unit/interchangable?
- 96 Accord Keeps reving up and down at high RPM's
- d16 tranny
- civic picture thread?
- suspensions Opinions?
- INNOVATIVE street mounts into ek review
- Type R/b16 valves cotters retainers combo?
- Integra LS cluster into 97 Civic DX.
- D series out B series in
- Ilregular Idle
- misfire and idle problem, please help
- looking for pics of hatch with ws2
- Any advice on polishing my GS-R's??? (fat fives)
- What do i need to complete swap? help!!
- Radiator antifreeze DISAPPEARING..HELP
- d16z6 mini me with y8 intake mani, ecu?
- Another brake/suspension problem, please help.
- 1998 civic climate illumanation change
- '97 EX Coupe Keyless entry-Aftermarket radio
- Help! Car won't start...
- power when car is off
- Can't get torx screws out
- O2 Sensor Help on Civic CX
- B16A swap, VTEC hits at 5300rpm
- Wheel Stud Help!
- Can I get a pic of YOUR EK driver side mount?
- Del sol w/B18c swap...I need air cond. help
- I need a ex harness 96-98 for civic ny area
- 92-95 Honda civic floor Carpets??
- delsol b swap sohc powersteering
- Where does this hose go?
- what size injectors should i run full N/A build help ?
- Need motor mount help !!!!!
- IAT cel code 10 Help!
- Wheres power steering belt? Ej1
- Park and D4 indicators at ignition
- how to loop or delte PS correctly
- My hatchback got stolen!!! Atl people help!
- Exhaust System
- civic tie rod ends
- Is there anything like this?
- Rear disc conversion question
- How much would you pay for this sol?
- full gasket kits from ebay?
- walbro fuel pump
- My 00 Si stolen
- EK OEM Hood Bra
- jdm b16 oil pan gasket
- Any way to paint my EG carpet Red?
- Power Windows Automatic roll-up
- Please Help...A B18C swapped EG9
- whats the name of this gasket??
- crankshaft pulley question
- Fuel pressure?
- got a jdm b16 in my ek. how would i run a caT conv?
- Is there a way to fit 5 x 100 wheels on my Civic?
- ecu questions please help...
- where to get CTR PF mirror SWITCH?
- VTEC oil pressure switch circuit?
- question regarding setup
- doing a b20 vtec
- ecu ?'s
- Polyurethane Insert On 98 Ex?
- EK front cowl part #?
- cluster question
- Ecu help...
- will b16A FIt?
- Wiring headunit
- USDM ITR seats into eg coupe?
- How to fix running rich?? Em1
- So I got CTR Headlamps
- 92-95 Rear Bumpers
- exhaust leak into cabin help
- Rear engine mount
- Rear Disk Breaks
- 2000 civic si factory lip kit
- will this pass smog?
