View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Funny noise and loss of power
- how do i reset my computer p28
- Distributor question
- DIY : Walbro fuel pump install
- wiring help...
- get into mid rpm range...bog down. problem???
- HELP!!!! Walbro fuel pump install problem!!!
- EG Depo Foglight help.
- JDM cars, chassis numbers different???
- how to change spark plugs
- should i get an aftermarket steering wheel?
- 92 Civic hatch or 98 Acura 1.6EL
- Estimate price of B16A2 swap into 92 vx hb?
- B16A2 Burning alot of oil
- Difficulty changing camshaft on SOHC ?
- 97 Civic Dx Swap
- Using a p30 ecu on a GSR swap?? NEED INPUT
- auto tranny
- Hatch wont start! hellppp plz
- stage-2 Y8 Cam fit in Z6 ? help!
- S2k cluster in EG with a K20
- Easy Question: What size is a OEM JDM GSR exhaust manifold flange? 2 1/4 or 2 1/2?
- want to turbo my car dont really know where to start.
- just joined and wanted to say what up to everyone!!!!
- evap controll canister where is it located???
- Need some help?
- tranny codes
- Sir or oem headlights
- honda civic D15B7 head swap please help
- z6 cv axles question
- V-Tec
- d16y8 tranny ???
- Manual steering rack vs. Power rack mounting...
- my 97 ls-t is acting up, have no clue what it can be, please help!!!!!!!!!
- *TRANNY AND BLOCK ISSUES*
- 92-95 oem fogs
- 92-95 si
- quick temp. question
- Muffler ? teg on an EG ? ? ? ?
- HELP!
- Getting Head...Haha J/k...upgrading motor, but still CA smog legal...how?
- Odd gauge cluster problem....
- 92 ex sedan- no spark- help please asap
- anybody here know how to fix an offset light?
- Dre's Civic
- Making a OBD0-OBD1 conversion harness. Soldering Help!!!
- rear disc swap and broke some bolts
- HB pulls power on and off
- Burning Oil but not smoking?
- how much can i get for civic head lights
- Black soot?
- hids in eg6 headlights
- (SEARCHED) DOOR SKIN INSTALLATION
- EG fuel pump question.
- which sensor is this? (picture included)
- Is this harness from a Civic of any year?
- 95dx motor in 93dx
- cx swap
- Midori green spray paint
- NEED HELP 92 CIVIC CX STEERING STIFFNESS
- exhaust(s) ?
- Replacing bulb!!!
- auto/manual intake manifold
- Help me estimate the wheel and tire size and the offset of this EK?!?
- apexi WS 1 exhaust sound clip
- D15B Vtec Opinions?
- Exhaust line path... thinking about my options?
- exhaust size for B16a
- so tell me you EG freaks!
- powder window and lock conversion parts list
- Will these rims fit?
- NEED JDMB18C1 OBD-2 HELP
- Two plugs on the back of the block
- my radiator is clogged......will flushing it fix the clog???
- FOG LIGHT HELP 2000 SI !!!!!!!!!!!!!!!!!!!@$%@$%@$
- starter removal help needed
- bleeder valve question
- jdm eg cluster qusetion (about blubs and needles)
- Need steps to bleed brakes
- Need help with jdm power folding mirrors...
- Alignment Good?
- So I got a b16A for free?
- JDM d15b IM VS. d16y8 IM
- annoying road noise in rear
- in need of an "extra lenient" smog station/smog person
- H22A tranny problem (reverse)
- B16A2 Power Steering Pump & Bracket Question???
- IAT Sensors interchangeable?
- b18b into a 92 vx hatch wiring question
- ej1 rear seats
- i keep breaking my driver's-side axle
- Anybody know if you can/where you can get this stuff...
- ek exhaust ?
- gsr into a ex vtec not working
- questions??????????
- 96-00 spoiler on 92-95
- Lookin for specs on a 95 civic
- I-VTEC Module ?
- What kind of TRANNY is best for a JDM B16a 1st gen?
- whats a b16a8
- electronic oil pressure is leakin oil... what 2 do now
- Need info. EK steering wheel on a EG hatch HELP
- Someone must know...ebrake cables...Integra-99-00 Civic Si's = the same??need help!
- Passenger window in eg problem
- Will a 99 civic DX ECU work with 98 b18b motor?
- Anyone with the NRG short hub?
- did gsr swap into a ex have a clip on wire harn. dont know whats its for
- CTR Steering Wheel nooooobie Qs? NEED HELP FAST!
- 92 civic jdm fenders?????
- y8 tranny improvement
- Can anyone please identify this part?
- What did I snap?
- Green EKs
- why is everybody running a p28?
- my b18b1....
- si Lip
- WTT: 00 Si, 70,400 mi.....Tennessee; must see
- header ?
- Lowering wrenches needed to adjust omni full coilovers?
- my alarm problem
- EJ vs EK
- question about reusable parts
- EG hatch colors
- my car wont start
- Exhaust parts for a swap..ek?
- CTR Power Window Switches on USDM, dual window switches on RHD?
- first post thought i would ask everyones opinion
- d16y8 question
- Widest tires possible
- i think my tranny took a dump!
- brake setup
- Adding more TQ to a B16A 1st gen.
- 97 del sol b16a2 into 97 civic ex "yes i searched"
- ASR [aspec, a-spec] subframe reinforcement: compatible swaybars?
- PRELUDE BRAKES ON A EG?
- Speedo, and Tach not working????
- whistling from throttle??
- Battery light constantly on, where should I buy an Alt from?
- Blown Headgasket?
- Any DIY's on how to remove LSD from tranny?
- CEL turns on and off...
- EK4 brake pads
- dc camber kit = 95 coupe camber kit?
- who has done a GSR SWAP ina EK
- my fan dont turn on?
- IM gasket question!
- Is this a GSR tranny?
- I finally got J's Limp Penis for the EG!!! look inside
- KYB AGX top nut: I hate you!
- eg? or ej? axel help
- B20 bottom/B16b head???????
- Pics of my Sol
- Cruise Control lines
- ek9ctr cams
- Another kseries how to
- Anyone knows who makes these for EG....
- A/C HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!
- is it ok to block off the egr
- help with hkb hub install
- remanufactured distributors? good or not?
- Type R head on a b16a?
- ECU CUT OFF SWITCH
- braking wheel woble
- Clifford Alarm Question.. car won't start!
- How do u elimanate Emissions?
- PasswordJDM EK OEM Foglights and OEM Style Aftermarket.. difference?
- Noise after getting New T-belt
- Triangle Tires
- I need guidance to greatness! NW Indiana/Chicago area.
- New to the Honda scene
- Anyone know any sacramento area engine shops JDM.....
- looking for b16 eng,tran,ecu in ontario
- 03-24-06 - STOLEN Civic HB Silver CF hood/trunk blacktop keep a look out!!
- ek obd2-obd1 question
- radiator fan problem
- petty f***ing theives once again!
- 1995 Civic High idling problem?
- Civic Si/Gsr rear disc
- Civic headlight question
- HELP WITH SWAP!
- Civic Auto Door Lock Problem???
- LS Swap...for my EG Hatch
- Del Sol reliability? Thinking of buying one.
- oem ctr hids???
- Car Shutting Off Randomly
- first time at the track...
- B18B into 92 civic wiring
- Need your help deciding??
- Oil where it dosnt belong
- going to the track tonight.
- buy hid s???
- need swap info. help please asap!
- D series vtec head on non vtec block?
- Disappearing CEL (CEL) Check Engine Light
- CX Vtec-E Dizzy on a d16z6
- 94 si ... need some advice been without a car for a week
- Update on Mugen Exterior Part Availability
- Questions on Speedometer malifunction
- check engine light / vtech??
- Help!! Evap Question?????
- Are you looking to rebuild your block? Link inside!
- b16 daily car hook up....
- tranny?
- brakes upgrade question in dx
- Evo2 or N1
- Having issues with skunk2 mani & tb install...help!!
- Signs of a Bad 02 Sensor? What are they?
- Wheels off balance..??
- exhaust help
- d16z6 on d15b
- C1 or C5?? Help Me Decide!!!
- Quick poll....for CA swaps and BAR
- Sluggish accelerator...
- Zex 105300 Stage-2 - Valve Lash?
- Help No Power To Fuel Pump
- brake question
- Best exhaust for 99 Si ? (what would you buy if you had unlimited funds?)
- LS VTEC or B20 VTEC?
- del sol sideskirt options??? HELP
- Diffrence between the Z6 and y8?
- 94 coupe carpet in 92 sedan
- surging idle
- Brake upgrade and 15" wheels
- my friend just told me he bought a TYPE R
- ***Shift Light Help QandA
- has anyone have any experience w/ an ebay distributor?
- help with engine serial #
- 93 civic with 99 seats
- Transmission or Clutch Problem?
- 90-93 teg back seats in 92 hatch (searched)
- vtec controller on single cam? ya? na?
- sleeving?
- high rpm miss
- my temp gauge stays on cold
- HELP!!!! gauge cluster/turn signal/clock problem.....
- anyone eliminated abs on Si hatch?
- Help looking for d16y7/y8 conversion HOW TO?
- anyone know about this???
- lookin for engine harness...obd2a ex
- B16 swap into EG hatch
- "Spoon" VIS CF Lip Install EK
- CLUSTER QUESTIONS!!!
- Turbo how to?????
- were can i find a del sol lip?
- vtec not engaging/ low oil?
- EK '96-'00 Civic Password:JDM Aluminum Cooling Plate
- main fuse box diagram
- hot start problem + random stalling = bad main relay??? help pls.
- Break in period?
