View Full Version : Honda Civic / Del Sol (1992 - 2000)
- SRS Light?
- engine ID,HELP PLEASE
- EX engine harness on GSR motor
- new ek...carfax plz?
- My EG build Thread
- CTR Cams in a GSR
- need map for 96 civic
- The New Eg....Did A Little Tradin.... Ya Thoughts?
- B16 bolt on diameter
- turbo set up????????????
- Fuel pump
- Head Gasket question
- What exhaust?? quite first performance second??
- convert 96-98 dashwire to 99 si and brake light don't work
- AUTO WIRE HARNESS ON 5 SPEED .. HELP!!
- b18c into ek civic
- (please delete)
- 93 civic instrument cluster
- 00 si airbag question
- Dudes! Just finished an ls swap in my eg coupe...
- Quick corner light Question!!
- Civic hatch body parts
- H22 into 98 civic 4dr
- changed the tranny now fuel pump wont start?
- Need !HELP IDENTIFYING PLUG WIRES!*** 2000 civic si
- Swaping out D series tranny in garage noob...???
- HID Kit/Intake Suggestions!
- EG rear seat matching
- radiator fan
- Looking for a corner lens wiring diagram.
- EJ6-JDM ITR - 193.8 whp/133 ft/lbs - STOCK MOTOR / STOCK ECU : DYNO CHART INSIDE
- Rusted exhaust maanifold nuts stuck
- oil pan leak;what gasket to use? OEM or replacement
- please help b16 problem
- B16 OR GSR TRANNY IN MY EM1? LOOK!!!
- ctr intake cam?
- d16y7 to d16y8 help
- Gas milage on B16a swap
- Options for using integra alternator?
- is my friends 92si worth fixing?
- Ignition timing problem
- will the greddy evo 2 fit 96-00 civic hatch?
- 97 Civic dx Power Door Swap Questions
- Civic Misses when accelerating....
- How to spot a bad ecu??
- d16y7 intake manifold to d16y8
- 97 ex swap
- where is the wire i tap into for rear speakers in eg hatch?
- si sway bar question.
- Anyone know where I can buy something like this?
- Finished building my civic v. electrical issue
- Head gasket problem
- Very important question Reguarding an EG
- How much would you PAY for this?
- Exhaust leak question, help!
- Emergency Mini-Me swap
- h22a has a rod nock help
- b-series swap questions...
- Extended stud question
- is eg coupe and hatch carpet the same?
- another one of those is it worth it thread d vs b
- What's the difference between the jdm d15 an the d16z6
- Carbon Fiber Hood w/ scratch
- Erratic Idling
- cheapest bestest pads..????
- b16a i/h/e/skunk2 IM del sol at the track
- skunk2 intake manifold issues
- 93 hatch wheel bearing, how to?
- running lights in my EG wont work....
- EJ1 Engine Bay Clean up Questions
- Ej1 with ls.....Help plse....
- 2000 EM1 Si, project daily cruiser
- New Cams Binding. Please help!!
- did b16a2 swap have some questions
- Flushing the Rad. Question??
- LS swapped EG ( problems running )
- SI Dosnt Pull Like It Used Too... IDEAS???
- 97 ex swap questions
- does my lost motion assambly look ok?
- 1992 civic idle problem
- HELP! SWAP QUESTION
- !! needs a guide for replacing the entire drum brake
- 2000 EK civic SI factory security?
- h22 is in....
- Dual bend in del sol?
- Venom 400 Installation
- power rack need help to loop or not
- Clutch Life?
- 94 eg ferio boggling???
- Swapping a D15z1 vtec-e, into a 99 civic.
- Clutch choices...
- 97 Honda Civic - Need suggestions for replacing engine
- cluster has no power going to it
- Where exactly is the horn located in a 95 Civic EX?
- 1997 civic ex with jdmb18c swap obd2 diagonisic plug not reading codes look
- Ex/Si usdm clock not stayin at right time.
- bent rod?
- How to replace inner tie rod?
- Which MAP Sensor?
- Quick question on Eagle Rods
- sunroof seems to jam, scratches roof?
- motor swap question
- My new civic
- i need a new sunroof.any other cars are interchangable with a 95 civic coupe?
- Honda Civic Lx 2000 A.K.A The Killer From DR
- 1999 civic gsr swap ecu problem
- Manual Transmission acts like an Automatic
- rear sway bar????
- Clutch problems?
- loud exhaust, best direction to go?
- IM NEW!! SHOULD I TRADE??
- 93 civic ex transmission issues
- H22: tryin to get on road
- 1998 civic EX(ls Vtec) RICH AS HELL
- Help with low budget build!
- Swapped LS into eg problem ( help )
- HID's broken?
- 96 EK H22 internal or external coil?
- what other honda seat rails will fit a del sol?
- eg hatch wont get signal to injectors :S
- Help!!..Eg Coupe Steering Gone Crazy
- HELP sucked in water w/a '95 eg coupe
- Does a Chipped ECU make you fail smog check???
- Knocking/tapping from front end?
- Bike racks
- y7 to y8 im swap high idle holding 2k
- Stripped out threads. Anyway to re-thread?
- check list ??
- Super Loud Intake???
- Speedo Going Crazy
- built a 1988 crx for time attack
- help! white smoke?
- tachometer problem in 92 cx
- rear toe adjustment, bolt is seized
- lifetime of a carbon fiber hood?
- help: 00 civic hatch sounds ajar while driving
- B18b swapinto 92 Cx Hatchback
- lietime of a carbon fiber hood?
- Life of a carbon fiber hood?
- help: 2000 civic hatch sounds ajar while driving
- Stock EK exhaust.
- 99 civic ex, taillights dont work, fuse questions. pictures
- HELP H22 acting up It wont hold a steady rpm
- Any way to improve the turning radius of a Civic..?
- Eg AC evaporator O ring question
- Weird shaking in low RPM's (b16a)
- ek hatch spoilers questions
- Apexi WS2 or CTR Exhaust
- strut bolt heads snap off, what to do?
- 97 civic exhaust manifold question
- Ebay spoon power mirrors wiring to eg!!
- Failed SMOG - Civic DX w/ B18C1 - Please Help
- GSR output shaft seals?
- oil pressure switch
- temp guage goes to "h"
- new clutch: grinds when not pressed but not when pressed
- civic promblems need help
- 94 vx no highbeams
- ECU Chipping Kit... D16z6
- Steering Problems in EK, need help ASAP
- Junkyard Build
- axle question on a swap
- Car key issues
- b16/gsr trans synchro clearance
- Cruise Control NOT WORKING
- Anyone knows where to buy a good Throttle Position Sensor
- Em1 front left wheel bearing
- so i have 2 questions
- non power steering hepl?
- Motor swap general help!?ENGINE REMOVAL?
- subframe
- Just picked up my first Del Sol today
- RSX Seat Pan Swap (EG)
- loud rattling noises at high rpm
- leaking oil where left axle meets tranny
- Do 92-01 Prelude seats fit in 96-00 coupes??
- Removing injector wire cover
- help with cam specs
- eg b16 fuel rail?
- "Cheap" Gasket Kits?
- CEL code 41, help!!!
- Recent engine swap runs great but dies while driving
- Vinyl interior unpopular? (pics included)
- Del sol ==rear disc brake ????????
- Huge ratnest!!! Help
- Water Leak passenger side.
- Eg Jdm Console question
- helpp!!!
- sterring wheel shaking??????
- horn isn't working..
- an anoyying noise...
- EK CTR Shift Boot
- Starter/Cranking Problem? Fidanza Flywheel on a 91 Civic RT4WD.
- CODE 17: VSS Problem/Question
- 1992 cx civic timing
- wanted green floor harness 96-98 sedan
- fuel pump main relay problem
- Help! Need Opinion on skunk2 Retainer Condition!
- drop engineering motor mounts
- D series SPOON SPORTS HEADERS... legit check?
- 96-98 99-00 part difference
- '94 Civic wont start, please help!!
- erratic idle b16 coupe
- LS VTEC in B16 block?
- horn doesnt work
- how bad is it b16?
- HELP with my eg plssss!
- isuzu gemini
- Does anyone have the fuse box wireing diagram for the del sol?
- good place to buy Motor Mounts
- exhaust flanges can you order the weld on flanges alone somewhere?
- My 99 Hatch build thread.
- high compression single cam
- car wont start makes clicking sound
- Code 43 WTF???????
- A/C Compressor Oil.
- Low compression
- Engine misses randomly - new ICM and coil
- 1st time in the track
- finally got lsvtec rolling few probs though?!?
- 95 civic coupe k swap need help
- Clip for CTR Wing
- h22 into eg
- head gasket or something else??
- Removing air filter box
- Build Times
- lowering questions
- metal against metal schreeching sound
- climate control bezel?
- Need Head Code For 2000 D16Y8.
- My Dyno Numbers
- ek wiring issue obd2a , common problem
- JDM B16 OBD2 ?
- What's up, new EJ6 owner with Qs
- tps problem??
- Is this true about JDM B16A alternators? (RESOLVED)
- seat swap help...
- D15b ecu
- B18b1 trouble!?! Im stumped
- clutch line fitting sizes?
- Suspension setup for EK with h22?
- car wont start, keep blowing ACG fuse
- Here's my GY16P
- My Trans on my 95
- 1990 Civic Auto surges in top gear.... help please!
- interchangable seals/moldings?
- emission/inspection/ problems and question
- Nissan_Fanboy's EJ1 (B16a Questions)
