View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Advice for fellow enthusiast?
- !!!!!!Plz PLz i need help with building up my d15b!!!!!!
- Seat Swap options for 99-00 Civic Si...?
- 92 civic torque converter not locking into overdrive?
- help!!!
- power washing wheel wells on 95 coupe
- Odometer problem - VSS Issue?
- does anybody know the name of this lip?
- Hi everyone!!
- Exhaust Options in a Sedan??
- NEED HELP WITH FRONT LCA
- 96 civic dx no start troubleshoot - help a noob hotline
- Is a stock 2000 Si radiator sufficient to cool B18C1?
- Seats
- broken camshaft - pics inside
- Does an A/T b16 block delivers same power like an M/T b16?
- replacement sound padding
- dizzy pinout
- vss and quaife lsd problem
- y8 Mini Me
- D-series boosted question
- Where to buy Azenis?
- How much on top?
- AC on full blast, engine stalls, AC off, engine is fine...????? 1998 Civic DX
- Buddyclub coilover problem
- car running lean...help
- NEED HELP ASAP! car started sputtering like crazy and backfiring
- Help, Idle fluctuation, sputtering on light acceleration, no CEL
- 92 civic cx with 94 ls swap wont turn on. lights dont come on, nothing HELP!!!!
- 2 quick CEL blinks when key turn to accessory
- Civic Voltage Question
- Help with Tranny?
- need help N info N pic of ek h22 swap!!!!!
- needles in cluster dont lite up
- gauge cluster problems...??
- MSD DIGITAL SCI HELP PLEASE
- Spoon radiator cap sticker plastic peeled off
- valve adjustments?
- how to install cd player on the lower slot on 96-00 ??
- ---->need help with my b16.....please
- Temp gauge
- HELP!!!!
- just picked up a hatch
- WTB ????'s
- EK A/C Delete Panel
- EK CTR Grille Reviews?
- 00 Civic SI Stolen, Augusta GA
- need to get an opinion straight...
- magic additive that repairs cylinder walls and fixes piston ring seal!!!?
- n00b question
- Timing Belt question
- hondata s100 or s200??!
- mod exhaust ticket 27150/27151
- obd2 ls swap problems
- Good Car Alarms???
- power window conversion
- NEED ANSWERS
- leak down test or compression test
- searched. anyone running ls/gsr brakes with 14" del sol mini si's? what size spacers???
- O2 SENSOR
- need electrical assistants......
- I broke this? what is it?
- 2000 civic si cluster
- CEL -searched, this is new
- Mimi me questions...
- ITR Master Cylinder & Booster
- GS-R
- idle not right
- 97 civiv wheels
- Idel problem
- Terribe brakes / pedal slowly falls under pressure?
- nut broke off inside piece that holds on control arm?
- Noob, just wanted to say hi!
- 94 civic ex coupe.. what kind of oil should I use?
- Fuel Injector useage on B16a?? Need help!
- Key works only on ignition and trunk
- Broken bolt on transmission- I need to know it'[s size...
- would a 2000Si cluster
- Stalling Problems
- turbo gsr hatch or all motor gsr hatch ?
- Could this be my TPS? I just need some help. Need my car to be running.
- uk noobie with a 95eg
- ECU Fuse keeping on blown up
- Honda Wiring guru needed here
- single v installed just need some help on things
- cam gear help...
- Dizzy at full advance to hit base timing.
- h2b in ek under 12v when car is on + shocked by plug wires
- Who has a Part Number for a CTR Carbon Fibre Gauge Bezel?
- Engine miss wtf? sohc zc
- Does any one know of or have seen these oem honda rims on a civic ...?
- SHOW ME A PIC where the VSS sensor is on my 92 civic DX PLEASE
- a question for the del sol people
- Changing Ball joint
- stock suspension; negative camber problem
- Tach swap...
- em1 suspension question gc/koni
- broken hood latch
- hid in projectors write up pleasee!
- pcv valve help
- RC 310 injectors in a poormans R?
- HELP Code 43 95 civic EX
- just got a 95 civic
- climate control.. problem. need help
- which of "D"16 should i get?
- Del Sol rear bumper underside air flow ?
- help with b16b sawp
- engine swap motor mounts help
- abs axles?
- rpms sticking after pressing gas pedal.
- 00' Guage CLuster.
- ??Alternator Pulley??
- NEED HELP WITH CEL
- air intake
- NEED TO REMOVE MOLDINGS WITHOUT RUINING CAR OR MOLDINGS
- ANNOYING NOISE IN EK!!!!!
- lightened flywheel question
- CTR rear lip question
- y8/y7 mini me swap help need to know what i need.
- 94 civic sedan swap questions!!!!!
- idle help
- Weird problem
- pic request_mugen RNs!
- Jdm doors Vs. Usdm Doors?
- ek overheating issues please help
- Roaming idle with B18b1
- Car WONT STARTTTT!!!!!!!
- When i hit my Turn Signals...Hazards Come on??? HALP!!
- CEL came on
- HELP!! Need some information on Civic coupe!!
- Rough idle with A/C on
- Bulbs
- b16 engine
- More fuel pressure = better MPG?
- eg axle
- halo headlight legalities
- B16 engine help???
- transmission
- obd 2 problem codes
- civic ac condensor quick question
- can master cylinder be wrong
- help me decide
- edelbrock 4-2-1 header for b16?
- HELP!!!!!
- Throttle Question ?
- will 94-01 integra mirrors fit a 96-00 civic?
- looking for a technical answer about a sensor question
- Is this Auto or Manual ECU?
- intake manifold
- NEED 99-00 power mirror wiring Diagram
- integra e brake cable fir on civic?
- is my timing off? Pics inside (quick question)
- Overheating problem - need front bumper advice and knowledge about Duraflex bumpers
- My h22 start (is going to be slow)
- integra/civic
- 94 civic dx wont start
- Failed Smog today Any One can Help.
- Will integra brakes fit on my 92 si?
- camshaft question
- Drum brakes question
- Car has pretty much halved in economy in 5 years. Ideas?
- Wiring fogs without harness..
- manual trans with auto ecu?
- 96-2000 Hatch MPG question
- quick question
- IN SEARCH OF BETTER MPG
- ac compressor
- light fly wheel resurface?
- clutch ???? slave????
- most comfortable seat for a 97 dx
- hey im trying to get my door panel off but?
- bass and space from the eg folks
- alternator question
- New guy here with a odd window wiper problem, hope you guys can help
- short ram back to stock intake...need help and advice
- question about tein springs
- D16Y7 Idle Control Valve
- suspension issue
- Do my eyes decieve me?
- Greddy Emanage in b16a2,worth or not?
- CAN SOMEONE TELL ME WHY I HAVE A17 Pinned on a ....
- d15b from a 94 civic will it fit in my 98 civic hatchback?
- Pic request 92-95 Civic Coupe trunk badge location???
- how bad is it to run with a colder thermo
- looking for 94-95 b18c1 wiring harness
- need help with dizzy spark plug wiring!!!!
- Have a couple of newb questions that a search wont find.
- D-Series DC Headers???
- fuel or ignition problem?? 92 civic w/ls motor
- What's the diffrence between the USDM stock 92-95 lip and the SiR lip??
- Bleed just the rear?
- Opinion: EK fogs on EG
- WTB SI lip
- 96-97 and 98-00 rear hatch interchange info: why they are not plug and play
- idle air control
- drag slicks
- ROTA WHEELS which one??
- newbie here need help
- Oil cooler
- 1996 civic AC help!!! please
- Car struggling at acceleration
- cheap front bumper cover???
- I can't beleive this happened to me (Hasport inside)
- LoL! JDM stoplight BULB ?!?!
- HOW MUCH IS THIS ECU WORTH
- Are all d series ac compressors the same
- 92 civic lx b18b swap, computer question?!?!
- WOW-no brakes, is that safe?
- mini me swap
- H22 EG A/C question.
- Rear disc converting to ABS possible?
- z6...y8 compatible?
- am i [freak]ed?
- Question about fiberglass hood???
- B16A transmission for sale!!
- Another Y7 to Y8 Mini-me Swap Question
- Engine manag. for B16A
- Whats the difference between dx..cx..and other models
- Help me with my Air-Con!!
- stereo stolen but but not car
- wtb or trade for a honda
- 93 del sol si - abs yes or no when new ?
- brake lights????
- Special tools ?
- What does the d15b7 rev to no tach!!
- why can't i reply to any topic!
- pistons and rings
- d16y8 swap
- jdm civic type r cam shafts
- ebrake question and possible replacement
- Tech question on body kits
- about the o2 sensor on catalytic converter...
- Civic Si 99
- Strange shifts on 93 civic ex 107k advice thoughts thanks!!
- Cracking Noise???? 1996 civic
- Can I run 12psi???
- 95 Civic DX with Ebay shifter... lawl
- Rear Disc brake HELP.
- noob question... wat holding engine n tranny
- What Shaft
- 00 civic stalling
- need some opinions about a swap
- test pipe question
- n00b question. B18C1 swap into EJ8 can I use the GSR harness?
- Rear Brake Conversion Input needed asap!
- nissan alternator wire?
- Advice about replacing AC Compressor
- 98 ITR rear seats in a 99-00 hatch?
