View Full Version : Honda Civic / Del Sol (1992 - 2000)
- WTB: 99-00 OEM CIVIC REAR LIP
- People sporting the Mugen Twin Loop on their Si's
- Ok I need some help with this fuel pump problem!!!!!!
- Accord factory muffler on EG?
- Seat sits really oddly, help please
- Looking for a 99-00 Civic SI OEM Rear Lip...will pay however much
- Overheating/Heater
- Anybody have a Megan Exhaust? Need to know the sound.
- HOW FAST !!!!!
- Trouble Shooting Need Help ?
- code 43
- Greddy turbo kit is it worth it???
- Car stuttering when accelerating.
- Clutch Catches in different place all of a sudden??????
- lower rad hose
- compatibility of steering wheel?
- thermostats or waterpump
- installed steering rack, and forgot to align steering column
- Targa Top Leak ? ? ?
- Adjusted my valves now the ticking is Louder !!! help !!
- Starting Problem
- should i do thr red rota gt-3's on my blue 2000 si?
- have they made a j's racing air duct knock off
- speed sensor is not working
- no timing belt cover how to check timing
- synthetic or convenional
- Newb ? bout ABS
- Price of D16y8 Engine!???????
- z6 question
- Differences between civic trims
- inter mitt wipers quit working
- PROBLEMS WITH STOP LIGHTS
- cel 15 help
- Real Type-R motor
- d15b shiftlinkage problem
- Load poping noise when I turn or brake(not cv joint)
- removing door panel on 97 civic dx
- will d16y8 trans fit a d15b7
- EG catback will fit an EK?
- Reaccuring fuse problem
- engine question???
- I found a Turbo, but dunno if its worth it
- crx del sol
- ENGINE ? I NEED HELP
- b16 tranny leaking fluid...any help?
- Your thoughts on this exhaust
- another clutch problem
- bottom end bulid
- what chip to buy???
- Symptoms of a bad wheel bearing???
- Stickers and Emblems..
- what rad hoses to buy b16 in 93 coupe? *quick*
- fitment q's em1
- Skunk2 Billet Shift Knob Question.
- jdm thin side mouldings
- OMG!!! Are aftermarket windshields this fragile :(
- Search not working: Leaking t tops?
- De-Registration Certificate
- whats a good aftermarket clutch for an 00 si
- i just got an 00 si, wondering what i should do first.
- Anyone seen a yellow civic with plate "RICH EK" around town?
- does anyone know what 6 long flashes and 7 fast flashes mean.
- can anyone identify the brand of this shifter/ bushings?
- Need help with thin side moldings for EK (2 dr)
- Thoughts on the Honda Civic Dual Gauge Bezel dash pod
- B18A or B18B in a 97 EK hatch ?
- pic
- 99-00 si oem wheel offset
- trans squeak
- PLZ HELP JUST LOCKED MY KEY IN MY CAR>>>
- d16y8 performance possibilities
- RPM PROBLEMS help
- Whining Noise from Engine.
- My lights are acting up.
- what is the better ecu P61 or P28?? can anyone tell if my ecu is socketed??
- civic si Fog light help!!
- What motor does this vtec solenoid look like its from??
- ek hatch lighting problem???
- question before i continue my swap...
- b16a3 ?
- Altenator tightening question
- Smoke in car, dont know source, I NEED SOME HELP ASAP
- Red/Clear Inner tail light
- Question about Vtec
- exhaust problem 02' civic
- Removing a del Sol Antenna?! Arrggggghhhhh!
- what ecu should I use for my jdm sohc V D16A
- Comptech Ice Box
- Need wiring pin outs for 93 Civic Si please
- Difference in misfire and backfire?
- Hesitation on Start-up
- Car getting hot
- Field VAFC + HX = NO NO?
- opinions on 195/45/15 tires
- A noobie needs help
- lower rad hose leaking what to do?
- WHAT CAN BE THE PROBLEM?
- check engine light?
- thermostat prices?
- header info
- hunting idle help!!!! driving me crazy
- good deal or not
- 96-98 ecu pinout?
- timing belt install ?
- can anyone translate an ECU?
- what head gasket to use????
- grill help
- Need Help Identifying a Caliper (4 Pics) No other Forum can tell me...
- I need some wheel hub help fast!!!!!!!
- Leaky thermostat?
- baking headlights
- Cx Wiring to SI Wiring
- how much fuel psi should i be running?
- Mobil 1 Super Synthetic + D16y7 or any other honda engines
- 1/4 mile Times slips for sedans???
- Swap Question
- Oil Pan Questions
- brakes:hard line nut fitting rounded
- b16 radiator fan problems......need HELP!
- TYPE R EG
- 99 Keyless entry on EG
- fog light trick (on all the time) :)
- What are your opinions on honda brand fluid vs "name brand"?
- ecu
- (searched) Targa top w/ CF Trunk?
- Anyone from Pensacola,Destin,Panama city area..?
- Help
- smog ref ?
- need help with radiator support
- Help needed ASAP. AXLE won't stay in transmission
- 93 ex sedan AC into 92 dx hatch????
- HELP: 97 DX w/ 99 civic si headunit?
- mugen rear with ITR B pipe
- Template for placing 95 EX Sedan Civic Sidemarkers.
- block question
- Need help with 02...**SEARCHED**
- Oil light coming on
- Is it worth buying an adjustable cam gear on a stock car?
- 96 civic dx cluster compatable with 99 si?
- I NEED HELP WITH SMOG!!!SO CAL
- [FAQ] DIY RSX Front and Rear Seats into 96-00 Coupe
- Low idle cold/ Good idle warm Problem(Did Search)
- Del Sol Aux lights.
- Ebay Cai Vs. Name brand
- someone tried to break into my car !!
- Power Steering plugs??!!??
- Too much of a pain in the ass to return to stock?
- removeable steering wheel, issue
- Need Help with Ls Swap
- I'm about to bake the headlights... some opinions please!!!
- What does a missing link do?
- where did the saggy front bumper post go
- will a h22a fit in a 92-95 hatch and if so what kind of axels are needed
- NEED HELP? can i turbo a stock gsr
- BRIDE Brix 2 seats fitting into EK coupe...finally settle this
- custom rails
- HELP w/ Motor Swap
- Site for the EG Hatch like g2ic.com?
- trying to settle debate ... please settle this with your info.... =)
- main seal on d15b vtec
- virgin p28 on B16a 4 Breakin???
- 1993 Ls In 1992 Civic Lx
- amber clock help
- Anyone have EXTRA/SPARE Clifford Remotes not in use?
- Help me please!
- some pics of my 95 hatch
- brake question's for Ek Hatch
- what could be wrong with my car?
- When a rod starts to knock...?
- Alignment printout GOOD OR BAD ?
- Why does code 41 keep returning?
- Flange...?? Custom axleback
- I searched...info on using Dsm injectors
- Will an ITR HKS Hiper fit a 92 hatch?
- integra gsr dash/cluster swap into EG, got it semi worked, need help.
- No fuel!!!!!!!!!!
- EG rear sway bar question
- b20 head on ls block
- H22-EG additional resonator(s)
- car not starting?
- torque converter??
- what wire harness do i need????
- Docking Points
- DFW: for sale 92-95 parts
- Quick D-Series Axle ?
- enjo motor mounts
- DFW : WTB aic
- Is replacing radiator support a DIY job?
- Can AEM EMS be tuned with an IPAQ?
- compression check with motor outside the car?
- obd1 or obd2 EG ???
- posting permision?
- fs: black 3rd gen. integra interior
- WTB: gsr block
- timing belt tensioner woes
- D15b new clutch
- Anybody having trouble purchasing from kteller.com??
- overheating question
- Climate control on my 00 si??
- What can i do with my motor in my hatch?
- need help guys''''car starts sometimes than don't
- Tow hook dimensions?
- Please help me out (TIRES)
- 4 door lock actuators and window motors work for coupe/hatch?
- jdm gauge cluster
- Help with a jdm b16a swap
- EK pics
- Need help finding a 12v Power Source In EK
- Question about my oil pressure making sssshhh noise.
- HELP PLEASE!
- removing door handle problem :HELP:
- anybody ever done this swap?
- LS swap help
- mini me swap and trans swap or jdm d15
- Whats the best route to go w/ my stock motor?
- Radiator overflow tank how NECESSARY is it??
- Brake question for 96-00 EX civic
- cleaning out CAT, improvement in flow and/or HP?
- d15b vtec valve gasket?
- Where does this thing plug in??????
- new to honda tech
- air/fuel gauge hooking up?
- motor mounts 00EK / b swap
- any way to add decent horse without exaust?
- d series axles question 4g to 6g?
- Requesting info on an engine swap
- JDM ITR 5 lug + DC5-R rims + 2000 EK / rumor of wheel spacers?
- Hood latch cover?
- Building the Ultimate EK Hatch
- Brake swap
- for sale nitrious express remote bottle opener!!!!!! brand new in package
- axles
- del sol seats into an eg hatch wont work
- brake question
- Would you be scared if a mechanic told you this?
- JDMSh!t reputation
- Any Civic owners go to SWC?
- EK H22 wiring problems!!
- 94 Si w/ B16 swap stolen at 1:00pm today - Westchester County/Bronx NY
- These good mods
- mini me?
- rev limit is kicking in early... swap B16a sir2 with lsd please help. ?
- i need some help!!
- looking for a particular swap
- b16 distributor and Gsr cap
- A/C Removal
- The real deal behind why your tranny is grinding.
- Welding Quarter Panels TO EG
- 94-95 civic dash into 92-93?
- Need a few local guys to test out our new clutch... possible sponsorship
