View Full Version : Honda Civic / Del Sol (1992 - 2000)
- what is the best combantions of parts from a d-series engine?
- changing speedometer CX to Si
- wat do u guys think
- ecu question
- what are these 2 copper tubes comin out of this radiator for????
- who wants this? d16z6 short block free!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
- seat opinions
- 98 DX drivers window runner track...
- jdm d15b swap question
- Better Console
- Instrument Panel Conversion
- EK/EG civic Exhuast compatibililty...HELP....
- Header question.....
- need help changed head on my b20 and now it won't turn on.
- 97 depot fogs
- motor trouble. some one help me
- question about EK fog lights replacement.
- Need some clutch advise....please
- 99 Si Cluster Pinout
- B16 OR GSR TRANNY FOR SALE AROUND TORONTO???
- b18c1 into 97 4dr civic
- Brake Swap Question(s)
- ROADMING IDLE..IMPOSSIBLE TO FIX,TRIED EVERYTHING.
- 1999 civic hx differential fluid capacity.
- GSR Swap Question...
- Coilovers+Struts, del sol
- Anti freeze mixture..
- Think I messed up my Knock Sensor
- Fuel system won't hold a prime.
- gsr gears in a ls tranny???
- Noob to Honda Mods
- I'm New, I'm asking a stupid Question, Please don't assasinate me :D
- Anyone have a B18B1 intake manifold gasket cutout?
- vss help still needed!
- aem short ram intake vs aem cold air
- The stubborn coilover lock screw, need tips!
- Project plans
- Boost HX or Mini Me
- New car.
- HOW TO DO A RHD ek
- How much is can i sell my del sol for? (Not For Sale Thread)
- walbro install in a 98 hatch
- What motor do the 93' hatchbacks come with?
- O2 sensor wireing question
- how do you remove cam gears when the cams are not in the car
- front lip installation
- Why did my oil foam?
- What happened to my car.......
- newwbee help!!!intake manifolds
- Skunk2 Manifold Support Bracket
- Hood Pins on my Carbon Fiber Hood?
- stuck throttle, help???
- Broken hood release latch
- IDLE PROBLEMS...HELP!!!
- Valve Lash Problem HELP
- brake set up question
- SOHC, DOHC Si
- F.S.: H22a eg6 CLEAN smogged
- Peeple, put your fender lingings back in!!
- Does this axle seal look seated properly? [pic]
- Eg hatch sounds
- ?????? Who makes Lower sliders for JDM RECAROS?????
- different rear lower tiebars
- Need help identifying a cam.
- Does Anyone Have an EG Dash Lying Around? Request.
- Question
- z6 and y7 oil pan the same?
- a daily driven EJ/EK with a K?
- Hard to adjust GC coilovers
- LCA problem on EK with JDM ITR 5 lug
- check engine light problem!
- Need some advice, and help locating a car/shell
- Struts make sound of death
- Vtec vs. Catalytic Converter
- Any tricks for an auto tranny?
- Part # for AEM CAI for '98 EG Civic DOHC ?
- vacuum diagram??
- car on fire!!
- Tekniq snap off steering wheel System
- duckbill with led....
- How-To: Install Driver Side Axle Seal?
- what the hell is this noise comming from my car?
- mounts vs horsepower help
- passing smog/BAR with Greddy turbo
- symmic diamond euro headlights
- I got one for u guys
- vtec solenoid from 96-00 work on 92-95?
- H22 Turbo ???
- civic 98, going from manual to auto, wiring help needed
- b16 floods its self
- B18C type r motor cams?
- Rims: How big can i go ?
- Clutch Master and Slave Cylinder Question
- WTB 92-95 hatch Black interior
- Is My Si Cute?
- Which car do u perfer...
- brake upgrade Q?
- jdm EG climate control illumination problem?
- Can a battery be over powered??
- SWAP
- CAI/SRI intake?!
- fuel pressure drop at vtech engagement
- blox short cast iron manifold vs tubular/ram horn manifold
- wont go into gear????
- i think my axle are gone
- Header Question
- ITB for a d16y7
- dumb question
- password cf intake good?no?
- antenna block for EG hatch...anyone got a DIY or any hints ?
- car misses sometimes
- Rear bumper installation question.
- D16a6 Timing Belt tensioner same as D16z6?
- help... again =( tranny?axle?wheel bearing?
- Would going from B16 to D16 make you lose your enthusiasm?
- Replacing your worn carpet from Eh2's
- catalytic converter ?'s for a '00 Civic Si
- pulley removal
- ECU question
- HELP my si got hit i and i have some ???
- '98 Civic EX ... water leaks inside ...
- Eliminating Motor Movement
- Will EK hatch mudflaps fit the EK coupe?
- Attention HX owners: What is your gas milage?
- Finally swap is done and I got my intercooler pipes to fit with em1 fogs
- eg grey color
- Built LS/VTEC 1/4 mile ?!
- VSS and related items trouble shooting
- EX-R??
- b15b7 -> y7 intake manifold swap
- b18c5 Vs b18c-R in my 93 civic cx hatch
- 30/40 and 40/40 Proportioning valve question.
- New Del Sol guy here
- p/n for driver side axle seal?
- Flooded Motor Help..
- Will TWIN LOOP Muffler fit....
- question about shifting into fifth gear?
- F1 RACING STAGE 3 CLUTCH FROM E-BAY. any opinions?
- HID in EG6 Plastic Headlights
- check out this civic nice for a 4 door
- any aftrmk brakes for 15 inch wheels
- Mounting Nitrous in eK?
- h22 swap
- Gurus: Can you identify these 2 halfshafts?
- What AEM EMS?
- a quick question about the d15b
- jdm integra type r 4.7 final drive in ctr tranny
- strange vtec problem
- power door lock problem!!!
- I think i overfilled my tranny fluid.. would this cause a leak?
- why do ppl get aluminum radiators for stock motors?
- what's wrong????
- OEM honda civic wood grain? UKDM "wood trim"
- May Need help. Beer and $50 involved !
- how much does an eg gas tank weigh?
- shifter squeak?
- ECU PINOUTS
- Skunk2 intake manifold - worth it?
- B16A2 Vortec Project
- H22 wiring
- oil filters
- squealing when i turn the wheel ?
- rsx parts into ek
- 1998 Civic CX hatch w/Apexi WS cat-back and Suspension Tech. rear sway???
- wut cluster bulbs for del sol?
- Couple Vids and Pics NO 56k
- would a 99 ex distributor fit on a d16z6
- Rear disc conversion=less stopping power, wtf!!??
- b16a2 or b18b
- is my vtec screwed?????
- Clunking/Knocking noise...??
- phantom grip lsd problems (differential)
- NEED HELP... Wiring for *EK* Power Folding Mirror Conversion.. Serached!
- Please help me identify my new tranny!
- Where to buy HONDA civic power window relays???ASAP
- d16y7 intake swap what to look out for
- Cast iron exhaust maniold weldable??
- Rear HCP mount for H22A swap?
- MOTORS
- EMERGENCY HELP! Tranny/Oil Leak? Wheres it coming from? [pics]
- Should I Be Ok?
- 2000 lb ek hatch?
- goin Turbo NEED HELP
- does your brake fluid leak/evaporvate? mine does lol
- gsr or si wheels?
- need some adive
- Need 92-95 Si stock rear LCA's
- alignment shops in SoCal LB area?
- what suspension will work???
- Synthetic...Yes or No?
- Is this the camber kit i need?
- Why wont u PULL??!!!
- O2 sensor problems!! Need help
- issues with new clutch
- Engine running rough, tried higher octane, ran little better...d16y8 ... Why?
- Eg shell
- 92 vx gsr quarter panel rust?
- Need Info for timing a 92 Si Hatchback
- b-series swap?
- turbo kit for b16
- d15b2???
- Civic Rear disk conversion Question???
- Which ECU Should I use?
- need help now please !! Civic 1995 Si Canadian 10.3 inch front rotors/Teg knuckle problem...
- my cars next step...
- is a gsr oem downpipe compatible with the z6 header?
- JDM BB4 Brakes on an EG?
- HELP! Looking for intake couplings!!!
- CAI and Exhaust for Civic Type R EK9
- speedo not working
- Interior problem
- Why jdm eg steering wheel?
- what can i do to my 97 Lx coupe
- Throwout bearing Part Number Needed!!
- How do I get license plate surround off?
- Put in a new radiator now the horn doesnt work!! WTF?!?!
- D16a6 cam stuck? HELP!
- surging or racing idle
- marketplace forum help
- Vtec pressure valve
- Tire question !!!
- axel
- newb need help, LS => EK '96
- NGK Iridium Plugs. No Gap=Ok?
- AHHHH my water sprays the car behind me!
- about to take this out of the sol...
- Which site sells the Black ES Oval muffler?
- what can u do to a 97 coupe?
- H23 tranny on H22 motor in eg hatch question??
- EG GAUGE CLUSTER BULBS??
- Knock sensor
- gear ratios for 96 CX
- what are the best d-series parts
- 95 CIVIC SEATS
- civic ctr sidermarker
- Poll:How many of you....
- Rear disc intall help ,,,,,
- b16b in a EK
- mini me and manual swap combo..now the car won't start
- Wiring for power doors... wiring minds need to know
- stock body parts 00 SI
- Radio Codes
- 96-97 front bumper
- NEXEN Tires???
- camber kits need some opinions
- crank pully probs
- dual exhaust question
- better daily driver?
- EG Hatch Trunk Measurements
- Will 92-95 axles fit a 96 LX sedan?
