View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Need a few pages from 92-95 Helms manual...
- what is the cost for a starter replacement?
- b16a2 obd2 to obd1 help
- what ecu?
- WTB: mugen sports meter kit
- ITR intake mani and ITR T/B Question...
- 94 CIVIC DX HARD SHIFTING??
- h22 eg
- ZC Performance parts
- What a bitch to take off the door mouldings!!
- rack and pinion boot replacement question!! help!
- HYDROPLANED NEED HELP
- 99-00 civic grill question.
- what center caps sit flush on slipstreams?
- n/a ls motor
- Civic Brake Splash Gaurd Question (VERY INTERESTING!!)
- distributor help
- removing silicone/glue
- Need Help With Engine Wiring
- Acura Integra rear seats
- Massachussetts Inspection issue
- can u put an h tranny on a f20c(s2000 motor)
- Tune up
- Fresh Motor and New Clutch. Any difference in breaking in?
- MAIN RELAY DIAGRAM...
- bad tps cause no vtec?
- Best cam/ignition timing on a D16Z6
- Help Needed::: Did wire tuck now fuel pump wont prime.
- Are the front brake lines on the 98 EX and SI models the same?
- knocking sound when i accelerate and brake
- Rocker panel replacement
- steering wheels
- Just got into the EJ1 SCENE!
- Can someone read my plugs for me? Flooded with fuel?!?!
- No Purge Control Selenoid on my ZC HELP!! Yes I searched!
- !HELP! Main relay issuse. please help.
- Slight hesitation issues...'93 Civic VX...
- Question on RHD conversion in So. Cali
- HELP: Cluster problem, no gauge movement?
- anybody have a 96-00 inner fuse box diagram?
- 94 del sol w/ GSR swap worth it?
- '99 Civic SI Horn Problems
- Power steering tie-rod boot leak
- How do I know if I need to replace my rotors/pads?
- One Wheel Peel! But with the wrong wheel?!?!
- I want MORE POWER...
- How hard is it to put an EG exhaust manifold on an EK?
- power windows help
- Looking for estimate of cost to swap motor
- b16a bottom end and b18c1 with type r valvetrain in 99 ex?
- car looses power and stutters
- advantages of a aftermarket fual rail and cam gears...
- I think its the TPS?
- EG jdm folding mirror problem... help please!
- Fuel, Ignition, and ECU cutoff switch
- del sol exhaust???
- iacv repin trick.
- HELP PLEASE. WHICH BUSHES DO I NEED?
- compression results
- del sol seats in 92 civic
- Question regarding cracked distributor leak cover
- 99-00 si front end??
- Civic Auto swap Information
- Turbo manifold+wastegate=No Dipstick????????
- Mini-Me Project
- srs question
- cars stumbles even more...p1399
- turbo and fog lights
- Skunk2 harness help.
- Roaming Idle question....SEARCHED
- is there a thread for painted/custom sohc valvecovers?
- So, my exhaust fell off ... stock style replacement?
- clutch problems
- WONT START! HELP ME OUT PLEASE!
- Suspention help
- Looking for a GOOD shop to swap B-series into an EK in Lexington, Louisville or Cincinnati???
- What kind of ECU is this?
- What do STOCK '07 Civic Si mufflers go for?
- map sensor???
- dizzy question
- are obd1 and obd2 speed sensor plugs the same??????
- vacuum line diagram SOHC
- how much will B.A.R.D your Car??
- GSR in 77 civic?
- Stupid question
- crankshaft speed fluctuation sensor
- Retrofit R12 to R134, is it worth my while?
- Question
- Center Console Light Bulb
- h3 hid fit 99 fog?
- Timing question?
- OK, so I was just hit again after just fixing my right side! How much damage?
- Block Posting "pinning"
- Fellow EK owners need help?
- Fog lights for a eg sedan
- Hood cable is stuck. Hood won't open :-(
- JDM Navigation for ek
- slapping a jdm d15b vtec head on jdm d15b block but has b7 head
- 94 hatch B15Z1 Economy Vtec engine?????????????/
- Need recommendations on a suspension setup
- Bumper Removal HELPPPPPPPP ASAP
- eg injector questions
- Crank hard to turn, plastigauge reads ok, is this normal?
- will 91 crx function & forms fit on my 95 civic coupe or what mod is needed
- WTF is this HONDA ACCESS thing?? crazy jdm piece!!
- Prothane Motor Mount inserts
- EM1 sounds like a wrx - no misfire or mechanical problems!
- Racing_reject's 92 ls hatch build thread
- O2 sensor?
- What tools do I need for an engine swap?
- P/N for ITR shift boot
- HOFCO ALARM HELP PLEASE!!!
- What is your timing at, and what octane do you use?
- Will b18 header line up to my cat converter?
- 2000 civic ex idle problems
- what shift linkage do i use??
- Stupid Cat Q........
- Shift linkage???
- A.C help with my 94 honda civic Ex B16 set up ???? what do i need to connect it???
- obd1 iacv on obd2 harness
- OEM 99-00 si OEM front lip. whats the difference?
- D16Z6 front crank seal/oil pan
- 94 civic ex possible 1" master cylinders swap
- vtec problem
- Turboing d16z6 needing help
- 94 Del Sol - Replacing roof seal?
- wierd idle? 1992 civic ex
- Engine Harness/ECU/Injector Dilemma. PLEASE HELP!
- Auto to manual swap
- Any Help? Car spudders
- hood latch stuck. hood won't open
- broken motor mount bracket bolts
- D16 TROUBLEEE!!!
- 96 Integra Type R Cams?
- 1993 manual swap
- Just Bought a 2000 Civic Si, Seems like its low on power.
- 99 si cluster speedo and temp issue
- different between B Series and D Series
- Fit cluster in eg?
- lil ?
- jdm 96-98 ctr climate control parts
- B-Series exh. manifold heatshield question.
- b16 turbo - help
- OBD2B Wiring Harness into 96-98 Civic Option??
- tuning question [searched]
- milling a sohc. does it raise hp?
- How to clean intercooler?
- failed smog
- Who bought a 99 Si in pittsburgh, PA
- bumper air scoop
- help: huge and annoying problem
- someone please help..
- transmission
- Engine died, no spark
- supercharger...
- Ground Question???
- grinding clutch
- mid-rear brake light removal
- quick n easy sideskirt question...
- b16 jrsc vs h2b
- can i use a D tranny mount withe B tranny bracket for b16 into EK?????????
- CTR gauge cluster
- Curious Problem
- Another d15 mini me
- help with gsr swap!!
- b16a2 swap into my 98 dx HARNESS ISSUE HELPPP!!!!!!!!!
- Rusted rear suspension bolt (searched)
- Brake and wheel upgrades
- Low Oil Pressure on Startup???
- HELP!!! I have a problem and i don't know what to do..Please HELP!!!
- stering wheel swap?
- Question about timing...
- koni yellows vs. kyb agx's
- stolen key need help with ignition
- Just rebuilt my d16y8. What oil to use?
- GSR with cable tranny... putting in hydro tranny.. need some help
- distributor question
- maintaining a "stock" appearance..
- HID help please
- Thank you H-T
- SOMEONE JACKED ME FOR MY ECU
- Combination wiper switch malfunction question
- cahrcoal canister questions
- Rims....!!
- d16z6 starts then dies
- hood bra
- Rota wheels, why are they special?
- d16z6 wiring harness for 92 civic lx
- o2 sensor code 1 and code 61?
- WHERE DID THIS BOLT FALL FROM?! (PICS)
- Do magnaflow exhausts have maximum HP range?
- SOHC VTEC with single layer headgasket.
- Obd1 b18b1 motor into an obd2 ek coupe. WONT START!
- 94 head bolts
- what kinda of trim modle is my 93 hb with the engine code of d16b8?
- installing a master cyclinder on a 96 ex
- changing ball joints
- what kind of shock?
- WHERE CAN I FIND VOLK WHEELS IN ATLANTA,GA.?
- thinking twice about these wheels....anyone have pics of a EG or EJ coupe with sportmax rims 501's m
- need some advice please...NOOB
- Exhaust System
- **PROBLEM**
- Question On CTR Power Folding Mirrors...
- Oil Cap fell off & Ran dry on the dipstick, changed oil to recommended 3.8 Qts now overfilled!!
- auto axles on manual tranny?
- HX throttle cable work with SI bracket? SI bracket and Type R bracket the same?
- Changing crankshaft seal on a D16z6
- del sol shift linkage Q
- Weird squeak....
- Will 03 si spare tire fit my 99 Si? quick answer needed...thx
- tps check/adjustment
- brake upgrade quick ?
- gsr swap in 99 civic ex
- map vaccum
- Keyless Entry in my 98 Honda civic Ex Stopped working after I put in a new deck...
- Gunmetal Housing Vs. Stock OEM Headlights
- Which Clutch is bettee
- Rear splash guard + Rear lip = ??
- Looking for a few K series engine and transmissions!
- prelude seats in ej1
- Soft Clutch Pedal Issue
- si grill and dx grill help!@@??
- Which civic should i swap???
- Tire Size
- cig lighter?
- oil feed for b 16
- on my way guys
- ?b18b obd1-2?
- help on 92-95
- Spindle and Rotor Q's
- hey admin :S
- clutch pedal to the floor and nothing
- warped header..i think
- swap complete!! 92 hatch with an ls swap
- d16z6 tranny rebuild
- Help! So I park my car today and everything is fine. Then tonight...
- How to fix rolling idle
- EG Help! - No Power
- Need help with 13" wheels on my Civic EX 94
- Innovative Mouter Mounts 60A
- Honda NOOB!! coming from VW
- air conditioning for 1992 dx civic sedan
- DC header
- Start up idle problem
- Do em1's have rear sway bar endlink bushing?
- some Skunk
- WHAT AXLES FOR CABLE TRANS IN EG SOL ????
- outer tide rod help
- Do i have pilot bearing?????
