View Full Version : Honda Civic / Del Sol (1992 - 2000)
- friggin CAT!!! help?
- CTR rear lip + Exhaust?
- Ordered Koni Yellows.. Got Koni Reds.. NEED HELP!!!!!!!!!!!!!! ANYONE WITH KONI SHOCKS
- 92 cx hesitates
- Need some input...
- had an accident, fix the car or any other suggestion?
- Big brake kit for EG
- taking apart dash to get to blower motor
- do you have to take of the strut to adjust the height again?
- jdm d15b or gsr
- Removing flywheel to replace pilot bearing...question about flywheel
- will 2.5" ebay hi-flo 'cat' bolt to a 2.5" header?
- Alright, why does my wheel spin in nuetral?
- Anyone is Tristate area selling a eg Si???
- Some pics of me and my friend painting his engine bay without removing the engine
- sway bar rear lca mounting Q
- Registering a 95 Civic with a H22 Swap 7:04 AM 8/18/2004
- I need help with finding John Goff aka "J B G" the scammer.
- How to open trunk on del sol?
- problem p0133 car running slightly rich
- axles won't go all the way in
- installing front and rear GSR brakes on EK..looking for tips
- itr dc2 front end on 00 civic si can it be done>?? any pics?
- What is this on my clutch disc????
- *STOLEN* 92 civic hatch out of Renton Washington...keep on the look
- Will An Integra Wiper Switch Work On An EG??
- comptech rear lower tie bar
- CAR STOLEN: 1998 Civic coupe in Milpitas, CA!
- jun 3 cams in stock b16a2 worth it ?
- 2002 Civic Si seats in an EK
- squealing while turning....
- 1st gear tranny problems
- Questions about the 2004 Civic.....
- mechanics?
- Stripped the hex shaped bolt at the top of my strut
- looking to swap. what motor be best? b16?
- NEED MAJOR HELP, DRIVER SIDE HEADLIGHT AND CORNERLAMP really dim
- throwing code 43 Fuel supply system
- Maybe you guys can help, tried Hybrid forum...
- ITR Swap into a 92-95 Ex Civic...What all will I need?
- UCA
- replacing knock sensor cost?
- eg hatch question !
- automatic to standard,how hard is it
- LS-turbo 4-d00r?
- Civic Not Runnin Need Help
- new, and thats all i have to say
- OEM fog light how-to?
- auto to manual question
- BACKFIRE! BLACK SMOKE! PLEASE HELP MY COUPE!
- Hid Question!
- stereo installation for a 92 Honda Civic, Japanese Specs
- would TEIN pillow mounts adjust camber for a 97 civic ex?
- How hard is it to add A/C to a 1998 CX hatch?
- Brake Pad Sizes?
- converting Ek96 centre console to EK99-00 centre console (where the A/C vent is)
- Running rich! HELP!
- Headlight Painting
- Muffler Vs. Exhaust
- 2 tire questions
- tranny problem
- New Swap: Should I Replace Headgasket?
- will a auto cluster work in a 5 speed?
- CEL code 61
- what should i get a VSS for?
- omni power coilvers
- guage cluster paint
- Chassis Codes?!?!?
- D15b7 Dyno
- pic request. Edelbrock performer x intake for d16y8
- ac lines please help
- Intake Manifold for 97 Civic HX
- help me out with b16a2 obd1 jdm motor 92-95 eg hatch
- 92 Civic Blown Engine question
- Chipped P28 Programs for GSR...
- Will GSR rear sway bar fit on 92 hb si?
- Interior Color Code Question...
- Door Locking Mechanism in 93 Del Sol
- Need exhaust advice, leaning to EVO2 or SP2?
- ? about tranny and speed
- Bought 1992 EG6 - Swap - Need help!
- Why is my week-old alternator belt fraying??? *pics*
- Will a CRX Si ecu work with a d15b7?
- Help with motor swap.
- how hot should your your engine be?
- Which years are integra/civic interchangeable?
- problems with H&R sports on tokico blues - 98 civic coupe
- need help with a turbo kit
- HELP ASAP code #1, #7, and #41
- Question about my gears?
- timing wont stay advanced!
- high idle after mani swap
- D16 TPS
- Was told that the Hyme joint's tend to come loose on Traction bars. Any truth's?????
- mini-me question
- broken axel, wont go into reverse *urgent help*
- Del sol with trottlebodies or b18 engine
- Lookin for a motor swap?
- AC fan for radiator?
- 2000 GSR Bucket Seats into 98 EK?
- $1000 dollars into a 2dr 96 what should I do?
- Mount Question
- Del Sol WIndow Regulator
- What ECU And Harness?
- Quick queston
- New project maybe?
- Redline on D15B7?
- 99-00 Si vaccum diagram
- any aftermarket intake manifold for my gsr?
- USDM H22 OBD1 P13 ECU
- would I need a new clutch?
- good brand for used strust bar
- I NEED HELP TAKING APART MY THROTTLE BODY
- Major Oil Leak, Rear Main Seal Issues?
- Where to buy pins for obd 1 engine harness plugs?
- B20VTEC, help clarify the myths...
- Suspension tech's
- del sol head unit installation
- pre chipped/ pre programed ecu
- Brake Fluid
- Update!! my $500 hatchback has made some progress!! pics inside
- over heating
- o2 help
- how much to torque my head down
- quick question about motor mounts?
- LS drop in hatch
- people who have ek civics with TACHS
- SRS light on! any help
- d16z6 flywheel fit Y7?
- Does Integra front LCA and Integra front swaybar fit EK?
- Oil all over:(
- Apexi PS Revolution exhaust...
- Error - 0505 Idle Control System Malfunction
- Another "Trouble starting swap" thread (Pic's 56k may be a no no)
- Pimpin my ride for street racing.
- installing a cai question
- changed timing belt in friends civic d16y7... now rattle in valve train
- name this connector
- IDENTIFY THIS LSD!!!
- tb install help
- Ep wheel clearance
- ENgine coolant sensor
- How do I change out my IACV?????
- power window relay
- wheres that thread? vtec69
- EK9 modifications
- Swap start-up problems.....
- Need help, Tried searching....OBD1 B18B1 swap into a 96 EX.
- URGENT: checking BRAKE status
- 98 EX vtec without a vtec valve cover
- Where do you mount the JDM road flares???
- Need Answer ASAP please... TEINS from GSR.. will they fit 1999 Coupe?
- how to change dx manifold to ex manifold question?
- Qustion about tranny
- speedometer problem
- balljoint boot question
- Door conversion help!
- Keyless Entry with CX chassis??
- power steering leak help!
- transmission problems
- EP wheels on EK?
- Getting codes from 99 EX
- D16 Question
- car wont start!
- Where can i get Megan Gauges
- Code 20 and 21. On CRV-tec. Help.
- Help: Defrost Switch And Climate Control Problem!
- jdm ctr headlights need help
- Noob wants to know suspension swap options for EG coupe?
- So I have some money laying around...
- need cat and rezinator BAD for 92-95 hatch
- Vtec kick in?
- Soft clutch pedal with ACT XTSS
- Ground controls
- Ebay Strut Bar Combo... among other things (as usual) :)
- High Revvin my D
- Del Sol Gas Mileage Question...
- i need the yellow headlight light bulbs and fog light bulbs for my civic si
- 99-00 tail light hatchback
- my eg makes a gguurr noise when I crank it!!!
- Swap Suggestions 4 my 93 Coupe
- AC Parts Question
- lower strut bolt- i cant break the bastard loose!!!!
- quick question..
- gsr shifter question in eg...
- tranny has foreign materials in it...... how to clear?
- fan died today
- How much to pay for shocks?
- Other thanmark dealer who else produces aftermarket rubber bushings ?
- Fender rub all around on 205/50/16 16x7 40mm offset
- DIY: 96+ EK city lights on US spec cars...
- JDM OEM CTR NAV/CLIMATE CONTROL/GPS..HELP
- what kind of tranny do i have??????
- stripped head bolt???
- weird body problem
- haze on carbon fiber
- Hard wiring a cluster
- Si Rims
- H-T MEMS HELP ME OUT?????????
- rear disc brake conversion
- calling out Fred Villaba aka Kyosoeg6
- timing belt
- vtec help
- I need 99 civic side molding
- SRS light problem!!! please help!!!!
- stripping engine bay got a few Q's
- D16Z6 and D16Y5 heads
- **Civic Hatch Help**
- jdm itr axles fit on my ej1?
- i think my quaife diff is fried.. help!
- Compresión en el Motor?
- engine swaps in 94 civic si
- B&M Shift Stabilizer System
- Ever had to replace your windshield?
- VAFC Wide and Narr?
- How much to fix my motor?
- O2 Sensor
- Pistons difference????
- 16 inch Rota Grids and tires (not a fs thread)
- Did search already Mixed up parts for rear disc. Are they all interchangeable?
- 94 del sol trunk release
- egr lift sensor
- 2 questions 1.) whats this nut im missing? 2.) installing lower tie baR?
- hatchback floor that covers spare HELP
- Lip spoilers
- Need some help!!!
- b16 swap linkage question
- whats the dif between a B16b and a B16a?????????????
- Torn/Stripped Engine Mount
- center console help
- Gsr obd1 problem.............
- motor mount question
- Motor stumbles after reving
- Help With Speedometer> went crazy
- Will 195\60\14 (87 Integra Tires) fit 185\60\14 (91 CRX SI Wheels) ??
- NINJASPY please contact me ASAP
- slave cylinder on B16A question??? Please help asap... Thank you.
- anybody think this "gas magnet" thing will work??
- Temp, Oil Pressure, Etc guages universal?
- ECU chip
- mini-me or D16Z6 swap?
- OIL CHANGE (How Often Do You Change Oil)?
- seatbelt light/injector code?
- Putting Si or ITR calipers on a dx hub? (EK)
- ****NEED HELP WITH MY SWAP ASAP****
- n1 on del sol
- My 2001 Honda Civic LX is in bad shape
- help problem with swapping gsr brakes into eg,caliper keeps locking up
- Motor oil question
- $$$ need help with civic wiring and integra dash swap$$$
