View Full Version : Honda Civic / Del Sol (1992 - 2000)
- 96-00 bumpers fit 2000 civics ?
- AEM FPR confirm PSI please
- Slid on LCA, bent rear suspension?
- anyone know best engine swaps for 92 dx hatches
- I put a b18c1 in my 92 hatchback CX how can I put ac on my car
- How to close and secure a transtop that has stopped the roof driving.
- manuals
- In the middle of a head gasket installation NEED HELP ASAP!
- '97 Civic HX
- Need information or pictures of location of tranmission fluid...
- McGard Wheel Lock Key
- lips from islandmotor sports?
- can someone tell me how to take my stock steering wheel off
- Where to get Speed Master??
- Cali laws on intake
- motor swap
- DIY/How to: Tranny Removal
- B16a trouble
- Product Review: Kobalt gloves
- built NA sohc w/ safc question-
- New to site-1995 Civic CX
- quick SOHC valve cover question.
- Idling Warm - fan is kicking on WTF?
- Clusters
- Alternator Fitment
- JDM EG gauge cluster dimmer????
- Possible to swap in a Lude guage cluster into an EK??
- cheap RECARO knockoffs
- completely stripped tranny case bolts please help
- Del Sol window interchangeable?
- Those with 5th Gen Helms Manual
- Tie Rod question.
- Just changed my oil...almost no oil came out!
- Civic HX wiring diagram
- WANTED 95 EG COUPE right hand drive
- please help, few last minute questions
- New Tranny..
- EG with B18C.....strong vibration?
- Need part!
- removing 02 sensor
- 99 d16y7 into 96 civic ex
- B16A crank into B18C block
- doing mini me now. need help on belt
- J-SPEC - JDM
- How much does a whole rear disc brake conversion weight?
- where can i find a rear strut bar that looks liek this but isnt mugen?
- removing door panels
- Greddy turbo on 95 civic ex coupe
- Lip For a EK 4 door
- went to the track with my del SLOW
- EG: wiring back to the stock d16z6 from the b-series
- Ls/Vtec B18 Head....
- kamakazi header
- new motor, strange vibrations...
- Anybody change there gauge cluster lights on there 96-00 civic?
- Buddy Club Stage 3 cams..
- armrest for EG....
- Anti Sway Bars For A 1992 Civic DX 4door Sedan
- POWER ENTERPRISE BELT, how much do they go for.
- Another question about B18C1 swaps
- Brake Line Q (searched)
- How do you remove the hubs from honda's?
- 96-98 difference to 99-00 ek rad support
- d17a2 cyl bore
- I'm new to Hondas...
- 96 4 lug itr brakes vs 98 5 lug itr brakes
- 4 wheel aligment data. more proof camber does'nt cause tire wear.
- what is an OEM Honda Civic Type-R rear skirt made of?
- Best/Cheapest place to get a gsr or type r swap in NYC?
- 99 Civic HB in Black?
- HELP ME FIND MY 92 CX HATCH IN RICHMOND
- what chip do u guys use
- Cranking but no power, any help? (I jus finished searchin da archives)
- TEG CAT on A EH civic chassis
- BFGOODRICH 205/50/16 CLEARANCE PROBLEM??
- Carfax check - any help me out?
- Are all D series crank pulleys interchangeable?
- 92-95 HATCH OR COUPE
- clunky steering in my 95 vx
- SSF vs Forged
- Can someone tell how to take off door panels
- dash switched power
- If Anyone Here Recently Had A "Type R" Badge Stolen...
- an-r intake manifold gasket causing smoking!!!??
- I just caught a wicked deal ..
- CA PPL Help Get This Scammer (ebay related)
- Very rough idle
- what intake manifold
- EK Exhaust Dilemma
- where to find jdm eg6 foglights with yellow lense???
- 60ft times w/ d16z6
- what is the official weight of EG civics....mainly DX???
- <--- New Guy... need an answer
- want to talk about ek civic with type r 5 lug swaps..email me also
- Ractive fireball exhaust system... worth the money?
- Slow power/broken windows on 2000 Civic
- lug nut size for 03 civic ex
- axle nut with a torque wrench?
- anyone know the trouble code for the transmission? automatic
- motor problem
- 94 Civic ex And Jdm Eg9 parts.......
- 96-98 ex ecu and 99-00 ex ecu interchangability?
- Suspension Techniques Springs insight please.
- Rear Motor Mount: 92-95 civic=94+ GSR
- Offical Honda Performance Parts Department ??
- spoon exhaust
- EX tranny swapped Help Grinding!
- HELP IDLE PROBLEM!!
- new clutch - break in period
- another GC vs Tein SS thread>>a more comfortable ride?
- Help!! just swaped Si Sohc, Problems....
- need help with swap!
- possible new car
- Civic Si hub/knuckle question
- I misshifted in my R tranny dude...help
- Nology wires???? are they junk
- will the jdm eg6 sir interior fit the usdm eg6?
- knock sensor....
- need to know if i need a new ECU?
- are there any linear rate springs that drop 2"
- Red Dash Lights? Rice or Sweet?
- exaust fitting question ** warning ! noob Question **
- How to adjust timing on milled head?
- Tranny fluid
- carfax please
- Proud new owner of 97 ex coupe
- How can i make my headlights projector?
- nova people......know anywhere to get my tranny fixed?????
- Part Lookup Majestic Honda...
- Button for A/C on EG 92-95 Civic
- what engine is b18b1?
- lower control arms
- Headlight code 9003
- Neuspeed Race with Neuspeed Koni's?
- authentic c west for 00 Si coupe??
- professional trackers out there...need help (picture story)
- Swap In!!!
- I need dustboots for KYB AGX's HELP!!!
- Conversion Confusion...
- Another smog-test-result thread. (Smogged in CA) 56k maybe...
- b18 swap questions
- 14 inch wheels who runs them and what are they?
- quick q: '00 civic sedan seats in '93 civic coupe, will they fit?
- My question for all you smart honda guys!
- TRANS SWAP ATX TO MTX
- Noob Question prolly
- Short Shifters
- Apexi Timer help
- Help with alingment/steering rack?
- power gains on an LS/VTEC... with an ITR ECU/ ITR chipped ECU
- Bolt Size of C-pillar bar
- D16z6 Del Sol All Messed Up..... = (
- Quick exhaust question, which magna flow is best?
- Need help identifing a motor
- ls vs. b16
- Need a 99 - 00 Civic Si power steering pump and AC Bracket Mount
- where do i get a good ecu chip for my 99 civic si coupe
- 96 civic cx hatchback
- CRX, DA rear rotors same as EG?
- Can someone run a carfax for me?
- Performance Peddler Reliable?
- Looking for a Del Sol...
- speedo
- Ground Control or This
- Brake light coming on?
- tranny fluid line wont unscrew from civic hardline
- y1 trannies?
- Why can't i do certain posts, still? Mods/Admins please help.
- CTR question
- GSR Swap ? with CEL
- sohc dx eg oil pan fit on dohc zc??
- Just ordered motor
- wheel help please...
- whats the differents w/ delsol headlights and jdm h4h bulbs?
- Steering Wheel HELP!!!!
- LS Swap
- gsr rims on stock dx drums in the back
- What clutch
- will this work? switch stock 00si intake manifold for a 98 gsr one.
- TEST pipe= quieter VTEC crossover..??
- Finally a Good FAQ Website!
- Stock Del Sol height
- Will a stock GSR header fit a 96-00 Civic Cx motor?
- Random question involving vtec . . .
- which clutch?????jdm b18c
- Who can PROVE to me what a 16" x 7" Rota Slipstream really weighs???
- Buying Shocks & Springs
- metal head gasket and block guard
- any suggestions??
- Coilover question
- I did a search........B18c1 obd2a into Civic DX 1999 obd2b
- P29 ECU OBD What?
- debating on selling my b18c1 eg hatch for a new one... help me out
- mud flaps eg/sol compatiblility?
- b16a5
- Modified D16Y wanting to swap to a B16...compatible parts???
- EK9 front clip
- stuttering....again, please help!
- 95 honda civic D16z6 swap to B16c1, c5, or h23a, h22a
- tint shops in md dc va where? who?
- Floor board frame warped? HELP!
- will apexi n1 axle back for a hatchback fit a 4 dr w/thermal cat back
- what to do next?
- How to Identify your ECU
- Looking for a EK fs in the midwest area
- New Flywheel
- Can you bolt up to stock cat
- turn signal
- what tires?????
- LS Turbo or something else
- vss troubles still..
- prostreetonline.com timing belt kit???
- eg mud flaps???
- D16z6 Transmission
- tranny leaking?
- b18c5 bottom end swap on a b16a2????
- anyone with BW rear bumper on their 5th gen?
- Anyone have the C West 2 or N1 front bumper for their 5th gen?
- WTB: Factor Reflectors from inside 99-00 Headlights, From those guys who retro HIDs
- weird noise when the engine comes down?
- Do I need new brake pads for new rotors?
- wanted: 2000 honda civic si ecu
- Braking issues on my eg
- looking for tranny writeup
- Hood Locks at the track?
- ger throttle body to big for my car
- z6 head on dx block
- ek door handles
- D16Z6 or D16Y8 Tranny
- cab
- need to quiet the inside of my car
- Noob Here!!!1 Quick Question...
- taking off my door panel
- powder coating kit
- FREINDS HATCH WAS STOLEN LAST NIGHT RICHMOND VA
- Mounts for GSR Swap? (Names)
- DH Racing.com crank pulley?
- tire selection
- Info on 92-95 civic folding mirrors...
- questions about universal carsound cat. conv.
- d16y7 engine with vtec ecu ?
- Pulling the head off a B16, how to align timing belt onto cam gears?
- I HAVE A 96 CIVIC HB DX...AND I JUST BUY A 97 HX ENGINE, CAN I USE THE DX TRANSMISSION AND HARNESS??
- B16 Head studs torque specs?
- civic type r or integra type r carpet
- quick suspension question please help!
- Valve's Rattling
- ITR steering wheel in EK
