View Full Version : Honda Civic / Del Sol (1992 - 2000)
- KRAZY ass REV's at idle help!!!!
- how u hook up glow gauge lights in gauge cluster
- Think its worth it?
- Starter trouble
- Squeaky Clutch
- need help with part for new swap...???
- Gauge Clusters and A/M Gauges
- skunk2 questions(need answers asap)
- Guage help.....
- whats the toq. on the d16zc vtec??
- Turbo d15b7 question (searched)
- b20 into 92 dx hatch, wiring harness?
- Honda EP Civic question (01's+)
- Help... What mounts do I need to put a GSR swap into EK 6th gen chassis?
- Full Skunk2 Coil-overs
- Engine Diagnostic Guru's needed.
- d16z6 and d16y8 how do they differ
- accord harness in an ek
- Power Lock Upgrade - Already Searched
- Broken key in ignition
- How Do I Remove These Bushings? (pics)
- Thermostat question
- Do i need struts replaced ? Honda civic LX 97 with 100K miles
- a little help..
- Need some info about my clutch setup (please)
- cheap place to get unorthodox pullies?
- need help with emissions, EVAP
- del sol roof
- Seat removal help
- Timing belt question
- body straighting
- go fast parts
- 1st gen b16 intake manifold in 97 ex, what to change/plug?
- Clutch fluid leaking.. i know you guys know the diagnosis.
- Problematic '00 Si after timing belt/waterpump service...please help
- New to the Del Sol
- question about fitting....
- door handles
- Site for Tire Facts?
- YOUR EXPERIENCE WITH PROGRESS SPRINGS
- help, quick!
- knocking sound w/ Sportlines
- 95 Civic ex with a 150 shot
- Thinking of going LSvtec or B20vtec
- 1rst time Honda owner. Was given a 94 Del Sol S for New Years...Want to hop it up..
- pic request: 96-00 civic coupes
- i need a 96-00 sohc motor BADDD, live in NY i need some1 close
- 5 lug into ek axle question
- vis hood fitment = bAd
- New rear bearing, still noise from the back? Please help me
- HELP!!!IGNITION IS LOCKED!!
- EG oxygen Manual Wiring
- 92-93 Acura integra LS
- About to buy a '93 EG-6 with JDM B16A2.. what should I be wary of?
- would a 92-95 civic ecu start up a b16a
- super meddallion racing exhaust ....
- Newb to the board!
- compression. cylinder problem =/
- Oil filter opinions?
- 92 civic not starting still
- honda o2 sensor vs. bosch o2 sensor (are they the same?)
- Underdrive Pullys
- correct way to install rear sway? off or on ground?
- Balancing weights on aftermarket rims / tires
- Speaker Swap For 2dr 98 Civic Si
- Header/ exhaust question
- CEL came on and now i checked it but still have a question?
- thinkin of building a motor
- Just Purchase a 1980 Civic 1500. Need advice.
- ...why does my drivers side front wheel feel like its a square?
- World Sport swap with N1
- 99 si grill
- Baking Altezzas
- Got my h23eg back from the shop
- Knock sensor needed?
- shops in the usa that build d series motors
- Programming keyless entry 98 EX
- amber bulbs
- Mugen RnR question
- Thinking of geting a Gude Head Package for a d16z6- Any reviews or comments.
- 96-98 to 99-00 Front end conversion...
- fuel pump wont prime intermittently
- My new VTEC head w/ pics!
- Need help with LS build up!!!!!!!!
- clutch in 93 hatch
- clutch
- Oxygen Sensor? cat. converter? Oh you don't need those.
- Problem with eg
- vtec head on d15
- Primary and Secondary 02 sensor question
- my car wont start!!!!!
- Clutch problems.....Not grabbing? Worn out? Please help.....
- integra dash?
- gauge cluster questions, need answers ASAP
- Few questions about 92-95 coupe and hatch doors.
- Simple Question, What is the correct o2 sensor placement for a z6 / jdm d15?
- 92 to 96 swap
- Warming up question
- ECU help
- DelSol needs help asap pls! hellppp
- got my self a 1.5 vtec and need some info
- Does the doorpanel come in the lighter grey? (EK)
- Hey guys new to this site!!!!
- ..... Thermostat. How Do You Change Em?......
- B16a1 Valve Adjustment Specs
- my 2 hatches
- oops... my exhaust
- Spark plugs? Hp?
- y8 head on a6 block work ok?
- type r throttle bracket
- Looking for an old thread in this forum....tried searching.
- crx shocks on an eg?
- Are These OEM 96-00 Power Lock Acuators?
- ABS light on after dropping car 2 inches
- Antenna Replacement
- engine wont run
- Guage Cluster Problems
- Wheel bearing question!
- New Rule...Read if you don't want to lose %
- will this horn fit this steering wheel
- how do I keep my headlights from fading?
- Power Mirror Block Off Plate
- Rear brake conversion question on a civic?
- Air box removal in a 2000 Civic EX
- STOLEN EG! (near Tacoma, WA)
- JDM Interior?
- Heater and AC makes a funny noise
- whats the compression rate of the d15b?
- gsr lca?
- anyone know installation to cv joint replacement?!?!?
- Head Torque Specs????
- Can't get in car!
- Wa: STOLEN CAR
- BEST PSI FOR FALKEN AZENIS
- Preffered ECU for obd1 ZC ?
- Rear Trailing Arm Bushing (Part #?)
- 9003 bulb install
- Is my civic worth $3k
- Price of insurance for an 00 SI?
- Type R Valve Springs in SOHC?
- question about replacing icm ( ignitor ) with msd box
- blow off valve sound
- Does a site exist to get factory Honda parts for less than an arm and leg?
- Vent not circulating any air....
- Wiring Harness for B20 Swap into 96' Hatch
- Removing cat, a few quesitons
- Does the 2000 civic front bumper come with pre-drilled holes for the license plate?
- b16 99-00 si axles and 95-96 gsr b18 axles the same?
- JDM parts to look for in Japan
- FAQ: How to Build a HID wiring Harness
- Are 17's too big for an EK coupe
- Cheep turbo?
- Automatic B- series swap info...
- Integra TCM wiring schematic for Auto swap...
- question with balljoint
- need helpw ith swap
- Should i trade my GSR for this EK hatch?
- What intake for gsr swap 92 civic hb w/skunk2 manifold?
- Exhaust Search
- CB joints
- I took the hatch in to the shop
- FL people: Is driving w/ out a hood illegal?
- clicking noise while driving
- Will a stock 97 civic hatch exhaust fit an 92-95 civic hatch?
- found stolen civic ex/si (black) S.D./poway area
- Fading weatherstripping and window trim
- Is there a alternator Ground wire?
- Replacing a D16Y8 with a D16Z6 in an 00 civic EX (obd2 questions and such)
- Need to replace Steering Column. Options?
- Changing window regulator?
- For those of you with Power Inverters
- the all mighty turbonator
- skunk2 gsr manifold need help!! please!!
- hole in the tranny
- need brake help
- What to do about my ps pump?
- Clutch fluid?
- Converting 1993 Eg4 D15b2 to D15Z6, How easy and is it worth it?
- MI snow sucks... my ej just went down the drain basically
- header/exhaust question
- c HELP 92 civic will not start
- y8-z6
- Already searched this idle question
- ?'s about starters
- window tracks
- how much is a 94si shell worth?
- Skunk2 Noise
- diy alarms
- Weird vibration after header install
- spinners 15"
- MPG Gauge on Civic?
- Fuel injector / fuel pump
- gauges
- 2000 Honda Civic SE - Manual transmission noise - any ideas?
- Do you guys think this size tires will fit 99-00 SI wheels?
- Rear Suspension Squeaks on '01 Civic EX Sedan
- 1991 HONDA HACTH HELP WITH MULTIPORT UPGRADE
- WHAT IS NEEDED FOR REAR BRAKE CONVERSION ON 95 CIVIC EX???????????????
- Should I Replace my Fuel Tank?
- Rear Bumper
- Pics of Mounted H&R Race Springs
- Mugen parts question
- which flywheel for lsvtec?
- Need help w/install ACI rear lower tie bar
- eg 93 coupe bumper on 93 sedan?
- zc swap
- D16z6 and d16y6 is thre a difference?
- funky idle
- rear disk conversion help EK
- anyone know of any good tech shops around the wilmington NCShops around NC
- need a shop in central va to pass inspection
- how 2 bypass smog ref?
- help pls
- Tach sticks
- Civic Mounts
- advice for this setup - b16 / chipped p28... and much mo'
- quick question
- What is The Best Intake Manifold For My D16Z6 Head (Mini ME)
- turbo help
- stupid question of the day
- ls vtec help!
- i need some help!! whistling noise?!
- Re: 99-00 Civic Si Cluster in an 93 Civic CX Hatchback
- b18b
- Help with trouble codes - CEL is on again
- having swap porblems
- 96-00 a\c evaporater in 92-95 civic
- B18b transmission question
- D16Y7 OBD-2 TO OBD-1 *searched*
- Will a '94 gsr powersteering hose fit a '98 civic hx?
- Do the Y8 and Z6 use the same wiring harness?
- problems with my 5lug with +42 offset regamasters..
- car fax request.
- Need help for 2000 civic
- Turbo? Or EngIne SwaP?
- question about ecu
- car is idling very very low?
- Shift linkage - Civic vs. Integra *Questions*
- Door actuator replacement
- FITV leaking?
- *auto B16 swap help*
- Anyone familiar w/this site?
- h3 vs. h4 bulbs
- problem
- Moaning from Suspension
- muffler is this
- Good FYI Information in regards to ball joint
- Del Sol Interior
- ZACK..HELLO
- Security For Your Vehicle
