- vtec not working....another one
- Anyone ever heard of jabjunkies?
- B series Oil Pan
- what is the best d series tranny to use?
- WIRING ISSUES PLEASE HELP
- White Smoke passed 4k Rpm
- F20C-swapped EG4 full specs/build info here
- 94 Ex Help
- h22 eg6. need HELP location oil leaks...
- B16 Tranny Problems
- dx with a ex cluster?
- Won't reach temp????
- engine harness wiring help
- head gasket job/performance. advice?!?!
- 1994 Civic driver's side seat broke
- axle stuck in halfshaft
- H&R race springs on stock ek9 shocks
- car alarm issues. Need help ASAP!!
- No Power to Stereo & Cigarette Lighter, help please
- Lug Nut opinion
- TPS location 92 civic
- Quick opinion on extended lugnuts...
- d16z6 shutting off..
- help w my 2000 civic ex engine
- D16 and B16 Tranny questions
- I can't figure out what type of vehicle this vin number is.... I feel stupid
- manual to power door questions.
- Help with ignition lock? 99 Si
- 99 civic 2dr coupe quarter panel replacement
- Difference between JDM ZC and d16y8 engines?
- 99-00 civic climate control
- good or bad deal on gsr?
- b16 revs to 7200?
- Seat question about EG sedan
- Replacing vtec engine w/non ???
- what engine is this?p2a-5
- surging idle after about 10 mins
- 'Third time's a charm' EK build thread
- help adjusting coilover sleeves before putting them on the car
- b18c1 smoke after deceleration.
- YIKES!!!! I barely have brake pressure on my 93 Del Sol Si
- Need some guidance!!!
- Air BAg Light ?
- A/C Removal
- Headgasket, or something else?
- Changing rear hub
- Function & Form type 1
- sir lip
- will these coilover sleeves work on my eg?
- s2k seats in 92
- DASH HARNESS problems. power door lock conversion 99-00. EXPERTS NEEDED!!!!
- Civic runs only on obd2
- What cams are these?
- headlight issues FML
- Help!!!
- how much can i get ?
- which exhaust sould i use to pass emissions test?
- problem with temp gauge
- Pilot bearing
- D16y8 intake mani
- CTR Tranny help!
- honda ej2 trany problem
- Anyone go with NON-OEM parts for there civic 99-00 conversion ???
- changing ignition lock in my ej.
- ep3 seats in a eg coupe
- GSR brake conversion into EG???
- does a b18c valve cover fit a b16a??
- Speedo Jumping when cold/wet
- D16 all-motor question
- DEL SOL:high 11's low 12's what does it take?
- whats the difference between ex/lx catback exhaust
- Timing belt Package ( is this a good deal )
- Piston Help
- Buying a 99 hatch this weekend. Am I getting a good deal?
- driving, then all of a sudden pop! now car won't start
- EG's came prewired for a shiftlight? (diagram inside)
- someone wanna tell me wtf is going on here? wierd front end
- 2000 acura el ENGINE MOUNTS NEED HELP ASAP
- 94 hatch lmk what you think
- Caliper question
- 1996 civic coupe window problem
- EG dash clock?
- This a real CTR spoiler?
- EK carbon kevlar hatch 96-00
- Need help passing emissions! 93' Civic Sedan DX help.
- Rear Wheel Bearing Help
- idle bounce after ignition switch replace...
- Eg hatch with skunk2 im.... Whats cable?
- ls in a 93dr. map sensor question
- Side Markers
- corner lights, tail lights, and fog lights help
- Help with EK exhaust linkup
- Trying to sell a car.
- clucth helpppp plz need answers
- Will Ek Side Skirts Fit my Ej?
- Gsr Swap Need???
- Would these springs fit?
- 94 Civic DX Hatchback question
- Threads/links how to wire tuck/remove eg?
- PRO & CONS ABOUT LS VTEC
- Gsr swap into Em1 EVAP and LAT help
- Distributor Wiring Chart
- need help identifying this harness
- Front tranny mounts bolts stuck (mount is loose on frame)
- High Rev at Startup
- help with using an 'easy out' to remove a snapped valve cover stud..
- no power when taking off
- JUST A THOUGHT
- so i need a front tranny mount... any how to?
- 94 civic sedan cv joints axles jdm b16 question
- removing front lip from EM1 civic Si
- intake manifold question
- cant start car CEL wont shut off
- B_Series into 92 EG questions!
- CAN ANY1 help???
- Need help with a cambered wheel!
- Help with harness
- EJ8 Rear Sway bar Bracket question?
- Need a new fpr?
- Quick question
- new to honda tech
- 2005 Honda Odyssey Touring Model calipers
- Engine Question
- Valve Cover Flanged Bolts
- Installing OEM wing on Del Sol: Need hole locations.
- >>>b16a obd1 hellp ??????
- Motor runs extremely rich at high rpm
- EK oem sideskirts fit eh9?
- S2000 cluster gurus
- Cluster and Turn signals dont work
- scratch removal
- shaking problem
- Wire tuck questions
- WHAT MOTOR???????????
- Ek K20 Nitrous Ecu problem.
- 95 into a 97
- code 14
- best exhaust for an ej1 with a built b16(allmotor) ?
- help! gsr sway bar on eg
- Help! Bad Axle???
- Water pump
- My Eg project... What is it worth??
- gsr burning oil
- Carbon Fiber Hood latching question HELP PLEASE
- A noob that needs help
- Poormans Type R swap Problems!! Help!
- city lights uk
- key stuck!!
- i need help finding racing seat brackets 4 a sol
- boosting a d16y5 opinions
- Need Help
- obd2 ls crank angle
- Super Duper Quick Question about Fog Lights
- squeaking noise and removing trim
- mysterious oil leak
- 2000 si cluster in my ej
- Spoon Style Mirrors Wiring (EG) HELP!!!
- how much is my si swap worth?
- 92-95 oem tailpipe mufflers interchangeable mountings same??
- new to this one
- d15b wire confusion!
- EG Hatch W/GSR Swap ... Limp Mode Questions.
- secondary o2 problem
- PICS!!!
- Lowering of my 97 civic coupe
- re-did my valve cover too ;)
- vetc plez help
- HELP ! crank position center
- Wire Removal from Harness Connector
- how do i change real wheel bearings with drum brakes?
- 1997 Civic dx(94 gsr swap) need help
- do i have to redo my timing if i get new heads?!?!
- Anyone actually put rear integra seats into a 92-95 coupe?
- Tranny swap ? B16a..
- 2000 Si valve cover problem
- crazy idle after vtec hits
- D16Z6 problem, Wont turn after the flywheel is Torqued
- Fuel Tank Pressure Sub-Harness
- Have a problem!
- 97 lx sedan automatic engine pull question.
- car stutters/bogs when driven after 10 mins
- Does a b series A/C compressor fit and work on a D16y8?
- competition twin disc problem
- d15b7 starting issues
- Hatch dies when i depress the clutch..
- car wont start after shutting off???
- 1999 Honda Civic Ex Build
- Lower arm bar help
- Engine Pressure Question under load.
- overheating
- Throttle Body / Idle Funny
- brakes
- horrible idling + startup!
- Arp Rod bolts
- ITR Rear seat question
- Need a muffler for a 97 cx hatch
- 92 Civic ELD Code!?
- need help B18c swap in ej
- zc d16 true vtec hp ??
- adjustable cam gear in d15
- Del Sol Cruise control help??
- help please! asap valve bolt snapped
- New Ek Hatch owner =]
- Automatic trans install problems
- Shift Linkage Bolt Snapped... Help
- Frozen Tie Rod Lock Nut
- Change Oil manual trans/fluid quarts?? type??
- CEL does NOT come on.
- good deal?
- civic si from tampa fl
- good header for a 2.0L b series
- Need the Right AC bracket, Help plz
- del sol seat swap ????
- my car is throwing 3 codes please help!
- is this normal...(rev-limit ?_have searched)
- new headers?!?!
- F20C EG swap RWD
- Basic B series swap question for my 96 civic
- Wheel size?
- QUICK!! Which a/c belt for d eries comressor in B16
- Trunk Water Leak
- Dash Removal -- EK
- question/help
- opinions on best engine degreaser lol...
- IAT sensor wire colors
- bump stop on struts..
- F22 Throttle Body On JDM D15B
- Car wont start
- Vtec Not Kicking IN???
- surging idle problems
- Weird "wheel of fortune sound"
- Rear T bracket
- Anyone Have These Headlights?
- Just picked up a 93 HB. What did I get?
- question about rev limiter
- CEL: code 43 & srs light
- B16 help
- quartel panel repaired on a eg4dr
- Question about setting timing on Skunk 2 cam gears (tuner series)
- Anyone have a Vacuum line diagram for 1999 Civic Si
- HELP!! MY EJ1 BLOGGS
- sawp power interior
- Weird idle!!! Help ASAP!
- milano red or any coolor ciivc with black or c/f hood,roof and trunk?
- How do you remove the air silencer of a 99 ex?
- opinion about my 95 eg si **pictures inside**
- HID retrofit projector question...
