View Full Version : Honda Civic / Del Sol (1992 - 2000)
- civic seems like its dying
- spoon caliper problem....need help
- Cruise Control in 97 del sol
- VAFC Air flow Converter hook up?
- NEED HELP!!! OBD2 to a OBD 1 turbo problems
- Crank Pulley Worry.
- idle problem, A/C idle, bouncing idle desperate for help!!!
- Intermitant problem (Need help diagnosing issue)
- I got ripped off in Buying My DelSol - clock, steering rack, and blue smoke
- How do you remove third brake light in an '00 EX coupe?
- Different exhaust manifold gaskets? I thought they were all the same for B16
- Del sol gsr swap gets fuel no spark
- help gauge cluster blinkers and wioers not working
- Will Type-R brakes fit in HX wheels?
- Power window problem
- Quick flash of oil light, why?
- Help - Just had my k-swapped car stolen!!
- Cluster, blinkers, wipers don't work
- SRS light + Horn wont work?
- Gauge Cluster Problem - 00 Ex vtec with 98 ecu
- my 95 ex coupe
- 92 Civic Cluster n switch light wont light up
- *sigh* Cutting my floorboard for the H23 tranny cables, anyone have instructions?
- b20 ecu, p75 doesnt work well p2e single cam ecu runs good. help wtf!!!
- Open back seat from trunk
- ls tranny question ?
- swap problems on SOHC VTEC ZC! please help!
- How much does a Brand New Honda Civic cost in India?
- megan short shifters?
- gsr del sol. which exhaust?
- Just did Valve adjustment on my B18c1. Still ticking?
- Ej8 window keeps coming off track
- Amber it all?!
- Installing A/C in an EK with B18c1
- 96-98 climate control slider wont go all the way?
- Checking rods
- Spark Plug Color (PIC) Lean??
- gsr block help
- TOKICO ILLUMINA SHOCKS/GC
- motor build questions
- ECU PINOUT OBD2a automatic civic
- My del sol project
- ls swap!
- UNDERDRIVE CRANK PULLEY UPGRADE HARD TIME FINDING BELTS
- Wire Harness
- Type R head/LS block or LS VTEC or Type R head/B16 block? Which is Better B?
- Vx hatch question
- 95 Civic Auto to Manual Swap Rear Mount Question
- 95 Civic Lug Studs
- Help with b16 tranny/clutch...can't change gears
- clutch is going out?
- EJ8 Sunshade removal?
- What hose do I need to refill my ac refridgerant
- 94 EX SRS is only light on dash..shorted??
- How to Wheel Bearings?
- 92 hatchback cx with d16y8 problem?
- The build that seems to never end!!!!!
- 1993 Civic Automatic Tranny Problem
- Idle problems on cold starts
- Apexi N1 questions plz
- My Ek (not my choice that it was auto)
- Speedo Help.
- b16a turbo build
- Engine Compatibility
- EK - Shaved k20 build
- 97 dx - would it look good with a Si wing?
- ej9 mods????
- B16a goes tacktacktacktack.
- 94 civic dx swap questions
- engine idle funny and breath funny
- post your honda civic sedan
- 2 questions , 1 thread
- oil pan gasket
- BRAKE PROBLEM
- D16z6 in ek question?
- 95 civic: how remove crank pulley?
- Catalytic converter where?? jdm d15b vtec 1997
- Aftermarket Catalytic Converter and CA smog
- EVAP Canister removal
- Tranny axle not seating properly.
- need advise first turbo gsr
- 93 Eg si hatch Speedo acting crazy
- 98 civic LX header/cat replacement.
- Motor Swap Questions for a 97 Ek
- Aftermarket Intake manifold on D16Y8 fitment Question
- eg civic coupe and sedan spoiler difference
- Tranny Removal gone wrong HELP!!!
- HONDA theft proof????
- 2000 Honda civic... Transmissions Issues!
- Eg gsr swap, what t/b cable?(stock & skunk)
- Want to DIY fabric dye seats...What type of material are honda/integra seats
- Tranny Horsepower ratings
- 92 civic lighting/wiring help
- Car wont start. Replaced fuel pump. Main relay?
- NEED HELP: Trouble Starting Car
- 1997 civic test pipe question
- b series wont start vid inside.
- DIY on replacing Intake Manifold Gasket on d16y7
- auto to manual question plz help fast
- Q abt noise on front right side of car when mking hrd left u-turn/cornering hard left
- brake pads...
- Evo 8 seats in my ek. What do you guys think?
- '00 EX VTEC malfunction
- secondary o2 sensor wire
- front subframe swap out
- TDC/Crank Sensor Location
- 99-00 power window/lock conversion
- Check engine light codes- need help
- P06 AC Compressor??
- Will an EM1 wing fit on 96-98 EK sedan?
- Window Regulator Problem
- b16 not starting -- weak spark
- Lower Control Arm removal
- 98 accord radio fit/plug in to 96 civic
- Airmass header question.
- (ATTN: Civic Gurus) Front Suspension Question-Strut Forks
- Wiring Harness Keeps Burning Up. WTMF !
- red line issue
- CTR b16b swap in eg chassis questions
- slloow coolant leak.. ?
- Swap tips?
- wiring harness problem
- Knock sensor
- mileage question
- Civic throttle jerks
- Traction bar question... PICS
- what the best wheel locks???
- Car sometimes won't start...please help..
- Is this okay? Opearting Temperature.
- 94 civic dx 4 door cv shaft question
- 244whp 5psi.. what do you think?
- Is this possible?
- Trans issues
- Ek9 w/Fat Fives
- MINI ME SWAP QUESTIONS
- Vanishing Coolant Trick! .....help
- 1992 CIVIC VX with body side mouldings???
- HX RIMS: Which tires are best? 185/55/14?????
- Mini Me Question
- D15b2 hellpppp!!
- z6 head on b2 block ???
- CHANGING FROM DRUMS TO DISKS
- over heating/white smoke...
- Master Cylnder, Proportioning Valve, and other questions.
- Watch washers for fuel line on pump end!
- best source for restoration parts?
- ls swap 95ex with red line of 6k and idle at 100???
- B16 bad idle, no power, smell fuel. Getting spark.
- oil pressure gauge best way
- 94 civic overheating issue
- Braided Brake Lines: Difference between ABS & non-ABS for 92-95 Civic Si Hatch?
- 94 Del Sol Vtec A/C Problems
- exhaust help! anyone lol
- Need Diagnostic help with engine power loss
- '92 Civic Hatchback - Door Handle Problems
- LF:99-00 civic Harness
- Tach jumps from 3k to 0 but runs fine
- manual to power windows swap help!!!
- cel code 91 still on.
- B20 VTEC Headgasket leak on fresh rebuild
- TRANSMISSION INTERCHANGE
- 2000 Civic no start help please?
- abs removal clarification
- D16Z6 problems
- Bolts question..started and clutch housing bolts
- 1993 Honda Civic EX ECU Burnout
- PLEASE HELP! tach swap prob need to be solved today!
- My 1995 Civic CX Hatchback build!!!!
- Y7 versus Y8 valve cover
- converting power steering to manual steering on 95 Si
- EG headlights black/crystal
- 94 Civic, D16Z6, VTEC was working and now isn't, no CEL's, already been searching....
- S2000 Ap1 swap into my 1995 EG, HELP PLEASE!!!!!
- A/C Problem
- 93 del sol s to si rear brake conversion
- Please help with light switch!
- Clock turns off when headlights turned on
- 95ex D16 swap for H22A
- full coil overs, camber kits
- Boggg.
- HELP ME! ORDERED HASPORT MOUNTS FOR MY H22 eg CIVIC
- Timing Balancer belt Noise/Question.
- My EK Hatch Build Thread
- Rear brake lights and tail light stopped working
- Engine swap list - H22A EG
- 95 civic hatch swap
- ‼ Brake Booster Question soft spongy brake pedal feel.‼
- ticking noise
- warm up low rpm miss
- WHAT IS BEST HEAD GASKET FOR D16Z6
- EG cat back on EJ2
- d16y7 idle fluctuating..
- 95 civic si fuel filter part number
- missfirering ?? helpppp !!!!
- 94 civic - Will 99 Integra front brakes bolt on without any problems?
- Top Bolt on Pedal Set
- d15b2 or d16y7
- need a new carpet for my car
- Can i use exhaust headers from d15 on a d16?
- 97 jdm d15b vtec into 97 ek with p2j ecu: What engine wire harness should I use?
- Belt tensioner fail cams rotated 180degrees! helP!
- d15b oil pan question
- I got a couple of questions about short shifters..
- HELP!!! Boost on my D16y8 not kickin in. Anyone please, help!!
- Starter wire question from obd1 and obd2
- Swapping a eg with an H23 from cable to hydro... is it possible?
- How many pieces is a civic door hinge?
- eg wont start
- race springs or lowering springs?
- Car Bogs/Loses Power Temporarily when warming up?
- A/C Pulley/Belt Replacement Problem
- Can someone verify these CEL codes?
- eg custom intercooler piping kit? any dIY's out there
- QUICK COILOVER HELP!!! asap please!
- S2K Cluster install in my EJ8 help???
- How the !$#@ do you get axles out of the tranny?!?
- 93 Del Sol leaking roof
- Clogged injector(s)...
- motor swap help
- Why does my 95 civic d16 only rev to like 4.5k rpm
- civic starts then cuts off
- Lower ball join won't come out help
- engine coolant temp, how hot is too hot?
- b16a2 bogging and sputtering aroud 3k
- sticking throttle
- cel code 8
- How do i safely remove my a/c system?
- Wen installing a tps sensor...
- D15 smoking out every hole
- lug nuts
- 93 Si Cluster Lights Only Working Sometimes. Any Ideas?
- **** NEED ACURA EL PARTS ****
- 99 civic dx mods?
- d16z6 overheating - already replaced temp switch, radiator, thermostat
- Is srp 149193 in a d16y8 possible?
- Removal of Pedal Set
- Civic 96-00 Motor Mount for H22 and F22
- ECU tuned to run on 102 RON....... HELP??
- PGM FI Relay problem.
- D15b7 to JDM D15b swap, Help needed!
- map sensor
- 99 si gauge cluster in a 94 coupe?
- i need some advice PLEASE!!!
- vtec swap with no vtec
- Coilovers
- Y7 block/Y8 head OBDI - Hesitation/misfire on dirt track
- Is this D16Y8 Exhaust manifold and downpipe or D16Y7?
- sway bar end link for 98 civic
- Engine Swap on 2000 Civic Ex Coupe
- oil pan wont come off!!
