View Full Version : Honda Civic / Del Sol (1992 - 2000)
- D16z6 Engine Startup Issues
- 93 Del Sol Si - Fuel Injector Rebuild/New vtec gaskets/PCV "mod" = Not Starting
- 95 Civic EX automatic -- Transmission leak?
- Troubleshooting Issues: A/C Condensor replacement - 99 Civic EX
- Car wont start (main pgm fi relay?)
- Loose harmonic balancer, Damaged crank?
- 1996 hatch rear brake conversion and ek9 seat questions!
- 94 Civic EX Cpe rear disc conv
- 92 Hatch suspension problems
- 97 del sol B16a
- what is easiest way to get valve cover sit correctly on 97 civic lx
- Replace FPR vacuum hose with a silicone hose?
- HELP identifying my brakes!
- 94 Civic Coupe EX 5 SP - Clutch Switch, Unknown connectors - Cruise
- 94 Civic - good fuel good spark - crank no start
- 98 civic - Fuse #44 blows when key is turned to on
- 94 Del sol Motor Mount
- Need some input on engine mods for the stock d16
- Slow moving fuel gauge & low fuel light issue.
- 98 civic lx stalls/sputters intermittently
- 97 civic - Idle surging
- 96 Civic - low idle very low and pops and cracks when driving
- 99 Civic Ex isn't starting
- Thumping sound from rear right in reverse?
- 1997 Ex Auto Tranny Grinding
- Injectors size???
- Where's this oil leaking from?
- which seat for tall folks
- CEL code p0172
- 96 civic lx - power steering rack same for all 96-00 Civics?
- Brake problem
- 95 civic DX/D15B7 Cel#9
- Cluster doesn't tell me my speed
- 93 Del Sol Si - mini-me and clutch questions...
- '96 Civic Fastback VI electrical problems
- Y8 auto to Y7 auto
- Ignition switch causing issues?
- 93 Del Sol - Severe Loss of Throttle Response
- EJ2 - B16 Engine rebuild LOW oil pressure, good clearance
- 93 Civic Hatch CX D15B8 to D16Y7 ????
- Strange squeak from belt section
- Need a motor swap to beat mustangs and mercedes driven by rich A-holes
- 99 civic ex - What is my D16Y8 missing?
- 97 Civic LX - idle issue
- Will a D16z6 simply swap into a 97 del sol si shell?
- Water drops go into my Del Sol. Help me please.
- 00 Civic Si/B16a2 hesitation
- 00 Civic HX, 5-speed - D16y5 to D16y8 Transmission question
- Blinking D4 Light & Check Engine Light? (97' civic, automatic tran.)
- 1995 Civic del Sol Distributor
- 93 del sol si - NEW brake switch question
- 96 Civic D16Y7 Idle issue
- 96 civic ex with a 97 d16y5
- need help with info on ignition distributor
- EJ6 - Need help w/ coolant issue
- Radiator upper support - loose? Should there be a bushing?
- Alternator ground??
- 94 civic - looking for some ways to up the HP
- 90-93 integra catback on 99-00 ek hatch
- Wont start with key, only by jumping starter
- Weird electrical (I'm guessing) issue in my 98 DX hatch
- 99 Civic EX won't start
- ECU fix for A/C always on
- 00 Civic DX - misfire and hesitation
- 99 Civic struts
- 1996 civic what is this??? Plug
- Partial evap / charcoal canister delete
- 00 Civic Code 63 secondary o2
- EM1 in Japan?
- Small gashes inside head?
- Anyone know what size nut for the bottom alternator bolt?
- OEM top hats / strut mounts
- Fuse Size / Electrical query regarding Fuel Pump
- Will a new door be able to fit inside the car for transport?
- Installed 2013 Si seats in my EM1 today...
- Vtec doesn't work
- civic lites stay on
- 92 Civic Loses power while driving.
- Hose that's not connected-_-
- Need some info on JDM D15B
- Vogtland lower springs
- EK EJ Civic...BRAKE Light Stays On. (solved)
- 00 civic ex with manual rack - Did i mess up my rack & pinion? (solved)
- 2003 civic rims on ej6
- Ac just stopped working all of a sudden today.
- 98 civic ex - Cant get key fob to work
- 93 Civic Hatch to 93 Civic Sedan Dash Swap?
- 99 Civic Si - Question about dist. ignition coil...
- 93 Civic Si - C303/304 and C124/126--Tuck harness Q's
- Q's about interior seats
- Mini-me swap - d16y7 block + JDM d15b (P08) VTEC head
- EJ2 - Engine bay work
- Oil weight - what the previous owner did vs what should I do?
- 96 Civic Lx - speedo and radio stop working intermittently (gone to crusher)
- 92 vx sputtering/ missfire at idle. no cel
- head bolt threads stripped on d15b7 block helicoil repair
- Stage 3 xtd clutch for my d16y8 - break-in time?
- (Mini me) D16z6 complete with a D15b8 block - what will I need?
- 1996 Lx or Ex
- Horn and Fogs stopped working
- '95 Del Sol Si: Power Door Locks Not Working - Making Clicking Sounds
- From the Ground Up. Build Thread.
- Shift linkage
- What kinds of cluster and dash can I put in my 99 Civic ex coupe?
- '92 civic window crank assembly issues
- Need advice: '92 VX, crank pulley and crankshaft end stripped
- oil light in cluster not working
- Just got a 2000 Civic LX, CEL, combination of codes mean anything?
- Intermittent power failure with key fob
- Power steering fluid leak?
- 95 Civic - d15b swap questions (solved)
- RPM JUMP AT 1500
- 94 civic dx - CEL and Loss of power?!
- defi tach 2 blue wires
- Would 00 Civic si fenders bolt directly up to a 93 Civic with 00 si front end?
- brake problems? help!
- CARB E.O. Legal Air Intake for 95 Del Sol Vtec B16A3?
- Y5 block/Z6 head/chipped P06 ECU - vtec does not activate
- 00 civic dx - auto transmission jerks/shifts hard
- '96 CX with stock engine - Short shifter to fix the loose shifter?
- Do i need to swap sub-frames to fix this?
- 1995 civic issue with rpm gauge
- 95 Civic dx hatchback rear seat Gathers JDM install
- High Idle When SCS Connected
- Brake fluid leaking
- Front wheel bearing direction
- EG/B16a swap - CEL is on but does not blink codes with service connector jumped
- 95civic d15b7 head gasket help >~<
- Spoon Sports N1 exhaust for 99 civic si coupe?
- 99 civic, first gear wont go in
- New 95 hatch - good website to get a new timing belt?
- D16y7 with a y8 head swap on a 97 honda hatchback dx
- 93 Del Sol won't start, even with starting fluid
- Question about backfire
- EG losing brake pressure after swap
- How do I install A/C in my 98 civic hatchback?
- Will B18b1 Axels fit a 93 Delsol SI hub!?
- 1996 integra type R suspension on a 1996 civic ex with dx suspension?
- 2000 EX really bad compression
- Rebuilt b16 smoking
- Transmission hard to get into gear
- K-swapped 99-00 Civic/EM1 plug Identification
- 95' Civic EX, weird no-start problem
- Code p1456 2000 civic ex
- Car sputtering - CEL code P0505
- B20B no start after swap, got crank, spark, and fuel presure but no fuel in motor
- 96 Civic EX 5-speed/D16Y7 swap - intake, speedo, hood latch, exhaust questions
- EK AUTO TO MANUAL - no crank wiring issues
- 92 VX Hesitation, diagnosing questions
- 1993 Honda Del Sol Si 1.6L || Rear Toe Adjustment
- Spontaneous knocking noise
- Rear sway bar end links
- 99 Civic EX Overheating Issue
- d16y7 extremely leaky engine dip stick.
- 94 DX Coup - broken timing belt
- 92 hatch interior bolts sizes
- 2000 Acura EL (Civic EX) - Very low Idle
- 98 Civic Sputtering & Idling
- '95 Del Sol Si engine tick
- Is it REALLY this hard to seal a vtec solenoid?
- Eg civic with d16y8 how to hook up the ckf sensor
- 1998 Civic EX Power Window Problem
- Clutch losing pressure randomly
- help. 98 civic ex with Dx? trans.
- Civic 1999 - run permanently with no ignition lock
- EJ1 - B20/b18c1 head, p28 ecu with crome tune - Idle/ECU/Sensor issues
- Obd2 d15b jdm with p08 zr head an p28 ecu?
- 92-95 civic dx hatchback interior
- Heater Problem
- need help! hoses on iacv
- Did Head Job, Now No Heater!
- rear disc brake conversion
- 1999 civic sir - What mods to increase power for drag racing?
- Burnt ATF: to change or not to change?
- Tweeter Pod
- help!! broken cam gear key
- 98 Civic won't start?
- can you swap a 1.6sohc vtec head on a 1.5sohc non vtec motor
- door skin
- 95 Civic d16z6 dead cylinder?
- Cypress Green Civic EK4 B16a2 Build Thread
- d16y7 no fuel no spark (solved)
- 99 DX problems
- b20 vtec in em1 cold start issues
- 1997 civic lx no get up n move
- Navigating PDF Service Manual.
- Where did my post go?
- did I break some rule ?
- rim fitment help
- 96 Civic - Cooling Fans not coming on
- 1997 Civic Wont Hold Alignment
- 96 civic keyless entry
- B16a swap questions
- Stock EJ8 - Question about stage 3 clutch
- 95 CIVIC EX - D16Z6 to JDM D16Y1 SWAP - INTAKE QUESTION
- Civic is stalling. HELPPP
- 95 civic d16z6 - Engine Idle problem & CEL code 15
- 93 del sol turbocharged track car - Need suspension advice
- 2000 civic SiR Power Steering rack removal
- I need a mad sweet roof rack
- Bad wheel hop ej9
- 97 Del Sol brakes
- Civic EG e-brake question.
- B16a to b16b
- d15b head on d15z4 block
- Looping the power steering on my 99 Civic Si
- No Crank, no chek, no start
- Can I replace a power steering rack with a manual rack?
- 2000 civic si (EM1) - power to manual rack & pinion conversion question
- Where can I buy only the electrical switch and wires for my ignition?
- Radiator fan wire going to fuse box under dash
- 97 Civic EK Hatch - B18C Build Thread
- Positive wire straight from fan under dash?
- honda civic ex 1999 cold engine
- jdm d15b replacement engine burns oil (solved)
- Cel code 0
- HOIST POINTS FOR REMOVAL HELP
- Problem about replace an antenna on 1995 honda civic
- Surging idle
- 2000 honda civic dual stage vtec automatic or 3 stage vtec
- B16a2 275-300whp reliably?
- 2000 EX AC problems
- climate lights flickering. (not back-lighting)
- Does this sound like a rod knock?
- This dashboard is killing me. How the f do i get the airbag shit disconnected?
- CEL codes 3 and 7 - TPS not receiving proper voltage
- ej1 won't go past 4k rpms, but does once warmed up?
- civic distributors and caps question
- D16Y8 Knock Sensor Help
- Sputtering/Misfire at low RPMs
- Recommendations for shocks on my Del Sol
- Guy said he sold me ctr 5 bolt suspension but what is it really?????
- D16z6 stock compression pistons with P08 Head milled .045".
- Obd2b b series into obd2a civic
- Td86u and td63u distributors interchangeable?
- 93 Del Sol Speedo help
- Cylinder 1 miss at idle
- Del Sol: Removing Rear Window Trim and Paint Questions
- Vss problems?
- '95 del Sol B16A3-Experienced fuel cutoff at around 7500rpm (before 8200rpm redline)
- Power to manual rack swap
- Brake Light Cel Dim
- 95 civic/GSR swap - Running lean and jumping idle (solved)
- water pump failure
- 1998 civic DX coupe back seat
- Locating zc gaskets
- 96 Civic - Blowing FI E/M fuse #44
- Speedo/Vtec not working.
- 1993 Del Sol Exhaust question?
- Maurice's Paradise blue/green Ej1 Build
