View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Anyone remember the DIY CAI air box mod 4 inch???
- eg coupe exhaust fit eg hatch
- Transmission flush
- Cluster Swap Problems
- 96-00 hx axles same as 96-00 ex axles?
- Civic D15 intake nuts/timing belt/head bolts
- 4-1 header?
- ECU swap questions
- tach arrow jumping, help!
- Question about a VTi Cluster for 96-00 from the UK
- 1999 Si upgrade ideas
- ek fog lights
- WHATS THE DIFFERENCE BETWEEN these TWO types of Ground Contorls???
- HELP: ej6 window conversion
- Idle help
- (pending) PO170 Code...dont know what it means?
- Will a 1998 Civic Si INTAKE fit on a D16Y7?
- carbon/ un-burned oil all over rear bumper . .. .HELP
- 94 civic lx stock overheating???
- b18a1 swap for del sol
- Window Visors
- o2 Sensor on Test Pipe
- b16a2
- RPM Problem. (Wont stay steady) Please Help!!! *Videos*
- How To Set TPS, And other sensor questions
- How do I know if a thread includes a picture?????
- Running hot
- Eg suspension/ Need your OP
- Clutch Problems
- do i need a TOP HAT for coilovers
- h22
- What is the stock psi in the stock fuel pressure regulator on the honda del sol????
- APEXi vtec controller and code 44
- Electrical problem, car dying over night????
- Alternator Help!
- Need help
- 2000 Si drivetrain swap.
- Odd starting problem
- 1998 Civic: Voltage Signal from Transmission Sensor Out of Range
- 92 95 civic CF front clip quetion
- 93 sol::windows,cluster,rad fan,directionals not working >which relay or fuse?
- 96-00 civic
- Tilt Wheel?
- modify stock 99 dx intake?
- EJ's and EG's Post your pics here!
- linkage
- NEW HERE and got a problem
- cam issues...
- cam issues...
- heater problem
- integra dash in eg
- 99 civic dx hatchback
- ek side skirts on a eg
- Car doesnt shut off when i pull the injector plug
- why did my profile get deleted?
- OBD2 D15B ( 3 Stage VTEC ) Into 98 Civic EX
- Chipped or unchipped p28 ecu
- eg stolen last night austin tx
- 98 d16y8 swap into 95 cx hatch Axles?
- 4.785 or 4.9 for b16
- Why did the forum change??
- ...Best Way to Secure your car...
- k series help with eg....?!!!
- Front end; 98 different from 99-00????
- What Intake Arm Is This
- mugen lip help
- em1 catback? suggestions...?
- distributor help please!
- 94 Civic Coupe side marker plug question?
- how do i fix this.. i need brakes!!!!
- QICK CEL Q
- i dont get it?
- dash light dimmer switch?
- d16 ITBs
- were to go?
- 96-98 civic fogs
- Catalyst converter query on 00' Si
- 99 civic ex d16 timing degree. help. just did the timing belt...
- ATTN EVERYONE, from builthatch
- idleing problems...
- d series or b series?....
- PLZ Help with my window conversion.
- differences between engines???
- question harness engine 1998-1999
- engine lose power after 3000 rpm, need some help
- ek cluster in eg ????
- suspension question
- How and DOES a voltage stabilizer help ??
- the new hatch
- b18c1 in a 1995 ex coupe JDM ECU question?
- clutch?
- Temerature gaugue
- (noob) Got my first car a 96 civic ex cant find much info on a D16A engine
- help ASAP, JDM b16
- Will 06-08 si seats fit in my 97 dx hatchback?
- Good, inexpensive, Si Replica lip?
- engine + mounts from 00 si coupe in 00 hatch
- SOHC VTEC head codes for 92-95?
- DIY oil change?
- Fog Light Issue
- 1992 civic cx firing orders
- Help with quick release!
- ABS light on help
- y7 engine swap question
- Wire tuck questions (d16 or Bseries)
- need help got 97 ek put zc vtec in it
- d15b IM on d16y7 head
- insight for rims and springs for 95 coupe
- 93 Civic LSI Problems, Help Please!
- 180 or 195 thermostat
- Help .. My car won't start/ turn over...
- ugly sound when turning left... wtf
- what years and models did ek hatch come with a rear wiper
- d15b7 won't start
- Idle Issue
- D15Z1 VX engine burning oil. Need to buy another engine.....
- OBD2 Distributor
- help
- reverse lights wont work
- Looking for a carbon sunroof block off
- Question about motor mounts and axle/axle boot
- Vtec Not Working...Very Frustrated
- Stolen? what to do
- Oops a boo boo, Wrong ps fluid, drained put in proper, still no ps.
- check engine light acting funny...
- New Member. Heres my new ride.
- need del sol parts
- 00 civic ex gear grind in 3 and 4 gear
- Where to get Eg Z6 motor mounts
- Intermittent throttle problem. 00 2dr dx 5spd
- want to make sure, 96-98 Coupes? Roma Red? Milano Red?
- Crower Cam Kms Valvetrain...
- volt regulator help
- eg2 bumper protectors
- Del sol door panels repair???
- ecu problem need expert
- Bucket Seats/Racing Seats
- 93 civic hatchback DX 1.5L?
- Trying to identify a sensor hoping someone can help
- valve train???
- cat?
- help me make a decision
- master brake cylinder
- replacing/installing radio antenna
- what kind of bar is this?
- camber kit help
- Removed Cat and have CEL now, how to fix? (EK)
- NEED HELP: 97 Ex Suspension
- Swapping a 90 Integra Motor into my 93Civ.
- timing belt one tooth off!!!
- thermostat area
- integra seats to civic hatch
- Fat Five Center Caps
- Bogging issues with semi-built LS-Vtec. Searched. Please help!
- cel 10 IAT and bogging
- Looking to swap in an H22A4...
- windshield help for 96-00
- stuck bolt help
- How to install a turbo timer?
- is this front bumper worth fix'n
- throttle body problems
- axle problem!
- 92 Civic Hatch Question
- eg wiring help needed!!!
- HOW TO: DIY EP3 shifter into EJ1 chassis civc.
- drive axle wont go in
- b18c5 swap car wont start !!! please help
- need help on D16Z6 Coolant plumbing compared to the d16Y8's plumbing. Pictures inside!!!!
- need help on D16z6 coolant pictures, compared to the d16y8 plumbinginside!
- ATTN-HONDA GURU'S...New Civic Owner In Need of Help
- question on motor mounts for high HP engine
- random problem with high comp. b20 vtec in EG coupe.. PLEASE HELP!
- timing fustration, please help!
- Bought my first car.
- fuel filter?
- EG factory color
- SRS Light for 96 Sedan
- AUTO TRANSMISSION CHECK / REFILL MELTDOWN
- Will an integra hood fit on a civic?
- reset srs
- Gearing a SOHC tranny?
- h22a into a 95 civic
- car was running fine now it wont start.. help
- is it the same?
- What is this piece called?
- Em1 tranny help!!!!
- d series harnes question
- bad headgasket or????
- Ignition coil fuse (2000 Si)
- GSR QUESTIONS ON EJ1
- Difficult Pic Request: Stock White 99-00 EJ6 w/ SI or LS wheels
- Dashboard color change.......
- fuel pump?
- Needs help on a swap PLS !!!!!!
- D15b7 to D16a Axles
- Want to Buy Access
- ring hrned16y8 in 94 wiring help ahhhh
- Brake pedal freeplay
- i need advice on parts plz
- quick question....
- need h-t's help...i cant decide what to do. im confused.
- New member pics of my Civic
- sum1 broke my driver's side left rear window 92 civic hatch. how much to replace?
- INJECTORS WIRING
- ek ej underhood insulator? where to find one? pics inside!
- silly suspension question? but i do need help
- Coolant Leak... On slave cylinder?
- what B series mounts is used 92-95 civic?
- b16 intake choice
- Should i rebuild my d15b7 or swap for something else
- B16 NOOB
- Code 41 and 43
- ckf bypass trick
- NEED HELP FROM MODERATOR!!!!!!!
- Window Visors
- suspension problem
- civic cel code ?
- How to verify it is in fact my valve stems/seals/guides that need replaced?
- another vtec prob.pls help
- Sputtering and no throttle acceleration on Y8
- Help! B18b1 in 97 EX coupe won't rev past 3k and bogs, no CEL!
- catback help
- 96-00 civic horn
- I'm new here and here is my ride...
- b16 turbo options
- hatchback air vents
- Interior courtesy lights fuse
- new ej8
- 94 Hatch having trouble starting.
- 93 Civic CX EG Hatch with D16Z6 swap...legal?
- exhaust from d to b
- 99 coupe black interior
- Temputrure
- Heater - A/C Blower fan speed. Possible fix to your slow blower.
- b16 sirII in ej1 coupe
- del sol fogs? how much
- milage numbers are not rolling!
- tranny problem please help
- Question on tranny fluid.. 92 civic.
- Water inside car
- GSR into EK - GSR Header Flange too big for EK Exhaust?
- Belt squell
- My bucket
- What steps should I take when replacing the alternator belt?
- pulled a CEL 9 today....confused???
- Clutch Pedal Travel/Freeplay all of a sudden changed!?
- where to put seafoam in on a gsr?
- Air bubbles on oil dipstick???
- REAL BAD IDLE ISSUES!!!!!!!!!!!!!!!!!
