View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Problem w/ JDM power folding mirrors on EK
- mini me swap tune up question
- can u BAR a jdm itr motor in 96 ek?
- D16y8 Head on D16y7 Block????
- 93 cx gsr no cel, 6500 fuel cut? ideas?
- 93 hatch/obd2 jdm d15b dual stage - fuel injectors won't spray
- Stolen: Seattle super street civic type r
- Is it must that I use Honda ATF fluid?
- CRX lip on EG???
- no heat please help
- b18a1 swap into 97 civic - What axles?
- front end shaking, need some help
- Clutch Squeaking
- 98 ek hatch b18c1 car blows no heat.
- i have a b18a1, thinking about a vtec head
- turbo d16 blowing what seems to be white smoke....
- How to get rid of EVAP code (99' EM1)...?
- b18c1 swapped into 93 civic - CEL codes 3, 22, 54, 65
- Vtec solenoid gasket leak
- HELP: Battery draining after a couple hours, battery new and alternator is okay
- NEED HELP!!! CAR CRANKS BUT DOESN'T START
- d16 problems: hesitation, bucking, jerking, low rpms when driving for a little bit :(
- jdm b16a into 00 civic ex
- Knock Sensor Help
- 98 ek foglight hid install
- Master bushing set
- h22 civic help!! plz
- gsr running lean what to check (solved)
- car starts when cold let it warm up and turn it off car backfires and wont start
- Rear subframe bolts
- HELP : MIND BOGGLING IDLE PROBLEM
- LCA bolt question
- Integra Sedan rear brakes???
- valve cover for 1999 civic SiR - what to buy??
- Trying to bolt on my OEM seat but the rail wont line up?? Urgent!
- Help! compression test results inside
- HELP driver door will not open from either side?
- DIY 96-00 Honda Civic Tune up and fuel filter
- b18a1 in to a 97 honda civic dx useing a ex harness
- Temp gauge plus belt issue
- power door locks, keep locking on their own every now and then?
- 97 Civic - Mode control and dash lights problems
- Need someone with a 96-00 civic to help out with insight/picture of headlight wiring!
- d16z6 compression issues.
- D15B Oil Pan Question
- Few issues with "poor mans type r"
- Ls & B16 swap Questions-Help Needed
- Vtec oil feed questions
- What year is this? *pic*
- 95 civic ex - clock resets and radio requires security code after car turned off
- Idle in the cold
- LCAs
- iacv woes..
- 95 coupe automatic door locks wont work
- Help !!!! OBD2a-OBD2b distributor plug problem after engine swap into 99 Civic DX
- Taking out the AC
- 1995 honda civic dx - fuel pump problem
- Having problem bleeding my clutch
- Speedo Gauge?
- P0135
- E-Brake light comes on while accelerating*HELP*
- HOW DO I INSTALL KILL SWITCH AND WHERE ON A EJ :)
- Will a D16Y7 oil pan fit a Y8??
- whats wrong with my radio?
- Smog Questions
- NEED HELP WITH DRIVER'S ED WORK
- Painting the valve cover
- Need help with 96 d16y8 swap into 2000 civic ex
- 93 Del Sol/Gsr swap won't start!
- Honda Parts Lookup
- Need Miscellaneous hardware
- 1 wire o2, cut shielded wire, now what?
- 92 cx hatch no headlights or tails help please!!
- ecu question
- Replacing entire fuel system, need help
- 99 Civic DX Cooling Issue HELP!!!
- My Del Sol Bogs! Need Help!
- Will 00 coupe lock switch work in 97 sedan?
- B Series Valve Covers
- 98 civic ex - no spark
- b18b valve adjustment..
- ek hatch exhaust question
- 98 DX interior help
- vtec wiring question
- fuel pump question
- Fuse keeps blowing after replacing brake switch
- gage problems...HELP ME PLEASE!!!!!!!!!!!
- Steering Ratio Improvement
- need help swapping b18c1 into 99 civic
- Seized caliper
- obd1 code 41
- OBD0 Dizzy to OBD1 harness??
- DC2 Recaro into 96 Hatch Seat Rail Help
- wiring obd1 ls into 99 civic
- Just bought a 99 civic ex with b16a swap few questions with pictures
- bent vacuum/// how bad is this
- motor wont turn over. no noise from starter at all.
- 1999 civic hx - low on coolant in radiator but overflow is full
- Unorthodox Pulley Set
- Interior Carpet
- Del Sol seat harness help
- My irish ek9
- EJ2 with street tuned SOHC ZC - What Spark Plugs Should I Use?
- throttle position sensor or pedal position sensor
- Stock EK hatch - i need more power :(
- basic bolt-ons
- 1991 EG SiR brake question.
- Bad Brake Squealing Even While Braking
- Stranded.. 98 civic EX - Only 2V at fuse 13 (fuel pump)
- 98 civic dx, code 0, ls swap
- Will 99-00 Civic Rear Lip Fit on a 96-98 civic??
- eg ferio rear disk ?
- theres a scratch on my b18b cylinder wall do i need to get it bored?
- car doesnt rev past 3500 rpm??
- Help, Id tranny verification
- d16z6, will not start warm
- My 00 EK build thread, plus a little something
- d15b-are the correct headbolts from d16z6?
- Help, Can't set ignition timing any more advanced -valve timing is good and normal.
- oil pressure sending unit / switch
- EG with gsr swap power steering ?
- clutch problem pls help
- why call it an EK
- Brand new CV shaft... defective?
- Sol won't start, can you help?
- Need help with B18c1 swap into 1997 civic dx hatch - no b/s answer
- 98 civic frame rail question??????????
- Cheap ebay fuel pressure regulator ?
- do i have to buy new headstuds???
- *** B16 LINE FROM FUEL FILTER TO FUEL RAIL *** NEED HELP
- whats the best build for single cam turbo..
- Distributor Question.
- Strange & Annoying Heat Issue
- Sexy 6th Gens!
- What's best motor to swap into my 97 dx considering price, versatility, power, etc
- 93civic bogging out
- Need help with unknown CEL number....
- How to remove resistor box (wiring it back to normal)
- ebay car covers?(auto armour)
- How do i find out the size of my pistons??
- Anybody use outdoor car covers?? Suggestions?
- Civic CX Decal
- Broken crankshaft keyway!!????!!
- Removal of 96 civic sedan brake lights in trunk lid?
- D16Z6: cel code 41 (o2 sensor heater)
- Is it necessary to break in my new rotors?
- 98 stalling wtf?
- 98 civic ex
- Need OBD0 ECU pin-out help
- aftermarket gsr header heatshield
- 96 civic srs light, no driver airbag!
- b16a2 smoke problem
- what happens when you drive with out a spark plug connected?
- 195/60 R15 tires on a 2000 Civic EJ, will it rub?
- Proper wiring obd2 ex harness to obd2 ls motor
- EG cluster jdm clone
- Show me you clean EG hatches!!!!!!
- Anti theft: how do you keep you're car from being stolen
- low oil pressure on build d16z6?????
- Engine Swap help
- throttle body swap on y7 to y8 possible
- How frequent do your haters make their presence known?
- Are the regular Civic oem catback the same as the SI (99-00)?
- IACV
- P1459/EVap Vent Solenoid
- OBD2 JDM b18c swapped into a 1999 US civic si problems...
- (91)ls swap into (1994) eg sedan
- eg b16 swap car randomly dies and wont restart
- How to make my hood as a blackboard
- 95 ESi Overheating
- state ref on 94 civic
- 99 Civic EX/Turbo/5-speed conversion with 3-wire IACV: Misses & bucks at ~4500 rpm
- gasket leak again?
- Error in service manual and everywhere else (Helms '96-'00) + online parts store
- d16z6 cam help
- ej1 arm rest?
- B16a ticking noise goes away only with valve lash set below spec
- Motor mount on a EK
- 99 EK/2000 gsr swap - my driver side motor mount broke!
- will my 1995 civic operate without a cluster?
- Change a/t filter and oil
- valve cover paint?
- starting issues have searched tons
- P73 OBD2A???
- Looking to get my 95 Del Sol Running -- Just purchased D17, What Now?
- Heat wrap vs. heat shields (searched)
- URGENT: Clutch pedal has no pressure and won't return when pressed
- how to pin a wire back into the map sensor plug? (solved)
- 1999/2000 Honda Civic Si Factory Exhaust Tip
- Pic request : Eg wheel well
- Intake Setup
- lower control arms
- Emergency! Coolant Hose Popped! Now More Problems
- D16y8 no vtec ecu
- ecu and d16y8
- Early 99 Civics have an OBD2a ECU?
- catalytic converter question
- speedometer, Speed sensor help!??!
- alpine type r subwoofer questions?
- recent swap cuts out just past 5k
- steering jerks to the right violently help please
- Skunk2 LCA question
- '96 D16y7/auto CX cranks, sparks, gas...no start
- engine shut off after warm up
- '99 Civic With CEL 41 and 90
- D15b7 balancer issue
- How To: Replace CV Axles 1998 Honda Civic LX
- Tuning my B16A
- LS swapp list/info help thanks..
- just did a ls swap in my eg hatch and having issues plz help!!!!!
- 01' Auto LS into Auto EK Hatch???
- b20 build
- 93 civic cx gsr: code zero 0. .
- all of a sudden bad gas mileage?!
- Broken dizzy cap screws
- Honda Del sol exhaust diagram
- Got into an accident my hood will not pop, any ideas?
- valves on my D15B8, does this look normal? please help!
- spark plug wires -b16 tune up
- What is "stock" spare tire size
- B16 crank pulley spin off, metal clanking, Bent valves? need serious help!
- help with 2000 honda civic
- heater problem help
- Solid CEL, anyone help!
- Help fuel pump not turning on (solved)
- d16a6 idle problem
- Ls swap on it's way
- 92 civic cx hatch wont start! doesnt want to crank
- DA pedal assembly in my EG
- 00 civic heater not blowing hot please help
- is it ok to take my b18b1 block to any machine shop to get bored?
- Gas leak ONLY when filling up
- 97 civic dx heats isnt good
- NEED CLARIFICATION!!!! 96-98 EX with 98+ Spec B18c5 swap
- Nardi Horn install help.
- SPOON V-TEC CONTROLLER VC-3E
- quick injectors question...
- Tilted DuckBill Spoiler, How To?
- staring issues after sitting longer then 20 mins any suggestions?
- Ek coupe cd player
- rear spoiler
- D16z6 VTEC question
- my b16 boggs at low rmps HELP PLEASE!!
- cooling in oil pan
- planning to do an integra cluster(98) swap in my ek
- What B seriers Axles should I get?
- 96 civic lx manual transmission noise when clutch pedal is not pressed in
- Bad MPG due to DIY o2 wire extension?
- just thought id throw it out there!!
- just thought id throe it out there!!
