View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Some bi$%^in and alittle tech question but mostly bi$%^in( btw its kinda long)
- Civic Axel Back on a Del Sol
- Water leaks into my hatch when it rains
- Buying used rims' and lip has a scuff
- 2000 Si Few Questions
- How-to ground wire
- 93 civic eg sedan, i need a vtec engine!!! help
- help on toe's ball-join and its little arm
- White Smoke, Searched already just checkin
- adding ABS?
- how much hp stock d-series tranny can hold?
- MotionR.com 6000k Xenon Bulbs
- dizzy???
- midori green civics!!!!!!!!!!!
- 96-00 EK guys with indash dvd players where did u put it? pix please
- suspension help please
- D16Z6/D16Y8 + Boost. Comparison.
- D2 Coilovers Slammed?
- EGR DIAGRAM
- I need your help with my Si
- Timing belt/ Water pump ?s
- Is the coupe headliner the same as the hatch for non sunroof?
- Which Bushings are these!!!
- how do i get to del sol rear speakers?
- Toyota engine swaps?
- OMNIPOWER SUSPENSION COILOVER SLIPS.
- K20 swap
- Will H4 bulbs fit in oem CTR headlights?
- Check out this HONDA VIDEO. Best Commercial EVER!!!
- Broken lug...
- DX header
- Weather Stripping Or Window Sealing
- Maybe someone can tell me why ????
- D-FUSER
- gauge cluster
- SOHC clutch service limit??
- Boring out Trottle Body
- Need help!!!
- Bouncing Idle question
- 205/50/15 or 195/50/15
- 93 hatch si clutch question
- Mini Me HELP!
- ECU Chip?
- h23
- QUESTION!!! HELP
- factory exhaust system for 97 hatch
- Please help me fast
- New import kid needs help
- selling a civic 96 EX coupe silver NJ $3500
- Help with registering(searched)
- EF Hatch Seats into an EG Hatch? Anyone ever do this?
- help!!! Motor Wash
- jdm b16 ecu question
- Serious Help!- Auto D to Manual B
- Which 5th gen. hatch...
- ecu pin out help!!
- 2000 CIVIC Si Question
- Wireing help anybody?
- Civic CRX REAR Trailing Arms
- fuel tank fitment?
- how to tell master cylinder is bad
- d15b
- Car Storage
- looking into buying a 1996 hatch.....what do you guys dont like about it
- Need Help With Ls Swap into EG
- B20
- Ek question
- SAFC Tuning
- 97 Ls motor into 00 si
- will honda centercaps fit rota rims?
- Can someone help me find a FUCKING GASKET FOR MY HEADER?????
- head swap done....now car wont start
- 99 Si with integra rate skunk2 coilovers + koni reds
- Spoon N-1 Muffler compatible with EK?
- 92-95 civic c/f dash trim....whos got it and where to get it....
- A Fun VSS problem
- H22 Civic
- stolen eg coupe in Pasadena, CA
- HELP... WHITE EG HB TURBO VIDEO, cannot find it
- Weight of a gutted EJ8 (ek coupe you fools)
- what would cause this? (help fast please)
- anyone used www.transcontinentals.com??
- Whats the rev limit
- HELP .. will a vx tranny fit my 95 ex motor ?
- What is the oil capacity of a b16a?
- D series turbo! Ideas on Tuning?
- compression
- catback off an 99 SI fit on a DC2?
- Just got a 92 4dr DX!
- HAving a problem with my OEM tails I just boguht!!
- 96 Civic headlight connector/plug question please help!!
- vtec,turbo?
- removing the ek wing
- Z6 stuttering/popping during acceleration, check list of what to look for?
- Bodyshop question: Replacing rear quarter panel, please help answer my questions
- What is a good Aftermarket Cat 2.25 inch
- ran my stock 95 ex coupe at track...
- insurance rates?
- E BRAKE LIGHT
- Moving up in the world
- ATTN: got an EG? is it automatic? CLICK HERE!
- CRAZY problems wiring an AutoMeter tachometer into my CX!!!!!
- antenna wire broke :(
- 96-98 vs 99-00
- Carpet for EG
- 92 civic cx hb signal lights
- 1996 Civic SI speedo problem
- Resonator
- Difference between airbag modules civic EK4
- STOLEN 323/626 area: 1997 Civic Hatchback CX - RED
- Help! My 1996 civic vti(UK) has the ignition light on the dash come on.....
- tachometer installation
- 98 civic coupe for sale
- Should ball joints be stiff?
- does 1992 honda civic si come vtec?
- wheels bearing need help
- Color Codes For All civic owners..!! from 88-04
- 6x9 speakers won't fit in speaker panels
- Running rich z6
- Question about mods for a 2001 Civic LX
- Anyone ever transported a motor in the back of a Hatch???
- what causes this?
- OBD2b to OBD1 Conversion frustration...
- Stock wheels: 13" VX vs. 14" HX
- D16Z6 owners. How many of you are pushing +140ft/lbs and with what mods?
- 17"s On An EJ1 Comfortable Ride?
- body kit for delsols
- handling issues
- >>> starter problems<<<<<
- PROblem with driver wINdow 97 hatch
- Need Carfax please
- 99 front end install
- Having some more problems..... Help plz?
- size of screws used for rotor on 96ek?
- Yes Another Mini Me Compression Question ? ? ? Help
- Eg project what to do first?
- Another Stolen Civic! So. Cal Area
- i swear my suspension is out to get me
- T25 off sr20 clocking issues need help quick
- Help Removing he Inside Paint
- Pic Request: Under Body
- 99 civic bumper removal...how do i do it...LOL
- building a 4 door sleeper.. need ideas
- 99 EX coupe climate control doesnt work. PLEASE HELP
- skunk2, SPOON, T1R, or Apex'i
- car is IDILING weird....When i rev it bogs.....help anyone?
- b16a (second gen) or a b18b block with b16 head??
- Cutting the bumper...
- URGENT HELP NEEDED!! ROTOR RUBBING ON CALIPER?????brand new brakes and bearing.
- NEED ECU HELP!! CHIPPED, P91
- please answer fast!
- gsr oil pump better then b16
- axles
- Del Sol Liscense Plate Body Pannel Removal
- ex and dx tranny
- Brake problems, Help please. Brake drum help needed too
- clanking noise help
- D16Z6 vs D16Y8 Sensors...swapping an OBD2 engine into an OBD1 car/harness
- Should I trade sedan for this coupe?
- Oil Inlet Flange
- Need some help guys. I really have searched.
- any 1 sellin in TRI state area a engine twin cam Vtec holla NJ NYC ......
- The 05 Si...
- anyone seen those new mobil oil commercials???
- what type r exhaust fits on 99coupe?
- 00 shocks on a 92-95 civic
- 99 Civic Si Milan RED "what rims to get Rota Circuit 10 or Rota Circuit 8"????
- brake rotor rubbing on inside of caliper URGENT!!! any help appreciated, hatch
- 99-00 civic headlamp question
- random question
- Curious as to how much improvment a y8 tranny makes.
- ECU problem and IACV problem
- Sebon 96-00 Civic Invader Hood FS
- STOP UR CAR FROM BEING JACKED>>
- Where does this plug in ?
- Anyone ever run a distributor cap with 2 of the 3 screws?
- wheres my coolant going?
- where can I get some of these?
- Where did you buy your acura EL/ domani front end from
- Car mysteriously died..............
- Wheres the link
- civic headlight conversion..... KIND OF
- Stock rear muffler section on aftermarket mid pipe?
- Will the Comptech rear sway bar/tie bar combo for the Integra work on the Del Sol?
- how much would you pay if you needed a 96-98 civic ex engine harness??
- +40mm Offset on EH2 Lowered 1.8F, 1.6R, ANY RUBBING?
- what shocks to get????
- Swapping Trannies
- valve cover bolt question??
- JDM EG Headlight Wiring HEEELLLLPPPPP!!!!!!
- 2000 civic si front sway bar on 93 EG?
- rsr exmag fit ment question
- kteller exhaust question...
- Hey I need some some help with posting
- Camber Kit question
- 97 ek, can i swap to 4dr rear door handle to remove the keyhole?
- custom catback set up
- OBX LSD HELP stuck axel??
- Problems with mini-me
- civic hx
- hx rims 4 sale
- sohc zc in EK?
- where to find a eg6 jdm wing
- (searched) swapig in my LS motor into my new del sol? quick links?
- tranny question
- Just got done with B18b1 swap into EG. wont run right, need help.
- '92 Hatch exhaust fits '96 hatch?
- soundproofing a civic coupe
- CEL, got a code 16..anyone with clues?
- GSR Leather Seats?
- HELP! car shaking under acceleration
- what probs will i run into swapping a jdm type r head on a U.S. B16 motor?
- Will 99Si e-brake cables fit EG?
- Snycro going bad....need advice
- omnipower vs d2 full coilovers
- EG wheel stud removal?
- gsr sunroof on hatch
- chipping ecu
- IM Gaskets interchangeable?
- electrical problem plz help
- B18 Tranny rebuild DIY?
- SOHC ZC ecu
- rear dissbreak Conversion
- timming problem
- Riverside!!!!!!!! Sieze your car as of friday....
- ARE AVID MOTOR MOUNTS ANY GOOD??
- exhaust HELP!!
- b18b1 wiring
- Differences in stock b-pipe from 91-DX/SI...I need to know.
- wireing
- routing exhaust piping on EG hatch w/ tie bar?
- sway bar
- Seafoam works great!
- k swap becomes more affordable
- d-serise oil pan material ?
- Get Honda Technical Service Bulletins online here!
- Need help finding a reliable tuner shop in VA
- over heating
- Need pics of Sparco flat bracket in an EG - yes, I searched.
- Jdm d15b and two questions
- im a retard, ran car without oil, what now?
- what was that one site to test the compression of a head/block combo of sohcs.
- 99-00 Si Tranny
- Burnout= Worn clutch??
- What dizzy will BOLT UP to Sir II B16 ?
- h22 ECu
- rear 99 LS Teg rear sway bar on an EK?
- EH2 with Sunroof
- eg fog light covers
