View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Stolen black 00 civic si
- Car starts but stops immediately
- help with front bumper install
- Del sol exhaust. Which should i get?
- B18c flywheel question
- 96 del sol vtec head swap
- 95 honda civic throttle problem
- 96-98 edm vti dash into 99-00
- Using ATF to flush engine?!
- 185/75/14s on a 1994 civic 4dr
- I have a big issue with valves...
- Leaky fuel rail
- B16A idle issue
- 98 civic dx shutting off while driving
- Ssr reverse mesh/ssr mesh wheels 16 5 stud
- Any brand(s) or type of gasket maker similar to Hondabond?
- 95 ex coupe issues. again.
- leak between stock FPR and AEM fuel rail?
- 2000 civic lx ball joint help!!
- 1997 honda civic dc po133 codes
- Sensitive Alarm on 98 Civic
- HMO b16 question
- Honda delsol 94 not starting
- ID wires on I believe Idle Air Controller.
- Front abs senders
- intake manifold
- b16a head and block dowel pin placement
- '98 Civic EX - modified / hacked thermostat
- 1996 Honda Civic DC reving in park
- resetting trip made odometer stop working for a day
- GSR in EG problem
- Horn stays on help!! Nrg(QR)&personal horn
- d16z6 with blown head gasket, 95 ej1
- Leaking coolant hoses - replacement question
- Coolant leak help!
- not getting gas after 3-5k rpm
- 97 EX Automatic IACV CEL code - where does sensor plug in?
- RPM LOW
- d16y8 dipstick relocation
- 92 Civic VX hatch - interested in performance and appearance mods
- Del sol transtop Rhd conversion window help! By pass transtop ecu.
- 1993 Civic DX d15b7 motor question[s]
- b16a swap in eg - no spark
- New Header for only M/T?
- Del Sol Loose Windows!? Help?
- Very Bad Idle
- Drilled or Slotted rotors???
- 2000 Civic, D16Y5 w/ "P2P" ECU Problems
- Engine upgrade or Super charger or Turbo
- Worth it to swap ECU (P2E to P06 chipped)
- Hesitation when accelerating 94 civic si coupe/dx trans
- question regarding timing on a b16
- Aluminum civic radiator question
- hasport mount question (gsr in ek)
- 1993 Civic with 1995 Del Sol B16A3 swap. Rebuilt head code 5 and 14
- ANTI-Theft?
- Is Mystic Brown (tan) interior somewhat uncommon on EG coupes?
- Invidia exhaust
- Del Sol Camber/Fitment
- seats for the tall guys?
- My ej2 build thread...h22 content
- RSX seats into 95 civic coupe
- 96 civic ls swap
- Battery Draw
- Help with viper 5701 remote starts
- What is the little felt piece that rides on the inner door window of a civic hatch ca
- Another Crank Pulley Fell Off
- '98 EX Tach stopped working
- will any delsol linkage fit any d series tranny
- Vibration when braking.
- Vibration when driving high speeds
- 95 Civic won't crank/start.
- cel on but not showing codes
- EM1 Front Bulkhead Measurements
- Need help: Auto to manual swap in 2000 civic Sedan.
- Tokico Blues giving me the blues, what the hell?
- 2000 EX Sedan d16y8 intake manifold hoses
- No start - B16A2 - EM1
- A quick rear window question
- CX to DX head swap acceleration problems
- AC Help!! Everything works but no cold air
- 95 civic heater control panel fix?
- 98 Honda Civic Violent Jerking
- Blinker Too Bright! Blinks Fast Sometimes. Looks like a fog light.
- Del Sol Suspension, what is needed to upgrade?
- HELP!!! 95 civic non abs conversion
- 1995 body kit fit 1997?
- question before i purchase gsr seats for my eg hatch
- 95 civic fuse keeps blowing out no lights on cluster, and parking light
- A/C causing engine to struggle
- Misfire after installing turbo?? Help!
- 2000 Honda Civic Subaru Rumble Exhaust
- How do I roll the fenders on my 96-00 civic?
- Rear ring *pic*
- del sol gsr swap what header to use?
- Civic Trade Good or Bad?
- Throttle body question
- 92 Civic CX - D15b8 to D15b7 swap has no power to anything
- where does this plug go?? and will this intake work with my car?
- CEL code 92 help
- Windshield Wiper Fuse Issue
- Would this RSX relay setup work with an EM1..??
- looked at faq, how do i get code for p28 while car is running
- Tie bars?
- 3 wire to 4 wire Alternator OBD1 to OBD2 Help!
- DC Sport 4-1 header has leak, need help
- 99 Civic LX - overheating problem
- Del Sol Performace Oil Pump Ugrade?
- D16Y8 idle dip a few times at cold start.
- NEED HELP:94 civic coupe interior lights,exterior lights flickering
- Eg dash light dont turn on need help
- D16 Engine turns but wont start
- 95 Civic with D16z6 wont start have spark and the fuel pump primes
- D16Y8 cranks but won't start
- 95 civic lx - d15b7 min-me to y8 vtec head - What distributor will work?
- eg sedan window help!
- Anyone attempted to wire up a glovebox light in an EG?
- CEL P0420
- Plastic Trunk Clips
- Torque spec
- Front Lip.
- Benen Kevlar duckbill (numbered)
- 94 Civic Lx, can't get out of park
- Issues from trying to swap a Z6 into my '97 EX. Bolts don't line up, and more.
- Spark Plug Wire Part # Question
- Engine harness issues
- Interior map light?
- 2000 Civic SI Regular Unleaded Gas / Black Smoke
- civic 98 idle problem with A/C
- How to adjust the lifters?
- Exhaust question. 92 hatch
- sohc compressor/b20 bracket in ek hatch
- Hello
- Foglight Ground Wire Broke
- Suspension Suggestions?
- Timing belt replacement question.....
- Help!! D15b auto gearbox.
- Need help opening hood with release cable not working
- How to force radiator fan to stay on? 98 EX
- 92 civc hatch getting 12 mpg suxxx!!! helpp!!
- Del sol Eg front end conversion
- putting a rear sway bar on my del sol...
- will ITR header bolt right on to a b16a?
- D15B spun rod bearing? ticking to knocking.. newbie
- what are these and what do i plug them up to?
- RPM needle bounces, motor jerks and sputters
- 97' EK hatch/H22 swap - ECU, bumper, brakes, RHD conversion, and engine questions
- 1999 EK Hatch
- Changing Brake Master Cylinder
- 1995 Civic EX Main Relay Problem(maybe)
- Door glass popped out of the u clips...
- How to fix EG manual mirrors that are loose and fold in while driving?
- 00 Civic Si - strong smell of overheating
- burning oil, d16y8 mini me. how should i test it?
- Where do I buy a good quality D16Y8 engine?
- 98 Civic DX Coupe - what can I do to get a little more kick out of it
- 93 DX Coupe (No trunk light) - Looking for constant power source near trunk area...
- 97 dx suspension
- Oil leak from distributor
- 97 civic suspension ideas
- 20% tint on windshield
- Best engine for project Del Sol?
- subframe swap question
- Need parts list for b16a3 swap into 98 Civic hatch
- y5 block z6 head mini-me swap with p28 ECU has no power
- how to check compression on a b16
- d16y7 misfire and misfire codes
- Starter? Or? (vid)
- oil leak?
- Which sem vinyl paint for grey civic interior?
- 95' Civic Gauge Cluster Malfunction
- 98 Civic EX Heater Issue
- d16y8 vin location
- Clogged Cat?
- Unknown plug that shares yellow wire from c922 ignition switch plug in dash fuse box
- CV joint nuissance
- Finally my 1st build!! aka 98 EJ8 jane
- OBD0-OBD1
- p30 ecu problems and questions
- 95 civic ex...more wiring issues.
- '94 Del Sol 3rd brake light inoperable.
- Just got a 92 Civic Hatch :)
- 98 Honda Civic P0172
- Replacing blown d16y8.. what swap to make
- Will EG 4dr Sedan front seats fit in an EG 2dr Coupe?
- 97 civic dying?
- Whats this?
- JDM Honda Civic EG4 VTI Owner's Manual
- Question about Sideskirts (EK)
- D16y8 vtec Ek coupe - i want to make it as fast as possible
- Is it possible to make the eg6 sir steering wheel detachable?
- Car Remote
- Car lost power "i needd help"
- Draining Motor Oil From Transmission
- civic starting problems
- Starter Problem
- Leaking coolant from intake manifold barb!
- 95 Civic - FRONT OF CAR SHAKES TAKING OFF IN FIRST GEAR
- Very Low Idle on D16y8
- Convert from 3-2 wire iacv
- some issues w/ my 94 del sol
- K20a2 Lose of power after vtec
- D15B7 obd1 Dizzy Parts fit in b16a obd0 dizzy housing?
- From D16Y8 to JDM D15B HELP
- Blinkers don't work
- hesitation at light throttle.
- 95 Civic EX not starting
- D16Y8 ignition timing. Off a tooth? (Pics)
- New member with some questions about 92-95 EG hatch
- Power and Non-power doors interchangeable?
- What do you think? Good deal?
- CV axle seal still leaking...
- Stalling/AC problem...
- o2 sensor Problem!?!
- F2d keyfob work with my ej8?
- Splicing fuel injectors
- New Tires today, vibration improved, but not gone
- Car-dumb girlie needs interior swap help!
- Idle/alternator problem?
- 98 cx hatch progress thread
- Need Help Please...
- 2000 Honda Civic w/ B18B1 no spark
- honda civic 95 lx sedan - accerlation issue
- Armature plate sheared off A/C assembly going down the road
- 95 Civic Coolant problem
- 95 EX cuts out when warm
- Flywheel Issue
- Del Sol Interior Clips
- Spoon Stroker kit for b16
- gauge cluster lights dont work
- '97 HX Civic battery draining
- 1998 OEM honda civic manifold/convertor & o2 sensors
- Replacement manual regulator
- Very odd noises happened this morning
- Door Jam problem
- Civic backfire on startup problem?
- 93 Civic Coupe - How do I get the rear trim panel off?
- brake light
- Rubbing noise when front wheels are turning -- Civic Si
- ['94 Civic EX] Slow turn over then starts (solved)
- Painting a heat shield - Caliper paint okay?
- car won't stay on
- 1997 HX Civic - best tranny for a build?
- cel code 13 eg si w/b16
- Potential problem after replacing internal Dizzy seal?
- Quick question: changing CV axels, should I buy tool?
- heat shield
- HELP ME ID THESE!
- ek hatch rear seats help
