96 civic hatch rear brake assembly conversion, drums to disc quest???
so i got a rear disc brake assembly off a 96 integra ls, to do on my 96 civic dx hatch . i started to disassemble it for new bushings, hubs n bearings, rotors, pads and blasting for powder coat...... i need to find out what proportion valve i need to make it work properly???? do need the speed sensor for abs thingy??????? and do i need anything else for convert???? if anyone has gone thru this with the same conversion with the same make n model......... thanks for looking and your help.........
Re: 96 civic hatch rear brake assembly conversion, drums to disc quest???
I did the same swap on my hatch last year. You don't need a new prop valve, as the one you have is the same as the Si one. I just removed all the ABS stuff on my Integra trailing arms, replaced the rotors and pads, painted everything and bolted it right up. I was also able to use the Integra E-brake cables (without hacking up anything on the floor) even though most will tell you they don't work. Good luck.
^what he said. Although, aren't the DC cabels longer?
I know they work, but I've never been able to figure that out.
As he also said, you've got the same prop valve as a SI. No need to replace it.
I dunno, my brakes came off a 97 SE Integra (I believe). The e-brake cables that were on there were the same as my DX ones and fit up through the floor the same way. Worst case senario is you have to buy Si cables, but it costs nothing to see if you can use what you already have.
i believe the integra ones are alil longer but they can be fit to work. as for the prop valve u dont need to buy one if u have a hatch. i think the sedan dx/lx are the only ones with different prop valves.
46210-S04-952 VALVE ASSY., PROPORTIONING 1998 INTEGRA RS
46210-S04-902 VALVE ASSY., PROPORTIONING 2000 CIVIC CX Hatch
46210-S04-902 VALVE ASSY., PROPORTIONING 2000 CIVIC DX Hatch
46210-S04-902 VALVE ASSY., PROPORTIONING 2000 CIVIC DX Coupe
46210-S04-902 VALVE ASSY., PROPORTIONING 2000 CIVIC HX Coupe
46210-S04-902 VALVE ASSY., PROPORTIONING 2000 CIVIC SI Coupe
46210-S04-912 VALVE ASSY., PROPORTIONING 2000 CIVIC DX Sedan
46210-S04-912 VALVE ASSY., PROPORTIONING 2000 CIVIC DX-V Sedan
46210-S04-912 VALVE ASSY., PROPORTIONING 2000 CIVIC LX Sedan
46210-S04-922 VALVE ASSY., PROPORTIONING 2000 CIVIC GX Sedan
46210-S04-962 VALVE ASSY., PROPORTIONING 2000 CIVIC EX Coupe
98dxhatchbuild
09-23-2017 02:29 PM
gray89si
08-10-2004 01:27 PM
civic_sleeper
09-18-2002 12:38 PM
