View Full Version : Honda Civic / Del Sol (1992 - 2000)
- h22 in a civic
- Intake heat shield
- Lost for sure 2000 Civic SI
- what do i need for ek power window swap?
- Intake Manifold: Skunk2 or BLOX
- So do i buy new rotas or used gsr blades for my beater (daily driver hatch)
- can i use a gsr intake manifold on ls motor
- Easiest Model to swap
- Ticket extension??
- anybody need a P28 ECU?
- what coilovers
- wireing
- delSol Dash light help???
- how do u install a profec b
- odd problem (starting related)
- a few EM1 q's
- K20 into a EK hatch
- cam/camgear won't stay at TDC.
- 96-00 civ gauges into 92-95 civ, tes I read the write up, I want pics damnit!!
- why am i only getting 180 miles per tank?
- Anyone have or seen this "book" before?
- what exhaust for an 96-00 hatch?
- 96 Honda revving up problem
- Well... I failed my Emissions test baddd
- hey help me out will u!
- type r engine in old honda civic
- civic parking/headlight issues
- 10 second AWD eg hatch DAILY DRIVER**********8
- cleaning rims..
- 3-digit CEL WTF?
- looking for custom interior parts....
- would this fit on a b16 in a del sol?
- quick question
- VIDEO-WHY HONDA IS NUMBER 1!!! L@@K
- Throttle Body Size Recomendations.
- HELP..96 Spec Type R Wheels on eg
- check valves.
- Intake manifold / ecu installation?
- Is a polished bar better than painted?
- Need Help...
- got a problem with 1996 civic ex. someone help me
- what mounts will i need to put b18a into eg 4 door
- Coilvers on 97 civic dx
- Rear bumper options, non transformer body kit crap...
- How do I replace a speed sensor?
- WHICH MODEL SHOULD I BUY?
- jdm d15b.. thinner headgasket ?
- please help
- Horn stopped working
- Cruise control in 92-95 dx hatch?
- wiring diagrams for FIELDS vtec afc...?
- Help please......
- stock hp numbers on dyno for 95 civic ex vtec?
- 1" Brake Master Cylinder
- FUNNY--Gsxr man for reals lives
- Time out to introduce myself...
- Oil leaking from headgasket, overheating
- del sol still moving in nuetral !!!!!
- ATTN all obd1 b18c1 owners, can you help me out...breather pipe, need for BAR visual?
- RS*R EXMAG Clearance With 99-00 OEM Civic Rear Lip.
- crvtec problems
- LS Turbo.......rocket motorsports???
- No heat..........core bypassed
- code 15 and no spark...................
- Need help for trade!
- guage cluster problems
- D15B in the phillipines. I need some help
- Trunk Mods in Ek and Eg Hatches?
- working on tranny...how do I hold down flywheel
- started up car with NO oil. now has loud ticking sound.
- engine fit
- Quiet Cat-back or exhaust for Del Sol?
- Omni Camber kit
- fan not turning on
- DIY o2 Sensor simulator anyone have any Instructions?
- 99-00 rear bumper Question
- B series transmissions - Hydro vs Cable
- seat issues will rsx fit 94 hatch
- 92 Civic gauge cluster QUESTION
- 93 civic starter problems ?
- resurfacing head
- the venom 400
- About to swap b16a2...
- Z6 head on Y7 block timing
- trouble with the str throttle body
- Exhaust sound clips...
- auto to 5spd???
- best B Series tranny?
- sensors? i searched
- Goodridge SS Brake Line fitment question
- Coolant Leak
- Virgin P28 with obd2 B18C1..... engine light? *VIDEO*
- z6 vs. a6
- Omnipower testpipe?
- civic 93 not start when hot
- Momo Rookie 92 cx Hatchback Brackets
- Cluster (tach) 92-95
- intake manifold swap, top mount throttle body to side mount throttle body
- *bauley approved* price on this civic
- d16 post mount on a b16
- Removing cruise control?
- need help: 92 prelude seats into my 92 cx, having issues
- Front shock tower bending more HELP
- del sol centerbore (newb kinda)
- D16y7 intake manifold question
- EK bumper on EG? *pics*
- DA knuckles, did search...
- d16z6 tranny bearing
- Fuel Pressure question
- Looking for Honda head flow chart, or CFM charts for stock heads.
- Normal engine temp??
- do all 96-98 honda civic LXs come 4door?
- Guess what?
- wiring question on 94 del sol auto to 5 speed
- help strut bar..!
- Weighed my EG today
- 95 Civic Ex coupe info...
- has anybody own a jdm ctr with LHD converted?
- tsudo exhaust feedback ...??
- 1992 Civic Ex....any comments?
- dc2 door panels on an eg
- Fuel Cap Where to BUY!?
- Black Civic on Delaware Rt.13 1/25
- alarm reccomendations?
- EG slim hub?
- KYB AGX adjustable struts
- Problem with lights...'03 Civic
- Clutch going bad or something?? Just had both cylinders replaced and no leaks this time...??? what t
- chip istalation
- EG FOG LIGHT
- Question about steering wheel ????? some helpful responses wanted...
- Does the 92dx hatch have a tach?
- Header Question
- HELP ME...
- How do I remove my factory head unit from my 04 Sedan?
- b18c5 ecu question???
- Ideas needed! Wich cams into B16A2 and what else?
- Key Blanks for a 1980 Civic?
- VTEC Oil Pressure Sensor Question....
- Painted Steelies
- Is Enjo going out of business???
- Which Master Cyclinder & Brake Booster?
- ude Frame damage on my EK AND ONLY LIABILTY!!!!!!!!!
- problem with vtec
- Has anyone ever seen a damani civic or something of that nature..
- Someone in Tacoma, Wa area want to let me borrow their cherry picker?
- width of hx wheels
- Is It Possible to Swap in ANY Car Engine
- weird clunking sound from rear passenger side...
- Going rate for USDM ITR exhaust
- Attempting to remove motor without cherry picker.
- best way to get metal shaving out of head?
- Should I get this car civic hatch 93 dx
- ls/vtec build
- EK master cylinder
- 92-95 Fog light
- b20/vtec ecu?
- Rotor Screws after drilling them out.
- You've got to see this!
- Si 5th loss?
- dumb ? but i need 2 know, thanx
- removing rust with what kind of sandpaper
- what material is the b16 intake manifold made of?
- obd2 swap in a obd1 civic
- Question abotu gsr sways on a civic.
- What EK years were HB's available
- This sucks has it ever happened to u. (not technical) what would u do about it..
- Dyno in Richmond Metro Area
- Question! Regarding nasty ass interior roof!
- Wheel stud question
- which direction do cam seals go? need ASAP! (b-series)
- custom carbon fiber dash in my eg
- Can I use my Y8 flywheel on my Z6?
- Poor Gas Mileage
- What oil to use for my 94 dx coupe?
- car stalls on first start up
- Wiring JDM EG6 Sir Mirrors
- Del sol/Good Deal?
- Crooked steering column in my 93 ex coupe
- HOW/Where do u check ur MP's
- TL rear seats...
- Any1 kno how much weight u.d save gutting a EG6?
- headers rubbing
- what i need to put k24 in eg
- muffler hit curb while reversing.. ?
- rear disc conversion?
- OEM D bracket for rear sway works with red sway bushing?
- security question??????????
- Im in Dire need of help. Plz answer the following questions
- Replaced cut EX harness for LX 4dr harness......Same problems!!!
- is this a legit APC short shift?
- Axles
- HELP! NEED TO LEARN HOW TO CONVERT DPFI-MPFI
- Brake Light Problem
- fitment on a Si/GSR front upper strut bar with a d16y7
- how much would it be to buy these parts???
- Type R Momo Wheels with SRS
- cam choice?
- Stronger power steering
- blinker problems
- all motor or tubro
- Tire sizes
- 4-2-1 or 4-1 Headers
- CEL #43 Vac Pressure Help!!!
- b16a2 gear ratios? (searched)
- Cryogen
- IS A GSR THROTTLE BODY 58MM OR 60MM... PLZ CLEAR THIS UP
- Anyone looking for a 91' Civic Si?
- 98 EX Problems!
- vtec cams in non vtec
- cat back exhaust
- 92 hatch, ls motor(obd2 to 1), and a smog ref....questions
- Help with EG steering column cover!
- Del Sol Rear Bumper
- New Member: Hi + Question on coilovers.
- Speed Sensors
- B16 build up suggestions please
- Building an EG shell from the ground up: When enough is enough?
- Honda optional wheels
- Looking to build a D series
- dx tranny swap with cx tranny..
- How are tien S techs? Lookin to get a set for my 93 coupe.. any1 got a pic
- HELP!! CAR WON'T START! ANY IDEAS?
- Car wont rev past 4500....help please!!
- Intake Manifold Sensor?? 00B18B1 in 97EX
- swaps for civic lx
- Fully built B20 Vtec how is the milege?
- 92-95 zc swap info
- HELP.........WHAT WOULD BE THE BEST SWAP?
- TPS question
- Rusted flywheel?
- question for tail lights
- Help: EK jdm Foglights trouble
- proportioning valve
- carfax on vin?
- Syphoning gas out of an EM1?
- Remove 98 hatch grill
- Head removal on 93 ex
- HELP Anyone familier with a 92-95 civic DX engine wire harness
- gsr cat in an ex
- OBD0 1 or 2?
- Slow ass honda
- opinions on tsudo exhaust?
- honda's fast?
- 92-95 oem/replica foglights ?
- KYB GR2 on 97 Civic (my review)
- 2000 EK doors = 2000 SI (SIR) doors???
- civic cx engine harness, large yellow wire, what is this?
- HELP WITH Ignition Control Module
- Installing a new stock antennae help!!
